path: root/arch/arm/mach-sa1100
2012-04-27arm/sa1100: fix sa1100-rtc memory resourceDmitry Artamonow
DEFINE_RES_MEM() takes the size of resource as a second argument, not the end address. Passing end address leads to following error in runtime during device registration: sa1100-rtc: failed to claim resource 0 Fix it. Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-04-02ARM: fix lcd power build failure in collie_defconfigPaul Gortmaker
Commit 086ada54abaa4316e8603f02410fe8ebc9ba2de1 "FB: sa1100: remove global sa1100fb_.*_power function pointers" got rid of all instances but one in locomolcd.c -- which was conditional on CONFIG_SA1100_COLLIE. The associated .power field which replaces the global is populated in mach-sa1100/collie.c so move the assignment there, but make it conditional on the locomolcd support, so use CONFIG_BACKLIGHT_LOCOMO in that file. Cc: arm@kernel.org Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-03-29Merge tag 'cleanup2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull "ARM: cleanups of io includes" from Olof Johansson: "Rob Herring has done a sweeping change cleaning up all of the mach/io.h includes, moving some of the oft-repeated macros to a common location and removing a bunch of boiler plate. This is another step closer to a common zImage for multiple platforms." Fix up various fairly trivial conflicts (<mach/io.h> removal vs changes around it, tegra localtimer.o is *still* gone, yadda-yadda). * tag 'cleanup2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (29 commits) ARM: tegra: Include assembler.h in sleep.S to fix build break ARM: pxa: use common IOMEM definition ARM: dma-mapping: convert ARCH_HAS_DMA_SET_COHERENT_MASK to kconfig symbol ARM: __io abuse cleanup ARM: create a common IOMEM definition ARM: iop13xx: fix missing declaration of iop13xx_init_early ARM: fix ioremap/iounmap for !CONFIG_MMU ARM: kill off __mem_pci ARM: remove bunch of now unused mach/io.h files ARM: make mach/io.h include optional ARM: clps711x: remove unneeded include of mach/io.h ARM: dove: add explicit include of dove.h to addr-map.c ARM: at91: add explicit include of hardware.h to uncompressor ARM: ep93xx: clean-up mach/io.h ARM: tegra: clean-up mach/io.h ARM: orion5x: clean-up mach/io.h ARM: davinci: remove unneeded mach/io.h include [media] davinci: remove includes of mach/io.h ARM: OMAP: Remove remaining includes for mach/io.h ARM: msm: clean-up mach/io.h ...
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Disintegrate asm/system.h for ARMDavid Howells
Disintegrate asm/system.h for ARM. Signed-off-by: David Howells <dhowells@redhat.com> cc: Russell King <linux@arm.linux.org.uk> cc: linux-arm-kernel@lists.infradead.org
2012-03-27Merge branch 'platforms' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM platform updates from Russell King: "This covers platform stuff for platforms I have a direct interest in (iow, I have the hardware). Essentially: - as we no longer support any other Acorn platforms other than RiscPC anymore, we can collect all that code into mach-rpc. - convert Acorn expansion card stuff to use IRQ allocation functions, and get rid of NO_IRQ from there. - cleanups to the ebsa110 platform to move some private stuff out of its header files. - large amount of SA11x0 updates: - conversion of private DMA implementation to DMA engine support (this actually gives us greater flexibility in drivers over the old API.) - re-worked ucb1x00 updates - convert to genirq, remove sa11x0 dependencies, fix various minor issues - move platform specific sa11x0 framebuffer data into platform files in arch/arm instead of keeping this in the driver itself - update sa11x0 IrDA driver for DMA engine, and allow it to use DMA for SIR transmissions as well as FIR - rework sa1111 support for genirq, and irq allocation - fix sa1111 IRQ support so it works again - use sparse IRQ support After this, I have one more pull request remaining from my current set, which I think is going to be the most problematical as it generates 8 conflicts." Fixed up the trivial conflict in arch/arm/mach-rpc/Makefile as per Russell. * 'platforms' of git://git.linaro.org/people/rmk/linux-arm: (125 commits) ARM: 7343/1: sa11x0: convert to sparse IRQ ARM: 7342/2: sa1100: prepare for sparse irq conversion ARM: 7341/1: input: prepare jornada720 keyboard and ts for sa11x0 sparse irq ARM: 7340/1: rtc: sa1100: include mach/irqs.h instead of asm/irq.h ARM: sa11x0: remove unused DMA controller definitions ARM: sa11x0: remove old SoC private DMA driver USB: sa1111: add hcd .reset method USB: sa1111: add OHCI shutdown methods USB: sa1111: reorganize ohci-sa1111.c USB: sa1111: get rid of nasty printk(KERN_DEBUG "%s: ...", __FILE__) USB: sa1111: sparse and checkpatch cleanups ARM: sa11x0: don't static map sa1111 ARM: sa1111: use dev_err() rather than printk() ARM: sa1111: cleanup sub-device registration and unregistration ARM: sa1111: only setup DMA for DMA capable devices ARM: sa1111: register sa1111 devices with dmabounce in bus notifier ARM: sa1111: move USB interface register definitions to ohci-sa1111.c ARM: sa1111: move PCMCIA interface register definitions to sa1111_generic.c ARM: sa1111: move PS/2 interface register definitions to sa1111p2.c ARM: sa1111: delete unused physical GPIO register definitions ...
2012-03-27Merge tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: driver specific updates" from Arnd Bergmann: "These are all specific to some driver. They are typically the platform side of a change in the drivers directory, such as adding a new driver or extending the interface to the platform. In cases where there is no maintainer for the driver, or the maintainer prefers to have the platform changes in the same branch as the driver changes, the patches to the drivers are included as well. A much smaller set of driver updates that depend on other branches getting merged first will be sent later. The new export of tegra_chip_uid conflicts with other changes in fuse.c. In rtc-sa1100.c, the global removal of IRQF_DISABLED conflicts with the cleanup of the interrupt handling of that driver. Signed-off-by: Arnd Bergmann <arnd@arndb.de>" Fixed up aforementioned trivial conflicts. * tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (94 commits) ARM: SAMSUNG: change the name from s3c-sdhci to exynos4-sdhci mmc: sdhci-s3c: add platform data for the second capability ARM: SAMSUNG: support the second capability for samsung-soc ARM: EXYNOS: add support DMA for EXYNOS4X12 SoC ARM: EXYNOS: Add apb_pclk clkdev entry for mdma1 ARM: EXYNOS: Enable MDMA driver regulator: Remove bq24022 regulator driver rtc: sa1100: add OF support pxa: magician/hx4700: Convert to gpio-regulator from bq24022 ARM: OMAP3+: SmartReflex: fix error handling ARM: OMAP3+: SmartReflex: fix the use of debugfs_create_* API ARM: OMAP3+: SmartReflex: micro-optimization for sanity check ARM: OMAP3+: SmartReflex: misc cleanups ARM: OMAP3+: SmartReflex: move late_initcall() closer to its argument ARM: OMAP3+: SmartReflex: add missing platform_set_drvdata() ARM: OMAP3+: hwmod: add SmartReflex IRQs ARM: OMAP3+: SmartReflex: clear ERRCONFIG_VPBOUNDINTST only on a need ARM: OMAP3+: SmartReflex: Fix status masking in ERRCONFIG register ARM: OMAP3+: SmartReflex: Add a shutdown hook ARM: OMAP3+: SmartReflex Class3: disable errorgen before disable VP ... Conflicts: arch/arm/mach-tegra/Makefile arch/arm/mach-tegra/fuse.c drivers/rtc/rtc-sa1100.c
2012-03-25ARM: 7343/1: sa11x0: convert to sparse IRQRussell King
Now that Neponset, UCB1x00 and SA1111 are all converted to use the IRQ allocation interfaces, we can enable sparse IRQ support for SA11x0 platforms.
2012-03-25ARM: 7342/2: sa1100: prepare for sparse irq conversionRob Herring
In preparation to convert SA1100 to sparse irq, set .nr_irqs for each machine and explicitly include mach/irqs.h as needed. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-03-25Merge branch 'sa11x0-mcp' into sa11x0Russell King
Conflicts: arch/arm/mach-sa1100/assabet.c arch/arm/mach-sa1100/collie.c arch/arm/mach-sa1100/generic.c arch/arm/mach-sa1100/lart.c arch/arm/mach-sa1100/shannon.c
2012-03-25Merge branch 'sa11x0-lcd' into sa11x0Russell King
2012-03-25ARM: sa11x0: remove unused DMA controller definitionsRussell King
Remove the new unused DMA controller definitions from mach/SA-1100.h. These are now private to the SA-11x0 DMA engine driver and contained within the driver. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-03-25ARM: sa11x0: remove old SoC private DMA driverRussell King
Now that all users are converted over to using the DMA engine API, we can get rid of the old platform dependent DMA driver. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-03-25Merge branch 'sa11x0-ir' into sa11x0Russell King
2012-03-25Merge branch 'sa1111' into sa11x0Russell King
Conflicts: arch/arm/common/sa1111.c arch/arm/mach-sa1100/neponset.c Fixed: arch/arm/mach-sa1100/assabet.c for the neponset changes
2012-03-24ARM: sa11x0: don't static map sa1111Russell King
The sa1111 support will ioremap() the device; there is no need for platforms to setup a static mapping for this. Remove the static mapping for this device from badge4, jornada720 and neponset. Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-03-24ARM: sa1111: provide a generic way to prevent devices from registeringRussell King
Some platforms don't want certain devices to be registered, because, eg, the interface is not wired. Provide a way for platforms to prevent various devices from being registered via a devid bitmask in the platform data. Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-03-23Merge branch 'pcmcia' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull #3 ARM updates from Russell King: "This adds gpio support to soc_common, allowing an amount of code to be deleted from each PCMCIA socket driver for the PXA/SA11x0 SoCs." * 'pcmcia' of git://git.linaro.org/people/rmk/linux-arm: PCMCIA: sa1111: rename sa1111 socket drivers to have sa1111_ prefix. PCMCIA: make lubbock socket driver part of sa1111_cs PCMCIA: add Kconfig control for building sa11xx_base.c PCMCIA: sa1111: jornada720: no need to disable IRQs around sa1111_set_io PCMCIA: sa1111: pass along sa1111_pcmcia_configure_socket() failure code PCMCIA: soc_common: remove explicit wrprot initialization in socket drivers PCMCIA: soc_common: remove soc_pcmcia_*_irqs functions PCMCIA: sa11x0: h3600: convert to use new irq/gpio management PCMCIA: sa11x0: simpad: convert to use new irq/gpio management PCMCIA: sa11x0: shannon: convert to use new irq/gpio management PCMCIA: sa11x0: nanoengine: convert reset handling to use GPIO subsystem PCMCIA: sa11x0: nanoengine: convert to use new irq/gpio management PCMCIA: sa11x0: cerf: convert reset handling to use GPIO subsystem PCMCIA: sa11x0: cerf: convert to use new irq/gpio management PCMCIA: sa11x0: assabet: convert to use new irq/gpio management PCMCIA: sa1111: use new per-socket irq/gpio infrastructure PCMCIA: pxa: convert PXA socket drivers to use new irq/gpio management PCMCIA: soc_common: add GPIO support for card status signals PCMCIA: soc_common: move common initialization into soc_common
2012-03-23Merge branch 'for-armsoc' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull #1 ARM updates from Russell King: "This one covers stuff which Arnd is waiting for me to push, as this is shared between both our trees and probably other trees elsewhere. Essentially, this contains: - AMBA primecell device initializer updates - mostly shrinking the size of the device declarations in platform code to something more reasonable. - Getting rid of the NO_IRQ crap from AMBA primecell stuff. - Nicolas' idle cleanups. This in combination with the restart cleanups from the last merge window results in a great many mach/system.h files being deleted." Yay: ~80 files, ~2000 lines deleted. * 'for-armsoc' of git://git.linaro.org/people/rmk/linux-arm: (60 commits) ARM: remove disable_fiq and arch_ret_to_user macros ARM: make entry-macro.S depend on !MULTI_IRQ_HANDLER ARM: rpc: make default fiq handler run-time installed ARM: make arch_ret_to_user macro optional ARM: amba: samsung: use common amba device initializers ARM: amba: spear: use common amba device initializers ARM: amba: nomadik: use common amba device initializers ARM: amba: u300: use common amba device initializers ARM: amba: lpc32xx: use common amba device initializers ARM: amba: netx: use common amba device initializers ARM: amba: bcmring: use common amba device initializers ARM: amba: ep93xx: use common amba device initializers ARM: amba: omap2: use common amba device initializers ARM: amba: integrator: use common amba device initializers ARM: amba: realview: get rid of private platform amba_device initializer ARM: amba: versatile: get rid of private platform amba_device initializer ARM: amba: vexpress: get rid of private platform amba_device initializer ARM: amba: provide common initializers for static amba devices ARM: amba: make use of -1 IRQs warn ARM: amba: u300: get rid of NO_IRQ initializers ...
2012-03-23Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci Pull PCI changes (including maintainer change) from Jesse Barnes: "This pull has some good cleanups from Bjorn and Yinghai, as well as some more code from Yinghai to better handle resource re-allocation when enabled. There's also a new initcall_debug feature from Arjan which will print out quirk timing information to help identify slow quirks for fixing or refinement (Yinghai sent in a few patches to do just that once the new debug code landed). Beyond that, I'm handing off PCI maintainership to Bjorn Helgaas. He's been a core PCI and Linux contributor for some time now, and has kindly volunteered to take over. I just don't feel I have the time for PCI review and work that it deserves lately (I've taken on some other projects), and haven't been as responsive lately as I'd like, so I approached Bjorn asking if he'd like to manage things. He's going to give it a try, and I'm confident he'll do at least as well as I have in keeping the tree managed, patches flowing, and keeping things stable." Fix up some fairly trivial conflicts due to other cleanups (mips device resource fixup cleanups clashing with list handling cleanup, ppc iseries removal clashing with pci_probe_only cleanup etc) * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (112 commits) PCI: Bjorn gets PCI hotplug too PCI: hand PCI maintenance over to Bjorn Helgaas unicore32/PCI: move <asm-generic/pci-bridge.h> include to asm/pci.h sparc/PCI: convert devtree and arch-probed bus addresses to resource powerpc/PCI: allow reallocation on PA Semi powerpc/PCI: convert devtree bus addresses to resource powerpc/PCI: compute I/O space bus-to-resource offset consistently arm/PCI: don't export pci_flags PCI: fix bridge I/O window bus-to-resource conversion x86/PCI: add spinlock held check to 'pcibios_fwaddrmap_lookup()' PCI / PCIe: Introduce command line option to disable ARI PCI: make acpihp use __pci_remove_bus_device instead PCI: export __pci_remove_bus_device PCI: Rename pci_remove_behind_bridge to pci_stop_and_remove_behind_bridge PCI: Rename pci_remove_bus_device to pci_stop_and_remove_bus_device PCI: print out PCI device info along with duration PCI: Move "pci reassigndev resource alignment" out of quirks.c PCI: Use class for quirk for usb host controller fixup PCI: Use class for quirk for ti816x class fixup PCI: Use class for quirk for intel e100 interrupt fixup ...
2012-03-07ARM: sa11x0: add SA-11x0 DMA deviceRussell King
Add sa11x0 DMA platform device and resources to the list of generic platform devices for SA11x0 machines. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-03-06ARM: remove bunch of now unused mach/io.h filesRob Herring
Now that many platforms don't need mach/io.h, remove the unused ones. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Pawel Moll <pawel.moll@arm.com> Acked-by: Nicolas Pitre <nico@linaro.org>
2012-02-28Merge branch 'rtc-sa1100' of git://github.com/hzhuang1/linux into next/driversArnd Bergmann
* 'rtc-sa1100' of git://github.com/hzhuang1/linux: ARM: mmp: enable rtc in pxa910 rtc: sa1100: enable clk support ARM: pxa: add rtc dummy clock ARM: sa1100: clean up clock support rtc: sa1100: declare irq in resource rtc: sa1100: remove verification code of alarm rtc: sa1100: remove periodic code
2012-02-28ARM: sa1100: clean up clock supportJett.Zhou
Add rtc clock support and clean clock support for gpio. Signed-off-by: Jett.Zhou <jtzhou@marvell.com> signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
2012-02-28rtc: sa1100: declare irq in resourceHaojian Zhuang
Avoid to hard coded irq in rtc-sa1100 driver since we could share it among arch-sa1100/arch-pxa/arch-mmp. We still keep hard coded register address since the requirement is enabling both rtc-sa1100 and rtc-pxa driver. The register addresses are conflict since they're only two wrappers on the same rtc device. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2012-02-24FB: sa11x0: convert to use platform resource and ioremap()Russell King
Convert the sa11x0 framebuffer driver to obtain the base address of its hardware registers from the platform resources, and ioremap this rather than relying on the static mappings. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-23arm/PCI: get rid of device resource fixupsBjorn Helgaas
Tell the PCI core about host bridge address translation so it can take care of bus-to-resource conversion for us. CC: Russell King <linux@arm.linux.org.uk> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-02-22Merge branch 'entry-macro-cleanup' of git://sources.calxeda.com/kernel/linux ↵Russell King
into for-armsoc
2012-02-21ARM: remove disable_fiq and arch_ret_to_user macrosRob Herring
Now that most platforms don't need disable_fiq and arch_ret_to_user macros, we can remove the empty macros or empty entry-macro.S files. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Ryan Mallon <rmallon@gmail.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Shawn Guo <shawn.guo@linaro.org>
2012-02-21PCMCIA: sa11x0: simpad: convert to use new irq/gpio managementRussell King
Convert Simpad socket driver to use the new irq/gpio management. This is slightly more involved because we have to touch the private platform header file to modify the GPIO bitmasks to be GPIO numbers. Acked-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-21PCMCIA: sa11x0: shannon: convert to use new irq/gpio managementRussell King
Convert Shannon socket driver to use the new irq/gpio management. This is slightly more involved because we have to touch the private platform header file to modify the GPIO bitmasks to be GPIO numbers. Acked-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-21FB: sa11x0: convert shannon display enable accesses to use GPIO subsystemRussell King
Rather than accessing GPSR and GPCR directly, use the GPIO subsystem instead. Acked-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-21FB: sa1100: remove global sa1100fb_.*_power function pointersRussell King
Now that we have platform data contained within the individual board code, we can get rid of the global function pointers, placing them inside the platform data instead. Acked-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-21FB: sa1100: move platform data to platform filesRussell King
Move platform data out of the sa1100fb driver into the various platform files themselves. Acked-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-18MFD: mcp-sa11x0/assabet: move assabet reset handling out of mcp-sa11x0.cRussell King
Move the assabet specific reset handling out of mcp-sa11x0.c, into its board file. This leaves the mcp code free from all board specific details. Acked-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-18ARM: sa11x0: add assabet ucb1x00 platform dataRussell King
Add ucb1x00 platform data to enable GPIO support on the UCB1300 device. Acked-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-18MFD: mcp/ucb1x00: separate ucb1x00 driver data from the MCP dataRussell King
Patch taken from 5dd7bf59e0 (ARM: sa11x0: Implement autoloading of codec and codec pdata for mcp bus.) by Jochen Friedrich <jochen@scram.de>. This adds just the codec data part of the patch. Acked-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-09ARM: sa11x0: badge4: move board specific ohci initialization to badge4.cRussell King
Move the handling of the 5v supply into badge4.c, removing this board specific detail from the sa1111 ohci driver. Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-09ARM: sa11x0: neponset: don't static map neponset registersRussell King
Now that we ioremap() the neponset register space, there's no need to static map the neponset registers. Get rid of this static mapping. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-09ARM: sa11x0: neponset: move register definitions to neponset.cRussell King
Move the board specific neponset register definitions to the board file, rather than mach/neponset.h. However, as the NCR_0 register definitions are used by some drivers, leave these behind. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-09ARM: sa11x0: assabet/neponest: create neponset device in assabet.cRussell King
The neponset board is a daughter board for the Assabet. Create the neponset platform device in assabet.c, where we don't have to wrap it with machine_is_assabet() stuff. We also create this device dynamically rather than keeping it as a static device. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-09ARM: sa11x0: neponset: suspend/resume in _noirq stateRussell King
Suspend and resume in the _noirq state, so that we're saving the state of the modem control signals as late as possible, and restoring them as early as possible. There's nothing to do in thaw/poweroff methods as we've already saved the necessary state. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-09ARM: sa11x0: neponset: place smc91x and sa1111 resources in neponset deviceRussell King
Complete the neponset device resources by covering the children's memory resources in the parent neponset device. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-09ARM: sa11x0: neponset: get parent IRQ from neponset device resourceRussell King
Obtain the parent IRQ from the neponset device resource rather than hard-coding it into the code. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-09ARM: sa11x0: neponset: implement support for sparse IRQsRussell King
Implement the necessary allocation/freeing functionality to support sparse IRQs with the Neponset device. On non-sparse IRQ platforms, this allows us to dynamically allocate from within the available IRQ number space. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-09ARM: sa11x0: neponset: dynamically create neponset child devicesRussell King
Use platform_device_register_full() to dynamically create the various neponset child platform devices, and place them below the neponset device itself to ensure proper PM ordering and device structure. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-09ARM: sa11x0: neponset: save and restore MDM_CTL_0Russell King
Save and restore the modem output control register across a suspend/ resume, as well as the NCR register. Place these in a locally allocated data structure rather than needing a new static variable. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-09ARM: sa11x0: neponset: add driver .owner initializerRussell King
Ensure that the driver .owner field is properly initialized. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-09ARM: sa11x0: neponset: shuffle some code aroundRussell King
Move the IRQ handler along side the rest of the IRQ code, and rearrange the include files. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-09ARM: sa11x0: neponset: provide function to manipulate NCR_0Russell King
Rather than having direct register accesses to NCR_0 scattered amongst the code, provide a function instead. This contains the necessary race protection for this platform, ensuring that updates to this register are safe. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
