path: root/arch/arm64/include/asm/irqflags.h
2014-02-26arm64: Add macros to manage processor debug stateVijaya Kumar K
Add macros to enable and disable to manage PSTATE.D for debugging. The macros local_dbg_save and local_dbg_restore are moved to irqflags.h file KGDB boot tests fail because of PSTATE.D is masked. unmask it for debugging support Signed-off-by: Vijaya Kumar K <Vijaya.Kumar@caviumnetworks.com> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2013-11-25arm64: Unmask asynchronous aborts when in kernel modeCatalin Marinas
The asynchronous aborts are generally fatal for the kernel but they can be masked via the pstate A bit. If a system error happens while in kernel mode, it won't be visible until returning to user space. This patch enables this kind of abort early to help identifying the cause. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2012-09-17arm64: IRQ handlingMarc Zyngier
This patch adds the support for IRQ handling. The actual interrupt controller will be part of a separate patch (going into drivers/irqchip/). Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
