path: root/arch/arm/mach-s5pc100/mach-smdkc100.c
2009-12-01SMDKC100: add SDHCI controllers 0, 1 and 2 supportKyungmin Park
Add required machine definitions for SDHCI controller 0, 1 and 2. SMDKC100 has 2 SDHCI/MMC ports. Port 1 is directly connected to controller 0. Port 1 can be conntected to controler 1 or 2, depending on jumper setup. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-12-01SMDKC100: add I2C0 and I2C1 buses supportKyungmin Park
Add required machine definitions for I2C 0 and 1 bus controllers. Currently no I2C device are defined yet. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-12-01SMDKC100: enable S3C FrameBufferKyungmin Park
Add required machine definitions for s3c-fb device. A 800x480 lcd device (simmilar to the one known from SMDK6410 boards) has been defined. The lcd controller is attached to GPIO lines and can be enabled/disabled with platform-lcd driver. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-12-01ARM: S5PC1XX: registers renameKyungmin Park
S5PC110 and S5PC100 register maps differs in many places, rename all defined registers to be S5PC100 specific. PA_SYS register known from S3C64XX series has been renamed to more adequate PA_CLK. Also system map has been also updated to cover more integrated peripherals. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-08-16ARM: S5PC100: Board and configuration fileByungho Min
SMDKC100 board support. The board can be obtained from meritech (http://www.meritech.co.kr) Signed-off-by: Byungho Min <bhmin@samsung.com> [ben-linux@fluff.org: fixup subject and description] Signed-off-by: Ben Dooks <ben-linux@fluff.org>
