It's really unnecessary to have plat-mxc, and let's merge it into
mach-imx. It's pretty much just a bunch of file renaming and
Kconfig/Makefile merge.
To make the change less invasive, we keep using Kconfig symbol
CONFIG_ARCH_MXC for mach-imx sub-architecture.
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
As all irqchips on imx have been changed to allocate their irq_descs,
and all unneeded mach/irqs.h inclusions on imx have been cleaned up,
now it's time to select SPARSE_IRQ for imx/mxc.
The SPARSE_IRQ support forces irqs allocation starting from 16. All
those static irq number definition for SoCs need to shift 16 to keep
non-DT boot works.
With all those static IRQ number and start definitions removed from
mach/irqs.h, the header becomes just a container of a couple of
mach-imx specific irq/fiq calls. Since mach/irqs.h is not included
by asm/irq.h now, the users of mxc_set_irq_fiq needs to explicitly
include mach/irqs.h themselves.
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Signed-off-by: Gwenhael Goavec-Merou <gwenhael.goavec-merou@armadeus.com>
To use common macros to define the gpio ports for imx{1,21,25,27} the
existing ones had to made more general and a few more base address defines
were necessary.
This is only available for mx1 machines with no in-tree user.
Now only the virtual addresses [0xf4000000, 0xf5ffffff] are used for
static per-SoC mappings. The few mappings of whole chip selects are
moved accordingly.
The now wrong defines for virtual base addresses are removed.
This makes it more assembler friendly and allows it to be used in situation
that need an unsigned long and not a pointer. Also the naming is
clearer. IOMEM is introduced without IMX_ prefix as it is used this way
in more than one ARM subarch and it might become globally available
soon.
The old names are defined only if the cpp symbol
IMX_NEEDS_DEPRECATED_SYMBOLS exists, which is defined (for now) for all
files below arch/arm/mach-mx1.
This was done earlier for mx2 and mx3, too.
USBD_INT0 is for now defined unconditionally to prevent breaking
drivers/usb/gadget/imx_udc.
While at it use IMX_IO_ADDRESS to define MX1_IO_ADDRESS which
adds a cast to the IO_ADDRESS macro fixing many warnings like
arch/arm/mach-mx1/generic.c:51: warning: passing argument 1 of 'mxc_init_irq' makes pointer from integer without a cast
Some headers have used (now) wrong names or havn't had protection at
all. This is needed before adding static inline functions to the
headers.
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Magnus Lilja <lilja.magnus@gmail.com>
Cc: Holger Schurig <hs4233@mail.mn-solutions.de>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Daniel Mack <daniel@caiaq.de>
Everyone should be free to include the files he actually needs.
Several comments in board config files stated "mandatory for
CONFIG_LL_DEBUG" but the correct name is CONFIG_DEBUG_LL.
Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
Instead of including other header files, define PHYS_OFFSET directly
Instead of including other header files, define CLOCK_TICK_RATE directly
This patch removes the inclusion of mach/hardware.h from mach/irqs.h and
switches to more meaningful names for the irq related macros.
Adds MX1 architecture to platform MXC. It will supersede mach-imx
and let it die.
Signed-off-by: Paulius Zaleckas <paulius.zaleckas@teltonika.lt>
Signed-off-by: Darius Augulis <augulis.darius@gmail.com>
