path: root/arch/arm/mach-tegra/fuse.c
2013-12-26Merge tag 'tegra-for-3.14-soc' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux into next/soc From Stephen Warren: ARM: tegra: SoC-specific core code changes This branch contains various miscellaneous changes to code in the mach-tegra/ directory. It is baased on v3.13-rc1, and shouldn't conflict with anything else. * tag 'tegra-for-3.14-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux: ARM: tegra: select PINCTRL_TEGRA124 for Tegra124 SoC ARM: tegra: use section-sized static mappings for LPAE too ARM: tegra: don't hard-code DEBUG_LL baud rate ARM: tegra: fix DEBUG_LL combined with LPAE ARM: tegra: switch FUSE clock on before usage Signed-off-by: Olof Johansson <olof@lixom.net>
2013-12-11ARM: tegra: add missing break to fuse initialization codeStephen Warren
Add a missing break to the switch in tegra_init_fuse() which determines which SoC the code is running on. This prevents the Tegra30+ fuse handling code from running on Tegra20. Fixes: 3bd1ae57f7bb ("ARM: tegra: add fuses as device randomness") Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-12-04ARM: tegra: switch FUSE clock on before usageAlexandre Courbot
FUSE clock is enabled by most bootloaders, but we cannot expect it to be on in all contexts (e.g. kexec). Ensure the FUSE clock is enabled before any of its registers is touched. Since FUSE is touched very early during system boot (before the clock devices are registered), directly manipulate the clock register bit in case the clock device cannot be acquired. Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-11-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: - Made x86 ablk_helper generic for ARM - Phase out chainiv in favour of eseqiv (affects IPsec) - Fixed aes-cbc IV corruption on s390 - Added constant-time crypto_memneq which replaces memcmp - Fixed aes-ctr in omap-aes - Added OMAP3 ROM RNG support - Add PRNG support for MSM SoC's - Add and use Job Ring API in caam - Misc fixes [ NOTE! This pull request was sent within the merge window, but Herbert has some questionable email sending setup that makes him public enemy #1 as far as gmail is concerned. So most of his emails seem to be trapped by gmail as spam, resulting in me not seeing them. - Linus ] * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (49 commits) crypto: s390 - Fix aes-cbc IV corruption crypto: omap-aes - Fix CTR mode counter length crypto: omap-sham - Add missing modalias padata: make the sequence counter an atomic_t crypto: caam - Modify the interface layers to use JR API's crypto: caam - Add API's to allocate/free Job Rings crypto: caam - Add Platform driver for Job Ring hwrng: msm - Add PRNG support for MSM SoC's ARM: DT: msm: Add Qualcomm's PRNG driver binding document crypto: skcipher - Use eseqiv even on UP machines crypto: talitos - Simplify key parsing crypto: picoxcell - Simplify and harden key parsing crypto: ixp4xx - Simplify and harden key parsing crypto: authencesn - Simplify key parsing crypto: authenc - Export key parsing helper function crypto: mv_cesa: remove deprecated IRQF_DISABLED hwrng: OMAP3 ROM Random Number Generator support crypto: sha256_ssse3 - also test for BMI2 crypto: mv_cesa - Remove redundant of_match_ptr crypto: sahara - Remove redundant of_match_ptr ...
2013-10-18ARM: tegra: add fuses as device randomnessStephen Warren
Various fuses on Tegra include information that's unique to an individual chip, or a subset of chips. Call add_device_randomness() with this data to perturb the initial state of the random pool. Suggested-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2013-09-24ARM: tegra: remove tegra_chip_uid()Stephen Warren
Following commit f5b38c5 "crypto: tegra - use kernel entropy instead of ad-hoc", this function is no longer used. It's also only accurate for Tegra20 and not later SoCs. So, remove it. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-09-17ARM: tegra: make tegra_init_fuse() __initStephen Warren
It's a one-time initialization function, called early during boot. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-03-19ARM: tegra: add speedo-based process id for Tegra114Danny Huang
Add speedo-based process identification for Tegra114. Based on the work by: Alex Frid <afrid@nvidia.com> Signed-off-by: Danny Huang <dahuang@nvidia.com> [swarren: added include of bug.h] Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-01-28ARM: tegra: add function to read chipidPrashant Gaikwad
Add function to read chip id from APB MISC registers. This function will also get called from clock driver to flush write operations on apb bus. Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-11-15ARM: tegra: Tegra30 speedo-based process identificationDanny Huang
This patch adds speedo-based process identification support for Tegra30. Signed-off-by: Danny Huang <dahuang@nvidia.com> [swarren s/Tegra3/Tegra30/ in log print, s/T30/Tegra30/ in commit description] Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-11-15ARM: tegra: Add speedo-based process identificationDanny Huang
Detect CPU and core process ID by checking speedo corner tables. This can provide a more accurate process ID. Signed-off-by: Danny Huang <dahuang@nvidia.com> [swarren s/Tegra2/Tegra20/ in log print] Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-11-15ARM: tegra: flexible spare fuse read functionDanny Huang
Change the spare fuse base from a definition to a variable. It provides flexibilty to read spare fuse on different chip. Signed-off-by: Danny Huang <dahuang@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-11-05ARM: tegra: move iomap.h to mach-tegraStephen Warren
Nothing outside mach-tegra uses this file, so there's no need for it to be in <mach/>. Since uncompress.h and debug-macro.S remain in include/mach, they need to include "../../iomap.h" becaue of this change. uncompress.h will soon be deleted in later multi-platform/single-zImage patches. debug-macro.S will need to continue to include this header using an explicit relative path, to avoid duplicating the physical->virtual address mapping that iomap.h dictates. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-09-06ARM: tegra: use IO_ADDRESS for getting virtual addressLaxman Dewangan
Use macro IO_ADDRESS for getting virtual address of corresponding physical address to make the consistency with rest of Tegra code-base. This macro calls the IO_TO_VIRT() which is defined in arch/arm/mach-tegra/include/mach/iomap.h Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-03-28Merge tag 'soc2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: More SoC support updates" from Olof Johansson: "This branch contains a handful of updates of SoC base code that had dependencies on other external trees that have now been merged: * Support for the new EXYNOS5250 SoC from Samsung * SMP and power domain support for Tegra3 from NVIDIA * ux500 updates for exporting SoC information through sysfs" Fix up trivial merge conflicts as per Olof. * tag 'soc2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (30 commits) ARM: mach-shmobile: ap4evb: Reserve DMA memory for the frame buffer ARM: EXYNOS: Fix compilation error with mach-exynos4-dt board ARM: dts: add initial dts file for EXYNOS5250, SMDK5250 ARM: EXYNOS: add support device tree enabled board file for EXYNOS5 ARM: EXYNOS: add support ARCH_EXYNOS5 for EXYNOS5 SoCs ARM: EXYNOS: add support get_core_count() for EXYNOS5250 ARM: EXYNOS: support EINT for EXYNOS4 and EXYNOS5 ARM: EXYNOS: add interrupt definitions for EXYNOS5250 ARM: EXYNOS: add support for EXYNOS5250 SoC ARM: EXYNOS: add support uart for EXYNOS4 and EXYNOS5 ARM: EXYNOS: add initial setup-i2c0 for EXYNOS5 ARM: EXYNOS: add clock part for EXYNOS5250 SoC ARM: EXYNOS: use exynos_init_uarts() instead of exynos4_init_uarts() ARM: EXYNOS: to declare static for mach-exynos/common.c ARM: EXYNOS: Add clkdev lookup entry for lcd clock ARM: dt: Explicitly configure all serial ports on Tegra Cardhu ARM: tegra: support for secondary cores on Tegra30 ARM: tegra: support for Tegra30 CPU powerdomains ARM: tegra: add support for Tegra30 powerdomains ARM: tegra: export tegra_powergate_is_powered() ...
2012-03-27Merge tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: driver specific updates" from Arnd Bergmann: "These are all specific to some driver. They are typically the platform side of a change in the drivers directory, such as adding a new driver or extending the interface to the platform. In cases where there is no maintainer for the driver, or the maintainer prefers to have the platform changes in the same branch as the driver changes, the patches to the drivers are included as well. A much smaller set of driver updates that depend on other branches getting merged first will be sent later. The new export of tegra_chip_uid conflicts with other changes in fuse.c. In rtc-sa1100.c, the global removal of IRQF_DISABLED conflicts with the cleanup of the interrupt handling of that driver. Signed-off-by: Arnd Bergmann <arnd@arndb.de>" Fixed up aforementioned trivial conflicts. * tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (94 commits) ARM: SAMSUNG: change the name from s3c-sdhci to exynos4-sdhci mmc: sdhci-s3c: add platform data for the second capability ARM: SAMSUNG: support the second capability for samsung-soc ARM: EXYNOS: add support DMA for EXYNOS4X12 SoC ARM: EXYNOS: Add apb_pclk clkdev entry for mdma1 ARM: EXYNOS: Enable MDMA driver regulator: Remove bq24022 regulator driver rtc: sa1100: add OF support pxa: magician/hx4700: Convert to gpio-regulator from bq24022 ARM: OMAP3+: SmartReflex: fix error handling ARM: OMAP3+: SmartReflex: fix the use of debugfs_create_* API ARM: OMAP3+: SmartReflex: micro-optimization for sanity check ARM: OMAP3+: SmartReflex: misc cleanups ARM: OMAP3+: SmartReflex: move late_initcall() closer to its argument ARM: OMAP3+: SmartReflex: add missing platform_set_drvdata() ARM: OMAP3+: hwmod: add SmartReflex IRQs ARM: OMAP3+: SmartReflex: clear ERRCONFIG_VPBOUNDINTST only on a need ARM: OMAP3+: SmartReflex: Fix status masking in ERRCONFIG register ARM: OMAP3+: SmartReflex: Add a shutdown hook ARM: OMAP3+: SmartReflex Class3: disable errorgen before disable VP ... Conflicts: arch/arm/mach-tegra/Makefile arch/arm/mach-tegra/fuse.c drivers/rtc/rtc-sa1100.c
2012-02-26ARM: tegra: export Tegra chipidPeter De Schrijver
The powergating and reset handling code needs to differentiate between Tegra variants. Therefore we export the chipid here. Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-02-26ARM: tegra: cleanup use of chipid registerPeter De Schrijver
The chipid register contains information about the Tegra variant and revision. We want differentiate between Tegra variants for powergating and secondary core bringup. This patch cleans up the reading and decoding of this register. In subsequent patches the variant will exported as a global variable. Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-02-06ARM: tegra: fuse: add bct strapping readingOlof Johansson
This is used by the memory setup code to pick the right memory timing table, if needed. Signed-off-by: Olof Johansson <olof@lixom.net>
2012-02-06ARM: tegra: fuse: add functions to access chip revisionOlof Johansson
Add function to get chip revision, and print it out at boot time. Restructure the fuse access to just use cached variables instead of always reading the fuses, and export those variables directly instead of using accessor functions. Add a SKU ID table of currently known values. Based on code originally by Colin Cross <ccross@android.com>. Changes since v1: * Add A01 minor rev support * Don't decode for A03p on anything but T2x Signed-off-by: Olof Johansson <olof@lixom.net> Acked-by: Stephen Warren <swarren@nvidia.com>
2012-02-06ARM: tegra: fuse: use apbio dma for register accessOlof Johansson
Use the apbio dma functions for accessing the fuse registers. Signed-off-by: Olof Johansson <olof@lixom.net>
2012-01-13arm: tegra: export tegra_chip_uidHenning Heinold
The crypto driver will need this api to use it in the RNG calculations. In order to build the crypto driver as a module, tegra_chip_uid has to be exported. Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Henning Heinold <heinold@inf.fu-berlin.de> Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-10-21[ARM] tegra: Add support for reading fusesColin Cross
The Tegra SOC contains fuses to identify the CPU type and bin, and a unique id. The CPU info is required to determine the correct voltages for each cpu and core frequency. Signed-off-by: Colin Cross <ccross@android.com>
