Since keypad-core header is not used, this patch removes it.
Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Cc: Joonyoung Shim <jy0922.shim@samsung.com>
Signed-off-by: Kukjin Kim <kgene@kernel.org>
This patch moves watchdog-reset header file into mach-s3c64xx.
Because it is not used for others except mach-s3c64xx.
This patch moves onenand-core header file into mach-s3c64xx.
This patch moves irq-uart header file into mach-s3c64xx.
This patch moves backlight header file into mach-s3c64xx.
This patch moves ata-core header file into mach-s3c64xx.
This patch moves regs-usb-hsotg-phy header file into mach-s3c64xx.
This patch moves spi-core header file into mach-s3c24xx.
Because it is not used for others except mach-s3c24xx.
This patch moves nand-core header file into mach-s3c24xx.
This patch moves fb-core header file into mach-s3c24xx.
This patch moves regs-srom header file into mach-exynos.
Because it is not used for others except mach-exynos.
This patch moves s5p-dev-mfc from plat-samsung into mach-exynos
because it is used for only exynos no other platforms.
This patch moves dev-backlight from plat-samsung into mach-s3c64xx
because it is used for only s3c64xx no other platforms.
This patch moves setup-camif from plat-samsung into mach-s3c24xx
because it can be used only for s3c24xx no other platforms.
The platform_device_id is not modified by the driver and core
uses it as const.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com>
Convert clk_enable/clk_disable to clk_prepare_enable/clk_disable_unprepare
calls as required by common clock framework. Removes this warning on probe:
WARNING: CPU: 0 PID: 1 at drivers/clk/clk.c:889 __clk_enable+0x28/0x9c()
Modules linked in:
CPU: 0 PID: 1 Comm: swapper Not tainted 3.19.0+ #46
[<c0013a98>] (unwind_backtrace) from [<c0010d8c>] (show_stack+0x10/0x14)
[<c0010d8c>] (show_stack) from [<c001b018>] (warn_slowpath_common+0x7c/0xa4)
[<c001b018>] (warn_slowpath_common) from [<c001b0d0>] (warn_slowpath_null+0x18/0x20)
[<c001b0d0>] (warn_slowpath_null) from [<c01a5f80>] (__clk_enable+0x28/0x9c)
[<c01a5f80>] (__clk_enable) from [<c01a600c>] (clk_enable+0x18/0x2c)
[<c01a600c>] (clk_enable) from [<c001860c>] (s3c_adc_probe+0x11c/0x18c)
[<c001860c>] (s3c_adc_probe) from [<c0153a10>] (platform_drv_probe+0x30/0x78)
[<c0153a10>] (platform_drv_probe) from [<c01523e0>] (driver_probe_device+0xb0/0x1fc)
[<c01523e0>] (driver_probe_device) from [<c01525dc>] (__driver_attach+0x68/0x88)
[<c01525dc>] (__driver_attach) from [<c0150df0>] (bus_for_each_dev+0x70/0x94)
[<c0150df0>] (bus_for_each_dev) from [<c0151c80>] (bus_add_driver+0xdc/0x1c4)
[<c0151c80>] (bus_add_driver) from [<c0152ba4>] (driver_register+0x9c/0xe0)
[<c0152ba4>] (driver_register) from [<c03041cc>] (adc_init+0x10/0x34)
[<c03041cc>] (adc_init) from [<c00087fc>] (do_one_initcall+0x110/0x1cc)
[<c00087fc>] (do_one_initcall) from [<c02ffccc>] (kernel_init_freeable+0xf4/0x1ac)
[<c02ffccc>] (kernel_init_freeable) from [<c022f4fc>] (kernel_init+0x8/0xe0)
[<c022f4fc>] (kernel_init) from [<c000e098>] (ret_from_fork+0x14/0x3c)
---[ end trace f4a1ea39a114fecf ]---
Signed-off-by: Sergiy Kibrik <sakib@meta.ua>
Reviewed-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com>
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
The pm-core.h file does not include all the necessary headers,
and has a static declaration for a function that is not
defined in the same file, causing SAMSUNG_PM_DEBUG to
break on s3c24xx:
arch/arm/mach-s3c24xx/include/mach/pm-core.h:50:91: warning: 's3c_pm_show_resume_irqs' used but never defined
arch/arm/mach-s3c24xx/include/mach/pm-core.h: In function 's3c_pm_debug_init_uart':
arch/arm/mach-s3c24xx/include/mach/pm-core.h:16:34: error: 'S3C2410_CLKCON' undeclared (first use in this function)
unsigned long tmp = __raw_readl(S3C2410_CLKCON);
This moves the code around slightly to avoid the errors.
We get lots of link errors based on the assumption that
any s3c24xx kernel would enable CONFIG_PM_SLEEP if it
enables CONFIG_PM. This tries to clean that up.
arch/arm/mach-s3c64xx/built-in.o: In function `s3c_pm_restore_core':
:(.text+0x5d0): undefined reference to `s3c_pm_do_restore_core'
:(.text+0x5d4): undefined reference to `s3c_pm_do_restore'
arch/arm/mach-s3c64xx/built-in.o: In function `s3c_pm_save_core':
:(.text+0x60c): undefined reference to `s3c_pm_do_save'
arch/arm/mach-s3c64xx/built-in.o: In function `s3c64xx_irq_pm_resume':
:(.text+0x670): undefined reference to `s3c_pm_do_restore'
arch/arm/mach-s3c64xx/built-in.o: In function `s3c64xx_irq_pm_suspend':
:(.text+0x6d8): undefined reference to `s3c_pm_do_save'
arch/arm/mach-s3c64xx/built-in.o: In function `s3c_cpu_resume':
:(.text+0x71c): undefined reference to `cpu_resume'
Pull ARM SoC platform changes from Olof Johansson:
"New and updated SoC support. Also included are some cleanups where
the platform maintainers hadn't separated cleanups from new developent
in separate branches.
Some of the larger things worth pointing out:
- A large set of changes from Alexandre Belloni and Nicolas Ferre
preparing at91 platforms for multiplatform and cleaning up quite a
bit in the process.
- Removal of CSR's "Marco" SoC platform that never made it out to the
market. We love seeing these since it means the vendor published
support before product was out, which is exactly what we want!
New platforms this release are:
- Conexant Digicolor (CX92755 SoC)
- Hisilicon HiP01 SoC
- CSR/sirf Atlas7 SoC
- ST STiH418 SoC
- Common code changes for Nvidia Tegra132 (64-bit SoC)
We're seeing more and more platforms having a harder time labelling
changes as cleanups vs new development -- which is a good sign that
we've come quite far on the cleanup effort. So over time we might
start combining the cleanup and new-development branches more"
* tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (124 commits)
ARM: at91/trivial: unify functions and machine names
ARM: at91: remove at91_dt_initialize and machine init_early()
ARM: at91: change board files into SoC files
ARM: at91: remove at91_boot_soc
ARM: at91: move alternative initial mapping to board-dt-sama5.c
ARM: at91: merge all SOC_AT91SAM9xxx
ARM: at91: at91rm9200: set idle and restart from rm9200_dt_device_init()
ARM: digicolor: select syscon and timer
ARM: zynq: Simplify SLCR initialization
ARM: zynq: PM: Fixed simple typo.
ARM: zynq: Setup default gpio number for Xilinx Zynq
ARM: digicolor: add low level debug support
ARM: initial support for Conexant Digicolor CX92755 SoC
ARM: OMAP2+: Add dm816x hwmod support
ARM: OMAP2+: Add clock domain support for dm816x
ARM: OMAP2+: Add board-generic.c entry for ti81xx
ARM: at91: pm: remove warning to remove SOC_AT91SAM9263 usage
ARM: at91: remove unused mach/system_rev.h
ARM: at91: stop using HAVE_AT91_DBGUx
ARM: at91: fix ordering of SRAM and PM initialization
Everything uses dmaengine now, so there is no reason to
keep this around any longer. Thanks to everyone who was involved
in moving the users over to use the dmaengine APIs.
Reviewed-by: Heiko Stuebner <heiko@sntech.de>
Acked-by: Vinod Koul <vinod.koul@intel.com>
It's useful to get the CPU ID/rev printed during boot sometimes, so
add a line with that information. Given that the fields have moved
within the register over time, don't try to be clever and parse it --
just print the raw values for now.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core update from Greg KH:
"Here's the set of driver core patches for 3.19-rc1.
They are dominated by the removal of the .owner field in platform
drivers. They touch a lot of files, but they are "simple" changes,
just removing a line in a structure.
Other than that, a few minor driver core and debugfs changes. There
are some ath9k patches coming in through this tree that have been
acked by the wireless maintainers as they relied on the debugfs
changes.
Everything has been in linux-next for a while"
* tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits)
Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries"
fs: debugfs: add forward declaration for struct device type
firmware class: Deletion of an unnecessary check before the function call "vunmap"
firmware loader: fix hung task warning dump
devcoredump: provide a one-way disable function
device: Add dev_<level>_once variants
ath: use seq_file api for ath9k debugfs files
debugfs: add helper function to create device related seq_file
drivers/base: cacheinfo: remove noisy error boot message
Revert "core: platform: add warning if driver has no owner"
drivers: base: support cpu cache information interface to userspace via sysfs
drivers: base: add cpu_device_create to support per-cpu devices
topology: replace custom attribute macros with standard DEVICE_ATTR*
cpumask: factor out show_cpumap into separate helper function
driver core: Fix unbalanced device reference in drivers_probe
driver core: fix race with userland in device_add()
sysfs/kernfs: make read requests on pre-alloc files use the buffer.
sysfs/kernfs: allow attributes to request write buffer be pre-allocated.
fs: sysfs: return EGBIG on write if offset is larger than file size
Pull ARM SoC platform changes from Arnd Bergmann:
"New and updated SoC support, notable changes include:
- bcm:
brcmstb SMP support
initial iproc/cygnus support
- exynos:
Exynos4415 SoC support
PMU and suspend support for Exynos5420
PMU support for Exynos3250
pm related maintenance
- imx:
new LS1021A SoC support
vybrid 610 global timer support
- integrator:
convert to using multiplatform configuration
- mediatek:
earlyprintk support for mt8127/mt8135
- meson:
meson8 soc and l2 cache controller support
- mvebu:
Armada 38x CPU hotplug support
drop support for prerelease Armada 375 Z1 stepping
extended suspend support, now works on Armada 370/XP
- omap:
hwmod related maintenance
prcm cleanup
- pxa:
initial pxa27x DT handling
- rockchip:
SMP support for rk3288
add cpu frequency scaling support
- shmobile:
r8a7740 power domain support
various small restart, timer, pci apmu changes
- sunxi:
Allwinner A80 (sun9i) earlyprintk support
- ux500:
Overall, a significant chunk of changes, coming mostly from the usual
suspects: omap, shmobile, samsung and mvebu, all of which already
contain a lot of platform specific code in arch/arm"
* tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (187 commits)
ARM: mvebu: use the cpufreq-dt platform_data for independent clocks
soc: integrator: Add terminating entry for integrator_cm_match
ARM: mvebu: add SDRAM controller description for Armada XP
ARM: mvebu: adjust mbus controller description on Armada 370/XP
ARM: mvebu: add suspend/resume DT information for Armada XP GP
ARM: mvebu: synchronize secondary CPU clocks on resume
ARM: mvebu: make sure MMU is disabled in armada_370_xp_cpu_resume
ARM: mvebu: Armada XP GP specific suspend/resume code
ARM: mvebu: reserve the first 10 KB of each memory bank for suspend/resume
ARM: mvebu: implement suspend/resume support for Armada XP
clk: mvebu: add suspend/resume for gatable clocks
bus: mvebu-mbus: provide a mechanism to save SDRAM window configuration
bus: mvebu-mbus: suspend/resume support
clocksource: time-armada-370-xp: add suspend/resume support
irqchip: armada-370-xp: Add suspend/resume support
ARM: add lolevel debug support for asm9260
ARM: add mach-asm9260
ARM: EXYNOS: use u8 for val[] in struct exynos_pmu_conf
power: reset: imx-snvs-poweroff: add power off driver for i.mx6
ARM: imx: temporarily remove CONFIG_SOC_FSL from LS1021A
This patch removes all unused static iomapping from exynos4/5_iodesc
table, and at the same time removes related macros from mach/map.h and
plat/map-s5p.h. All such mappings are present in exynos.c but not
currently there are no users of these mappings, so it is safe to remove
these.
Signed-off-by: Pankaj Dubey <pankaj.dubey@samsung.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Fix building of exynos_defconfig with CONFIG_PM_SLEEP disabled and
CONFIG_ARM_EXYNOS_CPUIDLE enabled by:
* adding EXYNOS_CPU_SUSPEND config option
* always building sleep.o
* building pm.o if EXYNOS_CPU_SUSPEND is enabled
* moving suspend specific code from pm.c to suspend.c
* enabling pm-common.o build also for EXYNOS_CPU_SUSPEND option
[ Please note that there are no changes in the code moved from pm.c
to suspend.c except making few functions non-static and cleaning
up includes. ]
Also while at it update Copyright dates.
The build error messages:
drivers/built-in.o: In function `exynos_enter_core0_aftr':
/home/bzolnier/linux/drivers/cpuidle/cpuidle-exynos.c:36: undefined reference to `cpu_suspend'
arch/arm/mach-exynos/built-in.o:(.data+0x74): undefined reference to `exynos_enter_aftr'
make: *** [vmlinux] Error 1
This patch has been tested on Exynos4210 based Origen board.
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into fixes
Merge "Samsung fixes for v3.18" from Kukjin Kim:
- fix ifdef around cpu_*_do_[suspend, resume] ops to check
CONFIG_ARM_CPU_SUSPEND and not CONFIG_PM_SLEEP
- fix exynos_defconfig build with PM_SLEEP=n and ARM_EXYNOS_CPUIDLE=n
- fix enabling Samsung PM debug functionality due to recently merged
patches and previous merge conflicts
- fix pull-up setting in sd4_width8 pin group for exynos4x12
* tag 'samsung-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
ARM: mm: Fix ifdef around cpu_*_do_[suspend, resume] ops
ARM: EXYNOS: Fix build with PM_SLEEP=n and ARM_EXYNOS_CPUIDLE=n
ARM: SAMSUNG: Restore Samsung PM Debug functionality
ARM: dts: Fix pull setting in sd4_width8 pin group for exynos4x12
Clearing obj-y, obj-m, obj-n, obj- in each Makefile is
a useless habit.
They are non-exported variables; therefore they are always empty
whenever descending into each subdirectory.
(Moreorver, obj-y and obj-m are also set to empty at the beginning
of scripts/Makefile.build)
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Peter Foley <pefoley2@pefoley.com>
In these Makefiles, at least one of "obj-y" and "obj-" is non-empty,
hence built-in.o is always created without such a trick.
Acked-by: Mike Turquette <mturquette@linaro.org>
Acked-by: Simon Horman <horms+renesas@verge.net.au> [shmobile]
Acked-by: David S. Miller <davem@davemloft.net> [networking]
Due to recently merged patches and previous merge conflicts, the Samsung
PM Debug functionality no longer can be enabled. This patch fixes
incorrect dependency of SAMSUNG_PM_DEBUG on an integer symbol and adds
missing header inclusion.
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
* cleanup/gpio-header-removal:
ARM: delete old reference to ARM_GPIOLIB_COMPLEX
ARM: kill CONFIG_NEED_MACH_GPIO_H
ARM: mach-s5p: get rid of all <mach/gpio.h> headers
ARM: s5p: cut the custom ARCH_NR_GPIOS definition
This resolves a massive amount of conflicts between the
mach/gpio.h removal and the s5p platform removal.
Almost all changes are trivial, as both sides remove
stuff.
arch/arm/Kconfig
arch/arm/mach-s5p64x0/common.c
arch/arm/mach-s5p64x0/dev-audio.c
arch/arm/mach-s5p64x0/include/mach/gpio-samsung.h
arch/arm/mach-s5p64x0/mach-smdk6440.c
arch/arm/mach-s5p64x0/mach-smdk6450.c
arch/arm/mach-s5p64x0/setup-fb-24bpp.c
arch/arm/mach-s5p64x0/setup-i2c0.c
arch/arm/mach-s5p64x0/setup-i2c1.c
arch/arm/mach-s5p64x0/setup-sdhci-gpio.c
arch/arm/mach-s5p64x0/setup-spi.c
arch/arm/mach-s5pc100/dev-audio.c
arch/arm/mach-s5pc100/include/mach/gpio-samsung.h
arch/arm/mach-s5pc100/mach-smdkc100.c
arch/arm/mach-s5pc100/setup-fb-24bpp.c
arch/arm/mach-s5pc100/setup-i2c0.c
arch/arm/mach-s5pc100/setup-i2c1.c
arch/arm/mach-s5pc100/setup-ide.c
arch/arm/mach-s5pc100/setup-keypad.c
arch/arm/mach-s5pc100/setup-sdhci-gpio.c
arch/arm/mach-s5pc100/setup-spi.c
arch/arm/mach-s5pv210/dev-audio.c
arch/arm/mach-s5pv210/include/mach/gpio-samsung.h
arch/arm/mach-s5pv210/mach-aquila.c
arch/arm/mach-s5pv210/mach-goni.c
arch/arm/mach-s5pv210/mach-smdkv210.c
arch/arm/mach-s5pv210/setup-fb-24bpp.c
arch/arm/mach-s5pv210/setup-fimc.c
arch/arm/mach-s5pv210/setup-i2c0.c
arch/arm/mach-s5pv210/setup-i2c1.c
arch/arm/mach-s5pv210/setup-i2c2.c
arch/arm/mach-s5pv210/setup-ide.c
arch/arm/mach-s5pv210/setup-keypad.c
arch/arm/mach-s5pv210/setup-sdhci-gpio.c
arch/arm/mach-s5pv210/setup-spi.c
arch/arm/plat-samsung/Kconfig
arch/arm/plat-samsung/s5p-irq-eint.c
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/soc
Merge "Samsung S5PV210 DT support for v3.17" from Kukjin Kim:
- support common clock framework for s5pv210 clock
- add generic PHY driver on s5pv210 to support it via DT
- add dt support for s5pv210-goni, smdkc110, smdkv210 and torbreck boards
- remove board files from mach-s5pv210 and unused codes
- enable multiplatform for s5pv210
* tag 's5pv210-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
clk: samsung: s5pv210: Remove legacy board support
ARM: SAMSUNG: Remove remaining legacy code
gpio: samsung: Remove legacy support of S5PV210
ARM: S5PV210: Enable multi-platform build support
cpufreq: s5pv210: Make the driver multiplatform aware
ARM: S5PV210: Register cpufreq platform device
ARM: S5PV210: move debug-macro.S into the common space
ARM: S5PV210: Untie PM support from legacy code
ARM: S5PV210: Remove support for board files
ARM: dts: Add Device tree for s5pc110/s5pv210 boards
ARM: dts: Add Device tree for s5pv210 SoC
ARM: S5PV210: Add board file for boot using Device Tree
phy: Add support for S5PV210 to the Exynos USB 2.0 PHY driver
clk: samsung: Add S5PV210 Audio Subsystem clock driver
ARM: SAMSUNG: Remove legacy clock code
serial: samsung: Remove support for legacy clock code
cpufreq: s3c24xx: Remove some dead code
ARM: S5PV210: Migrate clock handling to Common Clock Framework
clk: samsung: Add clock driver for S5PV210 and compatible SoCs
Merge "Samsung power management related updates for v3.17" from Kukjin Kim
- support cluster power off on exynos5420 and exynos5800
to save power.
- use PMU address via DT to remove PMU static mapping
- remove exynos_cpuidle_init() and exynos_cpufreq_init()
* Note that this is including tags/samsung-cleanup and
tags/exynos-cpuidle are already merged into arm-soc.
* tag 'power-exynos' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
ARM: EXYNOS: Move cpufreq and cpuidle device registration to init_machine
ARM: EXYNOS: Refactored code for using PMU address via DT
ARM: EXYNOS: Support cluster power off on exynos5420/5800
Under "arm/mach-exynos" many files are using PMU register offsets.
Since we have added support for accessing PMU base address via DT,
now we can remove PMU mapping from exynosX_iodesc. Let's convert
all these access using iomapped address.
This will help us in removing static mapping of PMU base address
as well as help in reducing dependency over machine header files.
Thus helping for migration of PMU implementation from machine to
driver folder which can be reused for ARM64 based SoC.
Also as we have removed static mappings from "regs-pmu.h" it does
not need map.h anymore. But "platsmp.c" needed this and till now it
got included indirectly. So lets move header inclusion of
"mach/map.h" from "regs-pmu.h" to "platsmp.c".
Reviewed-by: Tomasz Figa <t.figa@samsung.com>
After refactoring suspend/resume, which was last part with dependencies
on legacy code, all Kconfig symbols related to Samsung ATAGS support can
be deselected and more unused code removed. This includes most of s5p-*
code as well, as s5pv210 was their last user.
This makes it possible to enable the s5pv210 platform as part of a
multiplatform kernel. Also redundant Kconfig options are removed.
Since all in-tree boards have been moved to device tree, we can now drop
legacy code and make mach-s5pv210 DT-only. This patch does it.
Since S5PV210 now has a complete clock driver using Common Clock
Framework, there is no reason to keep the old code. Remove it together
with the whole legacy Samsung-specific clock framework which no longer
has any users.
This patch migrates the s5pv210 platform to use new clock driver
using Common Clock Framework.
Signed-off-by: Mateusz Krawczuk <m.krawczuk@partner.samsung.com>
[t.figa: Rebased and fixed merge conflicts.]
This patch removes supporting codes for s5pc100 because no more used
now.
[jason@lakedaemon.net: for drivers/irqchip/Kconfig]
Acked-by: Jason Cooper <jason@lakedaemon.net>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
This patch removes supporting codes for s5p6440 and s5p6450 because
seems no more used now. And if its supporting is required, DT based
codes should be supprted next time.
This renames all the local <mach/gpio.h> headers in the S5P platforms
to <mach/gpio-samsung.h> indicating a scope local to this platform,
and cuts the implicit inclusion of <mach/gpio.h> from <linux/gpio.h>
by removing the use of NEED_MACH_GPIO_H from all S5P variants.
Acked-by: Alexandre Courbot <acourbot@nvidia.com>
The number of GPIOs defined for the different S5P platforms using
the tricky #define macros are actually as follows:
S5P64x0: 180 GPIOs
S5PC100: 115 GPIOs
S5PV210: 252 GPIOs
The include file <asm-generic/gpio.h> will automatically bump us
to 256 GPIOs which is a nice default value that happens to encompass
all the S5P platform requirements under its roof.
Cut ARCH_NR_GPIOS and the custom spacing macro for extra GPIOs
that is not used anywhere in the kernel.
Pull ARM SoC fixes from Arnd Bergmann:
"A first set of bug fixes that didn't make it for the merge window, and
two Kconfig cleanups that still make sense at this point.
Unfortunately, one of the two cleanups caused an unintended change in
the original version, so we had to revert one part of it and do some
more testing to ensure the rest is really fine. There was also a
last-minute rebase of the patches to remove another bad commit"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: use menuconfig for sub-arch menus
ARM: multi_v7_defconfig: re-enable SDHCI drivers
ARM: EXYNOS: Fix compilation warning
ARM: exynos: move sysram info to exynos.c
ARM: dts: Specify the NAND ECC scheme explicitly on Armada 385 DB board
ARM: dts: Specify the NAND ECC scheme explicitly on Armada 375 DB board
ARM: exynos: cleanup kconfig option display
misc: vexpress: fix error handling vexpress_syscfg_regmap_init()
ARM: Remove ARCH_HAS_CPUFREQ config option
ARM: integrator: fix section mismatch problem
ARM: mvebu: DT: fix OpenBlocks AX3-4 RAM size
ARM: samsung: make SAMSUNG_DMADEV optional
remoteproc: da8xx: don't select CMA on no-MMU
bus/arm-cci: add dependency on OF && CPU_V7
ARM: keystone requires ARM_PATCH_PHYS_VIRT
ARM: omap2: fix am43xx dependency on l2x0 cache
The addition of Exynos to multi-platform configs creates a mess of config
options with options appearing before the Exynos config option. This is
due to arch/arm/plat-samsung/Kconfig being included out of order with the
other Samsung platform kconfig files. Reorder the kconfig files and move
all the options into a sub-menu. Some of the options are dead, so remove
those as well.
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: linux-samsung-soc@vger.kernel.org
The only remaining driver using the samsung dmadev code is the broken
samsung-ac97 sound driver. However, as found by Russell's autobuilder,
the elaborate dependency chains around it cause problems with
circular dependencies.
This is an attempt to simplify those dependencies by making the
SAMSUNG_DMADEV option user-selectable. I also try to keep the
default settings for all related options unchanged, so we don't
introduce any regressions against earlier testing on linux-next.
In particular, all s3c64xx and s5p* platforms keep selecting the
pl330 and pl08x drivers they require, but the select statement
is now moved towards the main platform option, and it remains
optional by unselecting CONFIG_DMADEVICES.
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm
Pull pwm changes from Thierry Reding:
"The majority of these changes are cleanups and fixes across all
drivers. Redundant error messages are removed and more PWM
controllers set the .can_sleep flag to signal that they can't be used
in atomic context.
Support is added for the Broadcom Kona family of SoCs and the Intel
LPSS driver can now probe PCI devices in addition to ACPI devices.
Upon shutdown, the pwm-backlight driver will now power off the
backlight. It also uses the new descriptor-based GPIO API for more
concise GPIO handling.
A large chunk of these changes also converts platforms to use the
lookup mechanism rather than relying on the global number space to
reference PWM devices. This is largely in preparation for more
unification and cleanups in future patches. Eventually it will allow
the legacy PWM API to be removed"
* tag 'pwm/for-3.16-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm: (38 commits)
pwm: fsl-ftm: set pwm_chip can_sleep flag
pwm: ab8500: Fix wrong value shift for disable/enable PWM
pwm: samsung: do not set manual update bit in pwm_samsung_config
pwm: lp3943: Set pwm_chip can_sleep flag
pwm: atmel: set pwm_chip can_sleep flag
pwm: mxs: set pwm_chip can_sleep flag
pwm: tiehrpwm: inline accessor functions
pwm: tiehrpwm: don't build PM related functions when not needed
pwm-backlight: retrieve configured PWM period
leds: leds-pwm: retrieve configured PWM period
ARM: pxa: hx4700: use PWM_LOOKUP to initialize struct pwm_lookup
ARM: shmobile: armadillo: use PWM_LOOKUP to initialize struct pwm_lookup
ARM: OMAP3: Beagle: use PWM_LOOKUP to initialize struct pwm_lookup
pwm: modify PWM_LOOKUP to initialize all struct pwm_lookup members
ARM: pxa: hx4700: initialize all the struct pwm_lookup members
ARM: OMAP3: Beagle: initialize all the struct pwm_lookup members
pwm: renesas-tpu: remove unused struct tpu_pwm_platform_data
ARM: shmobile: armadillo: initialize all struct pwm_lookup members
pwm: add period and polarity to struct pwm_lookup
pwm: twl: Really disable twl6030 PWMs
Pull ARM updates from Russell King:
- Major clean-up of the L2 cache support code. The existing mess was
becoming rather unmaintainable through all the additions that others
have done over time. This turns it into a much nicer structure, and
implements a few performance improvements as well.
- Clean up some of the CP15 control register tweaks for alignment
support, moving some code and data into alignment.c
- DMA properties for ARM, from Santosh and reviewed by DT people. This
adds DT properties to specify bus translations we can't discover
automatically, and to indicate whether devices are coherent.
- Hibernation support for ARM
- Make ftrace work with read-only text in modules
- add suspend support for PJ4B CPUs
- rework interrupt masking for undefined instruction handling, which
allows us to enable interrupts earlier in the handling of these
exceptions.
- support for big endian page tables
- fix stacktrace support to exclude stacktrace functions from the
trace, and add save_stack_trace_regs() implementation so that kprobes
can record stack traces.
- Add support for the Cortex-A17 CPU.
- Remove last vestiges of ARM710 support.
- Removal of ARM "meminfo" structure, finally converting us solely to
memblock to handle the early memory initialisation.
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (142 commits)
ARM: ensure C page table setup code follows assembly code (part II)
ARM: consolidate last remaining open-coded alignment trap enable
ARM: remove global cr_no_alignment
ARM: remove CPU_CP15 conditional from alignment.c
ARM: remove unused adjust_cr() function
ARM: move "noalign" command line option to alignment.c
ARM: provide common method to clear bits in CPU control register
ARM: 8025/1: Get rid of meminfo
ARM: 8060/1: mm: allow sub-architectures to override PCI I/O memory type
ARM: 8066/1: correction for ARM patch 8031/2
ARM: 8049/1: ftrace/add save_stack_trace_regs() implementation
ARM: 8065/1: remove last use of CONFIG_CPU_ARM710
ARM: 8062/1: Modify ldrt fixup handler to re-execute the userspace instruction
ARM: 8047/1: rwsem: use asm-generic rwsem implementation
ARM: l2c: trial at enabling some Cortex-A9 optimisations
ARM: l2c: add warnings for stuff modifying aux_ctrl register values
ARM: l2c: print a warning with L2C-310 caches if the cache size is modified
ARM: l2c: remove old .set_debug method
ARM: l2c: kill L2X0_AUX_CTRL_MASK before anyone else makes use of this
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux into next
Pull DeviceTree updates from Rob Herring:
- Another round of clean-up of FDT related code in architecture code.
This removes knowledge of internal FDT details from most
architectures except powerpc.
- Conversion of kernel's custom FDT parsing code to use libfdt.
- DT based initialization for generic serial earlycon. The
introduction of generic serial earlycon support went in through the
tty tree.
- Improve the platform device naming for DT probed devices to ensure
unique naming and use parent names instead of a global index.
- Fix a race condition in of_update_property.
- Unify the various linker section OF match tables and fix several
function prototype errors.
- Update platform_get_irq_byname to work in deferred probe cases.
- 2 binding doc updates
* tag 'devicetree-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (58 commits)
of: handle NULL node in next_child iterators
of/irq: provide more wrappers for !CONFIG_OF
devicetree: bindings: Document micrel vendor prefix
dt: bindings: dwc2: fix required value for the phy-names property
of_pci_irq: kill useless variable in of_irq_parse_pci()
of/irq: do irq resolution in platform_get_irq_byname()
of: Add a testcase for of_find_node_by_path()
of: Make of_find_node_by_path() handle /aliases
of: Create unlocked version of for_each_child_of_node()
lib: add glibc style strchrnul() variant
of: Handle memory@0 node on PPC32 only
pci/of: Remove dead code
of: fix race between search and remove in of_update_property()
of: Use NULL for pointers
of: Stop naming platform_device using dcr address
of: Ensure unique names without sacrificing determinism
tty/serial: pl011: add DT based earlycon support
of/fdt: add FDT serial scanning for earlycon
of/fdt: add FDT address translation support
serial: earlycon: add DT support
