This patch introduces common.[ch] which are used only in the
arch/arm/mach-s5p64x0/ directory. The common.c file merges
the cpu.c, init.c and irq-eint.c files which are used commonly
on S5P64X0 SoCs and the common.h local header file replaces
with plat/s5p6440.h and plat/s5p6450.h files.
Cc: Ben Dooks <ben-linux@fluff.org>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
* 'next/cleanup3' of git://git.linaro.org/people/arnd/arm-soc: (79 commits)
ARM: SAMSUNG: Move fimc plat. device from board files to plat-samsung
ARM: SAMSUNG: Cleanup resources by using macro
ARM: SAMSUNG: Cleanup plat-samsung/devs.c and devs.h
ARM: S5P: To merge devs.c files to one devs.c
ARM: S3C64XX: To merge devs.c files to one devs.c
ARM: S3C24XX: To merge s3c24xx devs.c files to one devs.c
ARM: S5P64X0: Add Power Management support
ARM: S5P: Make the sleep code common for S5P series SoCs
ARM: S5P: Make the common S5P PM code conditionally compile
ARM: SAMSUNG: Move S5P header files to plat-samsung
ARM: SAMSUNG: Move S3C24XX header files to plat-samsung
ARM: SAMSUNG: Moving each SoC support header files
ARM: SAMSUNG: Consolidate plat/pll.h
ARM: SAMSUNG: Consolidate plat/pwm-clock.h
ARM: SAMSUNG: Cleanup mach/clkdev.h
ARM: SAMSUNG: remove sdhci default configuration setup platform helper
ARM: EXYNOS4: Add FIMC device on SMDKV310 board
ARM: EXYNOS4: Add header file protection macros
ARM: EXYNOS4: Add usb ehci device to the SMDKV310
ARM: S3C2443: Add hsspi-clock from pclk and rename S3C2443 hsspi sclk
Fix up conflicts in
- arch/arm/mach-exynos4/{Kconfig,clock.c}
ARM_CPU_SUSPEND, various random device tables (gah!)
- drivers/gpio/Makefile
sa1100 gpio added, samsung gpio drivers merged
* 'next' of git://git.infradead.org/users/vkoul/slave-dma: (63 commits)
dmaengine: mid_dma: mask_peripheral_interrupt only when dmac is idle
dmaengine/ep93xx_dma: add module.h include
pch_dma: Reduce wasting memory
pch_dma: Fix suspend issue
dma/timberdale: free_irq() on an error path
dma: shdma: transfer based runtime PM
dmaengine: shdma: protect against the IRQ handler
dmaengine i.MX DMA/SDMA: add missing include of linux/module.h
dmaengine: delete redundant chan_id and chancnt initialization in dma drivers
dmaengine/amba-pl08x: Check txd->llis_va before freeing dma_pool
dmaengine/amba-pl08x: Add support for sg len greater than one for slave transfers
serial: sh-sci: don't filter on DMA device, use only channel ID
ARM: SAMSUNG: Remove Samsung specific enum type for dma direction
ASoC: Samsung: Update DMA interface
spi/s3c64xx: Merge dma control code
spi/s3c64xx: Add support DMA engine API
ARM: SAMSUNG: Remove S3C-PL330-DMA driver
ARM: S5P64X0: Use generic DMA PL330 driver
ARM: S5PC100: Use generic DMA PL330 driver
ARM: S5PV210: Use generic DMA PL330 driver
Fix up fairly trivial conflicts in
- arch/arm/mach-s5p64x0/dma.c
* 'next/board' of git://git.linaro.org/people/arnd/arm-soc: (34 commits)
ep93xx: add support Vision EP9307 SoM
ARM: mxs: Add initial support for DENX MX28
ARM: EXYNOS4: Add support SMDK4412 Board
ARM: EXYNOS4: Add MCT support for EXYNOS4412
ARM: EXYNOS4: Add functions for gic interrupt handling
ARM: EXYNOS4: Add support clock for EXYNOS4412
ARM: EXYNOS4: Add support new EXYNOS4412 SoC
ARM: EXYNOS4: Add support MCT PPI for EXYNOS4212
ARM: EXYNOS4: Add support PPI in external GIC
ARM: EXYNOS4: convert boot_params to atag_offset
ixp4xx: support omicron ixp425 based boards
ARM: EXYNOS4: Add support SMDK4212 Board
ARM: EXYNOS4: Add support PM for EXYNOS4212
ARM: EXYNOS4: Add support clock for EXYNOS4212
ARM: EXYNOS4: Add support new EXYNOS4212 SoC
at91: USB-A9G20 C01 & C11 board support
at91: merge board USB-A9260 and USB-A9263 together
at91: add support for RSIs EWS board
ARM: SAMSUNG: Fix mask value for S5P64X0 CPU IDs
ARM: SAMSUNG: Fix mask for S3C64xx CPU IDs
* 'next/cleanup' of git://git.linaro.org/people/arnd/arm-soc: (125 commits)
ARM: mach-mxs: fix machines' initializers order
mmc: mxcmmc: explicitly includes mach/hardware.h
arm/imx: explicitly includes mach/hardware.h in pm-imx27.c
arm/imx: remove mx27_setup_weimcs() from mx27.h
arm/imx: explicitly includes mach/hardware.h in mach-kzm_arm11_01.c
arm/imx: remove mx31_setup_weimcs() from mx31.h
ARM: tegra: devices.c should include devices.h
ARM: tegra: cpu-tegra: unexport two functions
ARM: tegra: cpu-tegra: sparse type fix
ARM: tegra: dma: staticify some tables and functions
ARM: tegra: tegra2_clocks: don't export some tables
ARM: tegra: tegra_powergate_is_powered should be static
ARM: tegra: tegra_rtc_read_ms should be static
ARM: tegra: tegra_init_cache should be static
ARM: tegra: pcie: 0 -> NULL changes
ARM: tegra: pcie: include board.h
ARM: tegra: pcie: don't cast __iomem pointers
ARM: tegra: tegra2_clocks: 0 -> NULL changes
ARM: tegra: tegra2_clocks: don't cast __iomem pointers
ARM: tegra: timer: don't cast __iomem pointers
Fix up trivial conflicts in
arch/arm/mach-omap2/Makefile,
arch/arm/mach-u300/{Makefile.boot,core.c}
arch/arm/plat-{mxc,omap}/devices.c
There are lots of conflicts between the omap and exynos cleanups
and the memory.h remove series.
arch/arm/mach-exynos4/mach-smdkc210.c
arch/arm/mach-exynos4/mach-smdkv310.c
arch/arm/mach-imx/mach-cpuimx27.c
arch/arm/mach-omap1/board-ams-delta.c
arch/arm/mach-omap1/board-generic.c
arch/arm/mach-omap1/board-h2.c
arch/arm/mach-omap1/board-h3.c
arch/arm/mach-omap1/board-nokia770.c
arch/arm/mach-omap1/board-osk.c
arch/arm/mach-omap1/board-palmte.c
arch/arm/mach-omap1/board-palmtt.c
arch/arm/mach-omap1/board-palmz71.c
arch/arm/mach-omap1/board-sx1.c
arch/arm/mach-omap1/board-voiceblue.c
arch/arm/mach-omap1/io.c
arch/arm/mach-omap2/board-generic.c
arch/arm/mach-omap2/io.c
arch/arm/plat-omap/io.c
The exynos4 updates conflict with code from the arm devel-stable branch
and new boards need to set atag_offset in place of boot_param.
arch/arm/Kconfig
arch/arm/mach-exynos4/include/mach/entry-macro.S
arch/arm/mach-exynos4/mct.c
arch/arm/mach-mxs/include/mach/gpio.h
arch/arm/plat-mxc/include/mach/gpio.h
drivers/video/omap/lcd_apollon.c
drivers/video/omap/lcd_ldp.c
drivers/video/omap/lcd_overo.c
Fix up all conflicts between the memory.h cleanup and bug fixes.
This sorts out merge conflicts with the arm/gpio branch that
already got merged into mainline Linux.
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm
* 'devel-stable' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (178 commits)
ARM: 7139/1: fix compilation with CONFIG_ARM_ATAG_DTB_COMPAT and large TEXT_OFFSET
ARM: gic, local timers: use the request_percpu_irq() interface
ARM: gic: consolidate PPI handling
ARM: switch from NO_MACH_MEMORY_H to NEED_MACH_MEMORY_H
ARM: mach-s5p64x0: remove mach/memory.h
ARM: mach-s3c64xx: remove mach/memory.h
ARM: plat-mxc: remove mach/memory.h
ARM: mach-prima2: remove mach/memory.h
ARM: mach-zynq: remove mach/memory.h
ARM: mach-bcmring: remove mach/memory.h
ARM: mach-davinci: remove mach/memory.h
ARM: mach-pxa: remove mach/memory.h
ARM: mach-ixp4xx: remove mach/memory.h
ARM: mach-h720x: remove mach/memory.h
ARM: mach-vt8500: remove mach/memory.h
ARM: mach-s5pc100: remove mach/memory.h
ARM: mach-tegra: remove mach/memory.h
ARM: plat-tcc: remove mach/memory.h
ARM: mach-mmp: remove mach/memory.h
ARM: mach-cns3xxx: remove mach/memory.h
Fix up mostly pretty trivial conflicts in:
- arch/arm/Kconfig
- arch/arm/include/asm/localtimer.h
- arch/arm/kernel/Makefile
- arch/arm/mach-shmobile/board-ap4evb.c
- arch/arm/mach-u300/core.c
- arch/arm/mm/dma-mapping.c
- arch/arm/mm/proc-v7.S
- arch/arm/plat-omap/Kconfig
largely due to some CONFIG option renaming (ie CONFIG_PM_SLEEP ->
CONFIG_ARM_CPU_SUSPEND for the arm-specific suspend code etc) and
addition of NEED_MACH_MEMORY_H next to HAVE_IDE.
* 'gpio' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (43 commits)
ARM: 7135/1: ep93xx: bring back missing <mach/gpio.h>
ARM: 7104/1: plat-pxa: break out GPIO driver specifics
ARM: 7103/1: plat-pxa: move PXA GPIO driver to GPIO subsystem
ARM: 7042/3: mach-ep93xx: break out GPIO driver specifics
ARM: 7101/1: arm/tegra: Replace <mach/gpio.h> with <mach/gpio-tegra.h>
ARM: 7094/1: arm/tegra: Move EN_VDD_1V05_GPIO to board-harmony.h
ARM: 7083/1: rewrite U300 GPIO to use gpiolib
ARM: 7074/1: gpio: davinci: eliminate unused variable warnings
ARM: 7063/1: Orion: gpio: add missing include of linux/types.h
ARM: 7055/1: arm/tegra: mach/gpio.h: include linux/types.h to fix build
ARM: 7054/1: arm/tegra: Delete custom gpio_to_irq, and irq_to_gpio
ARM: 7053/1: gpio/tegra: Implement gpio_chip.to_irq
ARM: 7052/1: gpio/tegra: Remove use of irq_to_gpio
ARM: 7057/1: mach-pnx4008: rename GPIO header
ARM: 7056/1: plat-nomadik: kill off <plat/gpio.h>
ARM: 7050/1: mach-sa1100: delete irq_to_gpio() function
ARM: 7049/1: mach-sa1100: move SA1100 GPIO driver to GPIO subsystem
ARM: 7045/1: mach-lpc32xx: break out GPIO driver specifics
ARM: 7044/1: mach-lpc32xx: move LPC32XX GPIO driver to GPIO subsystem
ARM: 7043/1: mach-ixp2000: rename GPIO header
Fix up trivial conflicts in arch/arm/mach-u300/Kconfig manually
arch/arm/mach-at91/board-usb-a9260.c
arch/arm/mach-at91/board-usb-a9263.c
arch/arm/mach-tegra/board-paz00.h
arch/arm/mach-tegra/board-seaboard.h
devel-stable
Boards used to specify zreladdr in their Makefile.boot with
zreladdr-y := x, so conflicting zreladdrs were silently overwritten.
This patch changes this to zreladdr-y += x, so that we end
up with multiple words in zreladdr in such a case. We can
detect this later and complain if necessary.
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Add suspend-to-ram support for SMDK6440/50
Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com>
arch/arm/plat-s5p/include/plat/pll.h
arch/arm/mach-exynos4/clock.c
arch/arm/mach-s3c2412/gpio.c
arch/arm/mach-s5p64x0/gpiolib.c
Removed
- arch/arm/plat-s3c24xx/include/mach/pwm-clock.h
- arch/arm/mach-s3c64xx/include/mach/pwm-clock.h
- arch/arm/mach-s5p64x0/include/mach/pwm-clock.h
- arch/arm/mach-s5pc100/include/mach/pwm-clock.h
- arch/arm/mach-s5pv210/include/mach/pwm-clock.h
- arch/arm/mach-exynos4/include/mach/pwm-clock.h
And created
- arch/arm/plat-samsung/include/plat/pwm-clock.h
[kgene.kim@samsung.com: changed title]
According to commit a3831cf ("ARM: Consolidate the
clkdev header files"), current mach/clkdev.h is no
needed in Samsung stuff.
This patch:
-- Adds platform device support for LCD-LTE480.
-- Adds platform data for FB with win_mode and default_bpp.
-- Enables FB device support and platform-lcd support.
-- Adds SPCON settings for LCD.
Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com>
This patch:
This patch adds GPIO lines settings(HSYNC, VSYNC, VCLK and VD) for LCD.
Set s3c_device_fb name as "s5p64x0-fb" for S5P6440 and S5P6450.
This patch adds:
-- Framebuffer related register mappings and bit fields.
-- IRQ number being used.
Some platforms (like OMAP not to name it) are doing rather complicated
hacks just to determine the base UART address to use. Let's give their
addruart macro some slack by providing an extra work register which will
allow for much needed cleanups.
This is basically a no-op as this commit is only adding the extra argument
to the macro but no one is using it yet.
Signed-off-by: nicolas Pitre <nicolas.pitre@linaro.org>
Reviewed-by: Kevin Hilman <khilman@ti.com>
arch/arm/mach-s5p64x0/clock-s5p6440.c
arch/arm/mach-s5p64x0/clock-s5p6450.c
arch/arm/mach-s5pc100/clock.c
arch/arm/mach-s5pv210/clock.c
into next/topic-dma-samsung
The default plat_data struct for TSADC is added in devs-ts.c
and duplication is removed from the following machines.
Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com>
This patch makes Samsung S5P64X0 to use DMA PL330 driver
on DMADEVICE. The S5P64X0 uses DMA generic APIs instead of
SAMSUNG specific S3C-PL330 APIs.
Signed-off-by: Boojin Kim <boojin.kim@samsung.com>
Acked-by: Vinod Koul <vinod.koul@intel.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
This patch adds to support PL330-DMA driver on DMADEVICE for S5P SoCs.
devel-stable
Signed-off-by: Jon Medhurst <tixy@yxit.co.uk>
CC: Kukjin Kim <kgene.kim@samsung.com>
According to commit 659fb32d1b67476f4ade25e9ea0e2642a5b9c4b5
("replace irq_gc_ack() with {set,clr}_bit variants"), this
should be fixed.
This patch adds devname for DMA clock.
NOTE: This patch should be added after merging new pl330 driver on dmaengine.
Rather than marking the mach/gpio.h header files which want to use the
trivial GPIOLIB implementation, mark those which do not want to use it
instead. This means that by default, you get the trivial implementation
and only have to do something extra if you need to. This should
encourage the use of the trivial default implementation.
As an additional bonus, several gpio.h header files become empty.
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Tested-by: Jamie Iles <jamie@jamieiles.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Many of the gpio_to_irq implementations use the gpiolib version of this
function. Provide the standard gpiolib gpio_to_irq() for everyone, but
allow platforms to override it if they wish. Add the neccessary
overrides for those platforms which do not use the standard definition.
Consolidate 24 trivial gpiolib implementions out of mach/gpio.h
into asm/gpio.h. This is basically the include of asm-generic/gpio.h
and the definition of gpio_get_value, gpio_set_value, and gpio_cansleep
as described in Documentation/gpio.txt
Tested-by: David Brown <davidb@codeaurora.org>
Acked-by: David Brown <davidb@codeaurora.org>
Tested-by: Linus Walleij <linus.walleij@linaro.org>
Tested-by: Shawn Guo <shawn.guo@linaro.org>
ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc
* 'next/devel' of ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (128 commits)
ARM: S5P64X0: External Interrupt Support
ARM: EXYNOS4: Enable MFC on Samsung NURI
ARM: EXYNOS4: Enable MFC on universal_c210
ARM: S5PV210: Enable MFC on Goni
ARM: S5P: Add support for MFC device
ARM: EXYNOS4: Add support FIMD on SMDKC210
ARM: EXYNOS4: Add platform device and helper functions for FIMD
ARM: EXYNOS4: Add resource definition for FIMD
ARM: EXYNOS4: Change devname for FIMD clkdev
ARM: SAMSUNG: Add IRQ_I2S0 definition
ARM: SAMSUNG: Add platform device for idma
ARM: EXYNOS4: Add more registers to be saved and restored for PM
ARM: EXYNOS4: Add more register addresses of CMU
ARM: EXYNOS4: Add platform device for dwmci driver
ARM: EXYNOS4: configure rtc-s3c on NURI
ARM: EXYNOS4: configure MAX8903 secondary charger on NURI
ARM: EXYNOS4: configure ADC on NURI
ARM: EXYNOS4: configure MAX17042 fuel gauge on NURI
ARM: EXYNOS4: configure regulators and PMIC(MAX8997) on NURI
ARM: EXYNOS4: Increase NR_IRQS for devices with more IRQs
Fix up tons of silly conflicts:
- arch/arm/mach-davinci/include/mach/psc.h
- arch/arm/mach-exynos4/Kconfig
- arch/arm/mach-exynos4/mach-smdkc210.c
- arch/arm/mach-exynos4/pm.c
- arch/arm/mach-imx/mm-imx1.c
- arch/arm/mach-imx/mm-imx21.c
- arch/arm/mach-imx/mm-imx25.c
- arch/arm/mach-imx/mm-imx27.c
- arch/arm/mach-imx/mm-imx31.c
- arch/arm/mach-imx/mm-imx35.c
- arch/arm/mach-mx5/mm.c
- arch/arm/mach-s5pv210/mach-goni.c
- arch/arm/mm/Kconfig
Add external interrupt support for S5P64X0.The external interrupt
group 0(0 to 15) is used for wake-up source in stop and sleep mode.
Add generic irq chip support
Signed-off-by: Padmavathi Venna <padma.v@samsung.com>
