path: root/arch/arm64/kernel/traps.c
2013-01-21taint: add explicit flag to show whether lock dep is still OK.Rusty Russell
Fix up all callers as they were before, with make one change: an unsigned module taints the kernel, but doesn't turn off lockdep. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-09-17arm64: Exception handlingCatalin Marinas
The patch contains the exception entry code (kernel/entry.S), pt_regs structure and related accessors, undefined instruction trapping and stack tracing. AArch64 Linux kernel (including kernel threads) runs in EL1 mode using the SP1 stack. The vectors don't have a fixed address, only alignment (2^11) requirements. Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
