path: root/arch/arm/mach-u300
2011-11-03Merge branch 'for-next' of git://git.infradead.org/users/sameo/mfd-2.6Linus Torvalds
* 'for-next' of git://git.infradead.org/users/sameo/mfd-2.6: (80 commits) mfd: Fix missing abx500 header file updates mfd: Add missing <linux/io.h> include to intel_msic x86, mrst: add platform support for MSIC MFD driver mfd: Expose TurnOnStatus in ab8500 sysfs mfd: Remove support for early drop ab8500 chip mfd: Add support for ab8500 v3.3 mfd: Add ab8500 interrupt disable hook mfd: Convert db8500-prcmu panic() into pr_crit() mfd: Refactor db8500-prcmu request_clock() function mfd: Rename db8500-prcmu init function mfd: Fix db5500-prcmu defines mfd: db8500-prcmu voltage domain consumers additions mfd: db8500-prcmu reset code retrieval mfd: db8500-prcmu tweak for modem wakeup mfd: Add db8500-pcmu watchdog accessor functions for watchdog mfd: hwacc power state db8500-prcmu accessor mfd: Add db8500-prcmu accessors for PLL and SGA clock mfd: Move to the new db500 PRCMU API mfd: Create a common interface for dbx500 PRCMU drivers mfd: Initialize DB8500 PRCMU regs ... Fix up trivial conflicts in arch/arm/mach-imx/mach-mx31moboard.c arch/arm/mach-omap2/board-omap3beagle.c arch/arm/mach-u300/include/mach/irqs.h drivers/mfd/wm831x-spi.c
2011-11-01Merge branch 'next/cleanup' of git://git.linaro.org/people/arnd/arm-socLinus Torvalds
* 'next/cleanup' of git://git.linaro.org/people/arnd/arm-soc: (125 commits) ARM: mach-mxs: fix machines' initializers order mmc: mxcmmc: explicitly includes mach/hardware.h arm/imx: explicitly includes mach/hardware.h in pm-imx27.c arm/imx: remove mx27_setup_weimcs() from mx27.h arm/imx: explicitly includes mach/hardware.h in mach-kzm_arm11_01.c arm/imx: remove mx31_setup_weimcs() from mx31.h ARM: tegra: devices.c should include devices.h ARM: tegra: cpu-tegra: unexport two functions ARM: tegra: cpu-tegra: sparse type fix ARM: tegra: dma: staticify some tables and functions ARM: tegra: tegra2_clocks: don't export some tables ARM: tegra: tegra_powergate_is_powered should be static ARM: tegra: tegra_rtc_read_ms should be static ARM: tegra: tegra_init_cache should be static ARM: tegra: pcie: 0 -> NULL changes ARM: tegra: pcie: include board.h ARM: tegra: pcie: don't cast __iomem pointers ARM: tegra: tegra2_clocks: 0 -> NULL changes ARM: tegra: tegra2_clocks: don't cast __iomem pointers ARM: tegra: timer: don't cast __iomem pointers ... Fix up trivial conflicts in arch/arm/mach-omap2/Makefile, arch/arm/mach-u300/{Makefile.boot,core.c} arch/arm/plat-{mxc,omap}/devices.c
2011-10-31Merge branch 'next/fixes' into next/cleanupArnd Bergmann
Conflicts: arch/arm/mach-mxs/include/mach/gpio.h arch/arm/plat-mxc/include/mach/gpio.h drivers/video/omap/lcd_apollon.c drivers/video/omap/lcd_ldp.c drivers/video/omap/lcd_overo.c
2011-10-31Merge branch 'depends/rmk/memory_h' into next/fixesArnd Bergmann
Fix up all conflicts between the memory.h cleanup and bug fixes. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-10-29ARM: mark empty gpio.h files emptyLinus Walleij
It is generally a better idea to make intentionally empty files contain the human-readable /* empty */ comment, also it makes the files play nice with "make distclean". Reported-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-10-28Merge branch 'devel-stable' of ↵Linus Torvalds
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'devel-stable' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (178 commits) ARM: 7139/1: fix compilation with CONFIG_ARM_ATAG_DTB_COMPAT and large TEXT_OFFSET ARM: gic, local timers: use the request_percpu_irq() interface ARM: gic: consolidate PPI handling ARM: switch from NO_MACH_MEMORY_H to NEED_MACH_MEMORY_H ARM: mach-s5p64x0: remove mach/memory.h ARM: mach-s3c64xx: remove mach/memory.h ARM: plat-mxc: remove mach/memory.h ARM: mach-prima2: remove mach/memory.h ARM: mach-zynq: remove mach/memory.h ARM: mach-bcmring: remove mach/memory.h ARM: mach-davinci: remove mach/memory.h ARM: mach-pxa: remove mach/memory.h ARM: mach-ixp4xx: remove mach/memory.h ARM: mach-h720x: remove mach/memory.h ARM: mach-vt8500: remove mach/memory.h ARM: mach-s5pc100: remove mach/memory.h ARM: mach-tegra: remove mach/memory.h ARM: plat-tcc: remove mach/memory.h ARM: mach-mmp: remove mach/memory.h ARM: mach-cns3xxx: remove mach/memory.h ... Fix up mostly pretty trivial conflicts in: - arch/arm/Kconfig - arch/arm/include/asm/localtimer.h - arch/arm/kernel/Makefile - arch/arm/mach-shmobile/board-ap4evb.c - arch/arm/mach-u300/core.c - arch/arm/mm/dma-mapping.c - arch/arm/mm/proc-v7.S - arch/arm/plat-omap/Kconfig largely due to some CONFIG option renaming (ie CONFIG_PM_SLEEP -> CONFIG_ARM_CPU_SUSPEND for the arm-specific suspend code etc) and addition of NEED_MACH_MEMORY_H next to HAVE_IDE.
2011-10-27Merge branch 'gpio' of ↵Linus Torvalds
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'gpio' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (43 commits) ARM: 7135/1: ep93xx: bring back missing <mach/gpio.h> ARM: 7104/1: plat-pxa: break out GPIO driver specifics ARM: 7103/1: plat-pxa: move PXA GPIO driver to GPIO subsystem ARM: 7042/3: mach-ep93xx: break out GPIO driver specifics ARM: 7101/1: arm/tegra: Replace <mach/gpio.h> with <mach/gpio-tegra.h> ARM: 7094/1: arm/tegra: Move EN_VDD_1V05_GPIO to board-harmony.h ARM: 7083/1: rewrite U300 GPIO to use gpiolib ARM: 7074/1: gpio: davinci: eliminate unused variable warnings ARM: 7063/1: Orion: gpio: add missing include of linux/types.h ARM: 7055/1: arm/tegra: mach/gpio.h: include linux/types.h to fix build ARM: 7054/1: arm/tegra: Delete custom gpio_to_irq, and irq_to_gpio ARM: 7053/1: gpio/tegra: Implement gpio_chip.to_irq ARM: 7052/1: gpio/tegra: Remove use of irq_to_gpio ARM: 7057/1: mach-pnx4008: rename GPIO header ARM: 7056/1: plat-nomadik: kill off <plat/gpio.h> ARM: 7050/1: mach-sa1100: delete irq_to_gpio() function ARM: 7049/1: mach-sa1100: move SA1100 GPIO driver to GPIO subsystem ARM: 7045/1: mach-lpc32xx: break out GPIO driver specifics ARM: 7044/1: mach-lpc32xx: move LPC32XX GPIO driver to GPIO subsystem ARM: 7043/1: mach-ixp2000: rename GPIO header ... Fix up trivial conflicts in arch/arm/mach-u300/Kconfig manually
2011-10-25Merge branch 'for-next' of git://git.linaro.org/people/triad/linux-pinctrlLinus Torvalds
* 'for-next' of git://git.linaro.org/people/triad/linux-pinctrl: pinctrl/sirf: fix sirfsoc_get_group_pins prototype pinctrl: Don't copy function name when requesting a pin pinctrl: Don't copy pin names when registering them pinctrl: Remove unsafe __refdata pinctrl: get_group_pins() const fixes pinctrl: add a driver for the CSR SiRFprimaII pinmux pinctrl: add a driver for the U300 pinmux drivers: create a pin control subsystem
2011-10-24mfd: Delete ab3550 driverLinus Walleij
The AB3550 never passed the prototype stage. Instead it was used as a precursor to AB5500 for testing basic building blocks used in that chip, since they had large similarities. Since AB3550 will not see the light of day in product form and since the prototypes are no longer used, let's delete the driver and any references to it. Cc: Mattias Wallin <mattias.wallin@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-10-17ARM: 7022/1: allow to detect conflicting zreladdrsSascha Hauer
Boards used to specify zreladdr in their Makefile.boot with zreladdr-y := x, so conflicting zreladdrs were silently overwritten. This patch changes this to zreladdr-y += x, so that we end up with multiple words in zreladdr in such a case. We can detect this later and complain if necessary. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-10-13pinctrl: add a driver for the U300 pinmuxLinus Walleij
This adds a driver for the U300 pinmux portions of the system controller "SYSCON". It also serves as an example of how to use the pinmux subsystem. This driver also houses the platform data for the only supported platform. This deletes the old U300 driver in arch/arm/mach-u300 and replace it with a driver using the new subsystem. The new driver is considerably fatter than the old one, but it also registers all 467 pins of the system and adds the power and EMIF pin groups and corresponding functions. The idea is to use this driver as a a reference for other implementation so it needs to be as complete and verbose as possible. Reviewed-by: Barry Song <21cnbao@gmail.com> [Fixup for changed function names and semantics in the v10 patch] Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-10-08Merge branch 'depends/rmk/devel-stable' into next/cleanupArnd Bergmann
2011-09-26ARM: add an extra temp register to the low level debugging addruart macroNicolas Pitre
Some platforms (like OMAP not to name it) are doing rather complicated hacks just to determine the base UART address to use. Let's give their addruart macro some slack by providing an extra work register which will allow for much needed cleanups. This is basically a no-op as this commit is only adding the extra argument to the macro but no one is using it yet. Signed-off-by: nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-09-08ARM: 7083/1: rewrite U300 GPIO to use gpiolibLinus Walleij
This rewrites the U300 GPIO so as to use gpiolib and struct gpio_chip instead of just generic GPIO, hiding all the platform specifics and passing in GPIO chip variant as platform data at runtime instead of the compiletime kludges. As a result <mach/gpio.h> is now empty for U300 and using just defaults. Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Debian kernel maintainers <debian-kernel@lists.debian.org> Cc: Arnaud Patard <arnaud.patard@rtp-net.org> Reported-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-08-23Merge branch 'atag_offset' of git://git.linaro.org/people/nico/linux into ↵Russell King
devel-stable
2011-08-22ARM: mach-u300: Setup consistent dma size at boot timeJon Medhurst
Signed-off-by: Jon Medhurst <tixy@yxit.co.uk> Acked-by: Linus Walleij <linus.walleij@stericsson.com>
2011-08-22ARM: 7034/1: mach-u300: delete irq_to_gpio() functionLinus Walleij
This function is not used in the U300 build, and on the whole the call is hard to consolidate so get rid of it from this machine. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-08-22ARM: 7033/1: mach-u300: break out GPIO driver specificsLinus Walleij
The <mach/gpio.h> file is included from upper directories and deal with generic GPIO and gpiolib stuff. Break out the platform and driver specific defines and functions into its own header file. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-08-21ARM: mach-u300: convert boot_params to atag_offsetNicolas Pitre
Someone was smoking good stuff with CONFIG_MACH_U300_2MB_ALIGNMENT_FIX here... Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-08-17mach-u300: retire AVE deviceLinus Walleij
We need to face the fact that there will never be a mainlined driver for the U300 advanced video encoder, so let's just drop the declaration of this device. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-08-17mach-u300: delete bogus memory mappingsLinus Walleij
Get rid of the bogus memory map to TCM (there is a real mechanism for handling that nowadays!) and the commented- out declaration of the ROM. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-08-17mach-u300: drop SEMI config optionLinus Walleij
When we have only dual-RAM configurations, the SEMI (shared memory interface) must always be enabled. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-08-17mach-u300: retire odd singlemem variantLinus Walleij
The U300 had a special variant where a memory was shared between two CPU:s and only one part of memory was accessible for the kernel. However it is now seriously legacy and only create problems for kernel consolidation, so let's retire it. Cc: Nicolas Pitre <nico@fluxnic.net> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-08-12ARM: gpio: make trivial GPIOLIB implementation the defaultRussell King
Rather than marking the mach/gpio.h header files which want to use the trivial GPIOLIB implementation, mark those which do not want to use it instead. This means that by default, you get the trivial implementation and only have to do something extra if you need to. This should encourage the use of the trivial default implementation. As an additional bonus, several gpio.h header files become empty. Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Tested-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-08-12ARM: gpio: consolidate gpio_to_irqRussell King
Many of the gpio_to_irq implementations use the gpiolib version of this function. Provide the standard gpiolib gpio_to_irq() for everyone, but allow platforms to override it if they wish. Add the neccessary overrides for those platforms which do not use the standard definition. Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-26Merge branch 'next/devel' of ↵Linus Torvalds
ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/devel' of ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (128 commits) ARM: S5P64X0: External Interrupt Support ARM: EXYNOS4: Enable MFC on Samsung NURI ARM: EXYNOS4: Enable MFC on universal_c210 ARM: S5PV210: Enable MFC on Goni ARM: S5P: Add support for MFC device ARM: EXYNOS4: Add support FIMD on SMDKC210 ARM: EXYNOS4: Add platform device and helper functions for FIMD ARM: EXYNOS4: Add resource definition for FIMD ARM: EXYNOS4: Change devname for FIMD clkdev ARM: SAMSUNG: Add IRQ_I2S0 definition ARM: SAMSUNG: Add platform device for idma ARM: EXYNOS4: Add more registers to be saved and restored for PM ARM: EXYNOS4: Add more register addresses of CMU ARM: EXYNOS4: Add platform device for dwmci driver ARM: EXYNOS4: configure rtc-s3c on NURI ARM: EXYNOS4: configure MAX8903 secondary charger on NURI ARM: EXYNOS4: configure ADC on NURI ARM: EXYNOS4: configure MAX17042 fuel gauge on NURI ARM: EXYNOS4: configure regulators and PMIC(MAX8997) on NURI ARM: EXYNOS4: Increase NR_IRQS for devices with more IRQs ... Fix up tons of silly conflicts: - arch/arm/mach-davinci/include/mach/psc.h - arch/arm/mach-exynos4/Kconfig - arch/arm/mach-exynos4/mach-smdkc210.c - arch/arm/mach-exynos4/pm.c - arch/arm/mach-imx/mm-imx1.c - arch/arm/mach-imx/mm-imx21.c - arch/arm/mach-imx/mm-imx25.c - arch/arm/mach-imx/mm-imx27.c - arch/arm/mach-imx/mm-imx31.c - arch/arm/mach-imx/mm-imx35.c - arch/arm/mach-mx5/mm.c - arch/arm/mach-s5pv210/mach-goni.c - arch/arm/mm/Kconfig
2011-07-11Merge branch 'master' into for-nextJiri Kosina
Sync with Linus' tree to be able to apply pending patches that are based on newer code already present upstream.
2011-06-23mach-u300: set apropriate FIFO trigger levelsLinus Walleij
The U300 just defined the fill level limits for the FIFOs to 1 item out of habit. It can easily handle four. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-06-23mach-u300: cleanup clockevent codeLinus Walleij
Use the new clockevents_config_and_register() function to register the U300 clockevent, since that code requires ->cpumask to be set we set this even on this UP system to please the framework. Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-06-09ARM: 6949/2: mach-u300: fix compilaton warning in IO accessorsLinus Walleij
The IO accessors for U300 were using u32 rather than the nominal void __iomem * type, rectify this by properly defining the virtual base for statically mapped peripherals to be void __iomem *. Requires fixing a field in struct clk as well. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-06-06ARM: 6947/2: mach-u300: fix compilation error in timerLinus Walleij
The introduction of the mmio timer accidentally referenced the old clocksource struct which does not exist anymore. Fix this by using a simple string instead. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-26gpio: move U300 GPIO driver to drivers/gpioLinus Walleij
This moves the U300 GPIO driver out of arch/arm/mach-u300 and into the desired location indicated by the subsystem maintainer. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-23clocksource: convert ARM 32-bit up counting clocksourcesRussell King
Convert ixp4xx, lpc32xx, mxc, netx, pxa, sa1100, tcc8k, tegra and u300 to use the generic mmio clocksource recently introduced. Cc: Imre Kaloz <kaloz@openwrt.org> Cc: Krzysztof Halasa <khc@pm.waw.pl> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: "Hans J. Koch" <hjk@hansjkoch.de> Acked-by: Colin Cross <ccross@android.com> Cc: Erik Gilling <konkers@android.com> Cc: Olof Johansson <olof@lixom.net> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-03-17Merge branch 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-arm: (289 commits) davinci: DM644x EVM: register MUSB device earlier davinci: add spi devices on tnetv107x evm davinci: add ssp config for tnetv107x evm board davinci: add tnetv107x ssp platform device spi: add ti-ssp spi master driver mfd: add driver for sequencer serial port ARM: EXYNOS4: Implement Clock gating for System MMU ARM: EXYNOS4: Enhancement of System MMU driver ARM: EXYNOS4: Add support for gpio interrupts ARM: S5P: Add function to register gpio interrupt bank data ARM: S5P: Cleanup S5P gpio interrupt code ARM: EXYNOS4: Add missing GPYx banks ARM: S3C64XX: Fix section mismatch from cpufreq init ARM: EXYNOS4: Add keypad device to the SMDKV310 ARM: EXYNOS4: Update clocks for keypad ARM: EXYNOS4: Update keypad base address ARM: EXYNOS4: Add keypad device helpers ARM: EXYNOS4: Add support for SATA on ARMLEX4210 plat-nomadik: make GPIO interrupts work with cpuidle ApSleep mach-u300: define a dummy filter function for coh901318 ... Fix up various conflicts in - arch/arm/mach-exynos4/cpufreq.c - arch/arm/mach-mxs/gpio.c - drivers/net/Kconfig - drivers/tty/serial/Kconfig - drivers/tty/serial/Makefile - drivers/usb/gadget/fsl_mxc_udc.c - drivers/video/Kconfig
2011-03-14mach-u300: define a dummy filter function for coh901318Linus Walleij
All platform data has to be made conditional on as to avoid cluttering the code with other #ifdef:s. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-03-14mach-u300: config U300 PL180 PL011 PL022 for DMALinus Walleij
This will configure the platform data for the PL180, PL011 and PL022 PrimeCells found in the U300 to use DMA with the generic PrimeCell DMA engine for COH 901 318. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-03-14mach-u300: use mmci driver for GPIO card detectLinus Walleij
The mmci driver can handle a GPIO pin for card detect, using IRQs and all just fine, so switch to using that. Delete the old bogus input device hack, if userspace need to detect MMC cards it should use udev like everyone else. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-02-17ARM: P2V: separate PHYS_OFFSET from platform definitionsRussell King
This uncouple PHYS_OFFSET from the platform definitions, thereby facilitating run-time computation of the physical memory offset. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Magnus Damm <damm@opensource.se> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2011-01-06Merge branch 'misc' into develRussell King
Conflicts: arch/arm/Kconfig arch/arm/common/Makefile arch/arm/kernel/Makefile arch/arm/kernel/smp.c
2010-12-22ARM: u300: convert sched_clock() to use new infrastructureRussell King
Convert u300 to use the new sched_clock() infrastructure for extending 32bit counters to full 64-bit nanoseconds. Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-22ARM: ensure all sched_clock() implementations are notrace markedRussell King
ftrace requires sched_clock() to be notrace. Ensure that all implementations are so marked. Also make sure that they include linux/sched.h Also ensure OMAP clocksource read functions are marked notrace as they're used for sched_clock() too. Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Mikael Pettersson <mikpe@it.uu.se> Tested-by: Eric Miao <eric.y.miao@gmail.com> Tested-by: Olof Johansson <olof@lixom.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-22ARM: U300: update clock source registrationRussell King
In d7e81c2 (clocksource: Add clocksource_register_hz/khz interface) new interfaces were added which simplify (and optimize) the selection of the divisor shift/mult constants. Switch over to using this new interface. Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-22Merge branch 'master' into for-nextJiri Kosina
Conflicts: MAINTAINERS arch/arm/mach-omap2/pm24xx.c drivers/scsi/bfa/bfa_fcpim.c Needed to update to apply fixes for which the old branch was too outdated.
2010-11-26ARM: 6483/1: arm & sh: factorised duplicated clkdev.cJean-Christop PLAGNIOL-VILLARD
factorise some generic infrastructure to assist looking up struct clks for the ARM & SH architecture. as the code is identical at 99% put the arch specific code for allocation as example in asm/clkdev.h Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-11-01Merge branch 'next-spi' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-spi' of git://git.secretlab.ca/git/linux-2.6: spi/pl022: fix erroneous platform data in U300 spi: fixed odd static string conventions in core code spi/bfin_spi: only request GPIO on first load spi/bfin_spi: handle error/status changes after data interrupts spi: enable spi_board_info to be registered after spi_master
2010-11-01spi/pl022: fix erroneous platform data in U300Linus Walleij
This fixes an erroneous use of LSB first in the U300 machine, the PL022 used in U300 is a standard ARM core that doesn't support this bit so it should never have been set. Cc: Kevin Wells <wellsk40@gmail.com>OA Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
