path: root/arch/arm64/lib/strnlen.S
2020-01-08arm64: lib: Use modern annotations for assembly functionsMark Brown
In an effort to clarify and simplify the annotation of assembly functions in the kernel new macros have been introduced. These replace ENTRY and ENDPROC and also add a new annotation for static functions which previously had no ENTRY equivalent. Update the annotations in the library code to the new macros. Signed-off-by: Mark Brown <broonie@kernel.org> [will: Use SYM_FUNC_START_WEAK_PI] Signed-off-by: Will Deacon <will@kernel.org>
2019-06-19treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 234Thomas Gleixner
Based on 1 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license version 2 as published by the free software foundation this program is distributed in the hope that it will be useful but without any warranty without even the implied warranty of merchantability or fitness for a particular purpose see the gnu general public license for more details you should have received a copy of the gnu general public license along with this program if not see http www gnu org licenses extracted by the scancode license scanner the SPDX license identifier GPL-2.0-only has been chosen to replace the boilerplate/reference in 503 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Alexios Zavras <alexios.zavras@intel.com> Reviewed-by: Allison Randal <allison@lohutok.net> Reviewed-by: Enrico Weigelt <info@metux.net> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190602204653.811534538@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-12-10arm64: string: use asm EXPORT_SYMBOL()Mark Rutland
For a while now it's been possible to use EXPORT_SYMBOL() in assembly files, which allows us to place exports immediately after assembly functions, as we do for C functions. As a step towards removing arm64ksyms.c, let's move the string routine exports to the assembly files the functions are defined in. Routines which should only be exported for !KASAN builds are exported using the EXPORT_SYMBOL_NOKASAN() helper. There should be no functional change as a result of this patch. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2018-10-26arm64: lib: use C string functions with KASAN enabledAndrey Ryabinin
ARM64 has asm implementation of memchr(), memcmp(), str[r]chr(), str[n]cmp(), str[n]len(). KASAN don't see memory accesses in asm code, thus it can potentially miss many bugs. Ifdef out __HAVE_ARCH_* defines of these functions when KASAN is enabled, so the generic implementations from lib/string.c will be used. We can't just remove the asm functions because efistub uses them. And we can't have two non-weak functions either, so declare the asm functions as weak. Link: http://lkml.kernel.org/r/20180920135631.23833-2-aryabinin@virtuozzo.com Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Reported-by: Kyeongdon Kim <kyeongdon.kim@lge.com> Cc: Alexander Potapenko <glider@google.com> Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-02-16arm64/efi: Make strnlen() available to the EFI namespaceThierry Reding
Changes introduced in the upstream version of libfdt pulled in by commit 91feabc2e224 ("scripts/dtc: Update to upstream commit b06e55c88b9b") use the strnlen() function, which isn't currently available to the EFI name- space. Add it to the EFI namespace to avoid a linker error. Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Rob Herring <robh@kernel.org> Reviewed-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2014-05-23arm64: lib: Implement optimized string length routineszhichang.yuan
This patch, based on Linaro's Cortex Strings library, adds an assembly optimized strlen() and strnlen() functions. Signed-off-by: Zhichang Yuan <zhichang.yuan@linaro.org> Signed-off-by: Deepak Saxena <dsaxena@linaro.org> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
