Add battery regulator which is always-on. The rail which is
powered from battery can be added on this rail as consumer.
bug 1218527
Change-Id: I2394e1894649cd4fa736646981374681f603c832
(cherry picked from commit 4b9cabe87060bf5f252206aba5b62ea1ccb2ff83)
Reviewed-on: http://git-master/r/193761
Tested-by: Preetham Chandru <pchandru@nvidia.com>
GVS: Gerrit_Virtual_Submit
Nvidia updates to
add names for platform id, clocks to data
descriptors. Correct 1.8V and 3.3V names
for touch screen.
Bug 1054288
Bug 1165520
Change-Id: I0ea7c63775ae64b8ec8386f5fdbe7503787a1e8f
Signed-off-by: David Jung <djung@nvidia.com>
Reviewed-on: http://git-master/r/159599
Reviewed-by: Simone Willett <swillett@nvidia.com>
Add power regulator support for atmel
Bug 1063749
Change-Id: I009cf857628486ba4d8bb2ba2c23d9aae12d3a07
Signed-off-by: Xiaohui Tao <xtao@nvidia.com>
Reviewed-on: http://git-master/r/147119
Add support for PM315
Bug 1157036
Change-Id: I2e5461c656c41d4172aca60525655cb780eaa17e
Original-author: Mike Thompson <mikthompson@nvidia.com>
Signed-off-by: Mike Thompson <mikthompson@nvidia.com>
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Signed-off-by: Syed Rafiuddin <srafiuddin@nvidia.com>
Reviewed-on: http://git-master/r/143506
Change-Id: I3498a0f1ebc531834ab06f1fcdb3641ec3fc12b0
Signed-off-by: Robert Collins <rcollins@nvidia.com>
Reviewed-on: http://git-master/r/142529
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
Bug 1042318
Disabled pull-up of SLEEPP pin of tps6591x regulator by adding
pull-up init data in platform data
Change-Id: I310c9656d4edfeec53058a0730ff0f2c0c200d78
Signed-off-by: Sumit Sharma <sumsharma@nvidia.com>
Reviewed-on: http://git-master/r/134760
Change to enable the pllu regulator.
Change-Id: I6f8beb00c71e55b017c10576bf0aa990e09b362d
Signed-off-by: Suresh Mangipudi <smangipudi@nvidia.com>
Reviewed-on: http://git-master/r/130990
Removed the board dependency for the vbus regulators and the vbus gpio in
tegra platforms. Vbus need not be specified from the board files any more.
Change-Id: I0dbab40f8737138bd469600810a7a17407329149
Reviewed-on: http://git-master/r/130648
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
The pin name for fuse supply for different chip have different
name as follows:
- Tegra20 has the name as vdd_fuse.
- Tegra30 and later have the name as vpp_fuse.
Correcting name of the regulator supply and implementing same
in odm driver.
Change-Id: Ic7a49f365fa30aa71b198ba588dcc4bfc36dcc98
Reviewed-on: http://git-master/r/130144
Set the register values for each of the board files to
keep the Core voltage to 0.95V in LP1.
This change is only for those platforms where LP1 is supported.
Enterprise and Kai are the main platforms for this change. There
is no support for Cardhu for LP1 and so is left blank and the
feature will be skipped for Cardhu platforms, except for AP37.
AP37 with a PM269 board needs this change and so Cardhu board
file is updated with the values specific to AP37.
This change is part of the feature to set VCore to 0.95V
Refer to http://git-master/r/124135 for more details
Bug 1035684
Change-Id: I6d1d984b0e7968b441cebbc37705c25647a4a85a
Signed-off-by: Karthik Ramakrishnan <karthikr@nvidia.com>
(cherry picked from commit b46921e475bd95e729896a6763bc94df1e03ee4a)
Reviewed-on: http://git-master/r/124780
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
arch/arm/boot/compressed/Makefile
arch/arm/boot/compressed/atags_to_fdt.c
arch/arm/boot/compressed/head.S
arch/arm/boot/dts/tegra30.dtsi
arch/arm/include/asm/bug.h
arch/arm/kernel/traps.c
arch/arm/mach-tegra/Makefile.boot
arch/arm/mach-tegra/board-cardhu-sdhci.c
arch/arm/mach-tegra/board-cardhu.c
arch/arm/mach-tegra/board-enterprise-sdhci.c
arch/arm/mach-tegra/board-enterprise.c
arch/arm/mach-tegra/board-harmony.c
arch/arm/mach-tegra/board-kai-sdhci.c
arch/arm/mach-tegra/board-ventana.c
arch/arm/mach-tegra/board-whistler.c
arch/arm/mach-tegra/clock.h
arch/arm/mach-tegra/fuse.h
arch/arm/mach-tegra/tegra2_usb_phy.c
arch/arm/mach-tegra/tegra3_clocks.c
arch/arm/mach-tegra/tegra3_dvfs.c
arch/arm/mach-tegra/tegra3_speedo.c
arch/arm/mach-tegra/timer.c
arch/arm/mach-tegra/usb_phy.c
arch/arm/mach-tegra/wakeups-t3.c
drivers/cpufreq/cpufreq_interactive.c
drivers/input/touchscreen/atmel_mxt_ts.c
drivers/mfd/tps65090.c
drivers/mmc/core/mmc.c
drivers/mmc/host/sdhci-tegra.c
drivers/mmc/host/sdhci.c
drivers/net/wireless/bcmdhd/bcmsdh_sdmmc_linux.c
drivers/regulator/Kconfig
drivers/regulator/core.c
drivers/regulator/tps80031-regulator.c
drivers/spi/Makefile
drivers/staging/nvec/nvec.c
drivers/tty/serial/Makefile
include/linux/mmc/card.h
sound/soc/tegra/tegra_max98095.c
sound/usb/card.c
Change-Id: I65043bc6ce9e97d0592683462215a39e50f403fd
Reviewed-on: http://git-master/r/121392
Reviewed-by: Bo Yan <byan@nvidia.com>
Tested-by: Bo Yan <byan@nvidia.com>
Disabled USB1 VBUS wake up on board revisions prior to E1291-A03 and
E1198-A02. We see repeated LP0 wakeups if the wake source is enabled.
bug 980993
Change-Id: I080696924aaea06f973392fe7682fecc7574bf02
Signed-off-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-on: http://git-master/r/103627
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Reviewed-on: http://git-master/r/119640
Enable vibrator rail in order to support the
vibrator.
bug 1005183
Change-Id: I7133b259df590ad9dd376693b2f3224eb4431ec4
Reviewed-on: http://git-master/r/113635
Allow for DSI panel support to be present in release builds.
Removed CONFIG_TEGRA_CARDHU_DSI config variable.
Bug 978305.
Change-Id: I2b34fa5c5331de897d2b753da90e26278a6b7870
Signed-off-by: Rakesh Iyer <riyer@nvidia.com>
Reviewed-on: http://git-master/r/106919
(cherry picked from commit 3168303db4130d4405d7a56c92ecf382c091e699)
Reviewed-on: http://git-master/r/108372
(cherry picked from commit 90009fb5e08722bd8625f06ef64fbc7ddde5a464)
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Change-Id: Ic96eda2deb63ac25bc1ac58ca696ed8a4ab52cf7
Reviewed-on: http://git-master/r/109537
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Fix copyright information for board files.
Bug 978305.
Change-Id: I1322892c5752c5855edecfd7ef06e88663e1f5cd
Reviewed-on: http://git-master/r/108371
(cherry picked from commit db95bb83cbdf396b3c4918701af994ab481607b9)
Change-Id: I04c57a256ab811f134c217967469f93b976fbfcc
Reviewed-on: http://git-master/r/109536
* NVC framework provides NVC_CFG_NODEV config for all
NVC compliant camera drivers to make sure to delete
the device nodes which are not found in I2C probing.
This config is not set for all focuser modules on PM269,
which introduces the issue.
* Earlier only sh532u focuser was suppose to be on
cardhu, hence this error condition did not get triggered
but newly added focuser has exposed this error.
* Set NVC_CFG_NODEV for both sh532u and ad5816 focusers.
* Add regulator supply for cam2 ad5816 focuser, it fixes
camera crash on first reboot on E1198 cardhu and I2C
warnings.
Bug 992611
Bug 995072
Change-Id: I3382a896e4e246a0a323bd13ae0889b6701351c7
Signed-off-by: Sudhir vyas <svyas@nvidia.com>
Reviewed-on: http://git-master/r/106960
Reviewed-by: Prayas Mohanty <pmohanty@nvidia.com>
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Reviewed-by: Frank Chen <frankc@nvidia.com>
Bug 949219
Change-Id: I91a67d30869e9800c483f112d58b9f76e2dbe361
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/103534
arch/arm/mach-tegra/pcie.c
Removed unused wake header file from Tegra board files
bug 980993
Change-Id: I61d919a2dc5b98caaca612b990fd1a7d06e76ae2
Reviewed-on: http://git-master/r/103622
- Add support for new focuser ad5816 driver to
cardhu boards.
- Add regulator for new focuser ad5816.
Bug 947792
Change-Id: I62e89e9188d307704098e2d4e88d276914836d70
Reviewed-on: http://git-master/r/103138
Removing tegra_gpio_enable and disable calls
from board files as they are supported through
set direction calls in the driver
Bug 984439
Change-Id: I51b17389dbb17b0e94e1635ec6d68acd01c743b4
Signed-off-by: Ashwini Ghuge <aghuge@nvidia.com>
Reviewed-on: http://git-master/r/102529
Bug 970890
Change-Id: I24c3b1e2c621afbb90ced552194403f147e20a6c
Signed-off-by: Ray Poudrier <rapoudrier@nvidia.com>
Reviewed-on: http://git-master/r/102984
Enabling the sh532u driver feature to not register itself
if it does not identify the sh532u device during probe.
This is for the case where the platform does not populate
the device.
Bug 929133
Change-Id: Ic5ac7fa0ae4c05e4978fe7aebc3fc630ef1c2fd3
Signed-off-by: Erik Lilliebjerg <elilliebjerg@nvidia.com>
Reviewed-on: http://git-master/r/92340
Bug 949219
Change-Id: I875f8688a272c415ebf345b8f30e4afdf7551b29
Reviewed-on: http://git-master/r/91523
arch/arm/mach-tegra/common.c
The VDD2 supply the power to three rails: 1.5V, LDO1 and LDO2.
LDO1 is used for PEX and LDO2 is used for SATA.
By default making the VDD2 off and enabling when
consumer requires.
Change-Id: I283f62277246214966e7635bc31b6eb066f9282b
Reviewed-on: http://git-master/r/96451
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
The gpio regulator which is controlled through the gpio, which
is open drain type, is using the gpio_switch regulator.
The open drain support is added into the fixed regulator
and hence moving the regulator to use fixed regulator.
Change-Id: I1428d7e10ff469587c45fe913c4be8b4e35cb5bd
Reviewed-on: http://git-master/r/94196
Adding support for E1198-A03 which have different regulators
and the identification of regulators are done based on board
sku id.
Change-Id: Iee76d2bc493308da5346011232db32b933fd8625
Reviewed-on: http://git-master/r/92284
Bug 953155
Change-Id: I9fbb87f17e590971d5a0bf313e740e8b3b4c890b
Signed-off-by: Kevin Huang <kevinh@nvidia.com>
Reviewed-on: http://git-master/r/91871
Specify correct device names for ventana and cardhu speaker
and digital mic regulators.
Bug 956562
Signed-off-by: Preetham Chandru <pchandru@nvidia.com>
Change-Id: Iaa357b3da52dc9f593558b7f7e0ffda10ce8d938
Reviewed-on: http://git-master/r/91531
Reviewed-by: Kiran Adduri <kadduri@nvidia.com>
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-by: Allen Martin <amartin@nvidia.com>
This reverts commit 6a1a6f4f69adf0febfd923795b45edeff63e75ed.
LP0 was fixed with 5b4b921.
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Bug 941960
Removed CONFIG_TEGRA_INTERNAL_TSENSOR_EDP_SUPPORT.
Add internal tsensor on kai.
Change-Id: Iaefa43112fbbaa42d43a428ecb86ad821e683f85
Signed-off-by: Hao Tang <htang@nvidia.com>
Reviewed-on: http://git-master/r/84350
Rebase-Id: R3253cda29f94927c189837ee6d405b73e949c66b
We don't need a static bool here, there's already a function that does
this.
Change-Id: I7e5f13fc706b44f87ee7032860b31a8d8f622f21
Reviewed-on: http://git-master/r/83624
Rebase-Id: Rd8a1d48dd3fdcbeab86745d6d572fcac6f75fbb1
Just set the opt in booleans in the platform data instead of checking
which function to register for pm_power_off.
Change-Id: If336ff69e4b61b4220e6766b2643c5fba74d01cc
Reviewed-on: http://git-master/r/83597
Rebase-Id: R1a26cf9ace13f35e2246304b77d42fc9359eacac
Use the mainline's regulator driver tps62360 for core power
in place of NV's tps6236x driver.
Change-Id: Ibfa0ef8f4d59f48b31867dc1b1b0635d39a738ef
Reviewed-on: http://git-master/r/78413
Rebase-Id: R24b6c07a82733297187e34007d41ccb3c95c2ee0
Using fixed regulator in place of gpio-switch regulator.
Fixed regulator is very similar to gpio-switch regulator
and it is available by default in linux kernel.
gpio-switch-regulator will be used only for the open
collector load switches.
bug 923713
Change-Id: I42480cb314135d475b4d4b56bb5e8e73eba2f77e
Reviewed-on: http://git-master/r/74536
Reviewed-on: http://git-master/r/76465
Rebase-Id: Rf6810be0f702b017083ac1c88d45b481ea2b2eb7
mach-tegra/tegra3_tsensor.h is used for the parameterized initialization
of the tsensor device. mach-tegra/include/mach/tsensor.h is used for the
tsensor device driver.
Really, mach-tegra/tegra3_tsensor.c should go away - probably becoming a
device driver.
Change-Id: I16edae878f1e97d1654252cfee49cd9dd7f77db7
Reviewed-on: http://git-master/r/72481
Rebase-Id: Raacadc9292eb0d330e025809ad5a59da486b02d6
Enabled vbus1 & vbus3 for PM311 & PM305 boards. In PM311 & PM305 the gpios
used to enable vbu1 and vbus3 are TEGRA_GPIO_PCC7 & TEGRA_GPIO_PCC6
Bug: 914114
Change-Id: Id52cf6399526cb135968370478b5ac1bd53fe364
Signed-off-by: Preetham Chandru R
Reviewed-on: http://git-master/r/72409
Rebase-Id: R32eb6de52e54784d2ed68e8bc9cfb436ae78405c
'en_ddr' should be 'always on' and enabled when boot.
'en_3v3_sys' should be enabled when boot.
Signed-off-by: Haley Teng <hteng@nvidia.com>
Reviewed-on: http://git-master/r/60426
Reviewed-on: http://git-master/r/66590
(cherry picked from commit 28ed5f661ecd55de42688e565c65ff9c0bd3bdda)
Change-Id: I86edb0d3317b02da964fc89b8d593d1d0d3b75b0
Reviewed-on: http://git-master/r/71963
Tested-by: Haley Teng <hteng@nvidia.com>
Rebase-Id: Rf98442e35d1481d09e2d29de990a52143cdd2f2a
Bug 888679
Change default regulator current to 6A on cardhu to support T33 based
board without VF
Change-Id: Ica8c1a9a4276ae1fb140c6a2ad1db04bd96c9471
Signed-off-by: Diwakar Tundlam <dtundlam@nvidia.com>
Reviewed-on: http://git-master/r/70187
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Rebase-Id: R27d28d21ea86bbd0055aa00be10de603d99d1227
Bug 860351
Bug 850614
Bug 852480
Bug 872156
Bug 824459
Change-Id: I60366c7eb918a76860dbbc087407d3f89663c00d
Reviewed-on: http://git-master/r/66166
Rebase-Id: Rf3aa0d747fe08d8117b7168d552aa39de78b3184
Enabling output capacitor discharge for the core power
supplied from tps62361x.
bug 871944
Reviewed-on: http://git-master/r/64838
(cherry picked from commit 8dfc169da3f7af3072956f766fb760830cf8b8ad)
Change-Id: Ib996d63a2b0e0ed43e1a76286e84266bf4ab4c72
Reviewed-on: http://git-master/r/68426
Rebase-Id: R5d39c2af7cd5887c78b6a35f36c60125e618a238
Bug 865305
Change-Id: I1e300db033a22935bcc0cd6c24f8d9d3460b3475
Reviewed-on: http://git-master/r/66120
Rebase-Id: R54cebc69c16bbedb4ed2dbf3fc33dbc34456cb57
Corrected the range check for enabling gpio for TSP62361B because
tegra_gpio_enable() is for tegra gpio only
Bug 897387
Reviewed-on: http://git-master/r/65123
(cherry picked from commit f7ef3d5a8a56a5050174383da1818c80a65729bd)
Change-Id: I66e08170596678a267f25602f0daf79a3e0d34bd
Signed-off-by: Chaitanya Bandi <bandik@nvidia.com>
Reviewed-on: http://git-master/r/66609
Rebase-Id: R14092c5f0f254e11358349e9ecfc84faa0228cb8
Based on characterization, at high temperatures Tegra will
draw more than 1mA, which is what the datasheet reports for
the low-power mode of LDO4.
So removing the LOW_POWER mode flag which makes LDO4 in low
power mode in suspend.
bug 890770
Reviewed-on: http://git-master/r/64825
(cherry picked from commit f4263c693e235c52d7ad4ad32d2508b4a6393508)
Change-Id: I9289a504af71fa488d30d77aa6cbb6e1d7dd05a4
Reviewed-on: http://git-master/r/65456
Rebase-Id: R3cf4b2dfa2b5fea9fe281cad769fb5addc241abd
Integrating MAX77663 PMIC based PM269 board into the Cardhu board.
The system will be find the correct PMIC using the Board ID of PMIC
in the Cardhu init phase.
Bug 849360
Reviewed-on: http://git-master/r/56354
(cherry picked from commit 4d7da62a829de4d051c458caa052a6d612f642fa)
Change-Id: I41a52b70d27378e6240522c16256f8c7e42144b5
Signed-off-by: Jin Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/64399
Rebase-Id: R6baa5408a249a41d577f22da8476ad020600b12d
used when the chip SKU is T33/T33S (cardhu case) or AP33 (enterprise case) to
initialize edp with a higher cpu regulator max_curr value.
bug 888679
Change-Id: Icb50b33b1fc9b1248886e040f4b9b927feee4242
(cherry picked from commit ea572ebf71bbced17f2df2313f03e032949fac68)
Reviewed-on: http://git-master/r/64210
Rebase-Id: R98017f0f2bbf6e745961c427d1dc2d05e042b303
Putting the LDO7 and LDO8 to OFF in sleep state.
bug 892613
Reviewed-on: http://git-master/r/63500
(cherry picked from commit 52897937e5c30cd7e0e6c096f166936a0d396a4f)
Change-Id: Ie51594f739e5e581dec17733550ebd4e8d28e040
Reviewed-on: http://git-master/r/64046
Rebase-Id: R58fc9d4c16f990658da18822505d0d9dbe7a31a5
supplied_to battery driver name is used to link charger
driver with battery driver. Using that upon
power_supply_changed() of charger, external_power_changed()
of battery driver get called.
Bug 872590
Change-Id: Ib80c1770a5a519d21430b3fad5759a848f5db1f3
Reviewed-on: http://git-master/r/64078
Rebase-Id: Rced3500a496746d8186f44e2948a37f6b1cb66b8
Registering the ricoh583 pmu driver.
Change-Id: I3547522d661852826185e50b6958234a04ca0b4b
Reviewed-on: http://git-master/r/62948
Rebase-Id: R458057614dd9db4aeb34d37de20c6753e78b3e51
