path: root/arch/arm64/boot/dts/renesas/r8a774b1-hihope-rzg2n.dts
2020-06-26arm64: dts: renesas: Add HiHope RZ/G2N Rev.3.0/4.0 main board supportLad Prabhakar
Add support for HiHope RZ/G2N Rev.3.0/4.0 main board support based on r8a774b1 SoC. Signed-off-by: Lad Prabhakar <prabhakar.mahadev-lad.rj@bp.renesas.com> Reviewed-by: Marian-Cristian Rotariu <marian-cristian.rotariu.rb@bp.renesas.com> Link: https://lore.kernel.org/r/1593004330-5039-10-git-send-email-prabhakar.mahadev-lad.rj@bp.renesas.com Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
2020-06-26arm64: dts: renesas: r8a774b1-hihope-rzg2n[-ex]: Rename HiHope RZ/G2N boardsLad Prabhakar
The existing DTS files for HiHope RZ/G2N boards are for Rev.2.0 version so reflect the same for the DTS file names so that the existing naming convention can be used for Rev.3.0/4.0 boards. Signed-off-by: Lad Prabhakar <prabhakar.mahadev-lad.rj@bp.renesas.com> Reviewed-by: Marian-Cristian Rotariu <marian-cristian.rotariu.rb@bp.renesas.com> Link: https://lore.kernel.org/r/1593004330-5039-3-git-send-email-prabhakar.mahadev-lad.rj@bp.renesas.com Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
2019-10-10arm64: dts: renesas: r8a774b1-hihope-rzg2n: Add display clock propertiesBiju Das
Add display clock properties for the HiHope RZ/G2N board. Signed-off-by: Biju Das <biju.das@bp.renesas.com> Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Link: https://lore.kernel.org/r/1570029619-43238-5-git-send-email-biju.das@bp.renesas.com Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
2019-10-10arm64: dts: renesas: r8a774b1-hihope-rzg2n: Enable HS400 modeBiju Das
This patch enables HS400 mode on HiHope RZ/G2N board. Signed-off-by: Biju Das <biju.das@bp.renesas.com> Link: https://lore.kernel.org/r/1569837778-55874-1-git-send-email-biju.das@bp.renesas.com Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
2019-10-01arm64: dts: renesas: Add HiHope RZ/G2N main board supportBiju Das
Basic support for the HiHope RZ/G2N main board: - Memory, - Main crystal, - Serial console Signed-off-by: Biju Das <biju.das@bp.renesas.com> Link: https://lore.kernel.org/r/1568725530-55241-5-git-send-email-biju.das@bp.renesas.com Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
