This supports CPU core power down on each CPU when CPU idle. When CPU go
into this state, it saves it's context and needs a proper configuration
in flow controller to power gate the CPU when CPU runs into WFI
instruction. And the CPU also needs to set the IRQ as CPU power down idle
wake up event in flow controller.
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>
Signed-off-by: Joseph Lo <josephl@nvidia.com>
Remove the duplicated code and use the cpuidle common code for initialization.
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
The en_core_tk_irqen flag is set in all the cpuidle driver which
means it is not necessary to specify this flag.
Remove the flag and the code related to it.
Acked-by: Kevin Hilman <khilman@linaro.org> # for mach-omap2/*
dev->state_count is initialized automatically by
cpuidle_register_device().
When drv->state_count is equal to dev->state_count, no need to init
this field, so removing it.
Reviewed-by: Joseph Lo <josephl@nvidia.com>
Adding the generic ARM_CPUIDLE_WFI_STATE support for Tegra114.
