path: root/arch/arm64/kernel/Makefile
2013-01-29arm64: SMP: enable PSCI boot methodMarc Zyngier
Wire the PSCI implementation into the SMP secondary startup code. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2013-01-29arm64: psci: add support for PSCI invocations from the kernelWill Deacon
This patch adds support for the Power State Coordination Interface defined by ARM, allowing Linux to request CPU-centric power-management operations from firmware implementing the PSCI protocol. Signed-off-by: Will Deacon <will.deacon@arm.com> [Marc: s/u32/u64/ in the relevant spots, and switch from an initcall to an simpler init function] Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2013-01-29arm64: SMP: rework the SMP code to be enabling method agnosticMarc Zyngier
In order to introduce PSCI support, let the SMP code handle multiple enabling methods. This also allow CPUs to be booted using different methods (though this feels a bit weird...). In the process, move the spin-table code to its own file. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2013-01-22arm64: Add simple earlyprintk supportCatalin Marinas
This patch adds support for "earlyprintk=" parameter on the kernel command line. The format is: earlyprintk=<name>[,<addr>][,<options>] where <name> is the name of the (UART) device, e.g. "pl011", <addr> is the I/O address. The <options> aren't currently used. The mapping of the earlyprintk device is done very early during kernel boot and there are restrictions on which functions it can call. A special early_io_map() function is added which creates the mapping from the pre-defined EARLY_IOBASE to the device I/O address passed via the kernel parameter. The pgd entry corresponding to EARLY_IOBASE is pre-populated in head.S during kernel boot. Only PL011 is currently supported and it is assumed that the interface is already initialised by the boot loader before the kernel is started. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-12-05arm64: add hypervisor stubMarc Zyngier
If booted in EL2, install an dummy hypervisor whose only purpose is to be replaced by a full fledged one. A minimal API allows to: - obtain the current HYP vectors (__hyp_get_vectors) - set new HYP vectors (__hyp_set_vectors) Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2012-09-17arm64: Build infrastructureCatalin Marinas
This patch adds Makefile and Kconfig files required for building an AArch64 kernel. Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
