In commit f0fba2ad (ASoC: multi-component - ASoC Multi-Component
Support), the name of the ak4104 codec driver was changed without
amending the platform code which uses it as well.
Signed-off-by: Daniel Mack <zonque@gmail.com>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
The display requires some milliseconds between GPIO_TFT_VA_EN
and GPIO_DISPLAY_ENABLE. Reorder initialisation to comply with
the display spec.
Also tune timings for better compliance with the spec.
Signed-off-by: Sven Neumann <s.neumann@raumfeld.com>
Acked-by: Daniel Mack <zonque@gmail.com>
The backlight control is going to change back to PWM in the
upcoming Raumfeld Controller hardware revision.
The file mfp-pxa2xx.c defines a macro, PGSR(), which translates a gpio
bank number to a PGSR register address. The function pxa2xx_mfp_suspend()
erroneously passed in a gpio number instead of a gpio bank number.
Signed-off-by: Paul Parsons <lost.distance@yahoo.com>
Cc: stable@kernel.org
Some files use GPIOF_ macros but don't include the header file
for them. These macros are being moved to <linux/gpio.h>, so add
includes for <linux/gpio.h> where needed.
* git://git.infradead.org/mtd-2.6: (97 commits)
mtd: kill CONFIG_MTD_PARTITIONS
mtd: remove add_mtd_partitions, add_mtd_device and friends
mtd: convert remaining users to mtd_device_register()
mtd: samsung onenand: convert to mtd_device_register()
mtd: omap2 onenand: convert to mtd_device_register()
mtd: txx9ndfmc: convert to mtd_device_register()
mtd: tmio_nand: convert to mtd_device_register()
mtd: socrates_nand: convert to mtd_device_register()
mtd: sharpsl: convert to mtd_device_register()
mtd: s3c2410 nand: convert to mtd_device_register()
mtd: ppchameleonevb: convert to mtd_device_register()
mtd: orion_nand: convert to mtd_device_register()
mtd: omap2: convert to mtd_device_register()
mtd: nomadik_nand: convert to mtd_device_register()
mtd: ndfc: convert to mtd_device_register()
mtd: mxc_nand: convert to mtd_device_register()
mtd: mpc5121_nfc: convert to mtd_device_register()
mtd: jz4740_nand: convert to mtd_device_register()
mtd: h1910: convert to mtd_device_register()
mtd: fsmc_nand: convert to mtd_device_register()
Fixed up trivial conflicts in
- drivers/mtd/maps/integrator-flash.c: removed in ARM tree
- drivers/mtd/maps/physmap.c: addition of afs partition probe type
clashing with removal of CONFIG_MTD_PARTITIONS
Convert to mtd_device_register() and remove the CONFIG_MTD_PARTITIONS
preprocessor conditionals as partitioning is always available.
Cc: Cc: David Woodhouse <dwmw2@infradead.org>
Cc: Artem Bityutskiy <dedekind1@gmail.com>
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
arch/arm/Kconfig
arch/arm/mach-ns9xxx/include/mach/uncompress.h
'consolidate-generic', 'consolidate-smp', 'consolidate-stmp' and 'consolidate-zones' into consolidate
Convert ixp4xx, lpc32xx, mxc, netx, pxa, sa1100, tcc8k, tegra and u300
to use the generic mmio clocksource recently introduced.
Cc: Imre Kaloz <kaloz@openwrt.org>
Cc: Krzysztof Halasa <khc@pm.waw.pl>
Acked-by: Eric Miao <eric.y.miao@gmail.com>
Acked-by: "Hans J. Koch" <hjk@hansjkoch.de>
Acked-by: Colin Cross <ccross@android.com>
Cc: Erik Gilling <konkers@android.com>
Cc: Olof Johansson <olof@lixom.net>
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
map_info
The set_vpp() method provided by physmap passes a map_info back to
the platform code, which has little relevance as far as the platform
is concerned (this parameter is completely unused).
Instead, pass the platform_device, which can be used in the pismo
driver to retrieve some important information in a nicer way, instead
of the hack that was in place.
The empty set_vpp function in board-at572d940hf_ek.c is left untouched,
as the board/SoC is scheduled for removal.
Cc: Andrew Victor <linux@maxim.org.za>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Cc: Philipp Zabel <philipp.zabel@gmail.com>
Cc: Eric Miao <eric.y.miao@gmail.com>
Cc: Ben Dooks <ben-linux@fluff.org>
Acked-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Acked-by: David Woodhouse <dwmw2@infradead.org>
* syscore:
PM: Remove sysdev suspend, resume and shutdown operations
PM / PowerPC: Use struct syscore_ops instead of sysdevs for PM
PM / UNICORE32: Use struct syscore_ops instead of sysdevs for PM
PM / AVR32: Use struct syscore_ops instead of sysdevs for PM
PM / Blackfin: Use struct syscore_ops instead of sysdevs for PM
ARM / Samsung: Use struct syscore_ops for "core" power management
ARM / PXA: Use struct syscore_ops for "core" power management
ARM / SA1100: Use struct syscore_ops for "core" power management
ARM / Integrator: Use struct syscore_ops for core PM
ARM / OMAP: Use struct syscore_ops for "core" power management
ARM: Use struct syscore_ops instead of sysdevs for PM in common code
Rather than each platform providing its own function to adjust the
zone sizes, use the new ARM_DMA_ZONE_SIZE definition to perform this
adjustment. This ensures that the actual DMA zone size and the
ISA_DMA_THRESHOLD/MAX_DMA_ADDRESS definitions are consistent with
each other, and moves this complexity out of the platform code.
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
The values of ISA_DMA_THRESHOLD and MAX_DMA_ADDRESS are related; one is
the physical/bus address, the other is the virtual address. Both need
to be kept in step, so rather than having platforms define both, allow
them to define a single macro which sets both of these macros
appropraitely.
devel-stable
To be able to relocate the .bss section at run time independently from
the rest of the code, we must make sure that no GOTOFF relocations are
used with .bss symbols. This usually means that no global variables can
be marked static unless they're also const.
Let's remove the static qualifier from current offenders, or turn them
into const variables when possible. Next commit will ensure the build
fails if one of those is reintroduced due to otherwise enforced coding
standards for the kernel.
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Tested-by: Tony Lindgren <tony@atomide.com>
Add REGULATOR_CHANGE_STATUS flag to magician bq24022 regulator to enable charging.
Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com>
Add REGULATOR_CHANGE_STATUS flag to hx4700 bq24022 regulator. Without this
flag the bq24022 cannot be enabled and the battery will not charge.
Tested-by: Dmitry Artamonow <mad_soft@inbox.ru>
Replace sysdev classes and struct sys_device objects used for "core"
power management by the PXA platform code with struct syscore_ops
objects that are simpler.
This reduces the code size and the kernel memory footprint. It also
is necessary for removing sysdevs entirely from the kernel in the
future.
This fixes the failure to register the IRQ_RTCAlrm alarm as a wakeup
event. It is misinterpreted as a gpio irq not a PWER bitmask. Fixed
this by converting the incorrect IRQ_TO_IRQ() to a correct version of
irq_to_gpio().
Reported-by: Nick Bane <nickbane1@gmail.com>
Avoid to mismatch between NR_BUILTIN_GPIO and GPIO interrupt number
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (65 commits)
ARM: 6826/1: Merge v6 and v7 DEBUG_LL DCC support
ARM: 6838/1: etm: fix section mismatch warning
ARM: 6837/1: remove unused pci_fixup_prpmc1100
ARM: 6836/1: kprobes/fix emulation of LDR/STR instruction when Rn == PC
Fix the broken build for Marvell Dove platform.
ARM: 6835/1: perf: ensure overflows aren't missed due to IRQ latency
ARM: 6834/1: perf: reset counters on all CPUs during initialisation
ARM: 6833/1: perf: add required isbs() to ARMv7 backend
ARM: 6825/1: kernel/sleep.S: fix Thumb2 compilation issues
ARM: 6807/1: realview: Fix secondary GIC initialisation for EB with MPCore tile
arm: mach-mx3: pcm043: add write-protect and card-detect for SD1
eukrea_mbimxsd51: add SD Card detect
eukrea_mbimxsd25-baseboard: add SD card detect
mx3/eukrea_mbimxsd-baseboard: add SD card detect support
mx3/eukrea_mbimxsd-baseboard: fix gpio request
ARM: mxs/mx28evk: add mmc device
ARM: mxs/mx23evk: add mmc device
ARM: mxs: dynamically allocate mmc device
ARM: mx51_efika: update platform data for new mfd changes
mx2/iomux: Set direction for CSPI2 pins
Use irq_set_chip_and_handler() instead. Converted with coccinelle.
Reorder
irq_set_chip()
irq_set_chip_data()
irq_set_handler()
to
irq_set_chip()
irq_set_handler()
irq_set_chip_data()
so the next patch can combine irq_set_chip() and irq_set_handler() to
irq_set_chip_and_handler().
Automated conversion with coccinelle.
Convert to the new function names. Automated with coccinelle.
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel-stable
arch/arm/mach-pxa/tosa.c
This patch moves the platform data definition from
arch/arm/plat-pxa/include/plat/i2c.h to include/linux/i2c/pxa-i2c.h so
it can be accessed from x86 the same way as on ARM.
This change should make no functional change to the PXA code. The move
is verified by building the following defconfigs:
cm_x2xx_defconfig corgi_defconfig em_x270_defconfig ezx_defconfig
imote2_defconfig pxa3xx_defconfig spitz_defconfig zeus_defconfig
raumfeld_defconfig magician_defconfig mmp2_defconfig pxa168_defconfig
pxa910_defconfig
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
If gpio_request fails when i > 0, gpios[0] is not freed in current
implementation.
implementation.
arch/arm/kernel/module.c
arch/arm/mach-s5pv210/sleep.S
'irqdata', 'pm', 'sh', 'smp', 'spear', 'ux500' and 'via' into devel
Otherwise userspace might be confused.
Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
So user can see if there's any mmc activity and if device's
charging.
It eats too much power, and anyway it's not usefull
during boot process. Userspace can enable it later.
GPIO15 seems to be not related to WiFi, so don't touch it.
Fix coefficients to get actual voltage, and make
voltage_max/voltage_min looks like values for LiIon battery.
It's very easy to press some keypad key when Z2 is closed,
so to prevent unexpected wakeups, use only 'Power' key to wake
Z2 from sleep.
Neither pxa25x_udc, nor pxa27x_udc use gpio_vbus/gpio_vbus_inverted
anymore. Drop those two fields from udc info completely.
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Switch from handling gpio-vbus in pxa25x_udc to using standard gpio-vbus
tranceiver.
tranceiver.
Cc: Steve Sakoman <sakoman@gmail.com>
tranceiver.
Cc: Ian Molton <spyro@f2s.com>
Use auto-computed shift and mult of timer with new API
clocksource_calc_mult_shift()/clockevents_calc_mult_shift().
Cc: Nicolas Pitre <nico@fluxnic.net>
set_pxa_fb_info() has been a long-standing wart in the naming scheme
of the pxa_set_xxx_info() functions. This renames the function, and
combines set_pxa_fb_parent() with set_pxa_fb_info().
Rework of patch from 2009:
PalmZ72: Add support for OV9640 camera sensor
Use gpio_request_array() / gpio_free_array() in backlight init and exit
functions. This makes the code cleaner and less error prone.
Since f0fba2ad1b it's required to register platform devices even for
AC'97 codecs. Register one on tosa (wm9712-codec).
pxa25x platforms were left out of major ASoC Update patch.
Since f0fba2ad1b a registration of pxa-pcm-audio device is required for
ASoC to function on pxa platforms. Register one also for pxa210/pxa25x.
Since 2e48928d8a0f38c1b5c81eb3f1294de8a6382c68 it's no longer possible to set
the name of the LED trigger for RFKILL events. Drop respective code from tosa-bt.c
Cc: Stephen Hemminger <shemminger@vyatta.com>
Cc: John W. Linville <linville@tuxdriver.com>
