path: root/arch/arm/mach-pxa/cm-x2xx.c
2011-04-24ARM / PXA: Use struct syscore_ops for "core" power managementRafael J. Wysocki
Replace sysdev classes and struct sys_device objects used for "core" power management by the PXA platform code with struct syscore_ops objects that are simpler. This reduces the code size and the kernel memory footprint. It also is necessary for removing sysdevs entirely from the kernel in the future. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-16ARM: pxa: clean up set_pxa_fb_infoRussell King - ARM Linux
set_pxa_fb_info() has been a long-standing wart in the naming scheme of the pxa_set_xxx_info() functions. This renames the function, and combines set_pxa_fb_parent() with set_pxa_fb_info(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-12-16ARM: pxa: Access SMEMC via virtual addressesMarek Vasut
This is important because on PXA3xx, the physical mapping of SMEMC registers differs from the one on PXA2xx. In order to get PCMCIA working on both PXA2xx and PXA320, the PCMCIA driver was adjusted accordingly as well. Also, various places in the kernel had to be patched to use __raw_read/__raw_write. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-12-16ARM: pxa: Introduce pxa{25x,27x,3xx}_map_io()Marek Vasut
This patch introduces pxa2xx_map_io() and pxa3xx_map_io() to distinguish between PXA25x/PXA27x and PXA3xx memory mapping. Also, fixup for platforms broken after introducing pxa{25x,27x}_map_io() and pxa3xx_map_io() is included. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-11-03ARM: pxa/cm-x2xx: remove duplicate call to pxa27x_init_irqMike Rapoport
Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-10-08ARM: pxa: encode IRQ number into .nr_irqsHaojian Zhuang
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Acked-by: Antonio Ospite <ospite@studenti.unina.it> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-12-01[ARM] pxa: allow platforms to control which uarts are registeredRussell King
For some platforms, it is inappropriate to register all PXA UARTs. In some cases, the UARTs may not be used, and in others we may want to avoid registering the UARTs to allow other drivers (eg, FICP) to make use of the UART. In addition, a while back there was a request to be able to pass platform data to the UART driver. This patch enables all of this by providing functions platforms can call to register each individual UART. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-04-04[ARM] pxa/cm-x2xx: fix ucb1400 not being registeredMarek Vasut
This patch fixes cm-x2xx not registering the ucb1400. This is because of the splitting of ucb1400 driver half year ago. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2009-03-09[ARM] pxa: add DM9000_PLATF_NO_EEPROM flag to CM-X... platformsMike Rapoport
Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2009-03-09[ARM] pxa: introduce pxa{25x,27x,300,320,930}.h for board usageEric Miao
Considering the header mess ATM, it is not always possible to include the correct header files within board code. Let's keep this simple: <mach/pxa25x.h> - for pxa25x based platforms <mach/pxa27x.h> - for pxa27x based platforms <mach/pxa300.h> - for pxa300 based platforms <mach/pxa320.h> - for pxa320 based platforms <mach/pxa930.h> - for pxa930 based platforms NOTE: 1. one header one board file, they are not compatible (i.e. they have conflicting definitions which won't compile if included together). 2. Unless strictly necessary, the following header files are considered to be SoC files use _only_, and is not recommended to be included in board code: <mach/hardware.h> <mach/pxa-regs.h> <mach/pxa2xx-regs.h> <mach/pxa3xx-regs.h> <mach/mfp.h> <mach/mfp-pxa2xx.h> <mach/mfp-pxa25x.h> <mach/mfp-pxa27x.h> <mach/mfp-pxa3xx.h> <mach/mfp-pxa300.h> <mach/mfp-pxa320.h> <mach/mfp-pxa930.h> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2008-12-17[ARM] pxa: convert legacy LCD setup of other boards to new oneEric Miao
Signed-off-by: Eric Miao <eric.miao@marvell.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Ian Molton <spyro@f2s.com> Cc: pHilipp Zabel <philipp.zabel@gmail.com> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Cc: Juergen Schindele <linux@schindele.name> Acked-by: Stefan Schmidt <stefan@datenfreihafen.org> Acked-by: Marc Zyngier <maz@misterjones.org> Acked-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Jaya Kumar <jayakumar.lkml@gmail.com>
2008-10-07[ARM] 5282/1: pxa: add CM-X255 supportMike Rapoport
Signed-off-by: Russ Dill <russ.dill@gmail.com> Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] 5281/1: pxa: split cm-x2xx.c to cm-x2xx.c and cm-x270.cMike Rapoport
2008-10-07[ARM] 5280/1: pxa: prepare cm-x2xx.c and cm-x2xx-pci.[ch] for addition of ↵Mike Rapoport
CM-X255 - Change CM-X255 and CM-X270 common function prefix from cmx270 to cmx2xx - Split cmx2xx_init to common and CM-X270-specific parts - Use dynamic assignement for DM9000 resources and led GPIOs. Signed-off-by: Russ Dill <russ.dill@gmail.com> Signed-off-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] 5286/2: pxa: rename cm-x270* to cm-x2xx* to allow addition of cm-x255 ↵Mike Rapoport
support Signed-off-by: Russ Dill <russ.dill@gmail.com> Signed-off-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
