The clk_fout_epll clock wasn't registered as part of the initial clock
work, which can cause problems if it is used by one of the hardware
blocks.
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Some of the startup output can be reduced to
KERN_DEBUG from KERN_INFO as it is only really
useful when trying to debug kernel initialisation
problems.
Add the PLL clock initialisation and clock registration
and include the clocks sourced via CLKDIVx for most of
the on-chip peripherals.
