Pull ARM fix from Russell King:
"Just one fix for a problem in the csum_partial_copy_from_user()
implementation when software PAN is enabled"
* 'fixes' of git://git.armlinux.org.uk/~rmk/linux-arm:
ARM: 8731/1: Fix csum_partial_copy_from_user() stack mismatch
An additional 'ip' will be pushed to the stack, for restoring the
DACR later, if CONFIG_CPU_SW_DOMAIN_PAN defined.
However, the fixup still get the err_ptr by add #8*4 to sp, which
results in the fact that the code area pointed by the LR will be
overwritten, or the kernel will crash if CONFIG_DEBUG_RODATA is enabled.
This patch fixes the stack mismatch.
Fixes: a5e090acbf54 ("ARM: software-based priviledged-no-access support")
Signed-off-by: Lvqiang Huang <Lvqiang.Huang@spreadtrum.com>
Signed-off-by: Chunyan Zhang <zhang.lyra@gmail.com>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
Pull networking fixes from David Miller:
1) Clamp timeouts to INT_MAX in conntrack, from Jay Elliot.
2) Fix broken UAPI for BPF_PROG_TYPE_PERF_EVENT, from Hendrik
Brueckner.
3) Fix locking in ieee80211_sta_tear_down_BA_sessions, from Johannes
Berg.
4) Add missing barriers to ptr_ring, from Michael S. Tsirkin.
5) Don't advertise gigabit in sh_eth when not available, from Thomas
Petazzoni.
6) Check network namespace when delivering to netlink taps, from Kevin
Cernekee.
7) Kill a race in raw_sendmsg(), from Mohamed Ghannam.
8) Use correct address in TCP md5 lookups when replying to an incoming
segment, from Christoph Paasch.
9) Add schedule points to BPF map alloc/free, from Eric Dumazet.
10) Don't allow silly mtu values to be used in ipv4/ipv6 multicast, also
from Eric Dumazet.
11) Fix SKB leak in tipc, from Jon Maloy.
12) Disable MAC learning on OVS ports of mlxsw, from Yuval Mintz.
13) SKB leak fix in skB_complete_tx_timestamp(), from Willem de Bruijn.
14) Add some new qmi_wwan device IDs, from Daniele Palmas.
15) Fix static key imbalance in ingress qdisc, from Jiri Pirko.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (76 commits)
net: qcom/emac: Reduce timeout for mdio read/write
net: sched: fix static key imbalance in case of ingress/clsact_init error
net: sched: fix clsact init error path
ip_gre: fix wrong return value of erspan_rcv
net: usb: qmi_wwan: add Telit ME910 PID 0x1101 support
pkt_sched: Remove TC_RED_OFFLOADED from uapi
net: sched: Move to new offload indication in RED
net: sched: Add TCA_HW_OFFLOAD
net: aquantia: Increment driver version
net: aquantia: Fix typo in ethtool statistics names
net: aquantia: Update hw counters on hw init
net: aquantia: Improve link state and statistics check interval callback
net: aquantia: Fill in multicast counter in ndev stats from hardware
net: aquantia: Fill ndev stat couters from hardware
net: aquantia: Extend stat counters to 64bit values
net: aquantia: Fix hardware DMA stream overload on large MRRS
net: aquantia: Fix actual speed capabilities reporting
sock: free skb in skb_complete_tx_timestamp on error
s390/qeth: update takeover IPs after configuration change
s390/qeth: lock IP table while applying takeover changes
Use XAUI rather than XGMII for DSA link ports, as this is the interface
mode that the switches actually use. XAUI is the 4 lane bus with clock
per direction, whereas XGMII is a 32 bit bus with clock.
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Pull ARM SoC fixes from Olof Johansson:
- A revert of all SCPI changes from the 4.15 merge window. They had
regressions on the Amlogic platforms, and the submaintainer isn't
around to fix these bugs due to vacation, etc. So we agreed to revert
and revisit in next release cycle.
- A series fixing a number of bugs for ARM CCN interconnect, around
module unload, smp_processor_id() in preemptable context, and fixing
some memory allocation failure checks.
- A handful of devicetree fixes for different platforms, fixing
warnings and errors that were previously ignored by the compiler.
- The usual set of mostly minor fixes for different platforms.
* tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (42 commits)
ARM64: dts: meson-gx: fix UART pclk clock name
ARM: omap2: hide omap3_save_secure_ram on non-OMAP3 builds
arm: dts: nspire: Add missing #phy-cells to usb-nop-xceiv
ARM: dts: Fix dm814x missing phy-cells property
ARM: dts: Fix elm interrupt compiler warning
bus: arm-ccn: fix module unloading Error: Removing state 147 which has instances left.
bus: arm-cci: Fix use of smp_processor_id() in preemptible context
bus: arm-ccn: Fix use of smp_processor_id() in preemptible context
bus: arm-ccn: Simplify code
bus: arm-ccn: Check memory allocation failure
bus: arm-ccn: constify attribute_group structures.
firmware: arm_scpi: Revert updates made during v4.15 merge window
arm: dts: marvell: Add missing #phy-cells to usb-nop-xceiv
arm64: dts: sort vendor subdirectories in Makefile alphabetically
meson-gx-socinfo: Fix package id parsing
ARM: meson: fix spelling mistake: "Couln't" -> "Couldn't"
ARM: dts: meson: fix the memory region of the GPIO interrupt controller
ARM: dts: meson: correct the sort order for the the gpio_intc node
MAINTAINERS: exclude other Socionext SoC DT files from ARM/UNIPHIER entry
arm64: dts: uniphier: remove unnecessary interrupt-parent
Pull KVM fixes from Radim Krčmář:
"ARM:
- A number of issues in the vgic discovered using SMATCH
- A bit one-off calculation in out stage base address mask (32-bit
and 64-bit)
- Fixes to single-step debugging instructions that trap for other
reasons such as MMMIO aborts
- Printing unavailable hyp mode as error
- Potential spinlock deadlock in the vgic
- Avoid calling vgic vcpu free more than once
- Broken bit calculation for big endian systems
s390:
- SPDX tags
- Fence storage key accesses from problem state
- Make sure that irq_state.flags is not used in the future
x86:
- Intercept port 0x80 accesses to prevent host instability (CVE)
- Use userspace FPU context for guest FPU (mainly an optimization
that fixes a double use of kernel FPU)
- Do not leak one page per module load
- Flush APIC page address cache from MMU invalidation notifiers"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (28 commits)
KVM: x86: fix APIC page invalidation
KVM: s390: Fix skey emulation permission check
KVM: s390: mark irq_state.flags as non-usable
KVM: s390: Remove redundant license text
KVM: s390: add SPDX identifiers to the remaining files
KVM: VMX: fix page leak in hardware_setup()
KVM: VMX: remove I/O port 0x80 bypass on Intel hosts
x86,kvm: remove KVM emulator get_fpu / put_fpu
x86,kvm: move qemu/guest FPU switching out to vcpu_run
KVM: arm/arm64: Fix broken GICH_ELRSR big endian conversion
KVM: arm/arm64: kvm_arch_destroy_vm cleanups
KVM: arm/arm64: Fix spinlock acquisition in vgic_set_owner
kvm: arm: don't treat unavailable HYP mode as an error
KVM: arm/arm64: Avoid attempting to load timer vgic state without a vgic
kvm: arm64: handle single-step of hyp emulated mmio instructions
kvm: arm64: handle single-step during SError exceptions
kvm: arm64: handle single-step of userspace mmio instructions
kvm: arm64: handle single-stepping trapped instructions
KVM: arm/arm64: debug: Introduce helper for single-step
arm: KVM: Fix VTTBR_BADDR_MASK BUG_ON off-by-one
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-amlogic into fixes
Amlogic fixes for v4.15-rc
- GPIO interrupt fixes
- socinfo fix for GX series
- fix typo
* tag 'amlogic-fixes-1' of git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-amlogic:
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes
Two fixes for dts compiler warnings
These recently started showing up with better dtc checks being
introduced.
* tag 'omap-for-v4.15/fixes-dt-warnings' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
In configurations without CONFIG_OMAP3 but with secure RAM support,
we now run into a link failure:
arch/arm/mach-omap2/omap-secure.o: In function `omap3_save_secure_ram':
omap-secure.c:(.text+0x130): undefined reference to `save_secure_ram_context'
The omap3_save_secure_ram() function is only called from the OMAP34xx
power management code, so we can simply hide that function in the
appropriate #ifdef.
Fixes: d09220a887f7 ("ARM: OMAP2+: Fix SRAM virt to phys translation for save_secure_ram_context")
Tested-by: Dan Murphy <dmurphy@ti.com>
"usb-nop-xceiv" is using the phy binding, but is missing #phy-cells
property. This is probably because the binding was the precursor to the phy
binding.
Fixes the following warning in nspire dts files:
Warning (phys_property): Missing property '#phy-cells' in node ...
Signed-off-by: Rob Herring <robh@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm
KVM/ARM Fixes for v4.15.
Fixes:
- A bit one-off calculation in out stage base address mask (32-bit and
64-bit)
We have phy-cells for usb_phy0, but it's missing for usb_phy1 and we get:
/ocp/l4ls@48000000/control@140000/usb-phy@1b00 or bad phandle
(referred from /ocp/usb@47400000/usb@47401800:phys[0])
Looks like the interrupt property is missing the controller and level
information causing:
Warning (interrupts_property): interrupts size is (4), expected multiple
of 12 in /ocp/elm@48078000
Commit 0515e5999a466dfe ("bpf: introduce BPF_PROG_TYPE_PERF_EVENT
program type") introduced the bpf_perf_event_data structure which
exports the pt_regs structure. This is OK for multiple architectures
but fail for s390 and arm64 which do not export pt_regs. Programs
using them, for example, the bpf selftest fail to compile on these
architectures.
For s390, exporting the pt_regs is not an option because s390 wants
to allow changes to it. For arm64, there is a user_pt_regs structure
that covers parts of the pt_regs structure for use by user space.
To solve the broken uapi for s390 and arm64, introduce an abstract
type for pt_regs and add an asm/bpf_perf_event.h file that concretes
the type. An asm-generic header file covers the architectures that
export pt_regs today.
The arch-specific enablement for s390 and arm64 follows in separate
commits.
Reported-by: Thomas Richter <tmricht@linux.vnet.ibm.com>
Fixes: 0515e5999a466dfe ("bpf: introduce BPF_PROG_TYPE_PERF_EVENT program type")
Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
Reviewed-and-tested-by: Thomas Richter <tmricht@linux.vnet.ibm.com>
Acked-by: Alexei Starovoitov <ast@kernel.org>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Daniel Borkmann <daniel@iogearbox.net>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Fixes for omaps for v4.15-rc cycle with two fixes for hangs with the
rest being compiler warning fixes and fixes for power states and devices
on various boards:
- Fix smatch issue introduced by recent omap device changes for legacy
resources
- Fix SRAM virt to phys related boot hang affecting n900 and other omap3 hs
devices found by pending CMA changes. While it seems that we have not hit
this in other use cases, let's fix it to avoid a nasty and hard to find
suprise as right now there is just luck keeping the SRAM virtual address
to physical address translation working with the 0xffff high_mask.
- Fix am335x reading of domain state registers that only exist for the
PM_CEFUSE domain and produce wrong results for other domains
- Fix missing setting for error code for omap device if allocation fails
- Fix missing modules_offs for omap3 MMC3 affecting n9/n950
- Fix cm_split_idlest() reading reserved registers showing wrong
idlestatus
- Fixes to correct #phy-cells property for compiler warnings that
recently started happening
- Add a missing OHCI remote-wakeup-connected property that I was supposed
to merge after the ohci-omap3 to ohci-platform changes but somehow managed
to drop. I only noticed this was missing while debugging the OHCI/EHCI GPS
and modem hang
- Fix a system hang with GPS or modem connected to the OHCI/EHCI bus that
typically happened within 20 - 40 minutes on an idle system. This turned
out to be an issue caused by using the parent interrupt controller directly
with the WUGEN + GIC stacked interrupt controller domains
- Fixes for logicpd-somlv GPMC for Ethernet and NAND that clearly
have been broken since we changed GPMC to use the interrupt controller
binding for some pins. And fix the wrong pin muxing for WLAN while at it
- Fixes for am437x interrupt and dma properties to fix compiler warnings
that recently started happening
* tag 'omap-for-v4.15/fixes-v2-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
ARM: dts: am437x-cm-t43: Correct the dmas property of spi0
ARM: dts: am4372: Correct the interrupts_properties of McASP
ARM: dts: logicpd-somlv: Fix wl127x pinmux
ARM: dts: logicpd-som-lv: Fix gpmc addresses for NAND and enet
ARM: dts: Fix omap4 hang with GPS connected to USB by using wakeupgen
ARM: OMAP2+: Missing error code in omap_device_build()
ARM: AM33xx: PRM: Remove am33xx_pwrdm_read_prev_pwrst function
ARM: dts: Add remote-wakeup-connected for omap OHCI
ARM: dts: am33xx: Add missing #phy-cells to ti,am335x-usb-phy
ARM: dts: omap: Add missing #phy-cells to usb-nop-xceiv
ARM: OMAP2+: Fix smatch found issue for omap_device
ARM: OMAP2/3: CM: fix cm_split_idlest functionality
ARM: OMAP3: hwmod_data: add missing module_offs for MMC3
"Just one fix this time around, for the late commit in the merge window
that triggered a problem with qemu. Qemu is apparently also going to
receive a fix for the discovered issue"
ARM: avoid faulting on qemu
git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into fixes
i.MX fixes for 4.15:
- A fix for vf610-zii-dev-rev-c board which correct the unit-address
of I2C EEPROM node to match the 'reg' property.
- We thought the RTC block on i.MX53 is compatible with the one found
on i.MX25, and added the device for i.MX53 device tree. But it turns
out that's not the case, and we have to revert the change.
* tag 'imx-fixes-4.15' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux:
Revert "ARM: dts: imx53: add srtc node"
ARM: dts: vf610-zii-dev-rev-c: Fix the I2C EEPROM address
http://github.com/Broadcom/stblinux into fixes
This pull request contains Broadcom ARM-based SoCs Device Tree fixes for 4.15,
please pull the following:
- Stefan provides a fix for the BCM2835 (Raspberry Pi) to fix warnings about
missing "#phy-cells" properties
- Florian provides two fixes for Nortsthar Plus, one that uses the correct
interrupt specifiers for the timer/watchdog and one that disables SATA
on BCM9582**HR boards since that leads to unidentified hangs right now
* tag 'arm-soc/for-4.15/devicetree-fixes-1' of http://github.com/Broadcom/stblinux:
ARM: dts: NSP: Fix PPI interrupt types
ARM: dts: NSP: Disable AHCI controller for HR NSP boards
ARM: dts: bcm283x: Fix DTC warnings about missing phy-cells
https://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into fixes
Renesas ARM Based SoC DT Fixes for v4.15
Add missing '#reset-cells' property to cpg nodes.
This flagged by recent dtc.
* tag 'renesas-dt-fixes-for-v4.15' of https://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas:
ARM: dts: r8a779x: Add '#reset-cells' in cpg-mssr
binding.
Fixes the following warning in Marvell dts files:
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Trivial fix to spelling mistake in pr_err error message
Acked-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
Signed-off-by: Kevin Hilman <khilman@baylibre.com>
commit 200a575b68d2 ("ARM: dts: meson: organize devices in their corresponding busses")
organized all peripherals in busses so that the base register offset of
the bus doesn't have to be included in all child-nodes anymore.
The GPIO interrupt controller however specifies the register offset
without subtracting the "cbus" base address. This leads to a problem
where of_iomap inside the irq-meson-gpio driver fails because it
actually tries to map 0x182209880 (cbus base = 0xc1100000 + 0xc1109880
for the GPIO interrupt controller). Fix this by using 0x9880 as register
offset.
Fixes: 7d32bc03bcfb ("ARM: dts: meson8b: enable gpio interrupt controller")
Signed-off-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
Acked-by: Jerome Brunet <jbrunet@baylibre.com>
Nodes are sorted by their register start address. Move gpio_intc to the
correct position.
No functional changes intended.
In response to compile breakage introduced by a series that added the
pud_write helper to x86, Stephen notes:
did you consider using the other paradigm:
In arch include files:
#define pud_write pud_write
static inline int pud_write(pud_t pud)
Then in include/asm-generic/pgtable.h:
#ifndef pud_write
#endif
If you had, then the powerpc code would have worked ... ;-) and many
of the other interfaces in include/asm-generic/pgtable.h are
protected that way ...
Given that some architecture already define pmd_write() as a macro, it's
a net reduction to drop the definition of __HAVE_ARCH_PMD_WRITE.
Link: http://lkml.kernel.org/r/151129126721.37405.13339850900081557813.stgit@dwillia2-desk3.amr.corp.intel.com
Suggested-by: Stephen Rothwell <sfr@canb.auug.org.au>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Cc: Oliver OHalloran <oliveroh@au1.ibm.com>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
Cc: Russell King <linux@armlinux.org.uk>
After emulating instructions we may want return to user-space to handle
single-step debugging. Introduce a helper function, which, if
single-step is enabled, sets the run structure for return and returns
true.
Signed-off-by: Alex Bennée <alex.bennee@linaro.org>
Reviewed-by: Julien Thierry <julien.thierry@arm.com>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
VTTBR_BADDR_MASK is used to sanity check the size and alignment of the
VTTBR address. It seems to currently be off by one, thereby only
allowing up to 39-bit addresses (instead of 40-bit) and also
insufficiently checking the alignment. This patch fixes it.
This patch is the 32bit pendent of Kristina's arm64 fix, and
she deserves the actual kudos for pinpointing that one.
Fixes: f7ed45be3ba52 ("KVM: ARM: World-switch implementation")
Cc: <stable@vger.kernel.org> # 3.9
Reported-by: Kristina Martsenko <kristina.martsenko@arm.com>
Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org>
This reverts commit 5b725054147deaf966b3919e10a86c6bfe946a18.
The rtc block on i.MX53 is a completely different hardware than the
one found on i.MX25.
Cc: <stable@vger.kernel.org> #4.14
Reported-by: Noel Vellemans <Noel.Vellemans@visionbms.com>
Suggested-by: Juergen Borleis <jbe@pengutronix.de>
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
at24mac602 should be at the I2C address 0x50, so that it matches the
'reg' property.
Fixes: d4cd158176c3 ("ARM: dts: vf610-zii-dev: Add .dts file for rev. C")
The DMA binding for eDMA needs 2 parameters, not 1.
The second, missing parameter is the tptc to be used for the channel.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Fixes the following warnings:
arch/arm/boot/dts/am437x-cm-t43.dtb: Warning (interrupts_property):
interrupts size is (8), expected multiple of 12 in
/ocp@44000000/mcasp@48038000
/ocp@44000000/mcasp@4803C000
The pin assignment for the wl127x interrupt was incorrect. I am
not sure how this every worked. This also eliminates a conflict with
the SMC911x ethernet driver and properly moves pinmuxes for the
related gpio to omap3_pmx_wkup from omap3_pmx_core.
Fixes: ab8dd3aed011 ("ARM: DTS: Add minimal Support for Logic PD
DM3730 SOM-LV")
This patch fixes and issue where the NAND and GPMC based ethernet
controller stopped working. This also updates the GPMC settings
to be consistent with the Logic PD Torpedo development from the
commit listed above.
Fixes: 44e4716499b8 ("ARM: dts: omap3: Fix NAND device nodes")
There's been a reproducable USB OHCI/EHCI cpuidle related hang on omap4
for a while that happens after about 20 - 40 minutes on an idle system
with some data feeding device being connected, like a USB GPS device or
a cellular modem.
This issue happens in cpuidle states C2 and C3 and does not happen if
cpuidle is limited to C1 state only. The symptoms are that the whole
system hangs and never wakes up from idle, and if a watchdog is
configured the system reboots after a while.
Turns out that OHCI/EHCI devices on omap4 are trying to use the GIC
interrupt controller directly as a parent instead of the WUGEN. We
need to pass the interrupts through WUGEN to GIC to provide the wakeup
events for the processor.
Let's fix the issue by removing the gic interrupt-parent and use the
default interrupt-parent wakeupgen instead. Note that omap5.dtsi had
this already fixes earlier by commit 7136d457f365 ("ARM: omap: convert
wakeupgen to stacked domains") but we somehow missed omap4 at that
point.
Fixes: 7136d457f365 ("ARM: omap: convert wakeupgen to stacked domains")
Cc: Dave Gerlach <d-gerlach@ti.com>
Cc: Nishanth Menon <nm@ti.com>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
Reviewed-by: Roger Quadros <rogerq@ti.com>
We need to set the error code if omap_device_alloc() fails.
Referring TRM Am335X series:
http://www.ti.com/lit/ug/spruh73p/spruh73p.pdf
The LastPowerStateEntered bitfield is present only for PM_CEFUSE
domain. This is not present in any of the other power domains. Hence
remove the generic am33xx_pwrdm_read_prev_pwrst hook which wrongly
reads the reserved bit fields for all the other power domains.
Reading the reserved bits leads to wrongly interpreting the low
power transitions for various power domains that do not have the
LastPowerStateEntered field. The pm debug counters values are wrong
currently as we are incrementing them based on the reserved bits.
Signed-off-by: Keerthy <j-keerthy@ti.com>
With the CMA changes from Joonsoo Kim <iamjoonsoo.kim@lge.com>, it
was noticed that n900 stopped booting. After investigating it turned
out that n900 save_secure_ram_context does some whacky virtual to
physical address translation for the SRAM data address.
As we now only have minimal parts of omap3 idle code copied to SRAM,
running save_secure_ram_context() in SRAM is not needed. It only gets
called on PM init. And it seems there's no need to ever call this from
SRAM idle code.
So let's just keep save_secure_ram_context() in DDR, and pass it the
physical address of the parameters. We can do everything else in
omap-secure.c like we already do for other secure code.
And since we don't have any documentation, I still have no clue what
the values for 0, 1 and 1 for the parameters might be. If somebody has
figured it out, please do send a patch to add some comments.
Debugged-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
This pull request brings in a fix for a warning that started occuring
when dtc from -next got merged.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Booting a kernel results in the kernel warning us about the following
PPI interrupts configuration:
[ 0.105127] smp: Bringing up secondary CPUs ...
[ 0.110545] GIC: PPI11 is secure or misconfigured
[ 0.110551] GIC: PPI13 is secure or misconfigured
Fix this by using the appropriate edge configuration for PPI11 and
PPI13, this is similar to what was fixed for Northstar (BCM5301X) in
commit 0e34079cd1f6 ("ARM: dts: BCM5301X: Correct GIC_PPI interrupt
flags").
Fixes: 7b2e987de207 ("ARM: NSP: add minimal Northstar Plus device tree")
Fixes: 1a9d53cabaf4 ("ARM: dts: NSP: Add TWD Support to DT")
Acked-by: Jon Mason <jon.mason@broadcom.com>
The AHCI controller is currently enabled for all of these boards:
bcm958623hr and bcm958625hr would result in a hard hang on boot that we
cannot get rid of. Since this does not appear to have an easy and simple
fix, just disable the AHCI controller for now until this gets resolved.
Fixes: 70725d6e97ac ("ARM: dts: NSP: Enable SATA on bcm958625hr")
Fixes: d454c3762437 ("ARM: dts: NSP: Add new DT file for bcm958623hr")
When qemu starts a kernel in a bare environment, the default SCR has
the AW and FW bits clear, which means that the kernel can't modify
the PSR A or PSR F bits, and means that FIQs and imprecise aborts are
always masked.
When running uboot under qemu, the AW and FW SCR bits are set, and the
kernel functions normally - and this is how real hardware behaves.
Fix this for qemu by ignoring the FIQ bit.
Fixes: 8bafae202c82 ("ARM: BUG if jumping to usermode address in kernel mode")
Pull ARM fixes from Russell King:
- LPAE fixes for kernel-readonly regions
- Fix for get_user_pages_fast on LPAE systems
- avoid tying decompressor to a particular platform if DEBUG_LL is
enabled
- BUG if we attempt to return to userspace but the to-be-restored PSR
value keeps us in privileged mode (defeating an issue that ftracetest
found)
ARM: 8722/1: mm: make STRICT_KERNEL_RWX effective for LPAE
ARM: 8721/1: mm: dump: check hardware RO bit for LPAE
ARM: make decompressor debug output user selectable
ARM: fix get_user_pages_fast
Detect if we are returning to usermode via the normal kernel exit paths
but the saved PSR value indicates that we are in kernel mode. This
could occur due to corrupted stack state, which has been observed with
"ftracetest".
This ensures that we catch the problem case before we get to user code.
Pull timer updates from Thomas Gleixner:
- The final conversion of timer wheel timers to timer_setup().
A few manual conversions and a large coccinelle assisted sweep and
the removal of the old initialization mechanisms and the related
code.
- Remove the now unused VSYSCALL update code
- Fix permissions of /proc/timer_list. I still need to get rid of that
file completely
- Rename a misnomed clocksource function and remove a stale declaration
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (27 commits)
m68k/macboing: Fix missed timer callback assignment
treewide: Remove TIMER_FUNC_TYPE and TIMER_DATA_TYPE casts
timer: Remove redundant __setup_timer*() macros
timer: Pass function down to initialization routines
timer: Remove unused data arguments from macros
timer: Switch callback prototype to take struct timer_list * argument
timer: Pass timer_list pointer to callbacks unconditionally
Coccinelle: Remove setup_timer.cocci
timer: Remove setup_*timer() interface
timer: Remove init_timer() interface
treewide: setup_timer() -> timer_setup() (2 field)
treewide: init_timer() -> setup_timer()
treewide: Switch DEFINE_TIMER callbacks to struct timer_list *
s390: cmm: Convert timers to use timer_setup()
lightnvm: Convert timers to use timer_setup()
drivers/net: cris: Convert timers to use timer_setup()
drm/vc4: Convert timers to use timer_setup()
block/laptop_mode: Convert timers to use timer_setup()
net/atm/mpc: Avoid open-coded assignment of timer callback function
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild
Pull more Kbuild updates from Masahiro Yamada:
- use 'pwd' instead of '/bin/pwd' for portability
- clean up Makefiles
- fix ld-option for clang
- fix malloc'ed data size in Kconfig
- fix parallel building along with coccicheck
- fix a minor issue of package building
- prompt to use "rpm-pkg" instead of "rpm"
- clean up *.i and *.lst patterns by "make clean"
* tag 'kbuild-v4.15-2' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild:
kbuild: drop $(extra-y) from real-objs-y
kbuild: clean up *.i and *.lst patterns by make clean
kbuild: rpm: prompt to use "rpm-pkg" if "rpm" target is used
kbuild: pkg: use --transform option to prefix paths in tar
coccinelle: fix parallel build with CHECK=scripts/coccicheck
kconfig/symbol.c: use correct pointer type argument for sizeof
kbuild: Set KBUILD_CFLAGS before incl. arch Makefile
kbuild: remove all dummy assignments to obj-
kbuild: create built-in.o automatically if parent directory wants it
kbuild: /bin/pwd -> pwd
Pull KVM updates from Radim Krčmář:
"Trimmed second batch of KVM changes for Linux 4.15:
- GICv4 Support for KVM/ARM
- re-introduce support for CPUs without virtual NMI (cc stable) and
allow testing of KVM without virtual NMI on available CPUs
- fix long-standing performance issues with assigned devices on AMD
(cc stable)"
* tag 'kvm-4.15-2' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (30 commits)
kvm: vmx: Allow disabling virtual NMI support
kvm: vmx: Reinstate support for CPUs without virtual NMI
KVM: SVM: obey guest PAT
KVM: arm/arm64: Don't queue VLPIs on INV/INVALL
KVM: arm/arm64: Fix GICv4 ITS initialization issues
KVM: arm/arm64: GICv4: Theory of operations
KVM: arm/arm64: GICv4: Enable VLPI support
KVM: arm/arm64: GICv4: Prevent userspace from changing doorbell affinity
KVM: arm/arm64: GICv4: Prevent a VM using GICv4 from being saved
KVM: arm/arm64: GICv4: Enable virtual cpuif if VLPIs can be delivered
KVM: arm/arm64: GICv4: Hook vPE scheduling into vgic flush/sync
KVM: arm/arm64: GICv4: Use the doorbell interrupt as an unblocking source
KVM: arm/arm64: GICv4: Add doorbell interrupt handling
KVM: arm/arm64: GICv4: Use pending_last as a scheduling hint
KVM: arm/arm64: GICv4: Handle INVALL applied to a vPE
KVM: arm/arm64: GICv4: Propagate property updates to VLPIs
KVM: arm/arm64: GICv4: Handle MOVALL applied to a vPE
KVM: arm/arm64: GICv4: Handle CLEAR applied to a VLPI
KVM: arm/arm64: GICv4: Propagate affinity changes to the physical ITS
KVM: arm/arm64: GICv4: Unmap VLPI when freeing an LPI
Pull MTD updates from Richard Weinberger:
"General changes:
- Unconfuse get_unmapped_area and point/unpoint driver methods
- New partition parser: sharpslpart
- Kill GENERIC_IO
- Various fixes
NAND changes:
- Add a flag to mark NANDs that require 3 address cycles to encode a
page address
- Set a default ECC/free layout when NAND_ECC_NONE is requested
- Fix a bug in panic_nand_write()
- Another batch of cleanups for the denali driver
- Fix PM support in the atmel driver
- Remove support for platform data in the omap driver
- Fix subpage write in the omap driver
- Fix irq handling in the mtk driver
- Change link order of mtk_ecc and mtk_nand drivers to speed up boot
time
- Change log level of ECC error messages in the mxc driver
- Patch the pxa3xx driver to support Armada 8k platforms
- Add BAM DMA support to the qcom driver
- Convert gpio-nand to the GPIO desc API
- Fix ECC handling in the mt29f driver
SPI-NOR changes:
- Introduce system power management support
- New mechanism to select the proper .quad_enable() hook by JEDEC
ID, when needed, instead of only by manufacturer ID
- Add support to new memory parts from Gigadevice, Winbond, Macronix
and Everspin
- Maintainance for Cadence, Intel, Mediatek and STM32 drivers"
* tag 'for-linus-20171120' of git://git.infradead.org/linux-mtd: (85 commits)
mtd: Avoid probe failures when mtd->dbg.dfs_dir is invalid
mtd: sharpslpart: Add sharpslpart partition parser
mtd: Add sanity checks in mtd_write/read_oob()
mtd: remove the get_unmapped_area method
mtd: implement mtd_get_unmapped_area() using the point method
mtd: chips/map_rom.c: implement point and unpoint methods
mtd: chips/map_ram.c: implement point and unpoint methods
mtd: mtdram: properly handle the phys argument in the point method
mtd: mtdswap: fix spelling mistake: 'TRESHOLD' -> 'THRESHOLD'
mtd: slram: use memremap() instead of ioremap()
kconfig: kill off GENERIC_IO option
mtd: Fix C++ comment in include/linux/mtd/mtd.h
mtd: constify mtd_partition
mtd: plat-ram: Replace manual resource management by devm
mtd: nand: Fix writing mtdoops to nand flash.
mtd: intel-spi: Add Intel Lewisburg PCH SPI super SKU PCI ID
mtd: nand: mtk: fix infinite ECC decode IRQ issue
mtd: spi-nor: Add support for mr25h128
mtd: nand: mtk: change the compile sequence of mtk_nand.o and mtk_ecc.o
mtd: spi-nor: enable 4B opcodes for mx66l51235l
