The ramp voltage for the ldo3 for PM269 is around 1mV/us.
Setting this value.
bug 872382
Reviewed-on: http://git-master/r/51364
(cherry picked from commit aa84b06982dbea58b815fc99bbbf84c7bdaddc78)
Change-Id: I2b7cd8883c06250490c3e27dd28384985706aa68
Reviewed-on: http://git-master/r/62341
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
Rebase-Id: R74b6d629197cc9b1cc591a4ac318f7105c7f28c5
Configuring the LDO4, LDO7 and LDO8 in low power mode in suspend.
bug 890770
Reviewed-on: http://git-master/r/60411
(cherry picked from commit 5c65acbba9526f66679ed6934e008c4205c7fd88)
Change-Id: I519e99ba02eac08fc93b69422fd129eea85eec3a
Reviewed-on: http://git-master/r/61439
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Rebase-Id: Rd5f3000c7845e3967b542268feaeeff169ad7498
Enable LP0 for cardhu family boards.
BUG 893759
Change-Id: Ic5cceeb1034104eefb3243036fbc2c3dc0125b43
Reviewed-on: http://git-master/r/60335
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: Rd7c4a6633a428895ebdb1e98932c696e7587271e
This change supports PM313 with 19X12 panel.
The change uses PM313 in "Single input to Dual output" mode
Bug ID : 822980
Reviewed-on: http://git-master/r/50215
(cherry picked from commit b83e795747fa860b5b7fb66b2067ebe4f15bcfd0)
Change-Id: Iabf707ded2976e9877481c215d0b1f1940781f14
Reviewed-on: http://git-master/r/60085
Rebase-Id: Rda6368b3e3d31b508be0cee4b13b322125495226
These initcalls weren't ensuring that they're actually running on the
board they care about, which breaks on a multi-board kernel.
Change-Id: Ifd8a3e523c2523b68ec4d7e30c2b87969b939931
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-on: http://git-master/r/60010
Rebase-Id: Rf189bc5a0510612b55504b3412f01cf8470038d0
Support for E1291-A05 board.
bug 881745
Reviewed-on: http://git-master/r/58053
(cherry picked from commit be104b795f0c46b8bbe1e45ca618fed74d81a7c6)
Change-Id: I0137f9e13ee9c01bd60125589b16023c899389c9
Reviewed-on: http://git-master/r/59287
Rebase-Id: R6450506e02427f4bae13857a52ed43dd530e720a
Adding support for E1257 platform.
bug 864294
Reviewed-on: http://git-master/r/50662
(cherry picked from commit 8217615021a6ffeb992327f6b010ea9deebc34e7)
Change-Id: I3429da1bca38e1ddc5b3c2156a0db6b23aeb5555
Reviewed-on: http://git-master/r/57806
Rebase-Id: R7fadbdc30bdca30e41e0b7fdb88628dbc8c32e82
bug 875709
Reviewed-on: http://git-master/r/56632
(cherry picked from commit b7077b25dfaa7c92c5f05f50688d26710eb57348)
Change-Id: I46b0bd4d939e5ffbce9599ad2c437a7d424b1d87
Reviewed-on: http://git-master/r/57258
Rebase-Id: Rb192b1590af659143cf62938ce5ab468526216ee
The SDMMC_VDD control is generated from the cpld programming
for pm269 and so it is not require to have gpio control for this.
bug 880984
Reviewed-on: http://git-master/r/56627
(cherry picked from commit 38ad9be02578b64d3f5eab8c6146abfc6c842d35)
Change-Id: Id7cae7a724c02754b3abbc937a7e80b9a51d7977
Reviewed-on: http://git-master/r/57254
Rebase-Id: R34a8cb39a5c557461ebbb540692487d357798eca
Adding support for PM311 based system.
bug 870139
Reviewed-on: http://git-master/r/50012
(cherry picked from commit d319d9980b6b225735ac97160fdee18fbabba2f0)
Change-Id: Iaa28921761e035e8fa29956b776f9379ae326b42
Reviewed-on: http://git-master/r/57251
Rebase-Id: R50fc9a079bd46a050084afed2b0f460e2916ebc9
Specify device names for ventana and cardhu speaker and digital mic
regulators. Also use same regulator name for ventana and cardhu
speaker supply.
Bug 872652
Change-Id: I5a254eee2037c86e208818f34cdff24aee0edad9
Signed-off-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-on: http://git-master/r/55668
Rebase-Id: R8a8bc937154783ba8bcfc21a237ab6043cc9ba0e
Bug 872590
Change-Id: I7e5bfe68a4f299f771b4af7094754e4167a44f29
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/54663
Rebase-Id: R9dce2ca60c88531d5b16ed669404b3f1a25a9e81
bug 869217
Reviewed-on: http://git-master/r/51291
(cherry picked from commit bdf107203561935aa8d1eb1be36cfbbd36adfbe4)
Change-Id: I3a342c87c65e586942396f12193726f0d60d17f1
Reviewed-on: http://git-master/r/54225
Tested-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Rebase-Id: Re3c83bf2dad8b8fb64b4372af15461c3b9a775bc
Use the device driver name instead of encoding the SDMMC controller in
the regulator supply name.
Change-Id: I08fb807c5a13eedd70bb9a5d47633334d51133d6
Reviewed-on: http://git-master/r/52502
Rebase-Id: R2966fc597604a2c8a0e5b2c9f507a4566e3400f9
http://nvbugs/876007
Change-Id: Id060bcc5ef20c0bc553bc171a3b96699140b2161
Reviewed-on: http://git-master/r/52136
Reviewed-by: Jin Qian <jqian@nvidia.com>
Tested-by: Jin Qian <jqian@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Rebase-Id: R6496b91629af42d4b6ac9a623cd63d03c14abab2
Adding support for PM305.
bug 846246
Original-Change-Id: Ib036c67c12984668e0b7153f76a1a1d44c5be14f
Reviewed-on: http://git-master/r/49820
Rebase-Id: R9e9eb93ddcea487159854533eead3fe8eb74e42b
Fix regulator_get error and reset the sensor/focuser properly
in the camera power on routine for PM269.
Bug 842713
Original-Change-Id: Ia3820ec9e7bcca850b090a48963606af855f5ad2
Reviewed-on: http://git-master/r/49101
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Rebase-Id: R5623445c753a3e8ffaaef38a5b105c8330e21b49
Setting the dsi_csi rails to 1200mV.
bug 869063
Original-Change-Id: If1bd3d804b5f3888e4bbd377ab2105c4ca7a2dda
Reviewed-on: http://git-master/r/49175
Rebase-Id: Re9e8cebb8e9db0a6f499514895bf3228eddbd479
Correcting the supply name for hvdd_pex voltage rail.
bug 868452
Original-Change-Id: I238051360baca044ea547ed0fed6cf7e4a663012
Reviewed-on: http://git-master/r/49174
Reviewed-by: Krishna Thota <kthota@nvidia.com>
Tested-by: Krishna Thota <kthota@nvidia.com>
Rebase-Id: R425970ed9eba558db187b9123241c433bf6addba
Adding support for the gpio changes for E1198-A02.
bug 864282
Change-Id: I96e985882a3f2d00a66b300e85cb24661f884746
Reviewed-on: http://git-master/r/48483
Rebase-Id: R07d861bb8832972e46a713d9ff195fef2cf6d1d2
The ldo2 power rail should be set to 1200mV on E1208-A03 based
pmu.
bug 863728
Original-Change-Id: I7730443bc052348a082d52a73e4f521ec34202f7
Reviewed-on: http://git-master/r/47491
Reviewed-by: Vivek Aseeja <vaseeja@nvidia.com>
Rebase-Id: Rfc2975d5b80492523a4a767c001a8e22c9decaa7
Add board support needed for PMU switch off when tsensor
detects temperature > TH3 threshold set.
bug 850047
Original-Change-Id: I7a283cedc735264dd8ea52801f7f1a103e9293cb
Reviewed-on: http://git-master/r/41531
Rebase-Id: R6dbc2c1acb741666f6d7dda88f1bbb26c465717c
Bug 853132
Original-Change-Id: I59cc6b2025926695ebee12d808fb49f556ffaa6d
Reviewed-on: http://git-master/r/42264
Rebase-Id: Rbd0d325e54141db2187dff6b11d5c0b20ff046d9
- Added table with EDP Capping values for different SKUs/regulator
currents in new file edp.c
- New entry point tegra_init_cpu_edp_limits()
- Added DebugFS entry under debug/edp to list the currently
selected EDP table
- Populated EDP table in edp.c with data from Bug 844268
- edp.c keeps main EDP table; cpu-tegra.c and board-cardhu-power.c
both read from there
Bug 840255
Original-Change-Id: I55c2ee16278be8cd3005218bedebe76846d137d8
Reviewed-on: http://git-master/r/40938
Rebase-Id: R70685c053f950a12fffd18f37c7f5ed381594f6d
Setting the rail voltage of the AVDD_PLLs to 1.2V and rail voltage
of PLL_SATA to 1.05V.
Original-Change-Id: Ibf5bb1d11b7b15cabb68f90da7e24dd999915c55
Reviewed-on: http://git-master/r/41179
Rebase-Id: Rc7f949b56c0d12d63f313aa005c4e71cbd0a3215
Added the board level suspend/resume and call the console
suspend from board level suspend/resume.
bug 820536
Original-Change-Id: I246265241246dc0682870571c927bd23023e5aca
Reviewed-on: http://git-master/r/41448
Reviewed-by: Narendra Damahe <ndamahe@nvidia.com>
Rebase-Id: R712acfe9a1ede8ef8d237ad993bcb5a9eac22a4d
Adding board level suspend/resume for cardhu.
Disabling the clock for console uart port if console_suspend
is enabled.
bug 820536
Original-Change-Id: Iecb78708ff7784dd131ffa83692b2419dba44e88
Reviewed-on: http://git-master/r/41147
Rebase-Id: R14dcb8c7822b2bdc7e66807e292776b68d08d12d
Adding the TPS6591x gpio definition in tps6591x core header
files.
bug 849976
Original-Change-Id: I1f7a7cc38e220c091ccf44db5af6e43c34daa1cd
Reviewed-on: http://git-master/r/41040
Rebase-Id: R78e6ca62b6b1740d52e316784fbc41264ef01f0d
Remove the hardcoding of the numerical value for different
sku bit and fab definition and using macro for better readability.
Original-Change-Id: Idf70c7a063b5416e170b3b7e61e896250c9ad70c
Reviewed-on: http://git-master/r/37644
Rebase-Id: Rd7e2bfcf6780b6b73a8438b904b8a13b0297b59d
Removing the always on in constraints of the power rail of backlights.
bug 850674
Original-Change-Id: I15b835012db75fdf74dc1d7a742da0573c5af06d
Reviewed-on: http://git-master/r/40798
Rebase-Id: R9ca33b8b4b489590f649160ae9e6df627391cbf0
Adding support for the E1256. The configuration is
same as the E1186 board.
bug 849990
Original-Change-Id: Idd89e282627b2f0924fc313a5ba28f9e9a6032be
Reviewed-on: http://git-master/r/40367
Rebase-Id: R3b1f22dc222f4ce000d2e84a48b7e2f379159750
The problem with slow PMU was fixed with a hardware
change to reduce capacitance on the power rail, so
delays are no longer needed
Original-Change-Id: Ib66378ca6bf18c112e90d44d3213dd5f6c870c92
Reviewed-on: http://git-master/r/37127
Rebase-Id: R41f0ab153ba153f896390874b41893ee6e11dce5
Bug 796825
Original-Change-Id: I91be0bca739a2daf32807306a611671f387a8988
Reviewed-on: http://git-master/r/36096
Rebase-Id: R5d303050d04b8e2ec2d9724a60bec9b0cbef6f02
Adding complete constraints of the regulators.
bug 843566
Original-Change-Id: Ifd07d15d257ff8c89c4a3cc31c9e72d886e6b431
Reviewed-on: http://git-master/r/39633
Rebase-Id: Rf443864c31cc255e428d6f0de51add028d85db78
Correct pingroup is DAP3_DOUT
Bug 825778
Original-Change-Id: I252398c4f1d653c73c5fd26a7b5c12410a962ade
Reviewed-on: http://git-master/r/39822
Rebase-Id: Rb3bb758d23520c165fa6369bcb16979ec1824b5b
Putting the unused vddio_gmi pins into the low power mode.
bug 833087
Original-Change-Id: I7595d011a61d5993fee167e89ed7eb204d5cb6b6
Reviewed-on: http://git-master/r/37877
Reviewed-by: Matthew Longnecker <mlongnecker@nvidia.com>
Rebase-Id: R3fa74a5ebc7720b95f91f8da7b665e634522f210
Enable PMU only features for LP0. System-wise LP0 is not enable by default yet.
1. Allow pmu SLEEP state
2. Keep 32KHz clk out from PMU enabled on LP0
3. Set core_power_req to be high enable
4. Turn off VDD1 (power for Vcore) on LP0
Original-Change-Id: Id6babdfc36de1a597f8df5d2943ef048699013d4
Reviewed-on: http://git-master/r/32853
Reviewed-by: Chih-Lung Huang <lhuang@nvidia.com>
Tested-by: Chih-Lung Huang <lhuang@nvidia.com>
Reviewed-by: Niket Sirsi <nsirsi@nvidia.com>
Tested-by: Niket Sirsi <nsirsi@nvidia.com>
Rebase-Id: R1be5db70870d950a7ffe1361e60aad4156398172
change the input supply to master 5v to enable VDDIO_HDMI
signal for HDMI.
Bug 825778
Bug 823160
Original-Change-Id: I2d6360ab3769ff876bdb7d0e0b34d9298aa780d0
Reviewed-on: http://git-master/r/35904
Rebase-Id: R0ad5c2ba75a7fd6c5ab26f27e6aa987681a6b014
Change-Id: If47d86312afd02fb8e193631b7baec66c3232864
Signed-off-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-on: http://git-master/r/47163
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Rebase-Id: Rfadb990de8dc73fd53392029cc622629c8b986bd
Tegra3 power management features have not been fully ported to
Linux 2.6.39 yet. Disable them temporarily.
Change-Id: Id9e1ebcab5f665845e6d1b685364f9cea9fe7329
Rebase-Id: Rd813fa7d2be0ae8eec44c02834e21c2a47b5a846
Rebase-Id: R53c264de0e30d06937fd88d97b9709b35c069f6d
The core_pwr_req signal need to be make high for the PMU A03 and A04.
bug 829846
Change-Id: Ie568a29e76823e86743893ea59953b0429cc027a
Reviewed-on: http://git-master/r/36544
Rebase-Id: Ra97979df79f413641d2d862f982e6a7a114c2387
The E1291-A04 power rails are different then the A02/A03 version of E1291.
Supporting the A04 power rails properly.
Change-Id: I4c7dc0afa5b6bb1a7350418ef07f4ee7192cff30
Reviewed-on: http://git-master/r/35722
Tested-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Rebase-Id: Rafba9f71503029ac561c01ad7c97595926854917
Configuring the tps6591x into DEV_SLP mode and
gpio2 of tps6591x into sleep mode for E1291-A04 board.
This is required in order to have the gpio2 follow the
'CORE_PWR_REQ' pin in E1291-A04. GPIO2 of tps6591x is
connected to the EN of the DC-DC converter which supply
core voltage.
bug 821295
Original-Change-Id: I01a8fa6c056872cff84dd0f2ae7601cee298ebcf
Reviewed-on: http://git-master/r/32614
Rebase-Id: R7eb913eabd4b8a51a688eb3bd09dff1ffc5c9545
This reverts commit 0885c8037152e4b11d669c845ddf09ba49e5c8b6.
Original-Change-Id: I254ca2966cdf28d548368340efb64617ce274a74
Reviewed-on: http://git-master/r/32698
Rebase-Id: R018aa71bbf41b0d3586002fe7226ff3573388407
Original-Change-Id: I57f033f44cfdf19d61bc5bab41cec23e51b40c11
Reviewed-on: http://git-master/r/32089
Rebase-Id: Re8f7d38f87635a3e709e83c8af6a81c67095210d
1. Set core_power_req to be high enable
2. Turn off VDD1 (power for Vcore) on LP0
Original-Change-Id: I81aedb4332c9e7ccd97def546a9a0611253f744a
Reviewed-on: http://git-master/r/32277
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Rebase-Id: R4886f57403bc6148a6641ed8abe875da037cd4cb
Original-Change-Id: I6282bbb63c34b8cc0d503cdd6eafe575fb78ef5f
Reviewed-on: http://git-master/r/31342
Rebase-Id: R71a8023042831f208803dd7d7cad84912db9d3c1
Adding platform data entry for the tps6236x device and registering
this device if board info has sku with bit0 as 1.
bug 821295
Original-Change-Id: I18618ef75eca66a1f699c003c787dcb1f06e7659
Reviewed-on: http://git-master/r/31388
Rebase-Id: Rb0d48c28c7460bd00874bd4cf972427e6939ba40
Adding GPIO_REG for power rails of PM269 board.
Bug 823160
Original-Change-Id: Idbb889420e033780900b1b1b700637017640414e
Reviewed-on: http://git-master/r/30366
Reviewed-by: Raymond Poudrier <rapoudrier@nvidia.com>
Rebase-Id: R2f23a797a5e751bb6fc781a4aa7ed0c1a9ea1805
