path: root/arch/arm/mach-sa1100/ssp.c
2008-01-26[ARM] Misc minor interrupt handler cleanupsJeff Garzik
mach-integrator/pci_v3.c: no need to reference 'irq' arg, its constant mach-omap1/pm.c: remove extra whitespace arch/arm/mach-sa1100/ssp.c: remove braces around single C stmt arch/arm/plat-omap/mcbsp.c: - remove pointless casts from void* - make longer lines more readable Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-06Initial blind fixup for arm for irq changesLinus Torvalds
Untested, but this should fix up the bulk of the totally mechanical issues, and should make the actual detail fixing easier. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-27[ARM] 3760/1: This patch adds timeouts while working with SSP registers. ↵Paul Sokolovsky
Such timeouts were en Patch from Paul Sokolovsky This patch adds timeouts while working with SSP registers. Such timeouts were envisioned by docstrings in ssp.c, but were not implemented. There were actual lockups while accessing touchscreen for iPaqs h1910, h4000 due to lack of the timeouts. This is updated version of previously submitted patch: 3738/1. Signed-off-by: Paul Sokolovsky <pmiscml@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
