Convert the W90x900 24-bit down-counting clocksource to the generic
mmio clocksource infrastructure
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
To be able to relocate the .bss section at run time independently from
the rest of the code, we must make sure that no GOTOFF relocations are
used with .bss symbols. This usually means that no global variables can
be marked static unless they're also const.
Let's remove the static qualifier from current offenders, or turn them
into const variables when possible. Next commit will ensure the build
fails if one of those is reintroduced due to otherwise enforced coding
standards for the kernel.
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Tested-by: Tony Lindgren <tony@atomide.com>
Use irq_set_chip_and_handler() instead. Converted with coccinelle.
Convert to the new function names. Automated with coccinelle.
This uncouple PHYS_OFFSET from the platform definitions, thereby
facilitating run-time computation of the physical memory offset.
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-by: Viresh Kumar <viresh.kumar@st.com>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Acked-by: Magnus Damm <damm@opensource.se>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Acked-by: Eric Miao <eric.y.miao@gmail.com>
Acked-by: Jiandong Zheng <jdzheng@broadcom.com>
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
arch/arm/Kconfig
arch/arm/common/Makefile
arch/arm/kernel/Makefile
arch/arm/kernel/smp.c
In d7e81c2 (clocksource: Add clocksource_register_hz/khz interface) new
interfaces were added which simplify (and optimize) the selection of the
divisor shift/mult constants. Switch over to using this new interface.
Acked-by: Wan zongshun <mcuos.com@gmail.com>
factorise some generic infrastructure to assist looking up struct clks
for the ARM & SH architecture.
as the code is identical at 99%
put the arch specific code for allocation as example in asm/clkdev.h
Acked-by: Paul Mundt <lethal@linux-sh.org>
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Acked-by: Eric Miao <eric.miao at canonical.com>
This patch is to add i2c driver support for nuc900.
Signed-off-by: Wan ZongShun <mcuos.com@gmail.org>
Reviewed-by: Marek Vasut <marek.vasut@gmail.com>
Reviewed-by: Baruch Siach <baruch@tkos.co.il>
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
'pl', 'spear' and 'versatile' into devel
add global control registers definition header file for nuc900
Signed-off-by: Wan ZongShun <mcuos.com@gmail.com>
This patch is to modify spi flash configuration,
the previous one can make spi driver work failed.
Add nuc900 kpi platform_device structure to nuc910_dev
This patch is to add nuc900 keypad arch platform data.
The patch re-organizes the nuc900 lcd arch platform data,
remove the lcd platform data setting from nuc950.c to dev.c
It can maximize the share codes between nuc900 series MCUs.
This patch is to fix nuc900 touchscreen clk definition bug,the .dev_id's
name should be 'nuc900-ts', it should be the same to pdev.name. or else,
the touchscreen driver will be not working well due to clock engine disabled.
Add audio support part in arch/arm/mach-w90x900
Signed-off-by: Wan ZongShun<mcuos.com@gmail.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
An LCD controller driver for nuc900s. The Linux LOGO is just fine and the
FB-Test application was ok, too.
Signed-off-by: Wang Qiang <rurality.linux@gmail.com>
Cc: Wang Zongshun <mcuos.com@gmail.com>
Cc: Krzysztof Helt <krzysztof.h1@poczta.fm>
'pending-dma-streaming', 'u300' and 'umc' into devel
NUC900 add gpio virtual memory map
Signed-off-by: Wang Zongshun <mcuos.com@gmail.com>
Enable timer0 to time4 clock support for nuc910
Makes it consistent with VMALLOC_START
Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Signed-off-by: Andreas Fenkart <andreas.fenkart@streamunlimited.com>
Most machine classes want some way to register a block of clk_lookup
structures, and most do it by implementing a clks_register() type
function which walks an array, or by open-coding a loop.
Consolidate all this into clkdev_add_table().
Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com>
Implement arch_reset(), reboot from shell become possible.
Signed-off-by: lijie <eltshanli@gmail.com>
This patch fix following bugs:
1. typo error, CLOCK_EVT_MODE_PERIODIC -> CLOCK_EVT_FEAT_PERIODIC
2. TCSR register of timer1 missed PRESCALE
3. timer1 should be enabled before register it to clock source.
Fix bug of uart0 platfrom data for nuc900
putc support for nuc900
fix compiling error for NUC900
* 'next-spi' of git://git.secretlab.ca/git/linux-2.6: (23 commits)
spi: fix probe/remove section markings
Add OMAP spi100k driver
spi-imx: don't access struct device directly but use dev_get_platdata
spi-imx: Add mx25 support
spi-imx: use positive logic to distinguish cpu variants
spi-imx: correct check for platform_get_irq failing
ARM: NUC900: Add spi driver support for nuc900
spi: SuperH MSIOF SPI Master driver V2
spi: fix spidev compilation failure when VERBOSE is defined
spi/au1550_spi: fix setupxfer not to override cfg with zeros
spi/mpc8xxx: don't use __exit_p to wrap plat_mpc8xxx_spi_remove
spi/i.MX: fix broken error handling for gpio_request
spi/i.mx: drain MXC SPI transfer buffer when probing device
MAINTAINERS: add SPI co-maintainer.
spi/xilinx_spi: fix incorrect casting
spi/mpc52xx-spi: minor cleanups
xilinx_spi: add a platform driver using the xilinx_spi common module.
xilinx_spi: add support for the DS570 IP.
xilinx_spi: Switch to iomem functions and support little endian.
xilinx_spi: Split into of driver and generic part.
add spi resource support
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (52 commits)
Input: bcm5974 - silence uninitialized variables warnings
Input: wistron_btns - add keymap for AOpen 1557
Input: psmouse - use boolean type
Input: i8042 - use platform_driver_probe
Input: i8042 - use boolean type where it makes sense
Input: i8042 - try disabling and re-enabling AUX port at close
Input: pxa27x_keypad - allow modifying keymap from userspace
Input: sunkbd - fix formatting
Input: i8042 - bypass AUX IRQ delivery test on laptops
Input: wacom_w8001 - simplify querying logic
Input: atkbd - allow setting force-release bitmap via sysfs
Input: w90p910_keypad - move a dereference below a NULL test
Input: add twl4030_keypad driver
Input: matrix-keypad - add function to build device keymap
Input: tosakbd - fix cleaning up KEY_STROBEs after error
Input: joydev - validate axis/button maps before clobbering current ones
Input: xpad - add USB ID for the drumkit controller from Rock Band
Input: w90p910_keypad - rename driver name to match platform
Input: add new driver for Sentelic Finger Sensing Pad
Input: psmouse - allow defining read-only attributes
Add nuc960 platform to w90x900.
Add nuc950 platform to w90x900.
Add the cpu.c and dev.c and modify w90p910 platform
to apply to use the common API(provided by cpu.c and dev.c)
at the same time, I renamed all w90x900 to nuc900 in every
c file of w90x900 platform and touchscreen's driver name.
The semaphore is used as mutex so make it a mutex.
Add clocksource/clockevent support for w90p910 platform.
Also have the driver send MSC_SCAN events as most keyboards do to aid
in updating keymap from userspace.
Tested-by: Wan ZongShun <mcuos.com@gmail.com>
Add keypad driver for the 4x4 keypad on an evaluation board based
on w90p910.
Reviewed-by: Trilok Soni <soni.trilok@gmail.com>
Add static setting cpu frequence for w90p910 platform.
Add wdt resource for w90p910 platform.
Add spi mfp api for w90p910 spi driver.
Add spi resource define for w90p910 spi driver.
When programming clock api, I named this spi device
as w90p910-usi, now, I think named it as w90p910-spi better
Add mac resource define for w90p910 mac driver.
