commit b6c7aabd923a17af993c5a5d5d7995f0b27c000a upstream.
Let's do the changes properly and fix the same problem everywhere, not
just for one case.
[bwh: Backported to 3.2: mohawk doesn't support suspend at all]
Only use the preallocated page table during the resume, not while
suspending. This avoids the overhead of having to switch unnecessarily
to the resume page table in the suspend path.
Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Tested-by: Shawn Guo <shawn.guo@linaro.org>
Tested-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Preallocate a page table and setup an identity mapping for the MMU
enable code. This means we don't have to "borrow" a page table to
do this, avoiding complexities with L2 cache coherency.
ARM920 and ARM926 save four registers, not three. Fix the size of
the suspend region required.
Commit 66a625a (ARM: mm: proc-macros: Add generic proc/cache/tlb struct
definition macros) introduced build errors when PM_SLEEP is not enabled.
The per-CPU do_suspend/do_resume functions are defined via the
preprocessor to constant 0. However, the macros which use these were
converted to assembly, resulting in undefined references to these
functions. Fix that by moving the ! ifdef section into proc-macros.S
and deleting it from all effected proc-*.S files.
Acked-by: Dave Martin <dave.martin@linaro.org>
Signed-off-by: Dave Martin <dave.martin@linaro.org>
CONFIG_PM is now set whenever we support either runtime PM in addition
to suspend and hibernate. This causes build errors when runtime PM is
enabled on a platform, but the CPU does not have the appropriate support
for suspend.
So, switch this code to use CONFIG_PM_SLEEP rather than CONFIG_PM to
allow runtime PM to be enabled without causing build errors.
This adds core support for saving and restoring CPU coprocessor
registers for suspend/resume support. This contains support for suspend
with ARM920, ARM926, SA11x0, PXA25x, PXA27x, PXA3xx, V6 and V7 CPUs.
Tested on Assabet and Tegra 2.
Tested-by: Colin Cross <ccross@android.com>
Tested-by: Kukjin Kim <kgene.kim@samsung.com>
Commit 81d11955bf0 ("ARM: 6405/1: Handle __flush_icache_all for
CONFIG_SMP_ON_UP") added a new function to struct cpu_cache_fns:
flush_icache_all(). It also implemented this for v6 and v7 but not
for v5 and backwards. Without the function pointer in place, we
will be calling wrong cache functions.
For example with ep93xx we get following:
Unable to handle kernel paging request at virtual address ee070f38
pgd = c0004000
[ee070f38] *pgd=00000000
Internal error: Oops: 80000005 [#1] PREEMPT
last sysfs file:
Modules linked in:
CPU: 0 Not tainted (2.6.36+ #1)
PC is at 0xee070f38
LR is at __dma_alloc+0x11c/0x2d0
pc : [<ee070f38>] lr : [<c0032c8c>] psr: 60000013
sp : c581bde0 ip : 00000000 fp : c0472000
r10: c0472000 r9 : 000000d0 r8 : 00020000
r7 : 0001ffff r6 : 00000000 r5 : c0472400 r4 : c5980000
r3 : c03ab7e0 r2 : 00000000 r1 : c59a0000 r0 : c5980000
Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: c000717f Table: c0004000 DAC: 00000017
Process swapper (pid: 1, stack limit = 0xc581a270)
[<c0032c8c>] (__dma_alloc+0x11c/0x2d0)
[<c0032e5c>] (dma_alloc_writecombine+0x1c/0x24)
[<c0204148>] (ep93xx_pcm_preallocate_dma_buffer+0x44/0x60)
[<c02041c0>] (ep93xx_pcm_new+0x5c/0x88)
[<c01ff188>] (snd_soc_instantiate_cards+0x8a8/0xbc0)
[<c01ff59c>] (soc_probe+0xfc/0x134)
[<c01adafc>] (platform_drv_probe+0x18/0x1c)
[<c01acca4>] (driver_probe_device+0xb0/0x16c)
[<c01ac284>] (bus_for_each_drv+0x48/0x84)
[<c01ace90>] (device_attach+0x50/0x68)
[<c01ac0f8>] (bus_probe_device+0x24/0x44)
[<c01aad7c>] (device_add+0x2fc/0x44c)
[<c01adfa8>] (platform_device_add+0x104/0x15c)
[<c0015eb8>] (simone_init+0x60/0x94)
[<c0021410>] (do_one_initcall+0xd0/0x1a4)
__dma_alloc() calls (inlined) __dma_alloc_buffer() which ends up
calling dmac_flush_range(). Now since the entries in the
arm920_cache_fns are shifted by one, we jump into address 0xee070f38
which is actually next instruction after the arm920_cache_fns
structure.
So implement flush_icache_all() for the rest of the supported CPUs
using a generic 'invalidate I cache' instruction.
Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi>
__lookup_processor_type
When hotplug CPU is enabled, we need to keep the list of supported CPUs,
their setup functions, and __lookup_processor_type in place so that we
can find and initialize secondary CPUs. Move these into the __CPUINIT
section.
All implementations of cpu_proc_fin() start by disabling interrupts
and then flush caches. Rather than have every processors proc_fin()
implementation do this, move it out into generic code - and move the
cache flush past setup_mm_for_reboot() (so it can benefit from having
caches still enabled.)
This allows cpu_proc_fin() to become independent of the L1/L2 cache
types, and eventually move the L2 cache flushing into the L2 support
code.
These are now unused, and so can be removed.
Tested-By: Santosh Shilimkar <santosh.shilimkar@ti.com>
... and rename the function since it no longer operates on just
pages.
Instruction fault status register, IFSR, was introduced on ARMv6 to
provide status information about the last insturction fault. It
needed for proper prefetch abort handling.
Now we have three prefetch abort model:
* legacy - for CPUs before ARMv6. They doesn't provide neither
IFSR nor IFAR. We simulate IFSR with section translation fault
status for them to generalize code;
* ARMv6 - provides IFSR, but not IFAR;
* ARMv7 - provides both IFSR and IFAR.
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
asm code really wants asm/hwcap.h, so include that instead.
There are actually only four separate implementations of set_pte_ext.
Use assembler macros to insert code for these into the proc-*.S files.
The CPU's dma_flush_range() operation needs to clean+invalidate the
given memory area if the cache is in writeback mode, or do just the
invalidate part if the cache is in writethrough mode, but the current
proc-arm{925,926,940,946} (incorrectly) do a cache clean in the
latter case. This patch fixes that.
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
The proc-*.S files have the _prefetch_abort pointer placed at the end
of the processor structure but the cpu-multi32.h defines it in the
second position. The patch also fixes the support for XSC3 and the
MMU-less CPUs (740, 7tdmi, 940, 946 and 9tdmi).
This patch adds a prefetch abort handler similar to the data abort one
and renames the latter for consistency. Initial implementation by Paul
Brook with some renaming by Catalin Marinas.
Signed-off-by: Paul Brook <paul@codesourcery.com>
Jon Eibertzon writes:
> We have noticed that the I-cache is disabled while waiting for
> interrupt in cpu_arm926_do_idle in arch/arm/mm/proc-arm926.S
> and we are curious to know why, because this causes us a great
> performance hit when executing in FIQ-handlers. Is it assumed
> here that every individual FIQ-handler re-enables the I-cache?
The I-cache disable is an errata workaround, so the solution is to
disable FIQs across the section with the I-cache disabled.
L_PTE_ASID is not really required to be stored in every PTE, since we
can identify it via the address passed to set_pte_at(). So, create
set_pte_ext() which takes the address of the PTE to set, the Linux
PTE value, and the additional CPU PTE bits which aren't encoded in
the Linux PTE value.
Don't set HWCAP_VFP in the processor support file; not only does it
depend on the processor features, but it also depends on the support
code being present. Therefore, only set it if the support code
detects that we have a VFP coprocessor attached.
Also, move the VFP handling of the coprocessor access register into
the VFP support code.
These files want to provide/access ELF hwcap information, so should
be including asm/elf.h rather than asm/procinfo.h
Patch from Catalin Marinas
The ARM926EJ-S CPU has the VFP coprocessor and therefore it should be shown
in the /proc/cpuinfo if CONFIG_VFP is enabled.
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (44 commits)
[ARM] 3541/2: workaround for PXA27x erratum E7
[ARM] nommu: provide a way for correct control register value selection
[ARM] 3705/1: add supersection support to ioremap()
[ARM] 3707/1: iwmmxt: use the generic thread notifier infrastructure
[ARM] 3706/2: ep93xx: add cirrus logic edb9315a support
[ARM] 3704/1: format IOP Kconfig with tabs, create more consistency
[ARM] 3703/1: Add help description for ARCH_EP80219
[ARM] 3678/1: MMC: Make OMAP MMC work
[ARM] 3677/1: OMAP: Update H2 defconfig
[ARM] 3676/1: ARM: OMAP: Fix dmtimers and timer32k to compile on OMAP1
[ARM] Add section support to ioremap
[ARM] Fix sa11x0 SDRAM selection
[ARM] Set bit 4 on section mappings correctly depending on CPU
[ARM] 3666/1: TRIZEPS4 [1/5] core
ARM: OMAP: Multiplexing for 24xx GPMC wait pin monitoring
ARM: OMAP: Fix SRAM to use MT_MEMORY instead of MT_DEVICE
ARM: OMAP: Update dmtimers
ARM: OMAP: Make clock variables static
ARM: OMAP: Fix GPMC compilation when DEBUG is defined
ARM: OMAP: Mux updates for external DMA and GPIO
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
On some CPUs, bit 4 of section mappings means "update the
cache when written to". On others, this bit is required to
be one, and others it's required to be zero. Finally, on
ARMv6 and above, setting it turns on "no execute" and prevents
speculative prefetches.
With all these combinations, no one value fits all CPUs, so we
have to pick a value depending on the CPU type, and the area
we're mapping.
Most MMU-based CPUs have a restriction on the setting of the data cache
enable and mmu enable bits in the control register, whereby if the data
cache is enabled, the MMU must also be enabled. Enabling the data
cache without the MMU is an invalid combination.
However, there are CPUs where the data cache can be enabled without the
MMU.
In order to allow these CPUs to take advantage of that, provide a
method whereby each proc-*.S file defines the control regsiter value
for use with nommu (with the MMU disabled.) Later on, when we add
support for enabling the MMU on these devices, we can adjust the
"crval" macro to also enable the data cache for nommu.
The "id(wb)BRR" suffix reports which CPU debugging options were (or
were not) selected at kernel build time. Rather than have every
proc-*.S file implement this, report the control register value,
from which this information can be deduced.
In noMMU mode, various of functions which are defined in mm/proc-*.S
is not valid or needed to be avoided. i.g. switch_mm is not needed,
just returns and this makes the I & D caches are valid which shows
great improvement of performance including task switching and IPC.
Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com>
Fix merge conflict in arch/arm/mm/proc-xscale.S
asm/hardware.h is not required for the majority of processor support
files, ioremap support, mm initialisation, acorn IO support, nor
the debug code (which picks up its machine specific includes via
debug-macros.S)
Move the hardware PMD and PTE page table definitions from pgtable.h
into pgtable-hwdef.h, and include pgtable-hwdef.h as necessary.
Patch from Ben Dooks
The `make buildcheck` is erroneously reporting that the .proc.info
list is referencing items in the .init section as it is not itself
postfixed with .init
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
infrastructure for it.
Let it rip!
