The addition of the new debounce code (commit
168ef3d9a56bd8bffe0ef4189c450888b4aefefe) broke the auto-disable of
debounce clocks on idle by forgetting to update the debounce clock
enable mask.
Add back the updating of bank->dbck_enable_mask so debounce clocks are
auto-disabled.
Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
Nobody uses that anymore, so remove and expect drivers to use the gpiolib
implementation.
Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com>
Cc: Tony Lindgren <tony@atomide.com>
Cc: David Brownell <david-b@pacbell.net>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
OMAP supports debouncing of gpio lines, implement the method using
gpiolib.
Access to some of the OMAP4 GPIO registers are not properly handled.
This patch fixes it.
This patch is tested on 3430SDP and 4430SDP boards
Signed-off-by: Charulatha V <charu@ti.com>
Acked-by: Kevin Hilman <khilman@deeprootsystems.com>
The generic gpiolib provides a debugfs interface to GPIOs which
provides identical (but nicer looking) data as the OMAP specific one.
This patch completely drops the OMAP specific interface
(/debug/omap_gpio) in favor of using the generic one (/debug/gpio.)
setwkuena and setdataout are covered already by wake_en and dataout fields.
Signed-off-by: Tero Kristo <tero.kristo@nokia.com>
Ensure GPIO debounce clocks are disabled when idle. Otherwise,
clocks will prevent PER powerdomain from entering retention.
Currently, the GPIO 'prepare' hook is only called when going to
off-mode, while the function is called 'prepare_for_retention.' This
patch renames the function to 'prepare_for_idle' and calls it for any
powersate != PWRDM_POWER_ON passing in the powerstate.
The hook itself is then responsible for doing various preparation
based on the powerstate.
According to the GPIO 'Wakeup and Interrupt' section of the TRM[1],
wake-up requests can only be generated on edge transitions.
Also for OMAP3, only edge GPIOs may lose interrupts when PER enters
RET/OFF state, this is addressed by gpio prepare|resume idle functions
[1] Section 25.5.3.1 OMAP34xx_ES3.1_TRM_V_Q
Signed-off-by: Chunqiu Wang <cqwang@motorola.com>
Off mode is now using the omap2 retention fix code for scanning GPIOs
during off-mode transitions. All the *non_wakeup_gpios variables
are now used for off-mode transition tracking on OMAP3. This patch fixes
cases where GPIO state changes are missed during off-mode.
Since IRQ_TYPE_EDGE_BOTH is defined as (IRQ_TYPE_EDGE_FALLING |
IRQ_TYPE_EDGE_RISING), testing against it with a bitwise AND also matches
both single-edge cases in addition to the intended both edges case. Fix it,
replacing with a more accurate expression.
Created and tested againts linux-2.6.34-rc3.
Applicable to 2.6.33-stable as well.
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
For omap4 case, this was wrongly writing GPIO_LEVELDETECTx
registers with OMAP24XX_ offset and OMAP4_ offset.
Bug introduced in commit:
commit 3f1686a9bfe74979c6ad538c78039730f665f77e
Author: Tony Lindgren <tony@atomide.com>
Date: Mon Feb 15 09:27:25 2010 -0800
omap: Fix gpio.c for multi-omap for omap4
Signed-off-by: Sergio Aguirre <saaguirre@ti.com>
This patch removes all the omap4 specific irq line
defines from plat/irqs.h and includes auto-generated
irqs-44xx.h
All the legacy naming style defines are replaced with the one
from irqs-44xx.h
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com>
Reviewed-by: Paul Walmsley <paul@pwsan.com>
[tony@atomide.com: updated to compile with usb-musb.c]
Set up METHOD_GPIO_44XX instead of trying to use the METHOD_GPIO_24XX.
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
omap: Replace orred CONFIG_ARCH_OMAP2/3/4 with CONFIG_ARCH_OMAP2PLUS
Replace ARCH_OMAP34XX with ARCH_OMAP3
Convert ARCH_OMAP24XX to ARCH_OMAP2
Allows compiling in omap2 and omap3.
The only usage of _toggle_gpio_edge_triggering is in
an #ifdef CONFIG_ARCH_OMAP1 block, so only provide it if
CONFIG_ARCH_OMAP1 is defined, too.
This fixes a compiler warning:
arch/arm/plat-omap/gpio.c:758: warning: '_toggle_gpio_edge_triggering' defined but not used
when compiling for ARCH_OMAP2, ARCH_OMAP3 or ARCH_OMAP4.
Flags is not used on 15xx.
Some chips, namely any OMAP1 chips using METHOD_MPUIO,
OMAP15xx and OMAP7xx, cannot be setup to respond to on-chip GPIO
interrupts in both rising and falling edge directions -- they can
only respond to one direction or the other, depending on how the
ICR is configured.
Additionally, current code forces rising edge detection if both
flags are specified:
if (trigger & IRQ_TYPE_EDGE_RISING)
l |= 1 << gpio;
else if (trigger & IRQ_TYPE_EDGE_FALLING)
l &= ~(1 << gpio);
else
goto bad;
This change implements a toggle function that will modify the ICR
to flip the direction of interrupt for IRQs that are requested with
both rising and falling flags. The toggle function is not called
for chips and GPIOs it does not apply to through the use of a flip_mask
that's added on a per-bank basis. The mask is only set for those
GPIOs where a toggle is necessary. Edge detection starts out the
same as above with FALLING mode first.
The toggle happens on EACH interrupt; without it, we have the
following sequence of actions on GPIO transition:
ICR GPIO Result
0x1 0 -> 1 (rising) Interrupt
0x1 1 -> 0 (falling) No interrupt
(set ICR to 0x0 manually)
0x0 0 -> 1 (rising) No interrupt
0x0 1 -> 0 (falling) Interrupt
That is, with the ICR set to 1 for a gpio, only rising edge interrupts
are caught, and with it set to 0, only falling edge interrupts are
caught. If we add in the toggle, we get this:
ICR GPIO Result
0x1 0 -> 1 (rising) Interrupt (ICR set to 0x0)
0x0 1 -> 0 (falling) Interrupt (ICR set to 0x1)
0x1 0 -> 1 ...
so, both rising and falling are caught, per the request for both
(IRQ_TYPE_EDGE_RISING | IRQ_TYPE_EDGE_FALLING).
Signed-off-by: Cory Maccarrone <darkstar6262@gmail.com>
This patch disables a GPIO module when all pins of a GPIO
module are inactive (clock gating forced at module level) and
enables the module when any gpio in the module is requested.
The module is enabled only when "mod_usage" indicates that no GPIO
in that module is currently active and the GPIO being requested
is the 1st one to be active in that module.
Each module would be disabled in omap_gpio_free() API when all
GPIOs in a particular module becomes inactive. The module is
re-enabled in omap_gpio_request() API when a GPIO is requested
from the module that was previously disabled.
Since individual GPIO's bookkeeping is added in this patch
via "mod_usage", the same is used in omap_set_gpio_debounce()
& omap_set_gpio_debounce_time() APIs to ensure that the gpio being
used is actually "requested" prior to being used (Nishant Menon's
<nm@ti.comSuggestion)
GPIO module level details are specific to hardware and hence
introducing this patch in low level layer (plat-omap/gpio.c)
Acked-by: Nishanth Menon <nm@ti.com>
Merge branch '7xx-iosplit-plat-merge' into omap-for-linus
The closing parenthesis was not in the right location.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Add context save and restore to enable off-mode.
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Use ioremap in gpio.c
This patch is part of a series which removes references to omap730 in code
which is shared with omap850, replacing them with references to omap7xx.
This updates all the remaining omap730 references in miscellaneous local
variables, macros and similar.
Signed-off-by: Alistair Buxton <a.j.buxton@gmail.com>
Reviewed-by: Zebediah C. McClure <zmc@lurian.net>
Turns INT_730_* to INT_7XX_* for definitions in irqs.h and all users.
This patch is part of a series which unifies all duplicated code between
omap730 and omap850. All cpu checks are converted to cpu_is_omap7xx() and
CONFIG_ARCH_OMAP850 is added to all CONFIG_ARCH_OMAP730 checks.
This was crashing omap850 devices.
Reported-by:
Signed-off-by: Angelo Arrifano <miknix@gmail.com>
Signed-obb-by: Tony Lindgren <tony@atomide.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6
* 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (47 commits)
OMAP clock: use debugfs_remove_recursive() for rewinding
OMAP2/3/4 core: create omap_device layer
OMAP: omap_hwmod: call omap_hwmod init at boot; create interconnects
OMAP2/3/4: create omap_hwmod layer
OMAP2/3 board-*.c files: read bootloader configuration earlier
OMAP2/3/4 PRCM: add module IDLEST wait code
OMAP2/3 PM: create the OMAP PM interface and add a default OMAP PM no-op layer
OMAP3 clock: remove superfluous calls to omap2_init_clk_clkdm
OMAP clock: associate MPU clocks with the mpu_clkdm
OMAP3 clock: Fixed processing of bootarg 'mpurate'
OMAP: SDRC: Add several new register definitions
OMAP: powerdomain: Fix overflow when doing powerdomain deps lookups.
OMAP: PM: Added suspend target state control to debugfs for OMAP3
OMAP: PM debug: Add PRCM register dump support
OMAP: PM debug: make powerdomains use PM-debug counters
OMAP: PM: Add pm-debug counters
OMAP: PM: Add closures to clkdm_for_each and pwrdm_for_each.
OMAP: PM: Hook into PM counters
OMAP: PM counter infrastructure.
OMAP3: PM: fix lockdep warning caused by omap3_pm_init
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: (23 commits)
at_hdmac: Rework suspend_late()/resume_early()
PM: Reset transition_started at dpm_resume_noirq
PM: Update kerneldoc comments in drivers/base/power/main.c
PM: Add convenience macro to make switching to dev_pm_ops less error-prone
hp-wmi: Switch driver to dev_pm_ops
floppy: Switch driver to dev_pm_ops
PM: Trivial fixes
PM / Hibernate / Memory hotplug: Always use for_each_populated_zone()
PM/Hibernate: Do not try to allocate too much memory too hard (rev. 2)
PM/Hibernate: Do not release preallocated memory unnecessarily (rev. 2)
PM/Hibernate: Rework shrinking of memory
PM: Fix typo in label name s/Platofrm_finish/Platform_finish/
PM: Run-time PM platform device bus support
PM: Introduce core framework for run-time PM of I/O devices (rev. 17)
Driver Core: Make PM operations a const pointer
PM: Remove platform device suspend_late()/resume_early() V2
USB: Rework musb suspend()/resume_early()
I2C: Rework i2c-s3c2410 suspend_late()/resume() V2
I2C: Rework i2c-pxa suspend_late()/resume_early()
DMA: Rework txx9dmac suspend_late()/resume_early()
Fix trivial conflict in drivers/base/platform.c (due to same
constification patch being merged in both sides, along with some other
PM work in the PM branch)
It is possible for GPIO IRQ lines configured with
falling edge triggering only to get IRQs at the
rising edge upon the exit of offmode. And vice
versa. Prevent such IRQs to arrive by generating
the IRQ obeying the detection scheme.
Signed-off-by: Eero Nurkkala <ext-eero.nurkkala@nokia.com>
Rename OMAP_MPUIO_BASE to OMAP1_MPUIO_BASE
Search and replace OMAP_IO_ADDRESS with OMAP1_IO_ADDRESS and OMAP2_IO_ADDRESS,
and convert omap_read/write into a functions instead of a macros.
Also rename OMAP_MPUIO_VBASE to OMAP1_MPUIO_VBASE.
In the long run, most code should use ioremap + __raw_read/write instead.
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-omap-pm
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-omap-pm into devel-stable
If IRQ triggering is enabled, it can trigger a pending interrupt
even for masked interrupts. Any pending GPIO interrupts can
prevent the powerdomain from hitting retention.
Problem found, reported and additional review and testing by Chunquiu
Wang.
Tested-by: Chunquiu Wang <cqwang@motorola.com>
gpio_get() should return DATAIN register value when the GPIO
is configured as input whereas it should return DATAOUT register
value when the GPIO is configured as output.
Now /sys/kernel/debug/gpio shows proper values for output GPIOs
Signed-off-by: Roger Quadros <ext-roger.quadros@nokia.com>
This patch adds GPIO support on OMAP4430 development platform.
Signed-off-by: Syed Rafiuddin <rafiuddin.syed@ti.com>
This patch reworks platform driver power management code
for omap drivers using late/early legacy callbacks.
The callbacks are converted for CONFIG_SUSPEND like this:
suspend_late() -> suspend_noirq()
resume_early() -> resume_noirq()
Signed-off-by: Magnus Damm <damm@igel.co.jp>
Acked-by: Pavel Machek <pavel@ucw.cz>
Some bootloader may initialize debounce register and this will make
dbclk not consist with the debounce register after linux kernel boot
up.
Signed-off-by: janboe <janboe.ye@gmail.com>
This patch adds the support for OMAP4. The platform and machine specific
headers and sources updated for OMAP4430 SDP platform.
OMAP4430 is Texas Instrument's SOC based on ARM Cortex-A9 SMP architecture.
It's a dual core SOC with GIC used for interrupt handling and SCU for cache
coherency.
As per 3430 TRM, there are 6 banks [0 to 191]
Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
Signed-off-by: Vikram Pandita <vikram.pandita@ti.com>
Flush posted write to IRQSTATUS register in GPIO IRQ handler.
This eliminates the below error for all peripherals that use GPIO interrupts.
<4>Spurious irq 95: 0xffffffdf, please flush posted write for irq 31
The GPIO IRQ enable/disable path attempts to also enable IRQ wake
support for the parent GPIO bank IRQ as well. However, since there is
no 'set_wake' hook for the bank IRQs, these calls will always fail.
Also, since the enable will fail on the suspend path, the disable on
the resume path will trigger unbalanced enable/disable warnings.
This was discovered in the suspend/resume path on OMAP3/Beagle using
the gpio-keys driver which disables/re-enables GPIO IRQ wakeups in the
suspend/resume path.
Changes to base IO subsystem.
Signed-off-by: Zebediah C. McClure <zmc@lurian.net>
