Make the IOCTL_PRIVCMD_MMAPBATCH_V2 (and older V1 version) map
multiple frames at a time rather than one at a time, despite the pages
being non-consecutive GFNs.
xen_remap_foreign_mfn_array() is added which maps an array of GFNs
(instead of a consecutive range of GFNs).
Since per-frame errors are returned in an array, privcmd must set the
MMAPBATCH_V1 error bits as part of the "report errors" phase, after
all the frames are mapped.
Migrate times are significantly improved (when using a PV toolstack
domain). For example, for an idle 12 GiB PV guest:
Before After
real 0m38.179s 0m26.868s
user 0m15.096s 0m13.652s
sys 0m28.988s 0m18.732s
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Reviewed-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Auto-translated physmap guests (arm, arm64 and x86 PVHVM/PVH) map and
unmap foreign GFNs using the same method (updating the physmap).
Unify the two arm and x86 implementations into one commont one.
Note that on arm and arm64, the correct error code will be returned
(instead of always -EFAULT) and map/unmap failure warnings are no
longer printed. These changes are required if the foreign domain is
paging (-ENOENT failures are expected and must be propagated up to the
caller).
When unmapping grants, instead of converting the kernel map ops to
unmap ops on the fly, pre-populate the set of unmap ops.
This allows the grant unmap for the kernel mappings to be trivially
batched in the future.
With Xen configured into the arm64 kernel, any driver allocating
DMA'able memory for PCI operations, must be GPL compatible, regardless
of its interaction with Xen. This patch relaxes the GPL requirement of
xen_dma_ops and its dependencies to allow open source drivers to be
compiled for the arm64 architecture.
Signed-off-by: Chuck Tuffli <chuck.tuffli@emulex.com>
Introduce support for new hypercall GNTTABOP_cache_flush.
Use it to perform cache flashing on pages used for dma when necessary.
If GNTTABOP_cache_flush is supported by the hypervisor, we don't need to
bounce dma map operations that involve foreign grants and non-coherent
devices.
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Acked-by: Ian Campbell <ian.campbell@citrix.com>
Introduce an arch specific function to find out whether a particular dma
mapping operation needs to bounce on the swiotlb buffer.
On ARM and ARM64, if the page involved is a foreign page and the device
is not coherent, we need to bounce because at unmap time we cannot
execute any required cache maintenance operations (we don't know how to
find the pfn from the mfn).
No change of behaviour for x86.
Reviewed-by: David Vrabel <david.vrabel@citrix.com>
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Merge xen/mm32.c into xen/mm.c.
As a consequence the code gets compiled on arm64 too.
In xen_dma_map_page, if the page is a local page, call the native
map_page dma_ops. If the page is foreign, call __xen_dma_map_page that
issues any required cache maintenane operations via hypercall.
The reason for doing this is that the native dma_ops map_page could
allocate buffers than need to be freed. If the page is foreign we don't
call the native unmap_page dma_ops function, resulting in a memory leak.
Suggested-by: Catalin Marinas <catalin.marinas@arm.com>
Use is_device_dma_coherent to check whether we need to issue cache
maintenance operations rather than checking on the existence of a
particular dma_ops function for the device.
This is correct because coherent devices don't need cache maintenance
operations - arm_coherent_dma_ops does not set the hooks that we
were previously checking for existance.
Remove code duplication in mm32.c by calling the native dma_ops if the
page is a local page (not a foreign page). Use a simple pfn_valid(pfn)
check to figure out if the page is local, exploiting the fact that dom0
is mapped 1:1, therefore pfn_valid always returns false when called on a
foreign mfn.
Dom0 is not actually capable of issuing outer_inv_range or
outer_clean_range calls.
The feature has been removed from Xen. Also Linux cannot use it on ARM32
without CONFIG_ARM_LPAE.
Remove the rbtree used to keep track of machine to physical mappings:
the frontend can grant the same page multiple times, leading to errors
inserting or removing entries from the mach_to_phys tree.
Linux only needed to know the physical address corresponding to a given
machine address in swiotlb-xen. Now that swiotlb-xen can call the
xen_dma_* functions passing the machine address directly, we can remove
it.
Tested-by: Denis Schneider <v1ne2go@gmail.com>
xen_dma_unmap_page, xen_dma_sync_single_for_cpu and
xen_dma_sync_single_for_device are currently implemented by calling into
the corresponding generic ARM implementation of these functions. In
order to do this, firstly the dma_addr_t handle, that on Xen is a
machine address, needs to be translated into a physical address. The
operation is expensive and inaccurate, given that a single machine
address can correspond to multiple physical addresses in one domain,
because the same page can be granted multiple times by the frontend.
To avoid this problem, we introduce a Xen specific implementation of
xen_dma_sync_single_for_device, that can operate on machine addresses
directly.
The new implementation relies on the fact that the hypervisor creates a
second p2m mapping of any grant pages at physical address == machine
address of the page for dom0. Therefore we can access memory at physical
address == dma_addr_r handle and perform the cache flushing there. Some
cache maintenance operations require a virtual address. Instead of using
ioremap_cache, that is not safe in interrupt context, we allocate a
per-cpu PAGE_KERNEL scratch page and we manually update the pte for it.
arm64 doesn't need cache maintenance operations on unmap for now.
The flag tells us that the hypervisor maps a grant page to guest
physical address == machine address of the page in addition to the
normal grant mapping address. It is needed to properly issue cache
maintenance operation at the completion of a DMA operation involving a
foreign grant.
This was introduced in commit e306e3be1cbe (Merge tag
'stable/for-linus-3.17-rc0-tag').
Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull Xen updates from David Vrabel:
- remove unused V2 grant table support
- note that Konrad is xen-blkkback/front maintainer
- add 'xen_nopv' option to disable PV extentions for x86 HVM guests
- misc minor cleanups
* tag 'stable/for-linus-3.17-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen-pciback: Document the 'quirks' sysfs file
xen/pciback: Fix error return code in xen_pcibk_attach()
xen/events: drop negativity check of unsigned parameter
xen/setup: Remove Identity Map Debug Message
xen/events/fifo: remove a unecessary use of BM()
xen/events/fifo: ensure all bitops are properly aligned even on x86
xen/events/fifo: reset control block and local HEADs on resume
xen/arm: use BUG_ON
xen/grant-table: remove support for V2 tables
x86/xen: safely map and unmap grant frames when in atomic context
MAINTAINERS: Make me the Xen block subsystem (front and back) maintainer
xen: Introduce 'xen_nopv' to disable PV extensions for HVM guests.
Pull ARM updates from Russell King:
"Included in this update:
- perf updates from Will Deacon:
The main changes are callchain stability fixes from Jean Pihet and
event mapping and PMU name rework from Mark Rutland
The latter is preparatory work for enabling some code re-use with
arm64 in the future.
- updates for nommu from Uwe Kleine-König:
Two different fixes for the same problem making some ARM nommu
configurations not boot since 3.6-rc1. The problem is that
user_addr_max returned the biggest available RAM address which
makes some copy_from_user variants fail to read from XIP memory.
- deprecate legacy OMAP DMA API, in preparation for it's removal.
The popular drivers have been converted over, leaving a very small
number of rarely used drivers, which hopefully can be converted
during the next cycle with a bit more visibility (and hopefully
people popping out of the woodwork to help test)
- more tweaks for BE systems, particularly with the kernel image
format. In connection with this, I've cleaned up the way we
generate the linker script for the decompressor.
- removal of hard-coded assumptions of the kernel stack size, making
everywhere depend on the value of THREAD_SIZE_ORDER.
- MCPM updates from Nicolas Pitre.
- Make it easier for proper CPU part number checks (which should
always include the vendor field).
- Assembly code optimisation - use the "bx" instruction when
returning from a function on ARMv6+ rather than "mov pc, reg".
- Save the last kernel misaligned fault location and report it via
the procfs alignment file.
- Clean up the way we create the initial stack frame, which is a
repeated pattern in several different locations.
- Support for 8-byte get_user(), needed for some DRM implementations.
- mcs locking from Will Deacon.
- Save and restore a few more Cortex-A9 registers (for errata
workarounds)
- Fix various aspects of the SWP emulation, and the ELF hwcap for the
SWP instruction.
- Update LPAE logic for pte_write and pmd_write to make it more
correct.
- Support for Broadcom Brahma15 CPU cores.
- ARM assembly crypto updates from Ard Biesheuvel"
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (53 commits)
ARM: add comments to the early page table remap code
ARM: 8122/1: smp_scu: enable SCU standby support
ARM: 8121/1: smp_scu: use macro for SCU enable bit
ARM: 8120/1: crypto: sha512: add ARM NEON implementation
ARM: 8119/1: crypto: sha1: add ARM NEON implementation
ARM: 8118/1: crypto: sha1/make use of common SHA-1 structures
ARM: 8113/1: remove remaining definitions of PLAT_PHYS_OFFSET from <mach/memory.h>
ARM: 8111/1: Enable erratum 798181 for Broadcom Brahma-B15
ARM: 8110/1: do CPU-specific init for Broadcom Brahma15 cores
ARM: 8109/1: mm: Modify pte_write and pmd_write logic for LPAE
ARM: 8108/1: mm: Introduce {pte,pmd}_isset and {pte,pmd}_isclear
ARM: hwcap: disable HWCAP_SWP if the CPU advertises it has exclusives
ARM: SWP emulation: only initialise on ARMv7 CPUs
ARM: SWP emulation: always enable when SMP is enabled
ARM: 8103/1: save/restore Cortex-A9 CP15 registers on suspend/resume
ARM: 8098/1: mcs lock: implement wfe-based polling for MCS locking
ARM: 8091/2: add get_user() support for 8 byte types
ARM: 8097/1: unistd.h: relocate comments back to place
ARM: 8096/1: Describe required sort order for textofs-y (TEXT_OFFSET)
ARM: 8090/1: add revision info for PL310 errata 588369 and 727915
arch_gnttab_map_frames() and arch_gnttab_unmap_frames() are called in
atomic context but were calling alloc_vm_area() which might sleep.
Also, if a driver attempts to allocate a grant ref from an interrupt
and the table needs expanding, then the CPU may already by in lazy MMU
mode and apply_to_page_range() will BUG when it tries to re-enable
lazy MMU mode.
These two functions are only used in PV guests.
Introduce arch_gnttab_init() to allocates the virtual address space in
advance.
Avoid the use of apply_to_page_range() by using saving and using the
array of PTE addresses from the alloc_vm_area() call (which ensures
that the required page tables are pre-allocated).
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Use BUG_ON(x) rather than if(x) BUG();
The semantic patch that fixes this problem is as follows:
// <smpl>
@@ identifier x; @@
-if (x) BUG();
+BUG_ON(x);
// </smpl>
Signed-off-by: Himangi Saraogi <himangi774@gmail.com>
ARMv6 and greater introduced a new instruction ("bx") which can be used
to return from function calls. Recent CPUs perform better when the
"bx lr" instruction is used rather than the "mov pc, lr" instruction,
and this sequence is strongly recommended to be used by the ARM
architecture manual (section A.4.1.1).
We provide a new macro "ret" with all its variants for the condition
code which will resolve to the appropriate instruction.
Rather than doing this piecemeal, and miss some instances, change all
the "mov pc" instances to use the new macro, with the exception of
the "movs" instruction and the kprobes code. This allows us to detect
the "mov pc, lr" case and fix it up - and also gives us the possibility
of deploying this for other registers depending on the CPU selection.
Reported-by: Will Deacon <will.deacon@arm.com>
Tested-by: Stephen Warren <swarren@nvidia.com> # Tegra Jetson TK1
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> # mioa701_bootresume.S
Tested-by: Andrew Lunn <andrew@lunn.ch> # Kirkwood
Tested-by: Shawn Guo <shawn.guo@freescale.com>
Tested-by: Tony Lindgren <tony@atomide.com> # OMAPs
Tested-by: Gregory CLEMENT <gregory.clement@free-electrons.com> # Armada XP, 375, 385
Acked-by: Sekhar Nori <nsekhar@ti.com> # DaVinci
Acked-by: Christoffer Dall <christoffer.dall@linaro.org> # kvm/hyp
Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> # PXA3xx
Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> # Xen
Tested-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> # ARMv7M
Tested-by: Simon Horman <horms+renesas@verge.net.au> # Shmobile
Since 11c7ff17c9b6dbf3a4e4f36be30ad531a6cf0ec9 (xen/grant-table: Force
to use v1 of grants.) the code for V2 grant tables is not used.
lazy MMU mode.
advance.
array of PTE addresses from the alloc_vm_area() call.
N.B. 'alloc_vm_area' pre-allocates the pagetable so there is no need
to worry about having to do a PGD/PUD/PMD walk (like apply_to_page_range
does) and we can instead do set_pte.
[v2: Add comment about alloc_vm_area]
[v3: Fix compile error found by 0-day bot]
Introduce HYPERVISOR_suspend() and a few additional empty stubs for
Xen arch specific functions called by drivers/xen/manage.c.
"arm: xen: implement multicall hypercall support." forgot to do this.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
As part of this make the usual change to xen_ulong_t in place of unsigned long.
This change has no impact on x86.
The Linux definition of struct multicall_entry.result differs from the Xen
definition, I think for good reasons, and used a long rather than an unsigned
long. Therefore introduce a xen_long_t, which is a long on x86 architectures
and a signed 64-bit integer on ARM.
Use uint32_t nr_calls on x86 for consistency with the ARM definition.
Build tested on amd64 and i386 builds. Runtime tested on ARM.
Cc: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
The grant mapping API does m2p_override unnecessarily: only gntdev needs it,
for blkback and future netback patches it just cause a lock contention, as
those pages never go to userspace. Therefore this series does the following:
- the bulk of the original function (everything after the mapping hypercall)
is moved to arch-dependent set/clear_foreign_p2m_mapping
- the "if (xen_feature(XENFEAT_auto_translated_physmap))" branch goes to ARM
- therefore the ARM function could be much smaller, the m2p_override stubs
could be also removed
- on x86 the set_phys_to_machine calls were moved up to this new funcion
from m2p_override functions
- and m2p_override functions are only called when there is a kmap_ops param
It also removes a stray space from arch/x86/include/asm/xen/page.h.
Signed-off-by: Zoltan Kiss <zoltan.kiss@citrix.com>
Suggested-by: Anthony Liguori <aliguori@amazon.com>
Suggested-by: David Vrabel <david.vrabel@citrix.com>
Suggested-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
On ARM, address size can be 32 bits or 64 bits (if CONFIG_ARCH_PHYS_ADDR_T_64BIT
is enabled).
We can't assume that the grant frame base address will always fits in an
unsigned long. Use phys_addr_t instead of unsigned long as argument for
gnttab_setup_auto_xlat_frames.
Signed-off-by: Julien Grall <julien.grall@linaro.org>
Event channels driver needs to be initialized very early. Until now, Xen
initialization was done after all CPUs was bring up.
We can safely move the initialization to an early initcall.
Also use a cpu notifier to:
- Register the VCPU when the CPU is prepared
- Enable event channel IRQ when the CPU is running
The 'xen_hvm_resume_frames' used to be an 'unsigned long'
and contain the virtual address of the grants. That was OK
for most architectures (PVHVM, ARM) were the grants are contiguous
in memory. That however is not the case for PVH - in which case
we will have to do a lookup for each virtual address for the PFN.
Instead of doing that, lets make it a structure which will contain
the array of PFNs, the virtual address and the count of said PFNs.
Also provide a generic functions: gnttab_setup_auto_xlat_frames and
gnttab_free_auto_xlat_frames to populate said structure with
appropriate values for PVHVM and ARM.
To round it off, change the name from 'xen_hvm_resume_frames' to
a more descriptive one - 'xen_auto_xlat_grant_frames'.
For PVH, in patch "xen/pvh: Piggyback on PVHVM for grant driver"
we will populate the 'xen_auto_xlat_grant_frames' by ourselves.
v2 moves the xen_remap in the gnttab_setup_auto_xlat_frames
and also introduces xen_unmap for gnttab_free_auto_xlat_frames.
[v3: Based on top of 'asm/xen/page.h: remove redundant semicolon']
These mappings are in fact special and require special handling in privcmd,
which already exists. Failure to mark the PTE as special on arm64 causes all
sorts of bad PTE fun. e.g.
e.g.:
BUG: Bad page map in process xl pte:e0004077b33f53 pmd:4079575003
page:ffffffbce1a2f328 count:1 mapcount:-1 mapping: (null) index:0x0
page flags: 0x4000000000000014(referenced|dirty)
addr:0000007fb5259000 vm_flags:040644fa anon_vma: (null) mapping:ffffffc03a6fda58 index:0
vma->vm_ops->fault: privcmd_fault+0x0/0x38
vma->vm_file->f_op->mmap: privcmd_mmap+0x0/0x2c
CPU: 0 PID: 2657 Comm: xl Not tainted 3.12.0+ #102
Call trace:
[<ffffffc0000880f8>] dump_backtrace+0x0/0x12c
[<ffffffc000088238>] show_stack+0x14/0x1c
[<ffffffc0004b67e0>] dump_stack+0x70/0x90
[<ffffffc000125690>] print_bad_pte+0x12c/0x1bc
[<ffffffc0001268f4>] unmap_single_vma+0x4cc/0x700
[<ffffffc0001273b4>] unmap_vmas+0x68/0xb4
[<ffffffc00012c050>] unmap_region+0xcc/0x1d4
[<ffffffc00012df20>] do_munmap+0x218/0x314
[<ffffffc00012e060>] vm_munmap+0x44/0x64
[<ffffffc00012ed78>] SyS_munmap+0x24/0x34
Where unmap_single_vma contains inlined -> unmap_page_range -> zap_pud_range
-> zap_pmd_range -> zap_pte_range -> print_bad_pte.
Or:
BUG: Bad page state in process xl pfn:4077b4d
page:ffffffbce1a2f8d8 count:0 mapcount:-1 mapping: (null) index:0x0
Modules linked in:
CPU: 0 PID: 2657 Comm: xl Tainted: G B 3.12.0+ #102
Call trace:
[<ffffffc00010f798>] bad_page+0xc4/0x110
[<ffffffc00010f8b4>] free_pages_prepare+0xd0/0xd8
[<ffffffc000110e94>] free_hot_cold_page+0x28/0x178
[<ffffffc000111460>] free_hot_cold_page_list+0x38/0x60
[<ffffffc000114cf0>] release_pages+0x190/0x1dc
[<ffffffc00012c0e0>] unmap_region+0x15c/0x1d4
x86 already gets this correct. 32-bit arm gets away with this because there is
not PTE_SPECIAL bit in the PTE there and the vm_normal_page fallback path does
the right thing.
xen_hvm_resume_frames stores the physical address of the grant table.
englighten.c was incorrectly setting it as if it was a page frame number.
This caused the table to be mapped into the guest at an unexpected physical
address.
Additionally, a warning is improved to include the grant table address which
failed in xen_remap.
Signed-off-by: Eric Trudeau <etrudeau@broadcom.com>
Various xen drivers fail to link when built as modules with the following
error:
ERROR: "phys_to_mach" [drivers/xen/xen-gntalloc.ko] undefined!
ERROR: "phys_to_mach" [drivers/net/xen-netfront.ko] undefined!
ERROR: "phys_to_mach" [drivers/net/xen-netback/xen-netback.ko] undefined!
ERROR: "phys_to_mach" [drivers/block/xen-blkfront.ko] undefined!
The mfn_to_pfn and pfn_to_mfn functions get inlined in these modules and
those functions require phys_to_mach. Export the symbol to fix the link
errors.
Signed-off-by: Josh Boyer <jwboyer@fedoraproject.org>
stable/for-linus-3.13
* stefano/swiotlb-xen-9.1:
swiotlb-xen: fix error code returned by xen_swiotlb_map_sg_attrs
swiotlb-xen: static inline xen_phys_to_bus, xen_bus_to_phys, xen_virt_to_bus and range_straddles_page_boundary
grant-table: call set_phys_to_machine after mapping grant refs
arm,arm64: do not always merge biovec if we are running on Xen
swiotlb: print a warning when the swiotlb is full
swiotlb-xen: use xen_dma_map/unmap_page, xen_dma_sync_single_for_cpu/device
xen: introduce xen_dma_map/unmap_page and xen_dma_sync_single_for_cpu/device
swiotlb-xen: use xen_alloc/free_coherent_pages
xen: introduce xen_alloc/free_coherent_pages
arm64/xen: get_dma_ops: return xen_dma_ops if we are running as xen_initial_domain
arm/xen: get_dma_ops: return xen_dma_ops if we are running as xen_initial_domain
swiotlb-xen: introduce xen_swiotlb_set_dma_mask
xen/arm,arm64: enable SWIOTLB_XEN
xen: make xen_create_contiguous_region return the dma address
xen/x86: allow __set_phys_to_machine for autotranslate guests
arm/xen,arm64/xen: introduce p2m
arm64: define DMA_ERROR_CODE
arm: make SWIOTLB available
arch/arm/include/asm/dma-mapping.h
drivers/xen/swiotlb-xen.c
[Conflicts arose b/c "arm: make SWIOTLB available" v8 was in Stefano's
branch, while I had v9 + Ack from Russel. I also fixed up white-space
issues]
Use xen_alloc_coherent_pages and xen_free_coherent_pages to allocate or
free coherent pages.
We need to be careful handling the pointer returned by
xen_alloc_coherent_pages, because on ARM the pointer is not equal to
phys_to_virt(*dma_handle). In fact virt_to_phys only works for kernel
direct mapped RAM memory.
In ARM case the pointer could be an ioremap address, therefore passing
it to virt_to_phys would give you another physical address that doesn't
correspond to it.
Make xen_create_contiguous_region take a phys_addr_t as start parameter to
avoid the virt_to_phys calls which would be incorrect.
Changes in v6:
- remove extra spaces.
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Implement xen_swiotlb_set_dma_mask, use it for set_dma_mask on arm.
Xen on arm and arm64 needs SWIOTLB_XEN: when running on Xen we need to
program the hardware with mfns rather than pfns for dma addresses.
Remove SWIOTLB_XEN dependency on X86 and PCI and make XEN select
SWIOTLB_XEN on arm and arm64.
At the moment always rely on swiotlb-xen, but when Xen starts supporting
hardware IOMMUs we'll be able to avoid it conditionally on the presence
of an IOMMU on the platform.
Implement xen_create_contiguous_region on arm and arm64: for the moment
we assume that dom0 has been mapped 1:1 (physical addresses == machine
addresses) therefore we don't need to call XENMEM_exchange. Simply
return the physical address as dma address.
Initialize the xen-swiotlb from xen_early_init (before the native
dma_ops are initialized), set xen_dma_ops to &xen_swiotlb_dma_ops.
Changes in v8:
- assume dom0 is mapped 1:1, no need to call XENMEM_exchange.
Changes in v7:
- call __set_phys_to_machine_multi from xen_create_contiguous_region and
xen_destroy_contiguous_region to update the P2M;
- don't call XENMEM_unpin, it has been removed;
- call XENMEM_exchange instead of XENMEM_exchange_and_pin;
- set nr_exchanged to 0 before calling the hypercall.
Changes in v6:
- introduce and export xen_dma_ops;
- call xen_mm_init from as arch_initcall.
Changes in v4:
- remove redefinition of DMA_ERROR_CODE;
- update the code to use XENMEM_exchange_and_pin and XENMEM_unpin;
- add a note about hardware IOMMU in the commit message.
Changes in v3:
- code style changes;
- warn on XENMEM_put_dma_buf failures.
Introduce physical to machine and machine to physical tracking
mechanisms based on rbtrees for arm/xen and arm64/xen.
We need it because any guests on ARM are an autotranslate guests,
therefore a physical address is potentially different from a machine
address. When programming a device to do DMA, we need to be
extra-careful to use machine addresses rather than physical addresses to
program the device. Therefore we need to know the physical to machine
mappings.
For the moment we assume that dom0 starts with a 1:1 physical to machine
mapping, in other words physical addresses correspond to machine
addresses. However when mapping a foreign grant reference, obviously the
1:1 model doesn't work anymore. So at the very least we need to be able
to track grant mappings.
We need locking to protect accesses to the two trees.
Changes in v8:
- move pfn_to_mfn and mfn_to_pfn to page.h as static inline functions;
- no need to walk the tree if phys_to_mach.rb_node is NULL;
- correctly handle multipage p2m entries;
- substitute the spin_lock with a rwlock.
Linux 3.11-rc7
As we need the git commit 28817e9de4f039a1a8c1fe1df2fa2df524626b9e
Author: Chuck Anderson <chuck.anderson@oracle.com>
Date: Tue Aug 6 15:12:19 2013 -0700
xen/smp: initialize IPI vectors before marking CPU online
* tag 'v3.11-rc7': (443 commits)
Linux 3.11-rc7
ARC: [lib] strchr breakage in Big-endian configuration
VFS: collect_mounts() should return an ERR_PTR
bfs: iget_locked() doesn't return an ERR_PTR
efs: iget_locked() doesn't return an ERR_PTR()
proc: kill the extra proc_readfd_common()->dir_emit_dots()
cope with potentially long ->d_dname() output for shmem/hugetlb
usb: phy: fix build breakage
USB: OHCI: add missing PCI PM callbacks to ohci-pci.c
staging: comedi: bug-fix NULL pointer dereference on failed attach
lib/lz4: correct the LZ4 license
memcg: get rid of swapaccount leftovers
nilfs2: fix issue with counting number of bio requests for BIO_EOPNOTSUPP error detection
nilfs2: remove double bio_put() in nilfs_end_bio_write() for BIO_EOPNOTSUPP error
drivers/platform/olpc/olpc-ec.c: initialise earlier
ipv4: expose IPV4_DEVCONF
ipv6: handle Redirect ICMP Message with no Redirected Header option
be2net: fix disabling TX in be_close()
Revert "ACPI / video: Always call acpi_video_init_brightness() on init"
Revert "genetlink: fix family dump race"
When linux is running as dom0, Xen doesn't show the physical cpu but a
virtual CPU.
On some ARM SOC (for instance the exynos 5250), linux registers callbacks
for cpuidle and cpufreq. When these callbacks are called, they will modify
directly the physical cpu not the virtual one. It can impact the whole board
instead of only dom0.
xen_pm_init was unconditionally setting pm_power_off and arm_pm_restart
function pointers. This breaks multi-platform kernels. Make this
conditional on running as a Xen guest and make it a late_initcall to
ensure it is setup after platform code for Dom0.
CC: stable@vger.kernel.org
Pull Xen bug-fixes from Konrad Rzeszutek Wilk:
- On ARM did not have balanced calls to get/put_cpu.
- Fix to make tboot + Xen + Linux correctly.
- Fix events VCPU binding issues.
- Fix a vCPU online race where IPIs are sent to not-yet-online vCPU.
* tag 'stable/for-linus-3.11-rc6-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen/events: mask events when changing their VCPU binding
xen/events: initialize local per-cpu mask for all possible events
x86/xen: do not identity map UNUSABLE regions in the machine E820
xen/arm: missing put_cpu in xen_percpu_init
When CONFIG_PREEMPT is enabled, Linux will not be able to boot and warn:
[ 4.127825] ------------[ cut here ]------------
[ 4.133376] WARNING: at init/main.c:699 do_one_initcall+0x150/0x158()
[ 4.140738] initcall xen_init_events+0x0/0x10c returned with preemption imbalance
This is because xen_percpu_init uses get_cpu but doesn't have the corresponding
put_cpu.
Commit 7b6d864b48d9 (reboot: arm: change reboot_mode to use enum
reboot_mode) and ff701306cd49 (arm64: use common reboot infrastructure)
change the prototype of arm_pm_restart on arm and arm64.
Update xen_restart accordingly.
Rename xen_secondary_init to xen_percpu_init.
Run xen_percpu_init on the each online cpu, reuse the current on_each_cpu call.
Merge xen_percpu_enable_events into xen_percpu_init.
We expect VCPUOP_register_vcpu_info to succeed, do not try to handle
failures.
If we are running in dom0, we have to wait for the arch specific code to
complete the initialization in order for us to successfully reset the
power_off and pm_restart functions.
Remove duplicated include.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
