path: root/arch/arm/mach-s3c2410
2011-05-27Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (97 commits) mtd: kill CONFIG_MTD_PARTITIONS mtd: remove add_mtd_partitions, add_mtd_device and friends mtd: convert remaining users to mtd_device_register() mtd: samsung onenand: convert to mtd_device_register() mtd: omap2 onenand: convert to mtd_device_register() mtd: txx9ndfmc: convert to mtd_device_register() mtd: tmio_nand: convert to mtd_device_register() mtd: socrates_nand: convert to mtd_device_register() mtd: sharpsl: convert to mtd_device_register() mtd: s3c2410 nand: convert to mtd_device_register() mtd: ppchameleonevb: convert to mtd_device_register() mtd: orion_nand: convert to mtd_device_register() mtd: omap2: convert to mtd_device_register() mtd: nomadik_nand: convert to mtd_device_register() mtd: ndfc: convert to mtd_device_register() mtd: mxc_nand: convert to mtd_device_register() mtd: mpc5121_nfc: convert to mtd_device_register() mtd: jz4740_nand: convert to mtd_device_register() mtd: h1910: convert to mtd_device_register() mtd: fsmc_nand: convert to mtd_device_register() ... Fixed up trivial conflicts in - drivers/mtd/maps/integrator-flash.c: removed in ARM tree - drivers/mtd/maps/physmap.c: addition of afs partition probe type clashing with removal of CONFIG_MTD_PARTITIONS
2011-05-25mtd: s3c2410: remove CONFIG_MTD_PARTITIONS testJamie Iles
MTD is now always build with partitioning support so this can be removed. Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-05-23Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (137 commits) ARM: bcmring: convert to use sp804 clockevents ARM: bcmring: convert to sp804 clocksource ARM: 6912/1: bcmring: Add clkdev table in init_early clockevents: ARM sp804: obtain sp804 timer rate via clks clockevents: ARM sp804: allow clockevent name to be specified clocksource: ARM sp804: obtain sp804 timer rate via clks clocksource: ARM sp804: allow clocksource name to be specified clocksource: convert OMAP1 to 32-bit down counting clocksource clocksource: convert MXS timrotv2 to 32-bit down counting clocksource clocksource: convert SPEAr platforms 16-bit up counting clocksource clocksource: convert Integrator/AP 16-bit down counting clocksource clocksource: convert W90x900 24-bit down counting clocksource clocksource: convert ARM 32-bit down counting clocksources clocksource: convert ARM 32-bit up counting clocksources clocksource: add common mmio clocksource ARM: update sa1100 to reflect PXA updates ARM: omap1: convert to using readl/writel instead of volatile struct ARM: omap1: delete useless interrupt handler ARM: s5p: consolidate selection of timer register ARM: 6939/1: fix missing 'cpu_relax()' declaration ...
2011-05-23Merge branch 'usb-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6 * 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (205 commits) USB: EHCI: Remove SPARC_LEON {read,write}_be definitions from ehci.h USB: UHCI: Support big endian GRUSBHC HC sparc: add {read,write}*_be routines USB: UHCI: Add support for big endian descriptors USB: UHCI: Use ACCESS_ONCE rather than using a full compiler barrier USB: UHCI: Add support for big endian mmio usb-storage: Correct adjust_quirks to include latest flags usb/isp1760: Fix possible unlink problems usb/isp1760: Move function isp1760_endpoint_disable() within file. USB: remove remaining usages of hcd->state from usbcore and fix regression usb: musb: ux500: add configuration and build options for ux500 dma usb: musb: ux500: add dma glue layer for ux500 usb: musb: ux500: add dma name for ux500 usb: musb: ux500: add ux500 specific code for gadget side usb: musb: fix compile error usb-storage: fix up the unusual_realtek device list USB: gadget: f_audio: Fix invalid dereference of initdata EHCI: don't rescan interrupt QHs needlessly OHCI: fix regression caused by nVidia shutdown workaround USB: OTG: msm: Free VCCCX regulator even if we can't set the voltage ...
2011-05-23Merge branches 'consolidate-clksrc', 'consolidate-flash', ↵Russell King
'consolidate-generic', 'consolidate-smp', 'consolidate-stmp' and 'consolidate-zones' into consolidate
2011-05-20ARM: 6910/1: MTD: physmap: let set_vpp() pass a platform_device instead of a ↵Marc Zyngier
map_info The set_vpp() method provided by physmap passes a map_info back to the platform code, which has little relevance as far as the platform is concerned (this parameter is completely unused). Instead, pass the platform_device, which can be used in the pismo driver to retrieve some important information in a nicer way, instead of the hack that was in place. The empty set_vpp function in board-at572d940hf_ek.c is left untouched, as the board/SoC is scheduled for removal. Cc: Andrew Victor <linux@maxim.org.za> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Philipp Zabel <philipp.zabel@gmail.com> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Acked-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-10ARM: S3C24XX: Add plaform device definition for USB High-Speed gadget ↵Thomas Abraham
controller. S3C2416, S3C2443 and S3C2450 includes a USB High-Speed Gadget controller module. This patch adds the following for supporting this controller. 1. Definition for USB High-Speed controller base address. 2. Platform device instantiation. 3. Declaration for platform data structure. 4. Functionality to setup platform data for the controller. Signed-off-by: Thomas Abraham <thomas.ab@samsung.com> Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-10ARM: S3C2416: Add USB Phy register definitionsThomas Abraham
Add register definitions required to configure the USB Phy. The definitions for PHYCTRL, PHYPWR, URSTCON and UCLKCON registers and corresponding bit field definitions are added. Signed-off-by: Thomas Abraham <thomas.ab@samsung.com> Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-24ARM / Samsung: Use struct syscore_ops for "core" power managementRafael J. Wysocki
Replace sysdev classes and struct sys_device objects used for "core" power management by Samsung platforms with struct syscore_ops objects that are simpler. This generally reduces the code size and the kernel memory footprint. It also is necessary for removing sysdevs entirely from the kernel in the future. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-29arm: Fold irq_set_chip/irq_set_handlerThomas Gleixner
Use irq_set_chip_and_handler() instead. Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Cleanup the irq namespaceThomas Gleixner
Convert to the new function names. Automated with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-21ARM: H1940/RX1950: Change default LED triggersVasily Khoruzhick
Change LED triggers to mimic WinMobile behavior: red blinking when battery is charging, orange solid when battery is charged. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-03-20ARM: S3C2410: H1940: Fix lcd_power_set functionVasily Khoruzhick
Current implementation of lcd_power_set is not reliable, sometimes it does not enable LCD at all. Mimic WinCE behavior to fix this issue. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-03-20ARM: S3C2410: H1940: Add battery supportVasily Khoruzhick
Add battery monitoring/charging support via pda_power and s3c_adc_battery drivers Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-03-20ARM: S3C2410: H1940: Use leds-gpio driver for LEDs managingVasily Khoruzhick
We can use generic leds-gpio driver, as latch api was converted to gpiolib. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-03-20ARM: S3C2410: H1940: Make h1940-bluetooth.c compile againVasily Khoruzhick
It was broken by removal of rfkill_set_led_trigger_name function, and now compiler complains about implicit declaration. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-03-20ARM: S3C2410: H1940: Add keys deviceArnaud Patard (Rtp)
Add buttons definition for H1940. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-03-16Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (91 commits) ARM: 6806/1: irq: introduce entry and exit functions for chained handlers ARM: 6781/1: Thumb-2: Work around buggy Thumb-2 short branch relocations in gas ARM: 6747/1: P2V: Thumb2 support ARM: 6798/1: aout-core: zero thread debug registers in a.out core dump ARM: 6796/1: Footbridge: Fix I/O mappings for NOMMU mode ARM: 6784/1: errata: no automatic Store Buffer drain on Cortex-A9 ARM: 6772/1: errata: possible fault MMU translations following an ASID switch ARM: 6776/1: mach-ux500: activate fix for errata 753970 ARM: 6794/1: SPEAr: Append UL to device address macros. ARM: 6793/1: SPEAr: Remove unused *_SIZE macros from spear*.h files ARM: 6792/1: SPEAr: Replace SIZE macro's with SZ_4K macros ARM: 6791/1: SPEAr3xx: Declare device structures after shirq code ARM: 6790/1: SPEAr: Clock Framework: Rename usbd clock and align apb_clk entry ARM: 6789/1: SPEAr3xx: Rename sdio to sdhci ARM: 6788/1: SPEAr: Include mach/hardware.h instead of mach/spear.h ARM: 6787/1: SPEAr: Reorder #includes in .h & .c files. ARM: 6681/1: SPEAr: add debugfs support to clk API ARM: 6703/1: SPEAr: update clk API support ARM: 6679/1: SPEAr: make clk API functions more generic ARM: 6737/1: SPEAr: formalized timer support ...
2011-03-07ARM: s3c24xx: Switch to common GPIO controlled UDC pullup implementationLars-Peter Clausen
Currently all boards using the s3c2410_udc driver use a GPIO to control the state of the pullup, as a result the same code is reimplemented in each board This patch changes these boards to use the common implementation for GPIO controlled pullup in the UDC driver. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17ARM: P2V: separate PHYS_OFFSET from platform definitionsRussell King
This uncouple PHYS_OFFSET from the platform definitions, thereby facilitating run-time computation of the physical memory offset. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Magnus Damm <damm@opensource.se> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-15Merge branch 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-arm: (161 commits) ARM: pxa: fix building issue of missing physmap.h ARM: mmp: PXA910 drive strength FAST using wrong value ARM: mmp: MMP2 drive strength FAST using wrong value ARM: pxa: fix recursive calls in pxa_low_gpio_chip AT91: Support for gsia18s board AT91: Acme Systems FOX Board G20 board files AT91: board-sam9m10g45ek.c: Remove duplicate inclusion of mach/hardware.h ARM: pxa: fix suspend/resume array index miscalculation ARM: pxa: use cpu_has_ipr() consistently in irq.c ARM: pxa: remove unused variable in clock-pxa3xx.c ARM: pxa: fix warning in zeus.c ARM: sa1111: fix typo in sa1111_retrigger_lowirq() ARM mxs: clkdev related compile fixes ARM i.MX mx31_3ds: Fix MC13783 regulator names ARM: plat-stmp3xxx: irq_data conversion. ARM: plat-spear: irq_data conversion. ARM: plat-orion: irq_data conversion. ARM: plat-omap: irq_data conversion. ARM: plat-nomadik: irq_data conversion. ARM: plat-mxc: irq_data conversion. ... Fix up trivial conflict in arch/arm/plat-omap/gpio.c (Lennert Buytenhek's irq_data conversion clashing with some omap irq updates)
2011-01-06Merge branch 'next-s3c24xx' into for-nextKukjin Kim
2011-01-06ARM: S3C24XX: Add address map and clock definitions for HSMMC0Yauhen Kharuzhy
Define maps for HSMMC devices. S3C2443 has one HSMMC device with base address 0x4A800000. S3C2416 has HSMMC0 at 0x4AC00000 and HSMMC1 at 0x4A800000. So suppose that S3C2443 has only HSMMC1. Define clock for hsmmc0 device and register it. Signed-off-by: Yauhen Kharuzhy <jekhor@gmail.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-01-03ARM: S3C24XX: irq_data conversionLennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> [kgene.kim@samsung.com: coding-style fixes] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-12-13Merge branch 'topic/workq-update' into topic/asocTakashi Iwai
Conflicts: sound/soc/codecs/wm8350.c sound/soc/codecs/wm8753.c sound/soc/sh/fsi.c sound/soc/soc-core.c
2010-11-25ARM: S3C2410: Adapt h1940-bluetooth to gpiolib changesVasily Khoruzhick
Replace in s3c_gpio_cfgpull with s3c_gpio_setpull. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-11-23ARM: Samsung: Define common audio-dma deviceJassi Brar
The ASoC uses common DMA driver for Audio devices. So it makes sense to a common audio-dma device shared across all platforms. Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-10-30Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (215 commits) ARM: memblock: setup lowmem mappings using memblock ARM: memblock: move meminfo into find_limits directly ARM: memblock: convert free_highpages() to use memblock ARM: move freeing of highmem pages out of mem_init() ARM: memblock: convert memory detail printing to use memblock ARM: memblock: use memblock to free memory into arm_bootmem_init() ARM: memblock: use memblock when initializing memory allocators ARM: ensure membank array is always sorted ARM: 6466/1: implement flush_icache_all for the rest of the CPUs ARM: 6464/2: fix spinlock recursion in adjust_pte() ARM: fix memblock breakage ARM: 6465/1: Fix data abort accessing proc_info from __lookup_processor_type ARM: 6460/1: ixp2000: fix type of ixp2000_timer_interrupt ARM: 6449/1: Fix for compiler warning of uninitialized variable. ARM: 6445/1: fixup TCM memory types ARM: imx: Add wake functionality to GPIO ARM: mx5: Add gpio-keys to mx51 babbage board ARM: imx: Add gpio-keys to plat-mxc mx31_3ds: Fix spi registration mx31_3ds: Fix the logic for detecting the debug board ...
2010-10-30ARM: Merge for-2637/s3c24xx/h1940Ben Dooks
2010-10-30ARM: h1940: add UDA1380 to i2c devices listVasily Khoruzhick
Register UDA1380 codec during H1940 machine init Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-10-30ARM: h1940: Fix backlight and LCD power functionsVasily Khoruzhick
Current implementation of LCD and backlight power control functions is not complete, as result PDA consumes power in suspend. Fix this issue by managing state of some latch bits, just like WinMobile does. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-10-28Merge branch 'for-rmk' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into devel-stable Conflicts: arch/arm/mach-s3c64xx/dev-audio.c
2010-10-25ARM: S3C: Change VMALLOC_END to use more vmalloc()/ioremap() areaKukjin Kim
This patch changes VMALLOC_END from 0xE0000000 to 0xF6000000, because some systems want to use more vmalloc()/ioremap() area and now don't use from at 0xE0000000 to 0xF6000000 (the start of Samsung SoCs' VA space) Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-20ARM: S3C2416: Add Power Management support for SMDK2416Abhilash Kesavan
Adds suspend-to-ram support for SMDK2416 based on existing 2412 PM code Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com> Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-20ARM: S3C24XX: Fix gpiolib support for ports K..MYauhen Kharuzhy
S3C2443 and S3C2416 has 12 GPIO banks (from A to M), increase ARCH_NR_GPIOS for this architectures. Also typo from previous commit has been fixed: CONFIG_CPU_S3C24XX instead CONFIG_CPU_244X. Signed-off-by: Yauhen Kharuzhy <jekhor@gmail.com> Tested-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-10-20arm: return both physical and virtual addresses from addruartJeremy Kerr
Rather than checking the MMU status in every instance of addruart, do it once in kernel/debug.S, and change the existing addruart macros to return both physical and virtual addresses. The main debug code can then select the appropriate address to use. This will also allow us to retreive the address of a uart for the MMU state that we're not current in. Updated with fixes for OMAP from Jason Wang <jason77.wang@gmail.com> and Tony Lindgren <tony@atomide.com>, and fix for versatile express from Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Jason Wang <jason77.wang@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-27ARM: h1940: Implement mmc_power functionVasily Khoruzhick
This patch implements h1940-specific set_power callback for s3cmci driver, so card power can be disabled when card is not inserted or before suspend. Without this patch PDA consumes power in suspend when card is inserted. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-09-26ARM: h1940: Use gpiolib for latch accessVasily Khoruzhick
This patch adds gpiolib support for h1940 latch. With this patch it's possible to use leds-gpio and uda1380 drivers (they require gpiolib support for appropriate pins). And now it's possible to drop leds-h1940 driver. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-08-27ARM: SAMSUNG: Fix on build warning regarding VMALLOC_END typeKukjin Kim
Fix this warning: arch/arm/mm/init.c: In function 'mem_init': arch/arm/mm/init.c:644: warning: format '%08lx' expects type 'long unsigned int', but argument 12 has type 'unsigned int' And removes the useless parens and white space. Reported-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Cc: Ben Dooks <ben-linux@fluff.org>
2010-07-27ARM: Convert platform reservations to use LMB rather than bootmemRussell King
2010-07-16ARM: Move platform memory reservations out of generic codeRussell King
Move the platform specific bootmem memory reservations out of arch/arm/mm/mmu.c into their respective platform files. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-20ARM: SAMSUNG: Move WDT device definitions in plat-samsungBanajit Goswami
This patch moves the definitions of watchdog timer device from plat-s3c24xx to plat-samsung. This will enable all Samsung S3C and S5P series SoC's to use common WDT device definition. Signed-off-by: Banajit Goswami <banajit.g@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-19ARM: SAMSUNG: Implements cfg_gpio function for Samsung touchscreenNaveen Krishna
This patch implements cfg_gpio function for Samsung touchscreen. And also modifies the H1940 machine respectively. Signed-off-by: Naveen Krishna Ch <ch.naveen@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-19ARM: SAMSUNG: Move mach/ts.h to plat/ts.hMaurus Cuelenaere
This moves mach-s3c2410/include/mach/ts.h to plat-samsung/include/plat/ts.h in order to prepare for s3c64xx support in the touchscreen driver. Signed-off-by: Maurus Cuelenaere <mcuelenaere@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-19ARM: Merge for-2635/fb-updates1Ben Dooks
Merge branch 'for-2635/fb-updates1' into for-linus/samsung2
2010-05-19ARM: Merge for-2635/gpio2Ben Dooks
Merge branch 'for-2635/gpio2' into for-linus/samsung2
2010-05-19ARM: Merge for-2635/rx1950Ben Dooks
Merge branch 'for-2635/rx1950' into for-linus/samsung2
2010-05-19ARM: Merge for-2635/acer-n35Ben Dooks
Merge branch 'for-2635/acer-n35' into for-linus/samsung2
