path: root/arch/arm/plat-orion
2012-05-26Merge tag 'clock' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc clock driver changes from Olof Johansson: "The new clock subsystem was merged in linux-3.4 without any users, this now moves the first three platforms over to it: imx, mxs and spear. The series also contains the changes for the clock subsystem itself, since Mike preferred to have it together with the platforms that require these changes, in order to avoid interdependencies and conflicts." Fix up trivial conflicts in arch/arm/mach-kirkwood/common.c (code removed in one branch, added OF support in another) and drivers/dma/imx-sdma.c (independent changes next to each other). * tag 'clock' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (97 commits) clk: Fix CLK_SET_RATE_GATE flag validation in clk_set_rate(). clk: Provide dummy clk_unregister() SPEAr: Update defconfigs SPEAr: Add SMI NOR partition info in dts files SPEAr: Switch to common clock framework SPEAr: Call clk_prepare() before calling clk_enable SPEAr: clk: Add General Purpose Timer Synthesizer clock SPEAr: clk: Add Fractional Synthesizer clock SPEAr: clk: Add Auxiliary Synthesizer clock SPEAr: clk: Add VCO-PLL Synthesizer clock SPEAr: Add DT bindings for SPEAr's timer ARM i.MX: remove now unused clock files ARM: i.MX6: implement clocks using common clock framework ARM i.MX35: implement clocks using common clock framework ARM i.MX5: implement clocks using common clock framework ARM: Kirkwood: Replace clock gating ARM: Orion: Audio: Add clk/clkdev support ARM: Orion: PCIE: Add support for clk ARM: Orion: XOR: Add support for clk ARM: Orion: CESA: Add support for clk ...
2012-05-15orion/kirkwood: create a generic function for gpio led blinkingArnaud Patard (Rtp)
dns323 and (at least) iconnect platforms are using hw led blinking, so, instead of having 2 identicals .gpio_blink_set gpio-led hooks, move dns323 code into gpio.c Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Tested-By: Adam Baker <linux@baker-net.org.uk> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-05-15kirkwood/orion: fix orion_gpio_set_blinkArnaud Patard (Rtp)
gpio registers are for 32 gpios. Given that orion_gpio_set_blink is called directly and not through gpiolib, it needs to make sure that the pin value given to the internal functions are between 0 and 31. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Tested-By: Adam Baker <linux@baker-net.org.uk> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-05-08ARM: Kirkwood: Replace clock gatingAndrew Lunn
Add a varient of the basic clk-gate code. This variant calls a function before gating the clock off. This function is used to disable the SATA or PCIe PHY. Now that all the drivers prepare and enable there clk as needed, there is no need for the common code to keep track of which clocks need gating on. Let the common clock framework turn off clocks which are not used. Buy using the added clk varient, when the clk framework turns off SATA or PCIe clocks, we also disabled SATA and PCIe PHYs which were not needed. The function kirkwood_pcie_id() can now be called outside of __init code, so remove this property for it, and functions it calls. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Jamie Lentin <jm@lentin.co.uk> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-05-08ARM: Orion: UART: Get the clock rate via clk_get_rate().Andrew Lunn
Let the machine pass to the platform which clock is used by the uart. Enable the clock and use clk_get_rate() to determine its rate. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Jamie Lentin <jm@lentin.co.uk> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-05-08ARM: Orion: WDT: Add clk/clkdev supportAndrew Lunn
Remove tclk from platform data. This makes the platform data structure empty, so remove it. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Jamie Lentin <jm@lentin.co.uk> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-05-08ARM: Orion: Eth: Add clk/clkdev support.Andrew Lunn
The t_clk is moved from the shared part of the ethernet driver into the per port section. Each port can have its own gated clock, which it needs to enable/disable, as oppossed to there being one clock shared by all ports. In practice, only kirkwood supports this at the moment. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Jamie Lentin <jm@lentin.co.uk> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-05-08ARM: Orion: SPI: Add clk/clkdev support.Andrew Lunn
Remove now redundant tclk from SPI platform data. This makes the platform data empty, so remove it. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Jamie Lentin <jm@lentin.co.uk> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-05-08ARM: Orion: Add clocks using the generic clk infrastructure.Andrew Lunn
Add tclk as a fixed rate clock for all platforms. In addition, on kirkwood, add a gated clock for most of the clocks which can be gated. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Jamie Lentin <jm@lentin.co.uk> [mturquette@linaro.org: removed redundant CLKDEV_LOOKUP from Kconfig] [mturquette@linaro.org: removed redundant clk.h from mach-dove/common.c] Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-03-16ARM: orion: wdt: use resource vice direct accessJason Cooper
Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-03-16ARM: Kirkwood: Remove tclk from kirkwood_asoc_platform_data.Andrew Lunn
It is not used anywhere in the sound driver. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-02-09ARM: orion: Fix USB phy for orion5x.Andrew Lunn
The patch "ARM: orion: Consolidate USB platform setup code.", commit 4fcd3f374a928081d391cd9a570afe3b2c692fdc broke USB on TS-7800 and other orion5x boards, because the wrong type of PHY was being passed to the EHCI driver in the platform data. Orion5x needs EHCI_PHY_ORION and all the others want EHCI_PHY_NA. Allow the mach- code to tell the generic plat-orion code which USB PHY enum to place into the platform data. Version 2: Rebase to v3.3-rc2. Reported-by: Ambroz Bizjak <ambrop7@gmail.com> Signed-off-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Ambroz Bizjak <ambrop7@gmail.com> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-02-09ARM: orion: Fix Orion5x GPIO regression from MPP cleanupAndrew Lunn
Patchset "ARM: orion: Refactor the MPP code common in the orion platform" broke at least Orion5x based platforms. These platforms have pins configured as GPIO when the selector is not 0x0. However the common code assumes the selector is always 0x0 for a GPIO lines. It then ignores the GPIO bits in the MPP definitions, resulting in that Orion5x machines cannot correctly configure there GPIO lines. The Fix removes the assumption that the selector is always 0x0. In order that none GPIO configurations are correctly blocked, Kirkwood and mv78xx0 MPP definitions are corrected to only set the GPIO bits for GPIO configurations. This third version, which does not contain any whitespace changes, and is rebased on v3.3-rc2. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-01-09Merge tag 'devel' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
New feature development This adds support for new features, and contains stuff from most platforms. A number of these patches could have fit into other branches, too, but were small enough not to cause too much confusion here. * tag 'devel' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (28 commits) mfd/db8500-prcmu: remove support for early silicon revisions ARM: ux500: fix the smp_twd clock calculation ARM: ux500: remove support for early silicon revisions ARM: ux500: update register files ARM: ux500: register DB5500 PMU dynamically ARM: ux500: update ASIC detection for U5500 ARM: ux500: support DB8520 ARM: picoxcell: implement watchdog restart ARM: OMAP3+: hwmod data: Add the default clockactivity for I2C ARM: OMAP3: hwmod data: disable multiblock reads on MMC1/2 on OMAP34xx/35xx <= ES2.1 ARM: OMAP: USB: EHCI and OHCI hwmod structures for OMAP4 ARM: OMAP: USB: EHCI and OHCI hwmod structures for OMAP3 ARM: OMAP: hwmod data: Add support for AM35xx UART4/ttyO3 ARM: Orion: Remove address map info from all platform data structures ARM: Orion: Get address map from plat-orion instead of via platform_data ARM: Orion: mbus_dram_info consolidation ARM: Orion: Consolidate the address map setup ARM: Kirkwood: Add configuration for MPP12 as GPIO ARM: Kirkwood: Recognize A1 revision of 6282 chip ARM: ux500: update the MOP500 GPIO assignments ...
2012-01-05Merge branch 'devel-stable' into for-linusRussell King
Conflicts: arch/arm/kernel/setup.c arch/arm/mach-shmobile/board-kota2.c
2011-12-19ARM: plat-orion: make gpiochip label uniqueHolger Brunck
The former implementation adds a fix gpiochip label string to the framework. This is confusing because orion_gpio_init is called more than once and this ends up in different gpiochips with the same label. This patch adds the already present orion_gpio_chip_count to the label string to make it unique in the system. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Cc: Lennert Buytenhek <kernel@wantstofly.org> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2011-12-18ARM: 7205/2: sched_clock: allow sched_clock to be selected at runtimeMarc Zyngier
sched_clock() is yet another blocker on the road to the single image. This patch implements an idea by Russell King: http://www.spinics.net/lists/linux-omap/msg49561.html Instead of asking the platform to implement both sched_clock() itself and the rollover callback, simply register a read() function, and let the ARM code care about sched_clock() itself, the conversion to ns and the rollover. sched_clock() uses this read() function as an indirection to the platform code. If the platform doesn't provide a read(), the code falls back to the jiffy counter (just like the default sched_clock). This allow some simplifications and possibly some footprint gain when multiple platforms are compiled in. Among the drawbacks, the removal of the *_fixed_sched_clock optimization which could negatively impact some platforms (sa1100, tegra, versatile and omap). Tested on 11MPCore, OMAP4 and Tegra. Cc: Imre Kaloz <kaloz@openwrt.org> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Colin Cross <ccross@android.com> Cc: Erik Gilling <konkers@android.com> Cc: Olof Johansson <olof@lixom.net> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: Alessandro Rubini <rubini@unipv.it> Cc: STEricsson <STEricsson_nomadik_linux@list.st.com> Cc: Lennert Buytenhek <kernel@wantstofly.org> Cc: Ben Dooks <ben-linux@fluff.org> Tested-by: Jamie Iles <jamie@jamieiles.com> Tested-by: Tony Lindgren <tony@atomide.com> Tested-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Krzysztof Halasa <khc@pm.waw.pl> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-12-13ARM: Orion: Remove address map info from all platform data structuresAndrew Lunn
Signed-off-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Michael Walle <michael@walle.cc> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-12-13ARM: Orion: Get address map from plat-orion instead of via platform_dataAndrew Lunn
Use an getter function in plat-orion/addr-map.c to get the address map structure, rather than pass it to drivers in the platform_data structures. When the drivers are built for none orion platforms, a dummy function is provided instead which returns NULL. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Michael Walle <michael@walle.cc> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-12-13ARM: Orion: mbus_dram_info consolidationAndrew Lunn
Move the *_mbus_dram_info structure into the orion platform and call it orion_mbus_dram_info everywhere. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Michael Walle <michael@walle.cc> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-12-13ARM: Orion: Consolidate the address map setupAndrew Lunn
Compile tested on Dove, orion5x, mv78xx0. Boot tested on Kirkwood. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Michael Walle <michael@walle.cc> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-08-24ARM: 7063/1: Orion: gpio: add missing include of linux/types.hAxel Lin
This patch adds missing include of linux/types.h to fix below build error. CC arch/arm/mach-mv78xx0/mpp.o In file included from arch/arm/mach-mv78xx0/include/mach/gpio.h:9, from /home/axel/repos/git/linux-2.6/arch/arm/include/asm/gpio.h:5, from include/linux/gpio.h:18, from arch/arm/mach-mv78xx0/mpp.c:10: arch/arm/plat-orion/include/plat/gpio.h:28: error: expected declaration specifiers or '...' before 'u32' make[1]: *** [arch/arm/mach-mv78xx0/mpp.o] Error 1 make: *** [arch/arm/mach-mv78xx0] Error 2 Signed-off-by: Axel Lin <axel.lin@gmail.com> Reviewed-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-08-12ARM: gpio: make trivial GPIOLIB implementation the defaultRussell King
Rather than marking the mach/gpio.h header files which want to use the trivial GPIOLIB implementation, mark those which do not want to use it instead. This means that by default, you get the trivial implementation and only have to do something extra if you need to. This should encourage the use of the trivial default implementation. As an additional bonus, several gpio.h header files become empty. Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Tested-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-08-12ARM: gpio: consolidate gpio_to_irqRussell King
Many of the gpio_to_irq implementations use the gpiolib version of this function. Provide the standard gpiolib gpio_to_irq() for everyone, but allow platforms to override it if they wish. Add the neccessary overrides for those platforms which do not use the standard definition. Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-08-12ARM: gpio: consolidate trivial gpiolib implementationsRussell King
Consolidate 24 trivial gpiolib implementions out of mach/gpio.h into asm/gpio.h. This is basically the include of asm-generic/gpio.h and the definition of gpio_get_value, gpio_set_value, and gpio_cansleep as described in Documentation/gpio.txt Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Tested-by: David Brown <davidb@codeaurora.org> Acked-by: David Brown <davidb@codeaurora.org> Tested-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Tested-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-07genirq: replace irq_gc_ack() with {set,clr}_bit variants (fwd)Simon Guinot
This fixes a regression introduced by e59347a "arm: orion: Use generic irq chip". Depending on the device, interrupts acknowledgement is done by setting or by clearing a dedicated register. Replace irq_gc_ack() with some {set,clr}_bit variants allows to handle both cases. Note that this patch affects the following SoCs: Davinci, Samsung and Orion. Except for this last, the change is minor: irq_gc_ack() is just renamed into irq_gc_ack_set_bit(). For the Orion SoCs, the edge GPIO interrupts support is currently broken. irq_gc_ack() try to acknowledge a such interrupt by setting the corresponding cause register bit. The Orion GPIO device expect the opposite. To fix this issue, the irq_gc_ack_clr_bit() variant is used. Tested on Network Space v2. Reported-by: Joey Oravec <joravec@drewtech.com> Signed-off-by: Simon Guinot <sguinot@lacie.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-05-23Merge branch 'devel-stable' into for-linusRussell King
Conflicts: arch/arm/Kconfig arch/arm/mach-ns9xxx/include/mach/uncompress.h
2011-05-23clocksource: convert ARM 32-bit down counting clocksourcesRussell King
Convert SP804, MXC, Nomadik and Orion 32-bit down-counting clocksources to generic mmio clocksource infrastructure. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: Alessandro Rubini <rubini@unipv.it> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: Lennert Buytenhek <kernel@wantstofly.org> Acked-by: Nicolas Pitre <nico@fluxnic.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-16ARM: dove: Consolidate mpp code with platform mpp.Andrew Lunn
Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-05-16ARM: orion: Refactor the MPP code common in the orion platformAndrew Lunn
mv78xx0 and kirkwood use identical mpp code. It should also be possible to rewrite the orion5x mpp to use this platform code. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-05-16ARM: orion: Consolidate setup of the crypto engine.Andrew Lunn
2011-05-16ARM: orion: Consolidate SATA platform setup.Andrew Lunn
2011-05-16ARM: orion: Consolidate USB platform setup code.Andrew Lunn
2011-05-16ARM: orion: Consolidate the XOR platform setup code.Andrew Lunn
2011-05-16ARM: orion: Consolidate the platform data setup for the watchdog.Andrew Lunn
2011-05-16ARM: orion: Consolidate SPI initialization.Andrew Lunn
This change removes the interrupt resource. The driver does not use it. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-05-16ARM: orion: Consolidate I2C initialization.Andrew Lunn
2011-05-16ARM: orion: Consolidate ethernet platform dataAndrew Lunn
2011-05-16ARM: orion: Consolidate the creation of the RTC platform data.Andrew Lunn
2011-05-16ARM: orion: Consolidate the creation of the uart platform data.Andrew Lunn
2011-05-16arm: orion: Use generic irq chipThomas Gleixner
The core interrupt chip is a straight forward conversion. The gpio chip is implemented with two instances of the irq_chip_type which can be switched with the irq_set_type function. That allows us to use the generic callbacks and avoids the conditionals in them. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-29arm: Fold irq_set_chip/irq_set_handlerThomas Gleixner
Use irq_set_chip_and_handler() instead. Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Reorder irq_set_ function callsThomas Gleixner
Reorder irq_set_chip() irq_set_chip_data() irq_set_handler() to irq_set_chip() irq_set_handler() irq_set_chip_data() so the next patch can combine irq_set_chip() and irq_set_handler() to irq_set_chip_and_handler(). Automated conversion with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Cleanup the irq namespaceThomas Gleixner
Convert to the new function names. Automated with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Cleanup irq_desc accessThomas Gleixner
Use the proper wrappers and use the flow type in irq_data. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-03ARM: Remove dependency of plat-orion GPIO code on mach directory includes.Lennert Buytenhek
This patch makes the various mach dirs that use the plat-orion GPIO code pass in GPIO-related platform info (GPIO controller base address, secondary base IRQ number, etc) explicitly, instead of having plat-orion get those values by including a mach dir include file -- the latter mechanism is problematic if you want to support multiple ARM platforms in the same kernel image. Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-03ARM: Remove dependency of plat-orion time code on mach directory includes.Lennert Buytenhek
This patch makes the various mach dirs that use the plat-orion time code pass in timer and bridge addresses explicitly, instead of having plat-orion get those values by including a mach dir include file -- the latter mechanism is problematic if you want to support multiple ARM platforms in the same kernel image. Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-01-13ARM: plat-orion: irq_data conversion.Lennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Acked-by: Nicolas Pitre <nico@fluxnic.net>
2010-12-22ARM: orion: convert sched_clock() to use new infrastructureRussell King
Convert orion platforms to use the new sched_clock() infrastructure for extending 32bit counters to full 64-bit nanoseconds. Acked-by: Nicolas Pitre <nico@fluxnic.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-22ARM: ensure all sched_clock() implementations are notrace markedRussell King
ftrace requires sched_clock() to be notrace. Ensure that all implementations are so marked. Also make sure that they include linux/sched.h Also ensure OMAP clocksource read functions are marked notrace as they're used for sched_clock() too. Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Mikael Pettersson <mikpe@it.uu.se> Tested-by: Eric Miao <eric.y.miao@gmail.com> Tested-by: Olof Johansson <olof@lixom.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
