When platform data were moved from arch/arm/mach-mv78xx0/common.c to
arch/arm/plat-orion/common.c with the commit "7e3819d ARM: orion:
Consolidate ethernet platform data", there were few typo made on
gigabit Ethernet interface ge10 and ge11. This commit writes back
their initial value, which allows to use this interfaces again.
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Andrew Lunn <andrew@lunn.ch>
Cc: <stable@vger.kernel.org> # v3.0.x
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
Removing orion ehci include from board files will raise a compiler
error because plat/common.h is using an enum provided by orion ehci
but not including the include itself. This just adds the missing include.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Pull removal of GENERIC_GPIO from Grant Likely:
"GENERIC_GPIO now synonymous with GPIOLIB. There are no longer any
valid cases for enableing GENERIC_GPIO without GPIOLIB, even though it
is possible to do so which has been causing confusion and breakage.
This branch does the work to completely eliminate GENERIC_GPIO."
* tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux:
gpio: update gpio Chinese documentation
Remove GENERIC_GPIO config option
Convert selectors of GENERIC_GPIO to GPIOLIB
blackfin: force use of gpiolib
m68k: coldfire: use gpiolib
mips: pnx833x: remove requirement for GENERIC_GPIO
openrisc: default GENERIC_GPIO to false
avr32: default GENERIC_GPIO to false
xtensa: remove explicit selection of GENERIC_GPIO
sh: replace CONFIG_GENERIC_GPIO by CONFIG_GPIOLIB
powerpc: remove redundant GENERIC_GPIO selection
unicore32: default GENERIC_GPIO to false
unicore32: remove unneeded select GENERIC_GPIO
arm: plat-orion: use GPIO driver on CONFIG_GPIOLIB
arm: remove redundant GENERIC_GPIO selection
mips: alchemy: require gpiolib
mips: txx9: change GENERIC_GPIO to GPIOLIB
mips: loongson: use GPIO driver on CONFIG_GPIOLIB
mips: remove redundant GENERIC_GPIO select
Pull ARM SoC platform updates (part 3) from Arnd Bergmann:
"This is the third and smallest of the SoC specific updates. Changes
include:
- SMP support for the Xilinx zynq platform
- Smaller imx changes
- LPAE support for mvebu
- Moving the orion5x, kirkwood, dove and mvebu platforms to a common
"mbus" driver for their internal devices.
It would be good to get feedback on the location of the "mbus" driver.
Since this is used on multiple platforms may potentially get shared
with other architectures (powerpc and arm64), it was moved to
drivers/bus/. We expect other similar drivers to get moved to the
same place in order to avoid creating more top-level directories under
drivers/ or cluttering up the messy drivers/misc/ even more."
* tag 'soc-for-linus-3' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (50 commits)
ARM: imx: reset_controller may be disabled
ARM: mvebu: Align the internal registers virtual base to support LPAE
ARM: mvebu: Limit the DMA zone when LPAE is selected
arm: plat-orion: remove addr-map code
arm: mach-mv78xx0: convert to use the mvebu-mbus driver
arm: mach-orion5x: convert to use mvebu-mbus driver
arm: mach-dove: convert to use mvebu-mbus driver
arm: mach-kirkwood: convert to use mvebu-mbus driver
arm: mach-mvebu: convert to use mvebu-mbus driver
ARM i.MX53: set CLK_SET_RATE_PARENT flag on the tve_ext_sel clock
ARM i.MX53: tve_di clock is not part of the CCM, but of TVE
ARM i.MX53: make tve_ext_sel propagate rate change to PLL
ARM i.MX53: Remove unused tve_gate clkdev entry
ARM i.MX5: Remove tve_sel clock from i.MX53 clock tree
ARM: i.MX5: Add PATA and SRTC clocks
ARM: imx: do not bring up unavailable cores
ARM: imx: add initial imx6dl support
ARM: imx1: mm: add call to mxc_device_init
ARM: imx_v4_v5_defconfig: Add CONFIG_GPIO_SYSFS
ARM: imx_v6_v7_defconfig: Select CONFIG_PERF_EVENTS
Pull ARM SoC cleanup from Olof Johansson:
"Here is a collection of cleanup patches. Among the pieces that stand
out are:
- The deletion of h720x platforms
- Split of at91 non-dt platforms to their own Kconfig file to keep
them separate
- General cleanups and refactoring of i.MX and MXS platforms
- Some restructuring of clock tables for OMAP
- Convertion of PMC driver for Tegra to dt-only
- Some renames of sunxi -> sun4i (Allwinner A10)
- ... plus a bunch of other stuff that I haven't mentioned"
* tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (119 commits)
ARM: i.MX: remove unused ARCH_* configs
ARM i.MX53: remove platform ahci support
ARM: sunxi: Rework the restart code
irqchip: sunxi: Rename sunxi to sun4i
irqchip: sunxi: Make use of the IRQCHIP_DECLARE macro
clocksource: sunxi: Rename sunxi to sun4i
clocksource: sunxi: make use of CLKSRC_OF
clocksource: sunxi: Cleanup the timer code
ARM: at91: remove trailing semicolon from macros
ARM: at91/setup: fix trivial typos
ARM: EXYNOS: remove "config EXYNOS_DEV_DRM"
ARM: EXYNOS: change the name of USB ohci header
ARM: SAMSUNG: Remove unnecessary code for dma
ARM: S3C24XX: Remove unused GPIO drive strength register definitions
ARM: OMAP4+: PM: Restore CPU power state to ON with clockdomain force wakeup method
ARM: S3C24XX: Removed unneeded dependency on CPU_S3C2412
ARM: S3C24XX: Removed unneeded dependency on CPU_S3C2410
ARM: S3C24XX: Removed unneeded dependency on ARCH_S3C24XX for boards
ARM: SAMSUNG: Fix typo "CONFIG_SAMSUNG_DEV_RTC"
ARM: S5P64X0: Fix typo "CONFIG_S5P64X0_SETUP_SDHCI"
GENERIC_GPIO has been made equivalent to GPIOLIB in architecture code
and all driver code has been switch to depend on GPIOLIB. It is thus
safe to have GENERIC_GPIO removed.
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
Now that all Marvell EBU platforms have been converted to use the
mvebu-mbus driver, we can remove the common plat-orion/addr-map.c code
that isn't compiled anymore.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
This commit convers the mach-mv78xx0 sub-architecture to use the
mvebu-mbus driver. We simply have to call mvebu_mbus_init() in the
->init_early() function, and modify the PCIe code so that it uses the
new functions provided by mvebu-mbus to create the needed PCIe
windows.
This commit migrates the mach-orion5x platforms to use the mvebu-mbus
driver and therefore removes the Orion5x-specific addr-map code.
The dove_init_early() function now initializes the mvebu-mbus driver
by calling mvebu_mbus_init().
We also convert a number of orion5x_setup_xyz_win() calls to the
appropriate mvebu_mbus_add_window() calls, as each board was doing its
own setup for the NOR window or other devices. Ultimately, those
devices will be probed from the DT.
The common address decoding windows are now registered in the
orion5x_setup_wins() function. It is worth noting that the four PCIe
address decoding windows will ultimately no longer have to be
registered here: it will be done automatically by the PCIe driver once
Dove has been migrated to use the upcoming mvebu PCIe driver.
This commit migrates the mach-dove platforms to use the mvebu-mbus
driver and therefore removes the Dove-specific addr-map code.
The address decoding windows are now registered in the
dove_setup_cpu_wins() function. It is worth noting that the four PCIe
This commit migrates the mach-kirkwood platforms to use the mvebu-mbus
driver and therefore removes the Kirkwood-specific addr-map code.
The kirkwood_init_early() function is now responsible for initializing
the mvebu-mbus driver by calling mvebu_mbus_init().
kirkwood_setup_wins() function. It is worth noting that the four PCIe
Kirkwood has been migrated to use the upcoming mvebu PCIe driver.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
The changes needed to migrate the mach-mvebu (Armada 370 and Armada
XP) to the mvebu-mbus driver are fairly minimal, since not many
devices currently supported on those SoCs use address decoding
windows. The only one being the BootROM window, used to bring up
secondary CPUs.
However, this BootROM window needed for SMP brings an important
requirement: the mvebu-mbus driver must be initialized at the
->early_init() time, otherwise the BootROM window cannot be setup
early enough to be ready before the secondary CPUs are started.
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64 into next/cleanup
* 'gic' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64:
irqchip: gic: Perform the gic_secondary_init() call via CPU notifier
irqchip: gic: Call handle_bad_irq() directly
arm: Move chained_irq_(enter|exit) to a generic file
arm: Move the set_handle_irq and handle_arch_irq declarations to asm/irq.h
+ Linux 3.9-rc3
mvebu cleanup for v3.10
- plat-orion: prep for mvebu-mbus driver
This patch adds a dedicated dbg_show function to the gpio-mvebu driver.
In addition to the generic gpiolib informations, this function displays
informations related with the specific Marvell registers (blink enable,
data in polarity, interrupt masks and cause).
Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
This patch converts the Marvell MV643XX ethernet driver to use the
Marvell Orion MDIO driver. As a result, PowerPC and ARM platforms
registering the Marvell MV643XX ethernet driver are also updated to
register a Marvell Orion MDIO driver. This driver voluntarily overlaps
with the Marvell Ethernet shared registers because it will use a subset
of this shared register (shared_base + 0x4 to shared_base + 0x84). The
Ethernet driver is also updated to look up for a PHY device using the
Orion MDIO bus driver.
For ARM and PowerPC we register a single instance of the "mvmdio" driver
in the system like it used to be done with the use of the "shared_smi"
platform_data cookie on ARM.
Note that it is safe to register the mvmdio driver only for the "ge00"
instance of the driver because this "ge00" interface is guaranteed to
always be explicitely registered by consumers of
arch/arm/plat-orion/common.c and other instances (ge01, ge10 and ge11)
were all pointing their shared_smi to ge00. For PowerPC the in-tree
Device Tree Source files mention only one MV643XX ethernet MAC instance
so the MDIO bus driver is registered only when id == 0.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
The GPIO driver uses gpiolib, thus it should be compiled when
CONFIG_GPIOLIB is defined and not only CONFIG_GENERIC_GPIO
The PCIe code was directly accessing the orion_mbus_dram_info
structure to get access to a description of the SDRAM chip selects in
order to configure the PCIe -> SDRAM address decoding
windows.
However, with the introduction of the orion-mbus driver, we are going
to remove this global structure and instead leave only the exported
mv_mbus_dram_info() function to access this description of the SDRAM
chip selects. Therefore, we simply switch to using this API.
-flagmail-match: MVEBU
X-flagmail-match: KIRKWOOD
X-flagmail-match: DOVE
For now, addr-map.c is needed by all 5 Marvell EBU
sub-architectures. However, we are going to introduce the orion-mbus
driver, which will replace the address decoding code from
addr-map.c. In order to ease the migration process, we will do that
one sub-architecture at a time, which will require us to remove the
compilation of addr-map.c one sub-architecture at a time.
Therefore, we split the unconditional obj-y inclusion of addr-map.c
into 5 conditionals obj-$(CONFIG_...) lines, one per sub-architecture.
During the system initialization, the orion_setup_cpu_mbus_target()
function reads the SDRAM address decoding registers to find out how
many chip-selects of SDRAM have been enabled, and builds a small array
with one entry per chip-select. This array is then used by device
drivers (XOR, Ethernet, etc.) to configure their own address decoding
windows to the SDRAM.
However, devices can only access the first 32 bits of the physical
memory. Even though LPAE is not supported for now, some Marvell boards
are now showing up with 8 GB of RAM, configured using two SDRAM
address decoding windows: the first covering the first 4 GB, the
second covering the last 4 GB. The array built by
orion_setup_cpu_mbus_target() has therefore two entries, and device
drivers try to set up two address decoding windows to the
SDRAM. However, in the device registers for the address decoding, the
base address is only 32 bits, so those two windows overlap each other,
and the devices do not work at all.
This patch makes sure that the array built by
orion_setup_cpu_mbus_target() only contains the SDRAM decoding windows
that correspond to the first 4 GB of the memory. To do that, it
ignores the SDRAM decoding windows for which the 4 low-order bits are
not zero (the 4 low-order bits of the base register are used to store
bits 32:35 of the base address, so they actually indicate whether the
base address is above 4 GB).
This patch allows the newly introduced armada-xp-gp board to properly
operate when it is mounted with more than 4 GB of RAM. Without that,
all devices doing DMA (for example XOR and Ethernet) do not work at
all.
Tested-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Pull ARM SoC cleanups from Arnd Bergmann:
"A large number of cleanups, all over the platforms. This is dominated
largely by the Samsung platforms (s3c, s5p, exynos) and a few of the
others moving code out of arch/arm into more appropriate subsystems.
The clocksource and irqchip drivers are now abstracted to the point
where platforms that are already cleaned up do not need to even
specify the driver they use, it can all get configured from the device
tree as we do for normal device drivers. The clocksource changes
basically touch every single platform in the process.
We further clean up the use of platform specific header files here,
with the goal of turning more of the platforms over to being
"multiplatform" enabled, which implies that they cannot expose their
headers to architecture independent code any more.
It is expected that no functional changes are part of the cleanup.
The overall reduction in total code lines is mostly the result of
removing broken and obsolete code."
* tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (133 commits)
ARM: mvebu: correct gated clock documentation
ARM: kirkwood: add missing include for nsa310
ARM: exynos: move exynos4210-combiner to drivers/irqchip
mfd: db8500-prcmu: update resource passing
drivers/db8500-cpufreq: delete dangling include
ARM: at91: remove NEOCORE 926 board
sunxi: Cleanup the reset code and add meaningful registers defines
ARM: S3C24XX: header mach/regs-mem.h local
ARM: S3C24XX: header mach/regs-power.h local
ARM: S3C24XX: header mach/regs-s3c2412-mem.h local
ARM: S3C24XX: Remove plat-s3c24xx directory in arch/arm/
ARM: S3C24XX: transform s3c2443 subirqs into new structure
ARM: S3C24XX: modify s3c2443 irq init to initialize all irqs
ARM: S3C24XX: move s3c2443 irq code to irq.c
ARM: S3C24XX: transform s3c2416 irqs into new structure
ARM: S3C24XX: modify s3c2416 irq init to initialize all irqs
ARM: S3C24XX: move s3c2416 irq init to common irq code
ARM: S3C24XX: Modify s3c_irq_wake to use the hwirq property
ARM: S3C24XX: Move irq syscore-ops to irq-pm
clocksource: always define CLOCKSOURCE_OF_DECLARE
refactored printing of the kernel warning:
"orion_mpp_conf: requested MPP%u config unavailable on this hardware\n"
which is not to be printed in case of variant_mask = 0 (unknown variant).
This check should be performed using a logical AND (&&) as opposed
to a bitwise AND (&).
Otherwise, test would fail (and message would not be printed) if
variant_mask != 1
Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Olof Johansson <olof@lixom.net>
Cc: Nicolas Pitre <nico@linaro.org>
Cc: Holger Brunck <holger.brunck@keymile.com>
The clockevent core is able to figure out the best mult and shift,
calculate min_delta_ns and max_delta_ns, with the necessary info passed
into clockevents_config_and_register(). Use this combined configure
and register function where possible to make the codes less error prone
and gain some positive diff stat.
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Reviewed-by: Anton Vorontsov <cbouatmailru@gmail.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Jason Cooper <jason@lakedaemon.net>
Tested-by: Roland Stigge <stigge@antcom.de>
Acked-by: Eric Miao <eric.y.miao@gmail.com>
Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: David Brown <davidb@codeaurora.org>
Tested-by: Tony Lindgren <tony@atomide.com>
Acked-by: Barry Song <baohua.song@csr.com>
Acked-by: Tony Prisk <linux@prisktech.co.nz>
Cc: Lennert Buytenhek <buytenh@wantstofly.org>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Jason Cooper <jason@lakedaemon.net>
Pull ARM SoC updates for Marvell mvebu/kirkwood from Olof Johansson:
"This is a branch with updates for Marvell's mvebu/kirkwood platforms.
They came in late-ish, and were heavily interdependent such that it
didn't make sense to split them up across the cross-platform topic
branches. So here they are (for the second release in a row) in a
branch on their own."
* tag 'mvebu' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (88 commits)
arm: l2x0: add aurora related properties to OF binding
arm: mvebu: add Aurora L2 Cache Controller to the DT
arm: mvebu: add L2 cache support
dma: mv_xor: fix error handling path
dma: mv_xor: fix error checking of irq_of_parse_and_map()
dma: mv_xor: use request_irq() instead of devm_request_irq()
dma: mv_xor: clear the window override control registers
arm: mvebu: fix address decoding armada_cfg_base() function
ARM: mvebu: update defconfig with I2C and RTC support
ARM: mvebu: Add SATA support for OpenBlocks AX3-4
ARM: mvebu: Add support for the RTC in OpenBlocks AX3-4
ARM: mvebu: Add support for I2C on OpenBlocks AX3-4
ARM: mvebu: Add support for I2C controllers in Armada 370/XP
arm: mvebu: Add hardware I/O Coherency support
arm: plat-orion: Add coherency attribute when setup mbus target
arm: dma mapping: Export a dma ops function arm_dma_set_mask
arm: mvebu: Add SMP support for Armada XP
arm: mm: Add support for PJ4B cpu and init routines
arm: mvebu: Add IPI support via doorbells
arm: mvebu: Add initial support for power managmement service unit
Select the generic mvebu kirkwood pincltr driver and generic mvebu
gpio driver. This requires minor changes to the DT, and the calls to
configure plat-orion gpio driver are removed.
Tested-by: Michael Walle <michael@walle.cc>
Tested-by: Simon Baatz <gmbnomis@gmail.com>
Tested-by: Jamie Lentin <jm@lentin.co.uk>
Tested-by: Joshua Coombs <josh.coombs@gmail.com>
git://github.com/MISL-EBU-System-SW/mainline-public into mvebu/everything
Add hardware I/O coherency support for Armada 370/XP
The purpose of this patch set is to add hardware I/O Coherency support
for Armada 370 and Armada XP. Theses SoCs come with an unit called
coherency fabric. A beginning of the support for this unit have been
introduced with the SMP patch set. This series extend this support:
the coherency fabric unit allows to use the Armada XP and the Armada
370 as nearly coherent architectures.
The third patches enables this new feature and register our own set
of DMA ops, to benefit this hardware enhancement.
The first patches exports a dma operation function needed to register
our own set of dma ops.
The second patch introduces a new flag for the address decoding
configuration in order to be able to set the memory windows as
shared memory.
Recent SoC such as Armada 370/XP came with the possibility to deal
with the I/O coherency by hardware. In this case the transaction
attribute of the window must be flagged as "Shared transaction". Once
this flag is set, then the transactions will be forced to be sent
through the coherency block, in other case transaction is driven
directly to DRAM.
Reviewed-by: Yehuda Yitschak <yehuday@marvell.com>
Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
The pool_size is always PAGE_SIZE, and since it is a software
configuration paramter (and not a hardware description parameter), we
cannot make it part of the Device Tree binding, so we'd better remove
it from the platform_data as well.
There is no need for the platform_data to give this ID, it is simply
the channel number, so we can compute it inside the driver when
registering the channels.
Since we got rid of the per-XOR channel 'mv_xor' driver, now the
per-XOR engine driver that used to be called 'mv_xor_shared' can
simply be named 'mv_xor'.
'struct mv_xor_shared_platform_data' used to be the platform_data
structure for the 'mv_xor_shared', but this driver is going to be
renamed simply 'mv_xor', so also rename its platform_data structure
accordingly.
mv_xor_platform_data used to be the platform_data structure associated
to the 'mv_xor' driver. This driver no longer exists, and this data
structure really contains the properties of each XOR channel part of a
given XOR engine. Therefore 'struct mv_xor_channel_data' is a more
appropriate name.
This member of the platform_data structure is no longer used, so get
rid of it.
Now that xor0 and xor1 are registered in a single driver manner, the
orion_xor_init_channels() function has become useless.
driver
Instead of registering one 'mv_xor_shared' device for the XOR engine,
and then two 'mv_xor' devices for the XOR channels, pass the channels
properties as platform_data for the main 'mv_xor_shared' device.
driver
With true DT clock providers available switch Kirkwood clock setup in
DT- enabled boards. While AUXDATA can be removed completely from bus
probing, some devices still don't know about DT. Therefore, some clkdev
aliases are created until these devices also move to DT.
Moving ARCH_MVEBU for multi-platform support caused several breakages in
recently added addr-map and pinctrl support for mvebu. This adds the
necessary selects and include paths to fix the build.
Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: Gregory CLEMENT <gregory.clement@free-electrons.com>
git://git.infradead.org/users/jcooper/linux into late/kirkwood
* 'kirkwood/addr_decode' of git://git.infradead.org/users/jcooper/linux:
arm: mvebu: add address decoding controller to the DT
arm: mvebu: add basic address decoding support to Armada 370/XP
arm: plat-orion: make bridge_virt_base non-const to support DT use case
arm: plat-orion: introduce PLAT_ORION_LEGACY hidden config option
arm: plat-orion: use void __iomem pointers for addr-map functions
arm: plat-orion: use void __iomem pointers for time functions
arm: plat-orion: use void __iomem pointers for MPP functions
arm: plat-orion: use void __iomem pointers for UART registration functions
arm: mach-mvebu: use IOMEM() for base address definitions
arm: mach-orion5x: use IOMEM() for base address definitions
arm: mach-mv78xx0: use IOMEM() for base address definitions
arm: mach-kirkwood: use IOMEM() for base address definitions
arm: mach-dove: use IOMEM() for base address definitions
arm: mach-orion5x: use plus instead of or for address definitions
arm: mach-mv78xx0: use plus instead of or for address definitions
arm: mach-kirkwood: use plus instead of or for address definitions
arm: mach-dove: use plus instead of or for address definitions
This branch had quite a few conflicts, in particular with the PCI static
map rework from Rob Herring, and a few other context conflicts due to
changes in Kconfig, etc.
I fixed up conflicts in:
arch/arm/Kconfig
arch/arm/mach-dove/common.c
arch/arm/mach-dove/include/mach/dove.h
arch/arm/mach-kirkwood/common.c
arch/arm/mach-kirkwood/include/mach/kirkwood.h
arch/arm/mach-mv78xx0/include/mach/mv78xx0.h
arch/arm/mach-orion5x/common.c
arch/arm/mach-orion5x/include/mach/orion5x.h
* multiplatform/platform-data:
ARM: spear: move platform_data definitions
ARM: samsung: move platform_data definitions
ARM: orion: move platform_data definitions
ARM: nomadik: move platform_data definitions
ARM: w90x900: move platform_data definitions
ARM: vt8500: move platform_data definitions
ARM: tegra: move sdhci platform_data definition
ARM: sa1100: move platform_data definitions
ARM: pxa: move platform_data definitions
ARM: netx: move platform_data definitions
ARM: msm: move platform_data definitions
ARM: imx: move platform_data definitions
ARM: ep93xx: move platform_data definitions
ARM: davinci: move platform_data definitions
ARM: at91: move platform_data definitions
Conflicts due to removed files:
arch/arm/mach-tegra/board-harmony.c
arch/arm/mach-tegra/board-trimslice.c
Conflicts due to code removal:
arch/arm/mach-tegra/board-paz00.c
Context conflicts in:
drivers/mmc/host/sdhci-tegra.c
drivers/net/irda/pxaficp_ir.c
For the Armada 370 and XP SoCs where the DT is used, we need to fill
at runtime the bridge_virt_base field on the
orion_addr_map_cfg. Therefore, remove the 'const' qualifier on this
field.
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Tested-by: Andrew Lunn <andrew@lunn.ch>
Until now, the PLAT_ORION configuration option was common to all the
Marvell EBU SoCs, and selecting this option had the effect of enabling
the MPP code, GPIO code, address decoding and PCIe code from
plat-orion, as well as providing access to driver-specific header
files from plat-orion/include.
However, the Armada 370 and XP SoCs will not use the MPP and GPIO code
(instead some proper pinctrl and gpio drivers are in preparation), and
generally, we want to move away from plat-orion and instead have
everything in mach-mvebu.
That said, in the mean time, we want to leverage the driver-specific
headers as well as the address decoding code, so we introduce
PLAT_ORION_LEGACY. The older Marvell SoCs need to select
PLAT_ORION_LEGACY, while the newer Marvell SoCs need to select
PLAT_ORION. Of course, when PLAT_ORION_LEGACY is selected, it
automatically selects PLAT_ORION.
Then, with just PLAT_ORION, you have the address decoding code plus
the driver-specific headers. If you add PLAT_ORION_LEGACY to this, you
gain the old MPP, GPIO and PCIe code.
Again, this is only a temporary solution until we make all Marvell EBU
platforms converge into the mach-mvebu directory. This solution avoids
duplicating the existing address decoding code into mach-mvebu.
The functions for address mapping management now take void __iomem
pointers, so we remove the temporary "unsigned long" casts from the
mach-*/common.c files.
The functions for time management now take void __iomem pointers, so
we remove the temporary "unsigned long" casts from the mach-*/common.c
files.
The registration function for MPP now takes void __iomem pointers, so
we remove the temporary "unsigned long" casts from the mach-*/mpp.c
files.
The registration functions for UARTs now take void __iomem pointers,
Platform data for device drivers should be defined in
include/linux/platform_data/*.h, not in the architecture
and platform specific directories.
This moves such data out of the orion include directories
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Cc: Vinod Koul <vinod.koul@intel.com>
Cc: Dan Williams <djbw@fb.com>
Cc: Bryan Wu <bryan.wu@canonical.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Chris Ball <cjb@laptop.org>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Liam Girdwood <lrg@ti.com>
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Takashi Iwai <tiwai@suse.de>
Move custom orion platforms gpio code to orion-gpio to remove the
dependency on mach/gpio.h.
The mv643xx ethernet controller limits the packet size for the TX
checksum offloading. This patch sets this limits for Kirkwood and
Dove which have smaller limits that the default.
As a side note, this patch is an updated version of a patch sent some years
ago: http://lists.infradead.org/pipermail/linux-arm-kernel/2010-June/017320.html
which seems to have been lost.
Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org>
The MV64XXX I2C driver needs a clock in order to calculate the baud
rate factors. So add an clk to the clk tree. Also add the base DT
properties for kirkwood devices.
