path: root/arch/arm/plat-s3c64xx/include/plat/irqs.h
2010-02-20ARM: S3C64XX: Move IRQ support into mach-s3c64xxBen Dooks
Move IRQ support to mach-s3c64xx as it is unlikely to be re-used outside this machine. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-01-21ARM: SMDK6410: Set up interrupt range for WM835x on 1190-EV1 PMIC boardMark Brown
The WM835x driver won't actually use this yet but it will in the future when the changes converting it to genirq are merged. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-01-15ARM: Add common entry code for system with two VICsBen Dooks
Add a common entry-macro-vic2.S for systems where there are two VICs so that the machine or platform directories just need to setup the correct information before including <asm/entry-macro-vic2.S> into their own entry-macro.S file. Since this code is from the S3C64XX project, we update the S3C64XX machine entry code to use this new header. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-09-17ARM: S3C64XX: Provide for board-specific IRQsMark Brown
Set up some IRQ space to allocation to off-SoC interrupt controllers. Default this to 16 IRQs. If individual boards require more than this then they will need to modify this file so allocating a small number helps reduce the number of modifications required. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-05-07[ARM] S3C64XX: Initial support for PM (suspend to RAM)Ben Dooks
Add the initial support for the S3C64XX based systems to use suspend-to-RAM to sleep. Includes basic debugging for use with the SMDK6410 usign the LEDs on the baseboard. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-02-26[ARM] S3C64XX: Rename IRQ_UHOST to IRQ_USBHBen Dooks
The USB OHCI host device expects the IRQ definition to be named IRQ_USBH, so rename the S3C64XX IRQ header to match. Signed-off-by: Ben Dooks <ben@simtec.co.uk> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-01-08[ARM] S3C64XX: Fix EINT group macro definitionMatt Hsu
Fix IRQ_EINT_GROUP which has an extra _ in it and an error in the IRQ offset. Signed-off-by: Matt Hsu <matt_hsu@openmoko.org> [ben-linux@fluff.org: rewrite description] Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-12-15[ARM] S3C: Add i2c1 device definitionBen Dooks
Add device definition and support functions for the second i2c device (i2c1). If this is selected, the first i2c bus will become index 0 instead of index -1. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-12-15[ARM] S3C64XX: Add external interrupt group definitionsBen Dooks
Add definitions for the external interrupt groups which accompany the original IRQ_EINT from the s3c24xx series. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-12-15[ARM] S3C64XX: Add IRQ_EINT supportBen Dooks
Add the necessary code to support IRQ_EINT(x) on the S3C64XX series of CPUs. Note, since there is no GPIO configuration support in the kernel, the irq set_type method does not configure the relevant pin to interrupt. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-12-15[ARM] S3C64XX: Map timer memory and interruptsBen Dooks
Add the physical to virtual memory mapping and the necessary interrupt demuxing for the PWM timer blocks. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-12-15[ARM] S3C64XX: Add VIC0 and VIC1 sourced interriptsBen Dooks
Add and initialise the two VIC (PL192) found on the S3C64XX series CPUs. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-12-15[ARM] S3C64XX: Add IRQ definitions for VIC0 and VIC1Ben Dooks
Add IRQ definitions for the VIC0 and VIC1 interrupts on the S3C6400 and S3C6410 SoCs. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-12-15[ARM] S3C64XX: Add UARTdevice definitionsBen Dooks
Add resources and information for the UART deviecs on the S3C64XX CPUs. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-12-15[ARM] S3C64XX: Initial arch header filesBen Dooks
Add the initial header files for the S3C64XX support to satisfy the minimal requirements to build a kernel. Some definitions will therefore be placeholders or empty functions that will ensure that the system can build and have base functionality. These will be filled in at a later date. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
