path: root/arch/arm/mach-pxa/magician.c
2008-10-07[ARM] ohci-pxa27x: introduce flags to avoid direct access to OHCI registersEric Miao
Direct access to USB host controller registers is considered to be not portable, and is usually a bad sign for poorly abstracted interface. Introduce .flags and .power_on_delay to "struct pxaohci_platform_data" so that most platforms don't bother to write their own .init/.exit() sequences. Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-26[ARM] pxa: make "gpio_leds" staticRussell King
Magician's "gpio_leds" was global, but actually is supposed to be private. Make it so. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-12[ARM] 5146/1: pxa2xx: convert all boards to call pxa2xx_transceiver_mode helperDmitry Baryshkov
Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-09[ARM] 5138/1: magician: set pwm-backlight .id = -1Philipp Zabel
There will always be only one pwm-backlight on this device. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-09[ARM] 5126/1: magician: remove superfluous mtd includesPhilipp Zabel
These were only needed for hardcoded flash partition tables, which were never submitted. It is better to have the bootloader pass the partition table to the kernel instead. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-09[ARM] 5125/1: magician: move gpio pin configuration into __initdata sectionPhilipp Zabel
The pin configuration array is only used during board init. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-09[ARM] 5119/1: magician: include linux/gpio.h instead of asm/gpio.hPhilipp Zabel
2008-07-09[ARM] 5042/1: magician: request GPIOs for pda_powerPhilipp Zabel
2008-07-09Merge branches 'pxa-misc', 'pxa-pwm' and 'pxa-multi' into pxaRussell King
2008-07-03[ARM] 5045/1: magician: use the pwm_bl driver for the LCD backlightPhilipp Zabel
magician has a GPIO that modifies the brightness level additionally to the PWM duty value. This patch makes use of the pwm_bl notify callback to present userspace with a single brightness scale. This gets rid of the pxa_set_cken calls and direct PWM register access. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-02[ARM] pxa: separate out power manager and clock registersRussell King
The power manager and core clock registers aren't present in PXA3 CPUs. Move them out of pxa-regs.h into pxa2xx-regs.h, and include pxa2xx-regs.h where necessary. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-24[ARM] 5020/1: magician: remove __devinit marker from pasic3_leds_infoPhilipp Zabel
Platform data must not be marked with __devinit. Even __devinitdata would be wrong as the platform driver can be compiled as a module. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-21[ARM] 5008/1: magician: add magician specific input GPIOs to MFP configPhilipp Zabel
Some input pin configuration that is not handled by drivers. This should serve mostly as documentation. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-21[ARM] 5007/1: magician: properly request GPIOs used by the machine code itselfPhilipp Zabel
Registers some GPIOs used in magician.c with the GPIO API. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] 4966/1: magician: add MFP pin configurationPhilipp Zabel
Although the GPIO alternate functions should be correctly set by the bootloader, configure them here to be sure. To save power, FFUART/BTUART/STUART are left unconfigured (output, low) until they are needed by pxaficp or the magician GSM chipset driver. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] 4965/1: magician: use htc-pasic3,leds-pasic3,ds1wm,leds-gpioPhilipp Zabel
This patch enables LEDs and the 1-wire bus (connected to a DS2760 battery monitor) on the magician. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] 4953/1: magician: add backlight power switching GPIOsPhilipp Zabel
2008-04-19[ARM] 4952/1: magician: add LCD detection, LCD power switching, update pxafb ↵Philipp Zabel
settings All magician devices I've encountered so far have featured the Toppoly TD028STEB1 display, so the Samsung LTP280QV support is untested. The power-on sequence is not correct because pxafb doesn't yet support enabling the LCD controller in the middle of the it. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] 4951/1: magician: enable external power supply (pda_power) driverPhilipp Zabel
2008-04-19[ARM] 4950/1: magician: enable MMC supportPhilipp Zabel
2008-04-19[ARM] 4949/1: magician: enable flash VPP GPIO and build in MTD, ↵Philipp Zabel
physmap-flash and JFFS2 This enables rootfs on StrataFlash if the bootloader supplies the partition list. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] 4948/1: magician: use htc-egpio to drive the GPIO/IRQ expander CPLDPhilipp Zabel
needed for power management (audio, BT, charging, GSM, LCD, SD), GSM, flash and SD operation and audio routing. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] 4944/2: magician: enable i2c busPhilipp Zabel
Since recent PXA changes the (non-power-)I2C bus has to be explicitly enabled from board initialisation code. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] 4942/1: magician: fix the backlight driver namePhilipp Zabel
corgi_bl was renamed to generic_bl. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-28[ARM] 4664/1: Add basic support for HTC Magician PDA phonesPhilipp Zabel
This includes irda, gpio keys, pxafb, backlight, ohci and flash (read-only). Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
