path: root/arch/arm/mach-shmobile/board-kota2.c
2013-03-15ARM: shmobile: kota2: Register pinctrl mappings for BSCLaurent Pinchart
Replace the GPIO-based BSC pinmux configuration by pinctrl mappings. Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
2013-03-15ARM: shmobile: kota2: Register pinctrl mappings for KEYSCLaurent Pinchart
Replace the GPIO-based KEYSC pinmux configuration by pinctrl mappings. Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
2013-03-15ARM: shmobile: kota2: Register pinctrl mappings for SDHI and MMCIFLaurent Pinchart
Replace the GPIO-based SDHI and MMCIF pinmux configuration by pinctrl mappings. Board code used the non-pulled-up version of the function GPIOs, but those are defined in the PFC driver as enabling the pull-ups anyway. Enable pull-ups on the MMCIF data and command pins through the pinconf API. Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
2013-03-15ARM: shmobile: kota2: Register pinctrl mappings for SCIFLaurent Pinchart
Replace the GPIO-based SCIF pinmux configuration by pinctrl mappings. Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
2013-03-15ARM: shmobile: sh73a0: Support sparse GPIO numbersGuennadi Liakhovetski
The SH73A0 SoC has sparse GPIO numbers. Declare the pin numbers ranges in the PFC SoC data and use the pin numbers in the GPIO API. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2013-02-21Merge tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC board specific changes from Arnd Bergmann: "These updates are all for board specific code, including - defconfig updates for shmobile, davinci, bcm2835, imx, omap and tegra - SD/MMC and I2C support on bcm2835 (Raspberry PI) - minor updates for PXA - shmobile updates to GPIO usage in board files - More things in OMAP board files are moved over to device tree probing - Better support for audio devices on some OMAP platforms" * tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (55 commits) ARM: imx_v4_v5_defconfig: Add VPU support ARM: imx: configs: enable netfilter support ARM: OMAP2+: Fix twl section warnings related to omap_twl4030_audio_init ARM: OMAP2+: omap2plus_defconfig: enable omap1 rtc RX-51: Register twl4030-madc device RX-51: Add leds lp5523 names from Maemo 5 2.6.28 kernel ARM: OMAP2+: AM33XX: omap2plus_defconfig: Add support for few drivers ARM: OMAP1: nokia770: enable CBUS/Retu ARM: OMAP2+: omap2plus_defconfig: enable CMA allocator ARM: OMAP2+: omap2plus_defconfig: enable TFP410 chip support ARM: OMAP3: igep0020: simplify GPIO LEDs dependencies ARM: OMAP2+: craneboard: support the TPS65910 PMU ARM: OMAP2+: craneboard: support NAND device ARM: OMAP3: cm-t3517: add MMC support ARM: OMAP2+: Remove apollon board support ARM: shmobile: armadillo800eva: set clock rates before timer init ARM: tegra: defconfig updates ARM: shmobile: mackerel: Use gpio_request_one() ARM: shmobile: kzm9g: Use gpio_request_one() ARM: shmobile: bonito: Use gpio_request_one() ...
2013-01-28ARM: shmobile: kota2: Use gpio_request_one()Laurent Pinchart
Replace occurences of gpio_request() and gpio_direction_*() by calls to gpio_request_one(). Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2013-01-14Merge tag 'gic-vic-to-irqchip' of git://sources.calxeda.com/kernel/linux ↵Olof Johansson
into next/cleanup From Rob Herring: Initial irqchip init infrastructure and GIC and VIC clean-ups This creates irqchip initialization infrastructure from Thomas Petazzoni. The VIC and GIC irqchip code is moved to drivers/irqchips and adapted to use the new infrastructure. All DT enabled platforms using GIC and VIC are converted over to use the new irqchip_init. * tag 'gic-vic-to-irqchip' of git://sources.calxeda.com/kernel/linux: irqchip: Move ARM vic.h to include/linux/irqchip/arm-vic.h ARM: picoxcell: use common irqchip_init function ARM: spear: use common irqchip_init function irqchip: Move ARM VIC to drivers/irqchip ARM: samsung: remove unused tick.h ARM: remove unneeded vic.h includes ARM: remove mach .handle_irq for VIC users ARM: VIC: set handle_arch_irq in VIC initialization ARM: VIC: shrink down vic.h irqchip: Move ARM gic.h to include/linux/irqchip/arm-gic.h ARM: use common irqchip_init for GIC init irqchip: Move ARM GIC to drivers/irqchip ARM: remove mach .handle_irq for GIC users ARM: GIC: set handle_arch_irq in GIC initialization ARM: GIC: remove direct use of gic_raise_softirq ARM: GIC: remove assembly ifdefs from gic.h ARM: mach-ux500: use SGI0 to wake up the other core arm: add set_handle_irq() to register the parent IRQ controller handler function irqchip: add basic infrastructure irqchip: add to the directories part of the IRQ subsystem in MAINTAINERS Fixed up massive merge conflicts with the timer cleanup due to adjacent changes: Signed-off-by: Olof Johansson <olof@lixom.net> Conflicts: arch/arm/mach-bcm/board_bcm.c arch/arm/mach-cns3xxx/cns3420vb.c arch/arm/mach-ep93xx/adssphere.c arch/arm/mach-ep93xx/edb93xx.c arch/arm/mach-ep93xx/gesbc9312.c arch/arm/mach-ep93xx/micro9.c arch/arm/mach-ep93xx/simone.c arch/arm/mach-ep93xx/snappercl15.c arch/arm/mach-ep93xx/ts72xx.c arch/arm/mach-ep93xx/vision_ep9307.c arch/arm/mach-highbank/highbank.c arch/arm/mach-imx/mach-imx6q.c arch/arm/mach-msm/board-dt-8960.c arch/arm/mach-netx/nxdb500.c arch/arm/mach-netx/nxdkn.c arch/arm/mach-netx/nxeb500hmi.c arch/arm/mach-nomadik/board-nhk8815.c arch/arm/mach-picoxcell/common.c arch/arm/mach-realview/realview_eb.c arch/arm/mach-realview/realview_pb1176.c arch/arm/mach-realview/realview_pb11mp.c arch/arm/mach-realview/realview_pba8.c arch/arm/mach-realview/realview_pbx.c arch/arm/mach-socfpga/socfpga.c arch/arm/mach-spear13xx/spear1310.c arch/arm/mach-spear13xx/spear1340.c arch/arm/mach-spear13xx/spear13xx.c arch/arm/mach-spear3xx/spear300.c arch/arm/mach-spear3xx/spear310.c arch/arm/mach-spear3xx/spear320.c arch/arm/mach-spear3xx/spear3xx.c arch/arm/mach-spear6xx/spear6xx.c arch/arm/mach-tegra/board-dt-tegra20.c arch/arm/mach-tegra/board-dt-tegra30.c arch/arm/mach-u300/core.c arch/arm/mach-ux500/board-mop500.c arch/arm/mach-ux500/cpu-db8500.c arch/arm/mach-versatile/versatile_ab.c arch/arm/mach-versatile/versatile_dt.c arch/arm/mach-versatile/versatile_pb.c arch/arm/mach-vexpress/v2m.c include/asm-generic/vmlinux.lds.h
2013-01-12irqchip: Move ARM gic.h to include/linux/irqchip/arm-gic.hRob Herring
Now that we have GIC moved to drivers/irqchip and all GIC DT init for platforms using irqchip_init, move gic.h and update the remaining includes. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Anton Vorontsov <avorontsov@mvista.com> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: David Brown <davidb@codeaurora.org> Cc: Daniel Walker <dwalker@fifo99.com> Cc: Bryan Huntsman <bryanh@codeaurora.org> Cc: Tony Lindgren <tony@atomide.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: Viresh Kumar <viresh.linux@gmail.com> Cc: Shiraz Hashim <shiraz.hashim@st.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Samuel Ortiz <sameo@linux.intel.com>
2013-01-12ARM: remove mach .handle_irq for GIC usersRob Herring
Now that the GIC initialization sets up the handle_arch_irq pointer, we can remove it for all machines and make it static. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Anton Vorontsov <avorontsov@mvista.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: David Brown <davidb@codeaurora.org> Cc: Daniel Walker <dwalker@fifo99.com> Cc: Bryan Huntsman <bryanh@codeaurora.org> Acked-by: Tony Lindgren <tony@atomide.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Shiraz Hashim <shiraz.hashim@st.com> Acked-by: Stephen Warren <swarren@nvidia.com> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Linus Walleij <linus.walleij@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-09-14ARM: SoC: convert shmobile SMP to SMP operationsMarc Zyngier
Convert shmobile SMP platforms to use struct smp_operations to provide their SMP and CPU hotplug operations. Cc: Paul Mundt <lethal@linux-sh.org> Cc: Magnus Damm <magnus.damm@gmail.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-06-30ARM: mach-shmobile: add fixed voltage regulators to kota2Guennadi Liakhovetski
On kota2 provide 1.8V and 3.3V supplies for its SD/MMC-card interfaces and a dummy regulator for the smsc911x driver. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Magnus Damm <damm@opensource.se> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-05-08ARM: shmobile: use machine specific hook for late initShawn Guo
Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Magnus Damm <damm@opensource.se> Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl>
2012-03-29Merge tag 'cleanup2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull "ARM: cleanups of io includes" from Olof Johansson: "Rob Herring has done a sweeping change cleaning up all of the mach/io.h includes, moving some of the oft-repeated macros to a common location and removing a bunch of boiler plate. This is another step closer to a common zImage for multiple platforms." Fix up various fairly trivial conflicts (<mach/io.h> removal vs changes around it, tegra localtimer.o is *still* gone, yadda-yadda). * tag 'cleanup2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (29 commits) ARM: tegra: Include assembler.h in sleep.S to fix build break ARM: pxa: use common IOMEM definition ARM: dma-mapping: convert ARCH_HAS_DMA_SET_COHERENT_MASK to kconfig symbol ARM: __io abuse cleanup ARM: create a common IOMEM definition ARM: iop13xx: fix missing declaration of iop13xx_init_early ARM: fix ioremap/iounmap for !CONFIG_MMU ARM: kill off __mem_pci ARM: remove bunch of now unused mach/io.h files ARM: make mach/io.h include optional ARM: clps711x: remove unneeded include of mach/io.h ARM: dove: add explicit include of dove.h to addr-map.c ARM: at91: add explicit include of hardware.h to uncompressor ARM: ep93xx: clean-up mach/io.h ARM: tegra: clean-up mach/io.h ARM: orion5x: clean-up mach/io.h ARM: davinci: remove unneeded mach/io.h include [media] davinci: remove includes of mach/io.h ARM: OMAP: Remove remaining includes for mach/io.h ARM: msm: clean-up mach/io.h ...
2012-03-29Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull more ARM updates from Russell King. This got a fair number of conflicts with the <asm/system.h> split, but also with some other sparse-irq and header file include cleanups. They all looked pretty trivial, though. * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (59 commits) ARM: fix Kconfig warning for HAVE_BPF_JIT ARM: 7361/1: provide XIP_VIRT_ADDR for no-MMU builds ARM: 7349/1: integrator: convert to sparse irqs ARM: 7259/3: net: JIT compiler for packet filters ARM: 7334/1: add jump label support ARM: 7333/2: jump label: detect %c support for ARM ARM: 7338/1: add support for early console output via semihosting ARM: use set_current_blocked() and block_sigmask() ARM: exec: remove redundant set_fs(USER_DS) ARM: 7332/1: extract out code patch function from kprobes ARM: 7331/1: extract out insn generation code from ftrace ARM: 7330/1: ftrace: use canonical Thumb-2 wide instruction format ARM: 7351/1: ftrace: remove useless memory checks ARM: 7316/1: kexec: EOI active and mask all interrupts in kexec crash path ARM: Versatile Express: add NO_IOPORT ARM: get rid of asm/irq.h in asm/prom.h ARM: 7319/1: Print debug info for SIGBUS in user faults ARM: 7318/1: gic: refactor irq_start assignment ARM: 7317/1: irq: avoid NULL check in for_each_irq_desc loop ARM: 7315/1: perf: add support for the Cortex-A7 PMU ...
2012-03-13ARM: __io abuse cleanupRob Herring
Several platforms incorrectly use __io() for casting to 'void __iomem *'. This converts all of those uses to use the common IOMEM macro. Reported-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: linux-sh@vger.kernel.org Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-03-12ARM: mach-shmobile: sh73a0, AG5EVM and Kota2 timer reworkMagnus Damm
Move the SoC specific timer code from AG5EVM and Kota2 to sh73a0 setup code. This makes is possible to share the SoC specific timer code across boards and it also removes the need for a board specific timer structure. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-03-12ARM: mach-shmobile: sh73a0 map_io and init_early updateMagnus Damm
Update the sh73a0 SoC and the AG5EVM and Kota2 boards to make use of the functions sh73a0_map_io() and sh73a0_add_early_devices(). Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-01-25ARM: shmobile: remove NR_IRQSRob Herring
Remove NR_IRQS and explicitly include mach/irqs.h as needed. shmobile properly allocates irq_descs for each irqchip, so setting .nr_irqs for each machine is not needed. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-01-18ARM: mach-shmobile: IRQ driven GPIO key support for Kota2Magnus Damm
Now when GPIO IRQs are supported on sh73a0 modify the Kota2 board code to switch from the polled "gpio-keys-polled" driver to the IRQ driven "gpio-keys" driver. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-01-05Merge branch 'devel-stable' into for-linusRussell King
Conflicts: arch/arm/kernel/setup.c arch/arm/mach-shmobile/board-kota2.c
2011-11-24ARM: mach-shmobile: Kota2 TPU LED platform dataMagnus Damm
This patch updates the Kota2 board support code to use the recently merged TPU LED driver whenever possible. The sh73a0 SoC has 5 TPU hardware blocks each with 4 timer channels which in theory allows a total of 20 LEDs to be controlled by "leds-renesas-tpu" driver instances. The Kota2 board has 4 LEDs connected to GPIO pins that also come with TPU pin functions, so this patch ties up these 4 LEDS and leaves the remaining 3 LEDS for the GPIO based LED driver. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-11-24ARM: mach-shmobile: Kota2 GIC Sparse IRQ fixMagnus Damm
Fix IRQ support on the Kota2 board. The sh73a0 and the Kota2 board make use of the ARM GIC hardware block as main interrupt controller. The following commit changed the default behaviour for non-device tree platforms and broke Kota2 irq support: f37a53c ARM: gic: fix irq_alloc_descs handling for sparse irq Without this fix the following warning triggers at boot: NR_IRQS:1024 nr_irqs:1024 1024 ------------[ cut here ]------------ WARNING: at arch/arm/common/gic.c:607 gic_init+0x90/0x2e4() Cannot allocate irq_descs @ IRQ16, assuming pre-allocated [<c000c868>] (unwind_backtrace+0x0/0xe0) from [<c001857c>] (warn_slowpath_commo) [<c001857c>] (warn_slowpath_common+0x48/0x60) from [<c00185d8>] (warn_slowpath_) [<c00185d8>] (warn_slowpath_fmt+0x2c/0x3c) from [<c029ee08>] (gic_init+0x90/0x2) [<c029ee08>] (gic_init+0x90/0x2e4) from [<c029f278>] (sh73a0_init_irq+0x30/0x18) [<c029f278>] (sh73a0_init_irq+0x30/0x184) from [<c029c0b4>] (init_IRQ+0x14/0x1c) [<c029c0b4>] (init_IRQ+0x14/0x1c) from [<c029a5cc>] (start_kernel+0x15c/0x2b8) [<c029a5cc>] (start_kernel+0x15c/0x2b8) from [<4000803c>] (0x4000803c) ---[ end trace 1b75b31a2719ed1c ]--- With this fix applied interrupts work as expected. Signed-off-by: Magnus Damm <damm@opensource.se> Acked-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-11-24ARM: mach-shmobile: Kota2 PINT fixMagnus Damm
Support PINT on sh73a0 and Kota2 using INTC PINT macros. With this patch applied the Kota2 ethernet is handled through one of the chained sh73a0 PINT interrupt controllers. sh73a0 PINT support is included in 3.2-rc but the Kota2 board code does not make use of this shared code base without this patch. Without this patch kota2 on-board ethernet is broken. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-11-15ARM: shmobile: convert smp platforms to gic_handle_irq()Marc Zyngier
Convert the SMP shmobile platforms to use gic_handle_irq() instead of the assembly macro. Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2011-11-11ARM: mach-shmobile: kota2: add comment out separatorKuninori Morimoto
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-08-29ARM: mach-shmobile: Kota2 SDHI0 and SDHI1 supportMagnus Damm
Add SDHI0 and SDHI1 support to the Kota2 board. SDHI0 is hooked up to a microSD card slot and SDHI1 to a wireless module that also connects to SCIFB. This depends on the recently merged code for TMIO_MMC_HAS_IDLE_WAIT together with PFC support for pull-ups on SDHI0 and SDHI1. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-08-29ARM: mach-shmobile: Kota2 SCIFA4 and SCIFB supportMagnus Damm
Add SCIFA4 and SCIFB support to the Kota2 board. Only pins are configured since the SCIF platform devices are already present in the sh73a0 code. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-08-29ARM: mach-shmobile: Kota2 MMCIF supportMagnus Damm
Add support for sh73a0 MMCIF hardware block on the Kota2 board. A non-removable eMMC chip is used with 8 data bits on the MMC bus. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-08-29ARM: mach-shmobile: Kota2 GPIO LEDs supportMagnus Damm
This patch ties in GPIO LEDs support on the Kota2 board. For now all LEDs are driven by the GPIO LED driver, but in the not so distant future the LEDs hooked up to TPU pin functions will be moved over to the recently posted LED TPU driver. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-08-29ARM: mach-shmobile: Kota2 GPIO Keys supportMagnus Damm
This patch ties in GPIO Keys support on the Kota2 board. For now the keys are used in polling mode, but after extending the sh73a0 PFC with IRQ support we should be able to switch to the IRQ driven driver. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-08-29ARM: mach-shmobile: Kota2 KEYSC supportMagnus Damm
This patch adds KEYSC support to the Kota2 board. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-08-29ARM: mach-shmobile: Kota2 SCIFA2 and SMSC911X supportMagnus Damm
Kota2 base board support including the on-chip SCIFA2 serial console and the on-board SMSC911X ethernet port. The s73a0 SMP bits are also updated to include Kota2. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
