path: root/arch/arm/plat-stmp3xxx
2011-01-06Merge branch 'misc' into develRussell King
Conflicts: arch/arm/Kconfig arch/arm/common/Makefile arch/arm/kernel/Makefile arch/arm/kernel/smp.c
2010-12-22ARM: stmp: update clock source registrationRussell King
In d7e81c2 (clocksource: Add clocksource_register_hz/khz interface) new interfaces were added which simplify (and optimize) the selection of the divisor shift/mult constants. Switch over to using this new interface. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-11-26ARM: 6483/1: arm & sh: factorised duplicated clkdev.cJean-Christop PLAGNIOL-VILLARD
factorise some generic infrastructure to assist looking up struct clks for the ARM & SH architecture. as the code is identical at 99% put the arch specific code for allocation as example in asm/clkdev.h Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-10-20arm: return both physical and virtual addresses from addruartJeremy Kerr
Rather than checking the MMU status in every instance of addruart, do it once in kernel/debug.S, and change the existing addruart macros to return both physical and virtual addresses. The main debug code can then select the appropriate address to use. This will also allow us to retreive the address of a uart for the MMU state that we're not current in. Updated with fixes for OMAP from Jason Wang <jason77.wang@gmail.com> and Tony Lindgren <tony@atomide.com>, and fix for versatile express from Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Jason Wang <jason77.wang@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-25Merge branches 'clks' and 'pnx' into develRussell King
2010-02-25Merge branch 'misc2' into develRussell King
2010-02-15ARM: 5928/1: Change type of VMALLOC_END to unsigned long.Fenkart/Bostandzhyan
Makes it consistent with VMALLOC_START Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Andreas Fenkart <andreas.fenkart@streamunlimited.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-12ARM: Consolidate clks_register() and similarRussell King
Most machine classes want some way to register a block of clk_lookup structures, and most do it by implementing a clks_register() type function which walks an array, or by open-coding a loop. Consolidate all this into clkdev_add_table(). Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-12ARM: 5910/1: ARM: Add tmp register for addruart and loadspTony Lindgren
Otherwise more complicated uart configuration won't be possible. We can use r1 for tmp register for both head.S and debug.S. NOTE: This patch depends on another patch to add the the tmp register into all debug-macro.S files. That can be done with: $ sed -i -e "s/addruart,rx|addruart, rx/addruart, rx, tmp/" arch/arm/*/include/*/debug-macro.S Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-19ARM: STMP3xxx: deallocation with negative index of descriptors[]Roel Kluin
The last deallocation is invalid. In the last iteration, i is -1. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: dmitry pervushin <dpervushin@embeddedalley.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-07-25ARM: includecheck fix: plat-stmp3xxx/pinmux.cJaswinder Singh Rajput
fix the following 'make includecheck' warning: arch/arm/plat-stmp3xxx/pinmux.c: linux/sysdev.h is included more than once. Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Acked-by: dmitry pervushin <dpervushin@embeddedalley.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-06-04[ARM] 5539/1: Freescale STMP: onboard devices declarationdmitry pervushin
Define onboard devices for Freescale STMP3xxx boards Signed-off-by: dmitry pervushin <dpervushin@embeddedalley.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-05-31[ARM] 5532/1: Freescale STMP: register definitions [3/3]dmitry pervushin
Replace HW_zzz register access macros by regular __raw_readl/__raw_writel calls Signed-off-by: dmitry pervushin <dpervushin@embeddedalley.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-05-07[ARM] 5501/1: Freescale STMP: fix compilation warningdmitry pervushin
To avoid compile-time warning, added parameter to the stmp3xxx_clock_read Signed-off-by: dmitry pervushin <dpervushin@embeddedalley.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-04-27[ARM] 5477/1: Freescale STMP platform support [6/10]dmitry pervushin
Sources: common STMP3xxx platform support Signed-off-by: dmitry pervushin <dpervushin@embeddedalley.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-04-27[ARM] 5466/1: Freescale STMP platform support [5/10]dmitry pervushin
Shared (platform) headers Signed-off-by: dmitry pervushin <dpervushin@embeddedalley.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
