path: root/arch/arm/mach-s3c2412/mach-vstms.c
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-22[ARM] 4508/1: S3C: Move items to include/asm-arm/plat-s3cBen Dooks
This patch moves items of the s3c24xx support into a new plat-s3c directory for items that use the s3c24xx support but are not directly s3c24xx compatible, such as the s3c2400 and s3c6400. git mv commands: git mv include/asm-arm/arch-s3c2410/iic.h include/asm-arm/plat-s3c/iic.h git mv include/asm-arm/arch-s3c2410/nand.h include/asm-arm/plat-s3c/nand.h git mv include/asm-arm/arch-s3c2410/regs-iic.h include/asm-arm/plat-s3c/regs-iic.h git mv include/asm-arm/arch-s3c2410/regs-nand.h include/asm-arm/plat-s3c/regs-nand.h git mv include/asm-arm/arch-s3c2410/regs-rtc.h include/asm-arm/plat-s3c/regs-rtc.h git mv include/asm-arm/arch-s3c2410/regs-serial.h include/asm-arm/plat-s3c/regs-serial.h git mv include/asm-arm/arch-s3c2410/regs-timer.h include/asm-arm/plat-s3c/regs-timer.h git mv include/asm-arm/arch-s3c2410/regs-watchdog.h include/asm-arm/plat-s3c/regs-watchdog.h Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-04-21[ARM] 4325/1: S3C24XX: remove s3c24xx_boardBen Dooks
Remove the use of struct s3c24xx_board as this is just as easily done by using the platform device registration functions to make the initialisation sequence easier. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-16[ARM] 4209/1: S3C24XX: remove unnecessary includes of iomd.hBen Dooks
Machines in the S3C24XX architectures should not be including <asm/hardware/iomd.h> as this is not needed. Also remove commented out includes Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-11[ARM] 4157/2: S3C24XX: move arch/arch/mach-s3c2410 into cpu componentsBen Dooks
The following patch and script moves the arch/arm/mach-s3c2410 directory into arch/arm/plat-s3c24xx for the generic core code and inti arch/arm/mach-s3c{cpu} for the cpu/machine support files Include directory include/asm-arm/plat-s3c24xx is added for the core include files. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
