path: root/arch/arm/mach-s3c2412/Makefile
2010-12-17ARM S3C24XX: Fix compilation of PM code for S3C2416Yauhen Kharuzhy
S3C2416 PM code uses low-level sleep routines from S3C2412 code, but these routines are compiled only for S3C2412 SoC. Split S3C2412_PM to two parts: S3C2412_PM, S3C2412_PM_SLEEP and select last in S3C2416's Kconfig. Signed-off-by: Yauhen Kharuzhy <jekhor@gmail.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2009-07-30ARM: S3C2412: CPUFREQ: Add core support.Ben Dooks
Add core support for frequency scaling on the S3C2412 SoC. Signed-off-by: Ben Dooks <ben@simtec.co.uk> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-07-03[ARM] JIVE: Initial machine support for Logitech JiveBen Dooks
This is the base machine support for the Logitech Jive machine. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-01-28[ARM] 4779/1: S3C2412: Add s3c2412_gpio_set_sleepcfg() callBen Dooks
Add s3c2412_gpio_set_sleepcfg() to allow the setting of the sleep configuration of the GPIO blocks. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-28[ARM] 4731/1: S3C2412: Check for incomplete sleepBen Dooks
Check if the sleep command returns due to a pending interrupt in the standby unit. If this happens, try and ack the IRQ before re-trying the resume. It is currently unclear whether the resume can be backed out of at this stage as this could cause a problem with level based interrupts. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-11[ARM] 4157/2: S3C24XX: move arch/arch/mach-s3c2410 into cpu componentsBen Dooks
The following patch and script moves the arch/arm/mach-s3c2410 directory into arch/arm/plat-s3c24xx for the generic core code and inti arch/arm/mach-s3c{cpu} for the cpu/machine support files Include directory include/asm-arm/plat-s3c24xx is added for the core include files. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
