commit 971a5b6fe634bb7b617d8c5f25b6a3ddbc600194 upstream.
The compat_elf_prpsinfo structure does not match the arch/arm struct
elf_pspsinfo definition. As result NT_PRPSINFO note in core file
created by arm64 kernel for aarch32 (compat) process has wrong size.
So gdb cannot display command that caused process crash.
Fix is to change size of __compat_uid_t, __compat_gid_t so it would
match size of similar fields in arch/arm case.
Signed-off-by: Victor Kamensky <victor.kamensky@linaro.org>
commit 27d7ff273c2aad37b28f6ff0cab2cfa35b51e648 upstream.
I'm not sure what I was on when I wrote this, but when iterating over
the hardware watchpoint array (hbp_watch_array), our index is off by
ARM_MAX_BRP, so we walk off the end of our thread_struct...
... except, a dodgy condition in the loop means that it never executes
at all (bp cannot be NULL).
This patch fixes the code so that we remove the bp check and use the
correct index for accessing the watchpoint structures.
commit fa2ec3ea10bd377f9d55772b1dab65178425a1a2 upstream.
include/linux/sched.h implements TASK_SIZE_OF as TASK_SIZE if it
is not set by the architecture headers. TASK_SIZE uses the
current task to determine the size of the virtual address space.
On a 64-bit kernel this will cause reading /proc/pid/pagemap of a
64-bit process from a 32-bit process to return EOF when it reads
past 0xffffffff.
Implement TASK_SIZE_OF exactly the same as TASK_SIZE with
test_tsk_thread_flag instead of test_thread_flag.
Signed-off-by: Colin Cross <ccross@android.com>
Acked-by: Will Deacon <will.deacon@arm.com>
commit de2db7432917a82b62d55bb59635586eeca6d1bd upstream.
pgprot_{dmacoherent,writecombine,noncached} don't need to generate
executable mappings with side-effects like __sync_icache_dcache() being
called when the mapping is in user space.
Reported-by: Bharat Bhushan <Bharat.Bhushan@freescale.com>
Tested-by: Laura Abbott <lauraa@codeaurora.org>
Tested-by: Bharat Bhushan <Bharat.Bhushan@freescale.com>
commit 71fdb6bf61bf0692f004f9daf5650392c0cfe300 upstream.
Special pte mappings are not intended to be executable and do not even
have an associated struct page. This patch ensures that we do not call
__sync_icache_dcache() on such ptes.
Reported-by: Steve Capper <Steve.Capper@arm.com>
commit 5044bad43ee573d0b6d90e3ccb7a40c2c7d25eb4 upstream.
Add DSB after icache flush to complete the cache maintenance operation.
The function __flush_icache_all() is used only for user space mappings
and an ISB is not required because of an exception return before executing
user instructions. An exception return would behave like an ISB.
Signed-off-by: Vinayak Kale <vkale@apm.com>
commit 4f00130b70e5eee813cc7bc298e0f3fdf79673cc upstream.
This provides better performance compared to Device GRE and also allows
unaligned accesses. Such memory is intended to be used with standard RAM
(e.g. framebuffers) and not I/O.
Cc: Mark Brown <broonie@kernel.org>
commit 0d651e4e65e96989f72236bf83bd4c6e55eb6ce4 upstream.
Switching between reading the virtual or physical counters is
problematic, as some core code wants a view of time before we're fully
set up. Using a function pointer and switching the source after the
first read can make time appear to go backwards, and having a check in
the read function is an unfortunate block on what we want to be a fast
path.
Instead, this patch makes us always use the virtual counters. If we're a
guest, or don't have hyp mode, we'll use the virtual timers, and as such
don't care about CNTVOFF as long as it doesn't change in such a way as
to make time appear to travel backwards. As the guest will use the
virtual timers, a (potential) KVM host must use the physical timers
(which can wake up the host even if they fire while a guest is
executing), and hence a host must have CNTVOFF set to zero so as to have
a consistent view of time between the physical timers and virtual
counters.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: Rob Herring <rob.herring@calxeda.com>
commit 7b22c03536a539142f931815528d55df455ffe2d upstream.
In ftrace_syscall_enter(),
syscall_get_arguments(..., 0, n, ...)
if (i == 0) { <handle orig_x0> ...; n--;}
memcpy(..., n * sizeof(args[0]));
If 'number of arguments(n)' is zero and 'argument index(i)' is also zero in
syscall_get_arguments(), none of arguments should be copied by memcpy().
Otherwise 'n--' can be a big positive number and unexpected amount of data
will be copied. Tracing system calls which take no argument, say sync(void),
may hit this case and eventually make the system corrupted.
This patch fixes the issue both in syscall_get_arguments() and
syscall_set_arguments().
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
commit 845ad05ec31e0f3872a321e10dbeaf872022632c upstream.
Written by Catalin Marinas, tested by APM on storm platform. This is needed
because of the failures encountered when running SpecWeb benchmark test.
Signed-off-by: Feng Kan <fkan@apm.com>
Acked-by: Kumar Sankaran <ksankaran@apm.com>
commit 82b2f495fba338d1e3098dde1df54944a9c19751 upstream.
Secondary CPUs write to __boot_cpu_mode with caches disabled, and thus a
cached value of __boot_cpu_mode may be incoherent with that in memory.
This could lead to a failure to detect mismatched boot modes.
This patch adds flushing to ensure that writes by secondaries to
__boot_cpu_mode are made visible before we test against it.
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Christoffer Dall <cdall@cs.columbia.edu>
commit 4ecf7ccb1973fd826456b6ab1e6dfafe9023c753 upstream.
An exclusive store instruction may fail for reasons other than lock
contention (e.g. a cache eviction during the critical section) so, in
line with other architectures using similar exclusive instructions
(alpha, mips, powerpc), retry the trylock operation if the lock appears
to be free but the strex reported failure.
Reported-by: Tony Thompson <anthony.thompson@arm.com>
commit 2b047252d087be7f2ba088b4933cd904f92e6fce upstream.
Ben Tebulin reported:
"Since v3.7.2 on two independent machines a very specific Git
repository fails in 9/10 cases on git-fsck due to an SHA1/memory
failures. This only occurs on a very specific repository and can be
reproduced stably on two independent laptops. Git mailing list ran
out of ideas and for me this looks like some very exotic kernel issue"
and bisected the failure to the backport of commit 53a59fc67f97 ("mm:
limit mmu_gather batching to fix soft lockups on !CONFIG_PREEMPT").
That commit itself is not actually buggy, but what it does is to make it
much more likely to hit the partial TLB invalidation case, since it
introduces a new case in tlb_next_batch() that previously only ever
happened when running out of memory.
The real bug is that the TLB gather virtual memory range setup is subtly
buggered. It was introduced in commit 597e1c3580b7 ("mm/mmu_gather:
enable tlb flush range in generic mmu_gather"), and the range handling
was already fixed at least once in commit e6c495a96ce0 ("mm: fix the TLB
range flushed when __tlb_remove_page() runs out of slots"), but that fix
was not complete.
The problem with the TLB gather virtual address range is that it isn't
set up by the initial tlb_gather_mmu() initialization (which didn't get
the TLB range information), but it is set up ad-hoc later by the
functions that actually flush the TLB. And so any such case that forgot
to update the TLB range entries would potentially miss TLB invalidates.
Rather than try to figure out exactly which particular ad-hoc range
setup was missing (I personally suspect it's the hugetlb case in
zap_huge_pmd(), which didn't have the same logic as zap_pte_range()
did), this patch just gets rid of the problem at the source: make the
TLB range information available to tlb_gather_mmu(), and initialize it
when initializing all the other tlb gather fields.
This makes the patch larger, but conceptually much simpler. And the end
result is much more understandable; even if you want to play games with
partial ranges when invalidating the TLB contents in chunks, now the
range information is always there, and anybody who doesn't want to
bother with it won't introduce subtle bugs.
Ben verified that this fixes his problem.
Reported-bisected-and-tested-by: Ben Tebulin <tebulin@googlemail.com>
Build-testing-by: Stephen Rothwell <sfr@canb.auug.org.au>
Build-testing-by: Richard Weinberger <richard.weinberger@gmail.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Acked-by: Peter Zijlstra <peterz@infradead.org>
When we take an exception at EL1, we only want to enable debug
exceptions if we're not currently stepping, otherwise we can easily get
stuck in a loop stepping into interrupt handlers.
Unfortunately, the current code tests the wrong bit in the mdscr, so fix
that.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull stray syscall bits from Al Viro:
"Several syscall-related commits that were missing from the original"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal:
switch compat_sys_sysctl to COMPAT_SYSCALL_DEFINE
unicore32: just use mmap_pgoff()...
unify compat fanotify_mark(2), switch to COMPAT_SYSCALL_DEFINE
x86, vm86: fix VM86 syscalls: use SYSCALL_DEFINEx(...)
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64
Pull arm64 update from Catalin Marinas:
- Since drivers/irqchip/irq-gic.c no longer has dependencies on arm32
specifics (the 'gic' branch merged), it can be enabled on arm64.
- Enable arm64 support for poweroff/restart (for code under
drivers/power/reset/).
- Fixes (dts file, exception handling, bitops)
* tag 'arm64-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64:
arm64: Treat the bitops index argument as an 'int'
arm64: Ignore the 'write' ESR flag on cache maintenance faults
arm64: dts: fix #address-cells for foundation-v8
arm64: vexpress: Add support for poweroff/restart
arm64: Enable support for the ARM GIC interrupt controller
This patch adds the arm_pm_poweroff definition expected by the
vexpress-poweroff.c driver and enables the latter for arm64.
Acked-by: Pawel Moll <pawel.moll@arm.com>
Pull ARM SoC late cleanups from Arnd Bergmann:
"These are cleanups and smaller changes that either depend on earlier
feature branches or came in late during the development cycle. We
normally try to get all cleanups early, so these are the exceptions:
- A follow-up on the clocksource reworks, hopefully the last time we
need to merge clocksource subsystem changes through arm-soc.
A first set of patches was part of the original 3.10 arm-soc
cleanup series because of interdependencies with timer drivers now
moved out of arch/arm.
- Migrating the SPEAr13xx platform away from using auxdata for DMA
channel descriptions towards using information in device tree,
based on the earlier SPEAr multiplatform series
- A few follow-ups on the Atmel SAMA5 support and other changes for
Atmel at91 based on the larger at91 reworks.
- Moving the armada irqchip implementation to drivers/irqchip
- Several OMAP cleanups following up on the larger series already
merged in 3.10."
* tag 'cleanup-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (50 commits)
ARM: OMAP4: change the device names in usb_bind_phy
ARM: OMAP2+: Fix mismerge for timer.c between ff931c82 and da4a686a
ARM: SPEAr: conditionalize SMP code
ARM: arch_timer: Silence debug preempt warnings
ARM: OMAP: remove unused variable
serial: amba-pl011: fix !CONFIG_DMA_ENGINE case
ata: arasan: remove the need for platform_data
ARM: at91/sama5d34ek.dts: remove not needed compatibility string
ARM: at91: dts: add MCI DMA support
ARM: at91: dts: add i2c dma support
ARM: at91: dts: set #dma-cells to the correct value
ARM: at91: suspend both memory controllers on at91sam9263
irqchip: armada-370-xp: slightly cleanup irq controller driver
irqchip: armada-370-xp: move IRQ handler to avoid forward declaration
irqchip: move IRQ driver for Armada 370/XP
ARM: mvebu: move L2 cache initialization in init_early()
devtree: add binding documentation for sp804
ARM: integrator-cp: convert use CLKSRC_OF for timer init
ARM: versatile: use OF init for sp804 timer
ARM: versatile: add versatile dtbs to dtbs target
The compat_stat structure doesn't match the arch/arm/ struct stat
definition. This patch fixes the compat types and struct compat_stat
definition accordingly.
For compiling with allmodconfig, need vga.h file, so generate it which
just only include the asm-generic one.
It is firstly used by drivers/gpu/drm/drm_irq.c.
The related error:
include/video/vga.h:22:21: fatal error: asm/vga.h: No such file or directory
Signed-off-by: Chen Gang <gang.chen@asianux.com>
Drivers use cmpxchg64, cmpxchg64_local to perform 64-bit operation, so
they can cross 32-bit and 64-bit platforms (it is a standard way).
when compiling with allmodconfig, CONFIG_64BIT=y the file
drivers/base/regmap/regmap-mmio.c will use readq and writeq so we need
implement these functions.
git://sources.calxeda.com/kernel/linux into late/clksrc
This is the 2nd part of ARM timer clean-ups for 3.10. This series has
the following changes:
- Add sched_clock selection logic to select the highest frequency clock
- Use full 64-bit arch timer counter for sched_clock
- Convert arch timer, sp804 and integrator-cp timers to CLKSRC_OF and
adapt all users to use clocksource_of_init
* tag 'clksrc-cleanup-for-3.10-part2' of git://sources.calxeda.com/kernel/linux:
ARM: vexpress: remove extra timer-sp control register clearing
ARM: dts: vexpress: disable CA9 core tile sp804 timer
ARM: vexpress: remove sp804 OF init
ARM: highbank: use OF init for sp804 timer
ARM: timer-sp: convert to use CLKSRC_OF init
OF: add empty of_device_is_available for !OF
ARM: convert arm/arm64 arch timer to use CLKSRC_OF init
ARM: make machine_desc->init_time default to clocksource_of_init
ARM: arch_timer: use full 64-bit counter for sched_clock
ARM: make sched_clock just call a function pointer
ARM: sched_clock: allow changing to higher frequency counter
This has a nasty set of conflicts with the exynos MCT code, which was
moved in a separate branch, and then fixed up when merged in, but still
conflicts a bit here. It should have been sorted out by this merge though.
The ESR_EL1 decoding process is a bit cryptic, and KVM has also
a need for the same constants.
Add a new esr.h file containing the appropriate exception classes
constants, and change entry.S to use it. Fix a small bug in the
EL1 breakpoint check while we're at it.
This converts arm and arm64 to use CLKSRC_OF DT based initialization for
the arch timer. A new function arch_timer_arch_init is added to allow for
arch specific setup.
This has a side effect of enabling sched_clock on omap5 and exynos5. There
should not be any reason not to use the arch timers for sched_clock.
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Simon Horman <horms@verge.net.au>
Cc: Magnus Damm <magnus.damm@gmail.com>
Cc: John Stultz <john.stultz@linaro.org>
Cc: linux-samsung-soc@vger.kernel.org
Cc: linux-omap@vger.kernel.org
Cc: linux-sh@vger.kernel.org
* arm64-klib:
arm64: klib: Optimised atomic bitops
arm64: klib: Optimised string functions
arm64: klib: Optimised memory functions
This patch uses the generic irqchip_init() function for initialising the
interrupt controller on arm64. It also adds several definitions required
by the ARM GIC irqchip driver but does not enable ARM_GIC yet.
This patch implements the AArch64-specific atomic bitops functions using
exclusive memory accesses to avoid locking.
This patch introduces AArch64-specific string functions (strchr,
strrchr).
This patch introduces AArch64-specific memory functions (memcpy,
memmove, memchr, memset). These functions are not optimised for any CPU
implementation but can be used as a starting point once hardware is
available.
The reg property of the cpu nodes in the DT now contains all the
affinity levels in (MPIDR[39:32] and MPIDR[23:0]) and that's what
boot_secondary() writes in the pen, so increase the mask in
secondary_holding_pen accordingly.
Signed-off-by: Javi Merino <javi.merino@arm.com>
When booting the kernel, the cpu logical id map must be initialised
using device tree data passed by FW or through an embedded blob.
This patch parses the reg property in device tree "cpu" nodes,
retrieves the corresponding CPUs hardware identifiers (MPIDR) and
initialises the cpu logical map accordingly.
The device tree HW identifiers are considered valid if all CPU nodes
contain a "reg" property, there are no duplicate "reg" entries and the
DT defines a CPU node whose "reg" property defines affinity levels
that matches those of the boot CPU.
The primary CPU is assigned cpu logical number 0 to keep the current
convention valid.
Based on a0ae02405076ac32bd17ece976e914b5b6075bb0 (ARM: kernel: add
device tree init map function).
Change the prototype of write_pen_release() accordingly and clarify
that's holding the hardware id of the secondary that's going to boot.
This is in preparation of getting HWIDs parsed from the DT.
In order to preserve some kind of source compatibility between
arm and arm64, introduce read_cpuid_{implementor,part_number,mpidr}
which are used on KVM to find out which CPU we're running on.
The expression to compute the padding needed to fill the uc_sigmask field
to 1024 bits actually computes the padding needed for 1080 bits.
Fortunately, due to the 16-byte alignment of the following field
(uc_mcontext) the definition in glibc contains enough bytes of padding
after uc_sigmask so that the overall offsets and size match in both
definitions.
Signed-off-by: Andreas Schwab <schwab@suse.de>
Pull signal handling cleanups from Al Viro:
"This is the first pile; another one will come a bit later and will
contain SYSCALL_DEFINE-related patches.
- a bunch of signal-related syscalls (both native and compat)
unified.
- a bunch of compat syscalls switched to COMPAT_SYSCALL_DEFINE
(fixing several potential problems with missing argument
validation, while we are at it)
- a lot of now-pointless wrappers killed
- a couple of architectures (cris and hexagon) forgot to save
altstack settings into sigframe, even though they used the
(uninitialized) values in sigreturn; fixed.
- microblaze fixes for delivery of multiple signals arriving at once
- saner set of helpers for signal delivery introduced, several
architectures switched to using those."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (143 commits)
x86: convert to ksignal
sparc: convert to ksignal
arm: switch to struct ksignal * passing
alpha: pass k_sigaction and siginfo_t using ksignal pointer
burying unused conditionals
make do_sigaltstack() static
arm64: switch to generic old sigaction() (compat-only)
arm64: switch to generic compat rt_sigaction()
arm64: switch compat to generic old sigsuspend
arm64: switch to generic compat rt_sigqueueinfo()
arm64: switch to generic compat rt_sigpending()
arm64: switch to generic compat rt_sigprocmask()
arm64: switch to generic sigaltstack
sparc: switch to generic old sigsuspend
sparc: COMPAT_SYSCALL_DEFINE does all sign-extension as well as SYSCALL_DEFINE
sparc: kill sign-extending wrappers for native syscalls
kill sparc32_open()
sparc: switch to use of generic old sigaction
sparc: switch sys_compat_rt_sigaction() to COMPAT_SYSCALL_DEFINE
mips: switch to generic sys_fork() and sys_clone()
Pull ARM virtualization changes:
"This contains parts of the ARM KVM support that have dependencies on
other patches merged through the arm-soc tree. In combination with
patches coming through Russell's tree, this will finally add full
support for the kernel based virtual machine on ARM, which has been
awaited for some time now.
Further, we now have a separate platform for virtual machines and qemu
booting that is used by both Xen and KVM, separating these from the
Versatile Express reference implementation. Obviously, this new
platform is multiplatform capable so it can be combined with existing
machines in the same kernel."
* tag 'virt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (38 commits)
ARM: arch_timer: include linux/errno.h
arm: arch_timer: add missing inline in stub function
ARM: KVM: arch_timers: Wire the init code and config option
ARM: KVM: arch_timers: Add timer world switch
ARM: KVM: arch_timers: Add guest timer core support
ARM: KVM: Add VGIC configuration option
ARM: KVM: VGIC initialisation code
ARM: KVM: VGIC control interface world switch
ARM: KVM: VGIC interrupt injection
ARM: KVM: vgic: retire queued, disabled interrupts
ARM: KVM: VGIC virtual CPU interface management
ARM: KVM: VGIC distributor handling
ARM: KVM: VGIC accept vcpu and dist base addresses from user space
ARM: KVM: Initial VGIC infrastructure code
ARM: KVM: Keep track of currently running vcpus
KVM: ARM: Introduce KVM_ARM_SET_DEVICE_ADDR ioctl
ARM: gic: add __ASSEMBLY__ guard to C definitions
ARM: gic: define GICH offsets for VGIC support
ARM: gic: add missing distributor defintions
ARM: mach-virt: fixup machine descriptor after removal of sys_timer
__ARCH_WANT_SYS_RT_SIGACTION,
__ARCH_WANT_SYS_RT_SIGSUSPEND,
__ARCH_WANT_COMPAT_SYS_RT_SIGSUSPEND,
__ARCH_WANT_COMPAT_SYS_SCHED_RR_GET_INTERVAL - not used anymore
CONFIG_GENERIC_{SIGALTSTACK,COMPAT_RT_SIG{ACTION,QUEUEINFO,PENDING,PROCMASK}} -
can be assumed always set.
This patch is a port of 575320d62 ("ARM: 7445/1: mm: update CONTEXTIDR
register to contain PID of current process") from ARM that introduces a
new Kconfig option which, when enabled, causes the kernel to write the
PID of the current task into the CONTEXTIDR register on context switch.
This is useful when analysing hardware trace, since writes to this
register can be configured to emit an event into the trace stream.
[catalin.marinas@arm.com: contextidr_thread_switch() moved to mmu_context.h]
Our uses of inline asm constraints for atomic operations are fairly
wild and varied. We basically need to guarantee the following:
1. Any instructions with barrier implications
(load-acquire/store-release) have a "memory" clobber
2. When performing exclusive accesses, the addresing mode is generated
using the "Q" constraint
3. Atomic blocks which use the condition flags, have a "cc" clobber
This patch addresses these concerns which, as well as fixing the
semantics of the code, stops GCC complaining about impossible asm
constraints.
git://linux-arm.org/linux-mr into for-arm-soc/arch-timers
The arch_timer driver supports a superset of the functionality of the
arm_generic driver, and is not tied to a particular arch.
This patch moves arm64 to use the arch_timer driver, gaining additional
functionality in doing so, and removes the (now unused) arm_generic
driver. Timer-related hooks specific to arm64 are moved into
arch/arm64/kernel/time.c.
Currently arch_counter_get_cnt{p,v}ct can be speculated, allowing for
stale time values to be read. This could be problematic for the delay
loop and other sensitive functions, as the time delta could jump around
unexpectedly.
This patch adds isbs to arch_counter_get_cnt{p,v}ct, preventing this
possibility.
Required for make allyesconfig.
Wire the PSCI implementation into the SMP secondary startup
code.
