path: root/arch/arm/mach-tegra/Makefile.boot
2011-12-17arm/tegra: add support for tegra30 based board cardhuPeter De Schrijver
Add support for the tegra30 based cardhu development board. Cardhu is a tablet formfactor reference design for tegra30. The patch provides a device tree for the board, updates Makefile.boot to build the dtb, includes the platform in Kconfig and updates board-dt.c. Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Colin Cross <ccross@android.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2011-12-07arm/dt: tegra: add dts file for paz00Marc Dietrich
This adds a dts file for paz00. As a side effect, this also enables the embedded controller which controls the keyboard, touchpad, power, leds, and some other functions. Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Marc Dietrich <marvin24@gmx.de> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2011-12-07arm/tegra: Add device-tree support for TrimSlice boardStephen Warren
* Add device-tree file for TrimSlice * Add that to the list of .dts files to build * Update board-dt.c to recognize TrimSlice board name v2: Makefile: Add board-trimslice-pinmux.c to obj-$(CONFIG_MACH_TEGRA_DT). v3: Makefile: Use brackets not braces around var names Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2011-11-01Merge branch 'next/devel' of git://git.linaro.org/people/arnd/arm-socLinus Torvalds
* 'next/devel' of git://git.linaro.org/people/arnd/arm-soc: (50 commits) ARM: tegra: update defconfig arm/tegra: Harmony: Configure PMC for low-level interrupts arm/tegra: device tree support for ventana board arm/tegra: add support for ventana pinmuxing arm/tegra: prepare Seaboard pinmux code for derived boards arm/tegra: pinmux: ioremap registers gpio/tegra: Convert to a platform device arm/tegra: Convert pinmux driver to a platform device arm/dt: Tegra: Add pinmux node to tegra20.dtsi arm/tegra: Prep boards for gpio/pinmux conversion to pdevs ARM: mx5: fix clock usage for suspend ARM i.MX entry-macro.S: remove now unused code ARM i.MX boards: use CONFIG_MULTI_IRQ_HANDLER ARM i.MX tzic: add handle_irq function ARM i.MX avic: add handle_irq function ARM: mx25: Add the missing IIM base definition ARM i.MX avic: convert to use generic irq chip mx31moboard: Add poweroff support ARM: mach-qong: Add watchdog support ARM: davinci: AM18x: Add wl1271/wlan support ... Fix up conflicts in: arch/arm/mach-at91/at91sam9g45.c arch/arm/mach-mx5/devices-imx53.h arch/arm/plat-mxc/include/mach/memory.h
2011-10-17ARM: 7022/1: allow to detect conflicting zreladdrsSascha Hauer
Boards used to specify zreladdr in their Makefile.boot with zreladdr-y := x, so conflicting zreladdrs were silently overwritten. This patch changes this to zreladdr-y += x, so that we end up with multiple words in zreladdr in such a case. We can detect this later and complain if necessary. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-10-13arm/tegra: device tree support for ventana boardPeter De Schrijver
Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2011-07-28arm/dt: tegra devicetree supportGrant Likely
Everything required to populate NVIDIA Tegra devices from the device tree. This patch adds a new DT_MACHINE_DESC() which matches against a tegra20 device tree. So far it only registers the on-chip devices, but it will be refined in follow on patches to configure clocks and pin IO from the device tree also. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-08-05[ARM] tegra: initial tegra supportErik Gilling
v2: Fixes from Mike Rapoport - remove unused header files (mach/dma.h and mach/nand.h) - remove tegra 1 references from Makefile.boot v2: fixes from Russell King - remove mach/io.h include from mach/iomap.h - fix whitespace in Kconfig v2: from Colin Cross - fix invalid immediate in debug-macro.S v3: - allow selection of multiple boards Signed-off-by: Colin Cross <ccross@android.com> Signed-off-by: Erik Gilling <konkers@android.com>
