There are lots of conflicts between the omap and exynos cleanups
and the memory.h remove series.
arch/arm/mach-exynos4/mach-smdkc210.c
arch/arm/mach-exynos4/mach-smdkv310.c
arch/arm/mach-imx/mach-cpuimx27.c
arch/arm/mach-omap1/board-ams-delta.c
arch/arm/mach-omap1/board-generic.c
arch/arm/mach-omap1/board-h2.c
arch/arm/mach-omap1/board-h3.c
arch/arm/mach-omap1/board-nokia770.c
arch/arm/mach-omap1/board-osk.c
arch/arm/mach-omap1/board-palmte.c
arch/arm/mach-omap1/board-palmtt.c
arch/arm/mach-omap1/board-palmz71.c
arch/arm/mach-omap1/board-sx1.c
arch/arm/mach-omap1/board-voiceblue.c
arch/arm/mach-omap1/io.c
arch/arm/mach-omap2/board-generic.c
arch/arm/mach-omap2/io.c
arch/arm/plat-omap/io.c
This patch moves SoC header files for supporting each SoCs to
plat-samsung directory. This is required to make one plat-
directory for Samsung SoCs.
Cc: Ben Dooks <ben-linux@fluff.org>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Use plat/regs-fb-v4.h in machine files instead of mach/regs-fb.h.
Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com>
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Acked-by: Eric Miao <eric.miao at canonical.com>
Since "s3c-fb: Automatically calculate pixel clock when none is given",
there's no need for manually calculating the pixel clock anymore so remove
these lines and add the correct refresh rate where appropriately.
Signed-off-by: Maurus Cuelenaere <mcuelenaere@gmail.com>
Cc: Pawel Osciak <p.osciak@samsung.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: InKi Dae <inki.dae@samsung.com>
devel-stable
arch/arm/Kconfig
arch/arm/Makefile
Move the core S3C64XX support to mach-s3c64xx as it is unlikely to be used
outside of this directory. Also move the SoC header files in with it.
This includes the clock, cpu, cpufreq, dma, gpiolib and pll support.
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
As per discussions with Russell King on linux-arm-kernel, it appears that
both mach-s3c6400 and mach-s3c6410 are so close together that they should
simply be merged into mach-s3c64xx.
Note, this patch does not eliminate any of the bits that are still common,
it is simply a move of the two directories together, any further common
code will be eliminated or moved in further patches.
