path: root/arch/arm/plat-omap/Makefile
2009-03-04ARM: OMAP: Allow I2C bus driver to be compiled as a moduleAaro Koskinen
Fixes a linker error when OMAP I2C bus driver is compiled as a module: ERROR: "i2c_register_board_info" [arch/arm/plat-omap/i2c.ko] undefined! The I2C utility functions used for board initialization should be always built-in. Signed-off-by: Aaro Koskinen <Aaro.Koskinen@nokia.com> Acked-by: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-09-05[ARM] omap: allow ioremap() to use our fixed IO mappingsRussell King
2008-07-03ARM: OMAP: SRAM: Move sram-fn.S from plat-omap to mach-omap1Tony Lindgren
This file is omap1 specific. Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-04-14ARM: OMAP: Timer32K: Move timer32k to mach-omap1Kevin Hilman
Move now OMAP1-specific timer32k code to mach-omap1 since OMAP2/3 32k timers are done in gptimer code. Signed-off-by: Kevin Hilman <khilman@mvista.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-04-14ARM: OMAP: Timer32K: Re-organize duplicated 32k-timer codeKevin Hilman
On OMAP2/3, the gp-timer code can be used for a 32kHz timer simply by setting the source to be the 32k clock instead of sys_clk. This patch uses the mach-omap2/timer-gp.c code for 32kHz timer on OMAP2, moving the logic into mach-omap2/timer-gp.c, and not using plat-omap/timer32k.c which, for OMAP2, is redundant with the timer-gp code. Also, if CONFIG_OMAP_32K_TIMER is enabled, the gptimer-based clocksource is not used. Instead the default 32k sync counter is used as the clocksource (see the clocksource in plat-omap/common.c.) This is important for sleep/suspend so there is a valid counter during sleep. Note that the suspend/sleep code needs fixing to check for overflows of this counter. In addition, the OMAP2/3 details are removed from timer32k.c leaving that with only OMAP1 specifics. A follow-up patch will move it from plat-omap common code to mach-omap1. Signed-off-by: Kevin Hilman <khilman@mvista.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-03-20ARM: OMAP: Fix missing makefile optionsTony Lindgren
Although audio and dsp drivers are not integrated yet, allow compiling in mailbox and mcbsp to see any build warnings. Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-02-08ARM: OMAP: Add helper module for board specific I2C bus registrationJarkko Nikula
This helper module simplifies I2C bus registration for different OMAP platforms by doing registration in one place only and to allow board specific bus configuration like clock rate and number of busses configured. Helper should cover OMAP processors from first to third generation. This patch just adds the feature and current implementation cleanup and board file modifications will be done in following patches. Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-09-20ARM: OMAP: abstract debug card setup (smc, leds)David Brownell
Additional cleanup for debug boards on H2/P2/H3/H4: move the init code that's not board-specific into a new file where it can be easily shared between all the different boards (avoiding code duplication, and making it easier to support more devices). Make H4 use that. This should be easy to drop in to the OMAP1 boards using these debug cards; the only difference seems to be that the p2 does an extra reset of the smc using the fpga (probably all boards could do that, if it's necessary) and doesn't use the gpio mux or request APIs. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-05-08ARM: OMAP: Sync core code with linux-omapTony Lindgren
This patch syncs omap specific core code with linux-omap. Most of the changes are needed to fix bitrot caused by driver updates in linux-omap tree. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-08ARM: OMAP: h4 must have blinky leds!!David Brownell
This adds generic support for the "debug board" LEDs used by most of TI's OMAP reference boards, and board-specific support for the H4. It's derived from the not-as-generic stuff used by OMAP1 H2/H3/P2. Those should be able to switch easily to this version, and clean up some of the omap1-specific code. In addition to H4 support, one key improvement is supporting not just the "old" ARM debug LED API (with timer and idle LEDs, plus four that can be handy for kernel debugging), but it also supports the "new" generic LED API (most useful for usermode stuff IMO). Either or both APIs can be enabled. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-04-02[ARM] 3455/1: ARM: OMAP: 7/8 Misc updates, take 2Tony Lindgren
Patch from Tony Lindgren Update misc OMAP core code from linux-omap tree: - McBSP updates by Samuel Ortiz, Andrzej Zaborowski - Whitespace cleanups by Ladislav Michl - Other fixes by various linux-omap developers Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-10[ARM] 3142/1: OMAP 2/5: Update files common to omap1 and omap2Tony Lindgren
Patch from Tony Lindgren This patch syncs the mainline kernel with linux-omap tree. The highlights of the patch are: - Serial port and framebuffer init improvments by Imre Deak - Common omap pin mux framework by Tony Lindgren - Common omap clock framework by Tony Lindren Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-07[ARM] 2887/1: OMAP 2/4: Update files common to omap1 and omap2, take 2Tony Lindgren
Patch from Tony Lindgren This patch syncs the mainline kernel with linux-omap tree. The highlights of the patch are: - Clock updates by Tuukka Tikkanen, Juha Yrjola, Daniel Petrini and Tony Lindgren - DMA fixes by Imre Deak, Juha Yrjola and Daniel Petrini - Add support to dual-mode hardware timers by Lauri Leukkunen - GPIO support for 24xx by Paul Mundt - GPIO wake-up support by Tony Lindgren - Better GPIO interrupt handler to not lose interrupts by Ralph Walden and Ladislav Michl - Power Management updates by Tuukka Tikkanen - Make Power Management code use new SRAM functions by Tony Lindgren Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-10[PATCH] ARM: 2803/1: OMAP update 11/11: Add cpufreq supportTony Lindgren
Patch from Tony Lindgren This patch adds minimal cpufreq support for OMAP taking advantage of the clock framework. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-10[PATCH] ARM: 2812/1: OMAP update 7c/11: Move arch-omap to plat-omapTony Lindgren
Patch from Tony Lindgren This patch move common OMAP code from arch-omap to plat-omap directory. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
