path: root/arch/arm/mach-shmobile/pm-r8a7779.c
2012-09-04ARM: shmobile: Move r8a7779's PM domain objects to a tableRafael J. Wysocki
Instead of giving a name to every r8a7779's PM domain object, put them all into a table and initialize them all together in a loop. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Magnus Damm <damm@opensource.se>
2012-09-04ARM: shmobile: Drop r8a7779_add_device_to_domain()Rafael J. Wysocki
If the r8a7779's PM domains are given names, this SoC and its boards will be able to use rmobile_add_device_to_domain() for adding devices to those domains and r8a7779_add_device_to_domain(), which is not used anywhere at the moment anyway, may be dopped. Accordingly, give names to the r8a7779's PM domains and drop r8a7779_add_device_to_domain(). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Magnus Damm <damm@opensource.se>
2012-03-28Disintegrate asm/system.h for ARMDavid Howells
Disintegrate asm/system.h for ARM. Signed-off-by: David Howells <dhowells@redhat.com> cc: Russell King <linux@arm.linux.org.uk> cc: linux-arm-kernel@lists.infradead.org
2012-01-12ARM: mach-shmobile: r8a7779 SMP support V3Magnus Damm
This patch contains r8a7779 SMP support V3 - now including CPU hotplug offine and online support. The r8a7779 power domain code is tied together with SMP glue code which allows us to control the power domains via CPU hotplug. At this point the kernel boots with the 4 Cortex-A9 cores in SMP mode and all CPU cores except CPU0 can be hotplugged. The code in platsmp.c is quite far from pretty, but it is kept like that intentionally to avoid creating layers of code that will go away in the near future anyway. The code needs to be updated when some per-SoC handling code will be added to the ARM architecture, see the following patch for more information: "[RFC PATCH 0/3] Per SoC descriptor" Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-01-10ARM: mach-shmobile: r8a7779 power domain support V2Magnus Damm
Add power domain control support for the r8a7779 SoC V2. This adds support for 4 power domains for I/O Devices together with code that can be used for CPU cores as well. The only out of the ordinary experience is the need for ioremap() of SYSC registers. Because of that we need to execute some init function before setting up the domains. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
