path: root/arch/arm/mach-pxa/saarb.c
2012-11-15ARM: pxa: remove pxa95x supportHaojian Zhuang
PXA95x isn't widely used. And it adds the effort on supporting multiple platform. So remove it. The assumption is that nobody will miss this support. If you are reading this text because you actually require pxa95x support on a new kernel, we can work out a way to revert this patch or add support to the mmp platform. Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-02-16arch/arm/mach-pxa/: included linux/gpio.h twiceDanny Kukawka
arch/arm/mach-pxa/pxa25x.c and arch/arm/mach-pxa/saarb.c included 'linux/gpio.h' twice, remove the duplicates. Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-01-09Merge branch 'samsung/driver' into next/driversArnd Bergmann
Conflicts: arch/arm/mach-mxs/include/mach/common.h Pull in previous samsung conflict merges and do a trivial merge of an mxs double-add conflict. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-01-05ARM: restart: pxa: use new restart hookRussell King
Hook these platforms restart code into the new restart hook rather than using arch_reset(). Acked-by: Richard Purdie <richard.purdie@linuxfoundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-11-14ARM: pxa: rename gpio_to_irq and irq_to_gpioHaojian Zhuang
Avoid to define gpio_to_irq() and irq_to_gpio() for potential name confliction since multiple architecture will be built together. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
2011-11-01Merge branch 'depends/rmk/memory_h' into next/fixesArnd Bergmann
Fix up all conflicts between the memory.h cleanup and bug fixes. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-10-31Merge branch 'depends/rmk/gpio' into next/fixesArnd Bergmann
This sorts out merge conflicts with the arm/gpio branch that already got merged into mainline Linux. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-10-08ARM: pxa: pxa95x/saarb depends on pxa3xx codeEric Miao
saarb uses pxa3xx_map_io and pxa3xx_handle_irq, which are part of the pxa3xx code. This makes sure the necessary header and implementation is used when building the board file. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-10-01ARM: 7104/1: plat-pxa: break out GPIO driver specificsLinus Walleij
The <mach/gpio.h> file is included from upper directories and deal with generic GPIO and gpiolib stuff. Break out the platform and driver specific defines and functions into its own header file. Cc: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-08-21ARM: mach-pxa: convert boot_params to atag_offsetNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-08-08ARM: gpio: convert includes of mach/gpio.h and asm/gpio.h to linux/gpio.hRussell King
Convert arch/arm includes of mach/gpio.h and asm/gpio.h to linux/gpio.h before we start consolidating the individual platform implementations of the gpio header files. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-26Merge branch 'next/devel' of ↵Linus Torvalds
ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/devel' of ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (128 commits) ARM: S5P64X0: External Interrupt Support ARM: EXYNOS4: Enable MFC on Samsung NURI ARM: EXYNOS4: Enable MFC on universal_c210 ARM: S5PV210: Enable MFC on Goni ARM: S5P: Add support for MFC device ARM: EXYNOS4: Add support FIMD on SMDKC210 ARM: EXYNOS4: Add platform device and helper functions for FIMD ARM: EXYNOS4: Add resource definition for FIMD ARM: EXYNOS4: Change devname for FIMD clkdev ARM: SAMSUNG: Add IRQ_I2S0 definition ARM: SAMSUNG: Add platform device for idma ARM: EXYNOS4: Add more registers to be saved and restored for PM ARM: EXYNOS4: Add more register addresses of CMU ARM: EXYNOS4: Add platform device for dwmci driver ARM: EXYNOS4: configure rtc-s3c on NURI ARM: EXYNOS4: configure MAX8903 secondary charger on NURI ARM: EXYNOS4: configure ADC on NURI ARM: EXYNOS4: configure MAX17042 fuel gauge on NURI ARM: EXYNOS4: configure regulators and PMIC(MAX8997) on NURI ARM: EXYNOS4: Increase NR_IRQS for devices with more IRQs ... Fix up tons of silly conflicts: - arch/arm/mach-davinci/include/mach/psc.h - arch/arm/mach-exynos4/Kconfig - arch/arm/mach-exynos4/mach-smdkc210.c - arch/arm/mach-exynos4/pm.c - arch/arm/mach-imx/mm-imx1.c - arch/arm/mach-imx/mm-imx21.c - arch/arm/mach-imx/mm-imx25.c - arch/arm/mach-imx/mm-imx27.c - arch/arm/mach-imx/mm-imx31.c - arch/arm/mach-imx/mm-imx35.c - arch/arm/mach-mx5/mm.c - arch/arm/mach-s5pv210/mach-goni.c - arch/arm/mm/Kconfig
2011-07-12ARM: pxa: enable MULTI_IRQ_HANDLER for all boardsEric Miao
2011-07-11ARM: pxa/saarb: make use of pxa3xx_map_io()Eric Miao
2011-03-21ARM: pxa2xx: reorganize I2C filesSebastian Andrzej Siewior
This patch moves the platform data definition from arch/arm/plat-pxa/include/plat/i2c.h to include/linux/i2c/pxa-i2c.h so it can be accessed from x86 the same way as on ARM. This change should make no functional change to the PXA code. The move is verified by building the following defconfigs: cm_x2xx_defconfig corgi_defconfig em_x270_defconfig ezx_defconfig imote2_defconfig pxa3xx_defconfig spitz_defconfig zeus_defconfig raumfeld_defconfig magician_defconfig mmp2_defconfig pxa168_defconfig pxa910_defconfig Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-12-18ARM: pxa: support saarb platformHaojian Zhuang
Saarb platform is a handheld platform that supports Marvell PXA955 silicon. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
