path: root/arch/arm/plat-s5p/irq.c
2010-08-05ARM: S5PV310: Add IRQ supportChanghwan Youn
This patch adds IRQ support for S5PV310. ARM GIC is installed in S5PV310 instead of VIC which is in every other CPUs in S5P series. Several irq combiners are used to resolve the lack of irq lines in current implementation. Signed-off-by: Changhwan Youn <chaos.youn@samsung.com> Signed-off-by: Hyuk Lee <hyuk1.lee@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-02-24ARM: S5P6442: Add IRQ supportKukjin Kim
This patch adds IRQ support for S5P6442. This patch adds interrupt register definitions, IRQ definitions for various interrupt sources and new VIC base for VIC2 in plat-s5p common irq code. Signed-off-by: Adityapratap Sharma <aditya.ps@samsung.com> Signed-off-by: Atul Dahiya <atul.dahiya@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-01-27ARM: S5P6440: Move common memory map definitions for S5PKukjin Kim
1. Moved common memory map definitions for S5P such as S5P_VA_XXX into plat-s5p/include/mach/map-s5p.h from mach-s5p6440/include/mach. 2. Removed unnecessary definitions in the map.h and irq.c 3. Removed the unnecessary support for unaligned UART address 4. Renamed S5P_VA_VICx definitions as VA_VICx 5. Moved the definitons of VIC_BASE to plat-s5p/include/plat/irqs.h Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-01-15ARM: S5P6440: Add IRQ supportKukjin Kim
This patch adds IRQ support for S5P6440 CPU. Signed-off-by: Adityapratap Sharma <aditya.ps@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
