path: root/arch/arm/plat-samsung/include/plat/gpio-cfg.h
2012-06-28treewide: Put a space between #include and FILEPaul Bolle
Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-11-17ARM: SAMSUNG: include linux/types.h at gpio-cfg.hAxel Lin
Include linux/types.h to fix below build error: CC drivers/power/max8903_charger.o In file included from arch/arm/plat-samsung/include/plat/gpio-fns.h:27, from arch/arm/mach-s3c2410/include/mach/gpio-fns.h:1, from arch/arm/mach-s3c2410/include/mach/gpio.h:27, from /home/axel/repos/git/linux-2.6/arch/arm/include/asm/gpio.h:5, from include/linux/gpio.h:30, from drivers/power/max8903_charger.c:23: arch/arm/plat-samsung/include/plat/gpio-cfg.h:27: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'samsung_gpio_pull_t' arch/arm/plat-samsung/include/plat/gpio-cfg.h:28: error: expected '=', ',', ';', 'asm' or '__attribute__' before 's5p_gpio_drvstr_t' arch/arm/plat-samsung/include/plat/gpio-cfg.h:55: error: expected specifier-qualifier-list before 'samsung_gpio_pull_t' arch/arm/plat-samsung/include/plat/gpio-cfg.h:146: error: expected declaration specifiers or '...' before 'samsung_gpio_pull_t' arch/arm/plat-samsung/include/plat/gpio-cfg.h:154: error: expected '=', ',', ';', 'asm' or '__attribute__' before 's3c_gpio_getpull' arch/arm/plat-samsung/include/plat/gpio-cfg.h:173: error: expected declaration specifiers or '...' before 'samsung_gpio_pull_t' arch/arm/plat-samsung/include/plat/gpio-cfg.h: In function 's3c_gpio_cfgrange_nopull': arch/arm/plat-samsung/include/plat/gpio-cfg.h:178: error: '__force' undeclared (first use in this function) arch/arm/plat-samsung/include/plat/gpio-cfg.h:178: error: (Each undeclared identifier is reported only once arch/arm/plat-samsung/include/plat/gpio-cfg.h:178: error: for each function it appears in.) arch/arm/plat-samsung/include/plat/gpio-cfg.h:178: error: expected ')' before 'samsung_gpio_pull_t' arch/arm/plat-samsung/include/plat/gpio-cfg.h:178: error: expected ')' before numeric constant arch/arm/plat-samsung/include/plat/gpio-cfg.h:178: error: too many arguments to function 's3c_gpio_cfgall_range' arch/arm/plat-samsung/include/plat/gpio-cfg.h: At top level: arch/arm/plat-samsung/include/plat/gpio-cfg.h:197: error: expected '=', ',', ';', 'asm' or '__attribute__' before 's5p_gpio_get_drvstr' arch/arm/plat-samsung/include/plat/gpio-cfg.h:208: error: expected declaration specifiers or '...' before 's5p_gpio_drvstr_t' make[2]: *** [drivers/power/max8903_charger.o] Error 1 make[1]: *** [drivers/power] Error 2 make: *** [drivers] Error 2 Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: stable@kernel.org Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-09-21ARM: SAMSUNG: Update the name of regarding Samsung GPIOKukjin Kim
According to gpio-samsung.c, this patch updates the name of regarding Samsung GPIO. Basically the samsung_xxx prefix is used in gpio-samsung.c instead of s3c_xxx, because unified name can reduce its complexity. Note: some s3c_xxx stil remains because it is used widely. It will be updated next time. Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-15ARM: S5P: Add function to register gpio interrupt bank dataMarek Szyprowski
This patch removes all global data from common s5p gpio interrupt handler code. This enables to reuse this code on EXYNOS4 platform. Instead of global data (IRQ_GPIOINT interrupt number, S5P_GPIOINT_GROUP_MAXNR groups count), a s5p_register_gpioint_bank() function is introduced. It is aimed to be called from gpiolib init. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-25Merge branch 'next-gpio-update' into for-nextKukjin Kim
2010-10-23ARM: SAMSUNG: Add s3c_gpio_cfgrange_nopull() helperBen Dooks
A number of the SDHCI code configure a GPIO to a special function and remove any pull-up, so add s3c_gpio_cfgrange_nopull() as a wrapper to the s3c_gpio_cfgall_range() to make the code that calls it fit on one line. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-23ARM: SAMSUNG: Add s3c_gpio_cfgall_range() functionBen Dooks
Add a function to configure a range of GPIOs function and pull in one go, mainly for the SDHCI and framebuffer helpers which tend to do this. Signed-off-by: Ben Dooks <ben-linux@fluff.org> [kgene.kim@samsung.com: Fix small comments] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-23ARM: SAMSUNG: Add GPIO configuration for a range of pinsBen Dooks
Add s3c_gpio_cfgpin_range() to configure a range of pins to the given value. This is useful for a number of blocks where the pins are in order and saves multiple calls to s3c_gpio_cfgpin(). Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-21ARM: S5P: Add common S5P GPIO Interrupt supportMarek Szyprowski
This patch adds common code to enable support of GPIO interrupt on S5P SoCs. The total number of GPIO pins is quite large on S5P SoCs. Registering irq support for all of them would be a resource waste. Because of that the interrupt support for standard GPIO pins is registered dynamically by the s5p_register_gpio_interrupt() function. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> [kgene.kim@samsung.com: minor title fixes] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-09-14ARM: SAMSUNG: Fix on drive strength valueKukjin Kim
This patch fixes on defined drive strength value for GPIO. According to data sheet, if we want drive strength 1x, the value should be 00(b), if 2x should be 10(b), if 3x should be 01(b), and if 4x should be 11(b). Also fixes comment(from S5C to S5P). Reported-by: Janghyuck Kim <janghyuck.kim@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-05-28ARM: SAMSUNG: gpio-cfg.h: update documentationBen Dooks
Update the documentation on the gpio configuration calls to add more references to useful information and also to document the values that are passed. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-28ARM: SAMSUNG: Fix documentation for s3c_gpio_cfgpin()Ben Dooks
Fix typo in s3c_gpio_cfgpin() documentation, the second argument is @to not @pin again. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-19ARM: SAMSUNG: move driver strength gpio configuration helper to common dirMarek Szyprowski
Driver strength parameter can be changed not only on S5PC100 but also on S5PV210/S5PC110 platforms, so move the helper functions to the common plat-samsung directory. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-06ARM: S3C24XX: Remove s3c2410_gpio_getcfg(), implement s3c_gpio_getcfg()Ben Dooks
Add s3c_gpio_getcfg() and change anything using s3c2410_gpio_getcfg() to use this instead. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-01-19ARM: SAMSUNG: Move GPIO headers to plat-samsungBen Dooks
Move the GPIO and GPIO configuration headers into arch/arm/plat-samsung as they are common to all the Samsung SoCs. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
