path: root/arch/arm/mach-realview
2010-08-03Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (291 commits) ARM: AMBA: Add pclk support to AMBA bus infrastructure ARM: 6278/2: fix regression in RealView after the introduction of pclk ARM: 6277/1: mach-shmobile: Allow users to select HZ, default to 128 ARM: 6276/1: mach-shmobile: remove duplicate NR_IRQS_LEGACY ARM: 6246/1: mmci: support larger MMCIDATALENGTH register ARM: 6245/1: mmci: enable hardware flow control on Ux500 variants ARM: 6244/1: mmci: add variant data and default MCICLOCK support ARM: 6243/1: mmci: pass power_mode to the translate_vdd callback ARM: 6274/1: add global control registers definition header file for nuc900 mx2_camera: fix type of dma buffer virtual address pointer mx2_camera: Add soc_camera support for i.MX25/i.MX27 arm/imx/gpio: add spinlock protection ARM: Add support for the LPC32XX arch ARM: LPC32XX: Arch config menu supoport and makefiles ARM: LPC32XX: Phytec 3250 platform support ARM: LPC32XX: Misc support functions ARM: LPC32XX: Serial support code ARM: LPC32XX: System suspend support ARM: LPC32XX: GPIO, timer, and IRQ drivers ARM: LPC32XX: Clock driver ...
2010-07-31Merge branches 'at91', 'ep93xx', 'kexec', 'iop', 'lmb', 'nomadik', 'nuc', ↵Russell King
'pl', 'spear' and 'versatile' into devel
2010-07-31ARM: 6278/2: fix regression in RealView after the introduction of pclkLinus Walleij
The patch to add the apb_pclk to the AMBA/PrimeCell bus broke RealView, since the clockdevice is not registered at probe() time. This moves clock initialization to a core_initcall() [rmk:moved before the problematical commit to avoid bisect problems] Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-30ARM: Fix Versatile/Realview/VExpress MMC card detection senseRussell King
The MMC card detection sense has become really confused with negations at various levels, leading to some platforms not detecting inserted cards. Fix this by converting everything to positive logic throughout, thereby getting rid of these negations. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-22ARM: AMBA: Add pclk definition for platforms using primecellsRussell King
Add a dummy clk definition for the APB pclk signal on all platforms using the AMBA bus infrastructure. This ensures that these platforms continue to work when the core amba bus code controls the APB pclk. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-18ARM: 6215/2: add character LCD platform data for RealView and VersatileLinus Walleij
This adds some platform data for the character LCD found in the RealView and Versatile reference designs from ARM. Signed-off-by: Linus Walleij <triad@df.lth.se> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-16ARM: Remove 'node' argument form arch_adjust_zones()Russell King
Since we no longer support discontigmem, node is always zero, so remove this argument. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-15ARM: 6227/1: PL022 SSP platform data for the RealViewsLinus Walleij
This adds platform data for the PL022 to the ARM RealView reference designs, adds the necessary clock definition and fixes a badly defined IRQ line on the PB1176. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-09ARM: 6204/1: Fixups for the RealView PB1176Linus Walleij
This is a number of basic fixes to the PB1176 that makes it tick properly: - Detect MMC insertion/removal even when PL061 GPIO is not compiled in. The register to read this status directly is removed on the PB1176. - Define the UART3 on the DevChip (where is actually is) and define the new UART4 serial port on the FPGA. - Also define the clocks for these two UARTs apropriately. - Remove the false notion that the PB1176 should have its CLCD on the ISSP, this is not the case, it is in the DevChip. - Remove the defintions and the previously commented-out PL081 DMAC. As confirmed by mail this was found to be broken on the PB1176 board and removed from the subsequent FPGA images. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-02ARM: 6201/1: RealView: Do not use outer_sync() on ARM11MPCore boards with L220Catalin Marinas
RealView boards with certain revisions of the L220 cache controller (ARM11* processors only) may have issues (hardware deadlock) with the recent changes to the mb() barrier implementation (DSB followed by an L2 cache sync). The patch redefines the RealView ARM11MPCore mandatory barriers without the outer_sync() call. Cc: <stable@kernel.org> Tested-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-01ARM: 6193/1: RealView: Align the machine_desc.phys_io to 1MB sectionCatalin Marinas
When not aligned, random bits could be written in the initial page table by the __create_page_tables() function. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-17Merge branch 'devel-stable' into develRussell King
Conflicts: arch/arm/Kconfig arch/arm/include/asm/system.h arch/arm/mm/Kconfig
2010-05-17Merge branches 'at91', 'bcmring', 'ep93xx', 'iop', 'misc', 'nomadik', ↵Russell King
'omap', 'pxa', 'spear' and 'versatile' into devel Conflicts: arch/arm/Makefile arch/arm/common/Makefile arch/arm/mm/Kconfig
2010-05-15ARM: rename mach_cpu_disable() to platform_cpu_disable()Russell King
Consistently name all SMP platform related functions. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-02ARM: 6057/1: Realview: register PMU IRQs during board initialisationWill Deacon
This patch updates the initialisation routines for the Realview boards and the Versatile Express board [ca9x4 tile] so that they register their PMU IRQs with the PMU framework in the Kernel. Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-02ARM: Indirect round/set_rate operations through clk structureRussell King
2010-05-02ARM: 5890/1: Fix incorrect Realview board IRQs for L220 and PMUWill Deacon
In anticipation of PMU support for Realview boards, the IRQs defined for some of these boards need updating. This patch removes incorrect L220 IRQ definitions, corrects incorrect PMU IRQs and adds any missing IRQs that are required. Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-02ARM: Make Integrator/Versatile/Reaview VCO code similarRussell King
2010-05-02ARM: Realview/Versatile: separate out common sched_clock()Russell King
Provide a common sched_clock() implementation for Versatile and Realview. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-02ARM: Realview/Versatile/Integrator: remove unused definitions from platform.hRussell King
2010-05-02ARM: Realview/Versatile: separate out common SP804 timer codeRussell King
2010-05-02ARM: Realview/Versatile/Integrator: separate out common clock codeRussell King
2010-05-02ARM: ICST: kill duplicate icst codeRussell King
The only difference between ICST307 and ICST525 are the two arrays for calculating the S parameter; the code is now identical. Merge the two files and kill the duplicated code. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-02ARM: ICST: indirect s2div and idx2s arrays via icst_paramsRussell King
2010-05-02ARM: ICST: move minimum VCO frequency to icst_paramsRussell King
2010-05-02ARM: ICST: use Hz instead of kHzRussell King
This makes the ICST support fit more nicely with the clk API, eliminating the need to *1000 and /1000 in places. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-02ARM: ICST: provide definitions for max/min VCO frequenciesRussell King
2010-05-02ARM: ICST: merge common ICST VCO structuresRussell King
The structures for the ICST307 and ICST525 VCO devices are identical, so merge them together. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-04-28ARM: 5957/1: ARM: RealView SD/MMC Card detection and write-protect using GPIOLIBColin Tuckley
The switch to using GPIOLIB broke the sd/mmc card detection on the RealView development boards if GPIO_PL061 was not selected. This patch selects GPIO_PL061 if GPIOLIB is selected. The sense of the return value from mmc_status has also changed and is corrected. Signed-off-by: Colin Tuckley <colin.tuckley@arm.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-01Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (100 commits) ARM: Eliminate decompressor -Dstatic= PIC hack ARM: 5958/1: ARM: U300: fix inverted clk round rate ARM: 5956/1: misplaced parentheses ARM: 5955/1: ep93xx: move timer defines into core.c and document ARM: 5954/1: ep93xx: move gpio interrupt support to gpio.c ARM: 5953/1: ep93xx: fix broken build of clock.c ARM: 5952/1: ARM: MM: Add ARM_L1_CACHE_SHIFT_6 for handle inside each ARCH Kconfig ARM: 5949/1: NUC900 add gpio virtual memory map ARM: 5948/1: Enable timer0 to time4 clock support for nuc910 ARM: 5940/2: ARM: MMCI: remove custom DBG macro and printk ARM: make_coherent(): fix problems with highpte, part 2 MM: Pass a PTE pointer to update_mmu_cache() rather than the PTE itself ARM: 5945/1: ep93xx: include correct irq.h in core.c ARM: 5933/1: amba-pl011: support hardware flow control ARM: 5930/1: Add PKMAP area description to memory.txt. ARM: 5929/1: Add checks to detect overlap of memory regions. ARM: 5928/1: Change type of VMALLOC_END to unsigned long. ARM: 5927/1: Make delimiters of DMA area globally visibly. ARM: 5926/1: Add "Virtual kernel memory..." printout. ARM: 5920/1: OMAP4: Enable L2 Cache ... Fix up trivial conflict in arch/arm/mach-mx25/clock.c
2010-02-25Merge branches 'clks' and 'pnx' into develRussell King
2010-02-25Merge branch 'misc2' into develRussell King
2010-02-15ARM: 5928/1: Change type of VMALLOC_END to unsigned long.Fenkart/Bostandzhyan
Makes it consistent with VMALLOC_START Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Andreas Fenkart <andreas.fenkart@streamunlimited.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-12ARM: Consolidate clks_register() and similarRussell King
Most machine classes want some way to register a block of clk_lookup structures, and most do it by implementing a clks_register() type function which walks an array, or by open-coding a loop. Consolidate all this into clkdev_add_table(). Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-12ARM: 5910/1: ARM: Add tmp register for addruart and loadspTony Lindgren
Otherwise more complicated uart configuration won't be possible. We can use r1 for tmp register for both head.S and debug.S. NOTE: This patch depends on another patch to add the the tmp register into all debug-macro.S files. That can be done with: $ sed -i -e "s/addruart,rx|addruart, rx/addruart, rx, tmp/" arch/arm/*/include/*/debug-macro.S Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-01-30ARM: 5907/1: ARM: Fix the reset on the RealView PBX Development boardColin Tuckley
2010-01-11ARM: 5873/1: ARM: Fix the reset logic for ARM RealView boardsColin Tuckley
Extend the patch from Philby John to the other "RealView" boards. Rename the constants and offsets to reflect their actual functions. Cc: Philby John <pjohn@in.mvista.com> Signed-off-by: Colin Tuckley <colin.tuckley@arm.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-09ARM: RealView: Fix typo in the RealView/PBX Kconfig entryCatalin Marinas
A previous patch was introducing a SPARSEMEM dependency on !HIGH_PHYS_OFFSET but it should actually be !REALVIEW_HIGH_PHYS_OFFSET. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-11-05RealView: Add sparsemem support for the RealView PBX platformCatalin Marinas
The RealView PBX board has two 512MB blocks of memory - one at 0x70000000 (with 256MB mirror at 0) and another at 0x20000000. Only the block at 0x70000000 (or the mirror at 0) may be used for DMA (e.g. framebuffer). This patch adds the sparsemem definitions to allow the use of all the memory split as follows: 256MB @ 0x00000000 (ZONE_DMA) 512MB @ 0x20000000 (ZONE_NORMAL) 256MB @ 0x80000000 (ZONE_NORMAL) Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-11-05RealView: Remove duplicated #define REALVIEW_SYS_FLAGS* statementsColin Tuckley
The platsmp.c file defines the REALVIEW_SYS_FLAGS* macros which are already present in platform.h. Just use the latter. Signed-off-by: Colin Tuckley <colin.tuckley@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-11-05RealView: Add default memory configurationCatalin Marinas
This patch adds a realview_fixup() function called during booting to set up the memory banks. This way there is no need to pass a "mem=" argument on the kernel command line. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-11-01ARM: 5774/1: Fix Realview ARM1176PB board rebootPhilby John
This is the fix for proper reboot of Realview ARM1176PB board when issuing the reboot command. Setting the eighth bit of control register SYS_RESETCTL to 1 to force a soft reset. arch_reset() is modified for realview machines to call machine specific reset function pointers. Signed-off-by: Philby John <pjohn@in.mvista.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-22ARM: 5720/1: Move MMCI header to amba include dirLinus Walleij
This moves the mmci platform data definition struct away from arch/arm/include/asm/mach/mmc.h into the more proper place among the other primecells in include/linux/amba/mmci.h and at the same time renames it to "mmci.h", and also the struct in this file confusingly named mmc_platform_data has been renamed mmci_platform_data for clarity. Cc: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-21ARM: 5718/1: Sane busids for RealView board componentsLinus Walleij
This removes the totally bogus bus ID:s with two-digit hex numerals either referring to the base address of corresponding versatile machine or just some arbitrarily chosen digit in favor of just using the device identifier as a string. I kept the "dev:" prefix for DevChips, "fpga:" prefix for FPGA:s and "issp:" prefix for the other processor bus, just in case someone likes them. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-12Merge branch 'devel-stable' into develRussell King
Conflicts: MAINTAINERS arch/arm/mm/fault.c
2009-09-02MMC: MMCI: convert realview MMC to use gpiolibRussell King
2009-07-24nommu: Do not allow REALVIEW_HIGH_PHYS_OFFSET if !MMUCatalin Marinas
2009-07-24nommu: Add MMU-less support for the RealView boardsCatalin Marinas
This patch defines the IO_ADDRESS macro for the !CONFIG_MMU case. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-07-24Thumb-2: Pass a Thumb-2 address to the secondary CPUs to jump toCatalin Marinas
This patch sets bit 0 in the startup address passed to the secondary CPUs so that they branch into Thumb-2 mode. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
