path: root/arch/arm/mach-vexpress
2011-05-23Merge branches 'consolidate-clksrc', 'consolidate-flash', ↵Russell King
'consolidate-generic', 'consolidate-smp', 'consolidate-stmp' and 'consolidate-zones' into consolidate
2011-05-23clockevents: ARM sp804: obtain sp804 timer rate via clksRussell King
This allows platforms to specify the rate of the SP804 clockevent via the clk subsystem. While ARM boards clock these at 1MHz, BCMRing also has SP804 timers but are clocked at different rates. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-23clockevents: ARM sp804: allow clockevent name to be specifiedRussell King
This allows platforms to specify the clcokevent name upon registration. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-23clocksource: ARM sp804: obtain sp804 timer rate via clksRussell King
This allows platforms to specify the rate of the SP804 clocksource via the clk subsystem. While ARM boards clock these at 1MHz, BCMRing also has SP804 timers but are clocked at different rates. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-23clocksource: ARM sp804: allow clocksource name to be specifiedRussell King
This allows platforms to specify the clocksource name upon registration, which is necessary should they wish to register more than one sp804 clocksource. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-23ARM: consolidate SMP cross call implementationRussell King
Rather than having each platform class provide a mach/smp.h header for smp_cross_call(), arrange for them to register the function with the core ARM SMP code instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-20ARM: 6910/1: MTD: physmap: let set_vpp() pass a platform_device instead of a ↵Marc Zyngier
map_info The set_vpp() method provided by physmap passes a map_info back to the platform code, which has little relevance as far as the platform is concerned (this parameter is completely unused). Instead, pass the platform_device, which can be used in the pismo driver to retrieve some important information in a nicer way, instead of the hack that was in place. The empty set_vpp function in board-at572d940hf_ek.c is left untouched, as the board/SoC is scheduled for removal. Cc: Andrew Victor <linux@maxim.org.za> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Philipp Zabel <philipp.zabel@gmail.com> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Acked-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-20ARM: 6909/1: VExpress: Use physmap driver instead of integrator-flashMarc Zyngier
Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-03-20ARM: 6771/1: vexpress: add support for multiple core tilesWill Deacon
The current Versatile Express BSP defines the MACHINE_START macro in the core tile code. This patch moves this into the generic board code and introduces a method for determining the current tile at runtime, allowing the Kernel to have support for multiple tiles compiled in. Tile-specific functions are executed via a descriptor struct containing the correct implementations for the current tile. Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-03-20Merge branches 'fixes', 'pgt-next' and 'versatile' into develRussell King
2011-02-27ARM: 6751/1: vexpress: select applicable errata workarounds in KconfigWill Deacon
The Cortex-A9 tile on the Versatile Express suffers from a number of engineering errata. This patch selects workarounds in the ARCH_VEXPRESS_CA9X4 Kconfig entry so that users don't need to worry about which ones to apply. Reported-by: Ulrich Weigand <ulrich.weigand@de.ibm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-19ARM: realview/vexpress: consolidate SMP bringup codeRussell King
Realview and Versatile Express share the same SMP bringup code, so consolidate the two implementations. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-19ARM: realview/vexpress: consolidate localtimer supportRussell King
Realview and Versatile Express local timer support is identical, so consolidate the implementations. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-19ARM: vexpress: use new init_early for clock tree and sched_clock initRussell King
Initialize the clock tree and our sched_clock() early. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-19ARM: vexpress: switch Versatile Express to use consolidated CLCDRussell King
This switches Versatile Express to use the conslidated CLCD panel support, including the display capabilities. As Versatile Express uses a PL111, it can support the full range of pixel formats - 444, 5551, 565 in both RGB and BGR mode. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-17ARM: P2V: avoid initializers and assembly using PHYS_OFFSETRussell King
As PHYS_OFFSET will be becoming a variable, we can't have it used in initializers nor assembly code. Replace those in generic code with a run-time initialization. Replace those in platform code using the individual platform specific PLAT_PHYS_OFFSET. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: David Brown <davidb@codeaurora.org> Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-17ARM: P2V: separate PHYS_OFFSET from platform definitionsRussell King
This uncouple PHYS_OFFSET from the platform definitions, thereby facilitating run-time computation of the physical memory offset. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Magnus Damm <damm@opensource.se> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-25ARM: 6633/1: vexpress: register platform PATA device.Nick Bowler
The compactflash device on this platform is not usable simply because it is never registered with the kernel. Fix that up. Signed-off-by: Nick Bowler <nbowler@elliptictech.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-25ARM: 6635/2: Configure reference clock for Versatile Express timersPawel Moll
Timers on Versatile Express mainboard are used as system clock/event sources. Driver assumes that they are clocked with 1MHz signal. Old V2M firmware apparently configured it by default, but on newer boards one can observe that "sleep 1" command takes over 30 seconds to finish, as the timers are fed with 32kHz instead... This patch performs required magic and also removes code clearing timer's control registers, as exactly the same operations are performed by the timer driver few jiffies later. Signed-off-by: Pawel Moll <pawel.moll@arm.com> Tested-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-25ARM: realview,vexpress: fix section mismatch warning for pen_releaseRussell King
Fix two section mismatch warnings in the platform SMP bringup code for Realview and Versatile Express: WARNING: arch/arm/mach-realview/built-in.o(.text+0x8ac): Section mismatch in reference from the function write_pen_release() to the variable .cpuinit.data:pen_release The function write_pen_release() references the variable __cpuinitdata pen_release. This is often because write_pen_release lacks a __cpuinitdata annotation or the annotation of pen_release is wrong. WARNING: arch/arm/mach-vexpress/built-in.o(.text+0x7b4): Section mismatch in reference from the function write_pen_release() to the variable .cpuinit.data:pen_release The function write_pen_release() references the variable __cpuinitdata pen_release. This is often because write_pen_release lacks a __cpuinitdata annotation or the annotation of pen_release is wrong. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-06Merge branch 'misc' into develRussell King
Conflicts: arch/arm/Kconfig arch/arm/common/Makefile arch/arm/kernel/Makefile arch/arm/kernel/smp.c
2011-01-06Merge branch 'smp' into miscRussell King
Conflicts: arch/arm/kernel/entry-armv.S arch/arm/mm/ioremap.c
2011-01-05Merge branch 'clksrc' into develRussell King
Conflicts: arch/arm/mach-vexpress/v2m.c arch/arm/plat-omap/counter_32k.c arch/arm/plat-versatile/Makefile
2011-01-05Merge branches 'ftrace', 'gic', 'io', 'kexec', 'mod', 'sa11x0', 'sh' and ↵Russell King
2011-01-05ARM: vexpress: add sched_clock() for Versatile ExpressRussell King
Add a sched_clock() implementation to Versatile Express using the new sched_clock() infrastructure for extending 32bit counters to full 64-bit nanoseconds. Tested-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-20ARM: CPU hotplug: add Versatile Express hotplug CPU supportRussell King
2010-12-20ARM: Fix subtle race in CPU pen_release hotplug codeRussell King
There is a subtle race in the CPU hotplug code, where a CPU which has been offlined can online itself before being requested, which results in things going astray on the next online/offline cycle. What happens in the normal online/offline/online cycle is: CPU0 CPU3 requests boot of CPU3 pen_release = 3 flush cache line checks pen_release, reads 3 starts boot pen_release = -1 ... requests CPU3 offline ... ... dies ... checks pen_release, reads -1 requests boot of CPU3 pen_release = 3 flush cache line checks pen_release, reads 3 starts boot pen_release = -1 However, as the write of -1 of pen_release is not fully flushed back to memory, and the checking of pen_release is done with caches disabled, this allows CPU3 the opportunity to read the old value of pen_release: CPU0 CPU3 requests boot of CPU3 pen_release = 3 flush cache line checks pen_release, reads 3 starts boot pen_release = -1 ... requests CPU3 offline ... ... dies ... checks pen_release, reads 3 starts boot pen_release = -1 requests boot of CPU3 pen_release = 3 flush cache line Fix this by grouping the write of pen_release along with its cache line flushing code to ensure that any update to pen_release is always pushed out to physical memory. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-20ARM: SMP: remove smp_mpidr.hRussell King
With "ARM: CPU hotplug: remove bug checks in platform_cpu_die()", we now do not use hard_smp_processor_id(), we no longer need to read the hardware processor ID. Remove the include providing this function. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-20ARM: SMP: consolidate trace_hardirqs_off() into common SMP codeRussell King
All platforms call trace_hardirqs_off() in their secondary startup code, so move this into the core SMP code - it doesn't need to be in the per-platform code. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-20ARM: SMP: consolidate the common parts of smp_prepare_cpus()Russell King
There is a certain amount of smp_prepare_cpus() which doesn't belong in the platform support code - that is, code which is invariant to the SMP implementation. Move this code into arch/arm/kernel/smp.c, and add a platform_ prefix to the original function. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-20ARM: SMP: Clean up ncores sanity checksRussell King
scu_get_core_count() never returns zero cores, so we don't need to check and correct if ncores is zero. Tegra was missing the check against NR_CPUS, leading to a potential bitfield overflow if this becomes the case. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-14ARM: GIC: private a standard get_irqnr_preamble assembler macroRussell King
Provide a standard get_irqnr_preamble assembler macro for platforms to use, which retrieves the base address of the GIC CPU interface from gic_cpu_base_addr. Allow platforms to override this by defining HAVE_GET_IRQNR_PREAMBLE. Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Tested-by: Abhijeet Dharmapurikar <adharmap@codeaurora.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-14ARM: GIC: consolidate gic_cpu_base_addr to common GIC codeRussell King
Every architecture using the GIC has a gic_cpu_base_addr pointer for GIC 0 for their entry assembly code to use to decode the cause of the current interrupt. Move this into the common GIC code. Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Tested-by: Abhijeet Dharmapurikar <adharmap@codeaurora.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-14ARM: GIC: Remove MMIO address from gic_cpu_init, rename to gic_secondary_initRussell King
We don't need to re-pass the base address for the CPU interfaces to the GIC for secondary CPUs, as it will never be different from the boot CPU - and even if it was, we'd overwrite the boot CPU's base address. Get rid of this argument, and rename to gic_secondary_init(). Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Tested-by: Abhijeet Dharmapurikar <adharmap@codeaurora.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-14ARM: GIC: provide a single initialization function for boot CPURussell King
Provide gic_init() which initializes the GIC distributor and current CPU's GIC interface for the boot (or single) CPU. Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Tested-by: Abhijeet Dharmapurikar <adharmap@codeaurora.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-07ARM: 6480/1: Use shared GIC entry macros on VexpressMagnus Damm
Use the GIC demux code in asm/hardware/entry-macro-gic.S on the Versatile Express subarchitecture. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-03ARM: SMP: pass an ipi number to smp_cross_call()Russell King
This allows us to use smp_cross_call() to trigger a number of different software generated interrupts, rather than combining them all on one SGI. Recover the SGI number via do_IPI. Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-11-30ARM: 6508/1: vexpress: Correct data alignment in headsmp.S for ↵Dave Martin
CONFIG_THUMB2_KERNEL Directives such as .long and .word do not magically cause the assembler location counter to become aligned in gas. As a result, using these directives in code sections can result in misaligned data words when building a Thumb-2 kernel (CONFIG_THUMB2_KERNEL). This is a Bad Thing, since the ABI permits the compiler to assume that fundamental types of word size or above are word- aligned when accessing them from C. If the data is not really word-aligned, this can cause impaired performance and stray alignment faults in some circumstances. In general, the following rules should be applied when using data word declaration directives inside code sections: * .quad and .double: .align 3 * .long, .word, .single, .float: .align (or .align 2) * .short: No explicit alignment required, since Thumb-2 instructions are always 2 or 4 bytes in size. immediately after an instruction. Reviewed-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Dave Martin <dave.martin@linaro.org> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-11-26ARM: 6483/1: arm & sh: factorised duplicated clkdev.cJean-Christop PLAGNIOL-VILLARD
factorise some generic infrastructure to assist looking up struct clks for the ARM & SH architecture. as the code is identical at 99% put the arch specific code for allocation as example in asm/clkdev.h Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-11-10ARM: 6472/1: vexpress ct-ca9x4: only set twd_base if local timers are being usedWill Deacon
In commit bde28b84, I made the assumption that CONFIG_SMP is always set for the quad-core ct-ca9x4 platform. As it turns out, people who aren't using the SMP goodness are confronted with a build failure. This patch fixes this issue by ensure that twd_base is only set if local timers are being used (and therefore SMP support is configured). Reported-by: Nicolas Pitre <nicolas.pitre@linaro.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-11-04ARM: 6432/1: move timer-sp.c from versatile to commonRob Herring
From: Rob Herring <rob.herring@smooth-stone.com> The timer-sp h/w used on versatile platforms can also be used for other platforms, so move it to a common location. Signed-off-by: Rob Herring <rob.herring@smooth-stone.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-10-20arm: return both physical and virtual addresses from addruartJeremy Kerr
Rather than checking the MMU status in every instance of addruart, do it once in kernel/debug.S, and change the existing addruart macros to return both physical and virtual addresses. The main debug code can then select the appropriate address to use. This will also allow us to retreive the address of a uart for the MMU state that we're not current in. Updated with fixes for OMAP from Jason Wang <jason77.wang@gmail.com> and Tony Lindgren <tony@atomide.com>, and fix for versatile express from Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Jason Wang <jason77.wang@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-10-19Merge branch 'devel-stable' into develRussell King
2010-10-05ARM: fix section mismatch warnings in Versatile ExpressRussell King
WARNING: vmlinux.o(.text+0xbf30): Section mismatch in reference from the function v2m_timer_init() to the function .init.text:sp804_clocksource_init() The function v2m_timer_init() references the function __init sp804_clocksource_init(). This is often because v2m_timer_init lacks a __init annotation or the annotation of sp804_clocksource_init is wrong. WARNING: vmlinux.o(.text+0xbf3c): Section mismatch in reference from the function v2m_timer_init() to the function .init.text:sp804_clockevents_init() The function v2m_timer_init() references the function __init sp804_clockevents_init(). This is often because v2m_timer_init lacks a __init annotation or the annotation of sp804_clockevents_init is wrong. WARNING: vmlinux.o(.text+0xc524): Section mismatch in reference from the function ct_ca9x4_init() to the function .init.text:l2x0_init() The function ct_ca9x4_init() references the function __init l2x0_init(). This is often because ct_ca9x4_init lacks a __init annotation or the annotation of l2x0_init is wrong. WARNING: vmlinux.o(.text+0xc530): Section mismatch in reference from the function ct_ca9x4_init() to the function .init.text:clkdev_add_table() The function ct_ca9x4_init() references the function __init clkdev_add_table(). This is often because ct_ca9x4_init lacks a __init annotation or the annotation of clkdev_add_table is wrong. WARNING: vmlinux.o(.text+0xc578): Section mismatch in reference from the function ct_ca9x4_init() to the (unknown reference) .init.data:(unknown) The function ct_ca9x4_init() references the (unknown reference) __initdata (unknown). This is often because ct_ca9x4_init lacks a __initdata annotation or the annotation of (unknown) is wrong. Fix these by making ct_ca9x4_init() and v2m_timer_init() both __init. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-10-04ARM: Provide common header for hard_smp_processor_id()Russell King
Provide a common header to read the SMP CPU number from the MPIDR. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-09-27ARM: 6411/1: vexpress: set RAM latencies to 1 cycle for PL310 on ct-ca9x4 tileWill Deacon
The PL310 on the ct-ca9x4 tile for the Versatile Express does not need to add additional latency when accessing its cache RAMs. Unfortunately, the boot monitor sets this up for an 8-cycle delay on reads and writes, resulting in greatly reduced memory performance when the L2 cache is enabled. This patch sets the L2 RAM latencies to the correct value of 1 cycle on the ct-ca9x4 tile before enabling the L2 cache. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-09-17ARM: 6395/1: VExpress: Set bit 22 in the PL310 (cache controller) AuxCtlr ↵Catalin Marinas
register Clearing bit 22 in the PL310 Auxiliary Control register (shared attribute override enable) has the side effect of transforming Normal Shared Non-cacheable reads into Cacheable no-allocate reads. Coherent DMA buffers in Linux always have a Cacheable alias via the kernel linear mapping and the processor can speculatively load cache lines into the PL310 controller. With bit 22 cleared, Non-cacheable reads would unexpectedly hit such cache lines leading to buffer corruption. Cc: Nicolas Pitre <nicolas.pitre@linaro.org> Cc: <stable@kernel.org> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-08-03Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (291 commits) ARM: AMBA: Add pclk support to AMBA bus infrastructure ARM: 6278/2: fix regression in RealView after the introduction of pclk ARM: 6277/1: mach-shmobile: Allow users to select HZ, default to 128 ARM: 6276/1: mach-shmobile: remove duplicate NR_IRQS_LEGACY ARM: 6246/1: mmci: support larger MMCIDATALENGTH register ARM: 6245/1: mmci: enable hardware flow control on Ux500 variants ARM: 6244/1: mmci: add variant data and default MCICLOCK support ARM: 6243/1: mmci: pass power_mode to the translate_vdd callback ARM: 6274/1: add global control registers definition header file for nuc900 mx2_camera: fix type of dma buffer virtual address pointer mx2_camera: Add soc_camera support for i.MX25/i.MX27 arm/imx/gpio: add spinlock protection ARM: Add support for the LPC32XX arch ARM: LPC32XX: Arch config menu supoport and makefiles ARM: LPC32XX: Phytec 3250 platform support ARM: LPC32XX: Misc support functions ARM: LPC32XX: Serial support code ARM: LPC32XX: System suspend support ARM: LPC32XX: GPIO, timer, and IRQ drivers ARM: LPC32XX: Clock driver ...
2010-07-31Merge branches 'at91', 'ep93xx', 'kexec', 'iop', 'lmb', 'nomadik', 'nuc', ↵Russell King
'pl', 'spear' and 'versatile' into devel
