path: root/arch/arm/mach-pxa/Kconfig
2016-08-09ARM: pxa: add pxa25x device-tree supportRobert Jarzmik
Add a device-tree machine entry (DT_MACHINE_START) for pxa25x based platforms. Take the opportunity to sort the file machine descriptions by alphabetical order. Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
2016-04-30ARM: pxa: activate pinctrl for device-tree machinesRobert Jarzmik
Pincontrol is not yet ready for all PXA platforms. For example, a legacy platform, if PINCTRL was activated, will fail its calls to gpio_request() or gpio_direction_output(), as the pinctrl driver might not be available, such as for pxa25x and pxa3xx. As a step forward, activate pincontrol for all device-tree available machines, ie. pxa27x device-tree based and pxa3xx device-tree based. If it appears later that pincontrol is also required for legacy platforms and if the mfp->pinctrl conversion can be achieved, then PINCTRL will be activated for the whole PXA architecture. Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2016-02-01ARM: pxa: don't select RFKILL if CONFIG_NET is disabledArnd Bergmann
Bluetooth is only supported when network support is part of the kernel, so it is a bit pointless to build the tosa-bt support without networking. If we try anyway, we get a Kconfig warning: warning: (TOSA_BT && H1940BT) selects RFKILL which has unmet direct dependencies (NET) This adds a dependency on CONFIG_NET to avoid that case. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
2016-02-01ARM: pxa: don't select GPIO_SYSFS for MIOA701Arnd Bergmann
GPIO_SYSFS is a common kernel functionality, not something that a board specific Kconfig should have to worry about. In MIOA701, we get a warning about the select when CONFIG_SYSFS is disabled: warning: (MACH_MIOA701) selects GPIO_SYSFS which has unmet direct dependencies (GPIOLIB && SYSFS) This just removes the select and instead enables the symbol in the defconfig file. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
2015-04-30ARM: pxa: pxa_cplds: add lubbock and mainstone IORobert Jarzmik
Historically, this support was in arch/arm/mach-pxa/lubbock.c and arch/arm/mach-pxa/mainstone.c. When gpio-pxa was moved to drivers/pxa, it became a driver, and its initialization and probing happened at postcore initcall. The lubbock code used to install the chained lubbock interrupt handler at init_irq() time. The consequence of the gpio-pxa change is that the installed chained irq handler lubbock_irq_handler() was overwritten in pxa_gpio_probe(_dt)(), removing : - the handler - the falling edge detection setting of GPIO0, which revealed the interrupt request from the lubbock IO board. As a fix, move the gpio0 chained handler setup to a place where we have the guarantee that pxa_gpio_probe() was called before, so that lubbock handler becomes the true IRQ chained handler of GPIO0, demuxing the lubbock IO board interrupts. This patch moves all that handling to a mfd driver. It's only purpose for the time being is the interrupt handling, but in the future it should encompass all the motherboard CPLDs handling : - leds - switches - hexleds The same logic applies to mainstone board. Fixes: 157d2644cb0c ("ARM: pxa: change gpio to platform device") Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Acked-by: Arnd Bergmann <arnd@arndb.de>
2014-12-26ARM: pxa: arbitrarily set first interrupt numberRobert Jarzmik
As IRQ0, the legacy timer interrupt should not be used as an interrupt number, shift the interrupts by a fixed number. As we had in a special case a shift of 16 when ISA bus was used on a PXA, use that value as the first interrupt number, regardless of ISA or not. Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
2014-12-26arm: pxa: fix pxa27x device-tree support kconfigRobert Jarzmik
Remove the useless CPU_PXA27x non existing kconfig option. The true options is PXA27x, which is already selected. Reported-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
2014-11-19arm: pxa: add pxa27x device-tree supportRobert Jarzmik
Add a device-tree machine entry (DT_MACHINE_START) for pxa27x based platforms. Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Acked-by: Arnd Bergmann <arnd@arndb.de>
2014-04-05Merge tag 'pwm/for-3.15-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm Pull pwm changes from Thierry Reding: "The legacy HAVE_PWM Kconfig symbol is finally being retired. Thanks a lot to Sascha Hauer for doing that. Three new drivers are added: Freescale FTM, Cirrus Logic CLPS711X and Intel Low Power Subsystem. An assortment of fixes and cleanups rounds things off for this release cycle" * tag 'pwm/for-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm: pwm: pxa: Constify OF match table pwm: pxa: Fix typo "pwm" -> "PWM" Revert "pwm: pxa: Use of_match_ptr()" pwm: add support for Intel Low Power Subsystem PWM pwm: Add CLPS711X PWM support pwm: atmel: correct CDTY calculation pwm: atmel: Fix polarity handling Documentation: Add device tree bindings for Freescale FTM PWM. pwm: Add Freescale FTM PWM driver support pwm: pxa: Use of_match_ptr() pwm: samsung: Use SIMPLE_DEV_PM_OPS macro pwm: renesas-tpu: Add dependency on HAS_IOMEM pwm: Remove obsolete HAVE_PWM Kconfig symbol
2014-03-21ARM: pxa: trizeps4 and trizeps4wl use the same fileArnd Bergmann
The trizeps4 and trizeps4wl platforms are both implemented using the same board file. Since the trizeps4wl code is a superset of trizeps4, it makes no sense to enable just the latter, but with the current Kconfig logic, it causes the board file not to be built at all. Selecting MACH_TRIZEPS4 from MACH_TRIZEPS4WL ensures that we are actually building the board file. Found during randconfig testing. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: Daniel Mack <zonque@gmail.com>
2014-03-21ARM: pxa: select I2C_GPIO only if I2C is onArnd Bergmann
The Arcom/Eurotech VIPER SBC enables the I2C_GPIO driver, but that has a dependency on I2C, and causes build failures if I2C is disabled. To keep existing configurations running while fixing the randconfig problems, this changes the logic to only enable I2C_GPIO if I2C is already enabled. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Daniel Mack <zonque@gmail.com>
2014-03-21ARM: pxa: enable pxafb unconditionally for some boardsArnd Bergmann
The SAAR and TAVOREVB machines try to call functions from the PXAFB frame buffer driver from their platform code, which only works if that driver is built-in. This patch ensures that both the generic frame buffer code and the specific pxafb driver are always enabled when we build a kernel for one of the two boards. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: Daniel Mack <zonque@gmail.com>
2014-03-21ARM: pxa: don't "select" SMC91X on MACH_XCEPArnd Bergmann
We normally don't hard-enable Kconfig options just because a board contains a specific piece of hardware. In this case, selecting SMC91X causes a build error, if we don't also enable basic network device driver support. Since the platform has no direct dependency on this driver at link time, we can just remove the 'select' statement. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: Daniel Mack <zonque@gmail.com>
2014-02-10pwm: Remove obsolete HAVE_PWM Kconfig symbolSascha Hauer
Before we had the PWM framework we used to have a barebone PWM api. The HAVE_PWM Kconfig symbol used to be selected by the PWM drivers to specify the PWM API is present in the kernel. Since the last legacy driver is gone the HAVE_PWM symbol can go aswell. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Cc: Thierry Reding <thierry.reding@gmail.com> Cc: linux-pwm@vger.kernel.orig Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2013-10-16cpufreq: remove CONFIG_CPU_FREQ_TABLEViresh Kumar
CONFIG_CPU_FREQ_TABLE will be always enabled when cpufreq framework is used, as cpufreq core depends on it. So, we don't need this CONFIG option anymore as it is not configurable. Remove CONFIG_CPU_FREQ_TABLE and update its users. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-06-18cpufreq: pxa: select CPU_FREQ_TABLEViresh Kumar
CPUFreq driver of this platform uses APIs from freq_table.c and so must select CPU_FREQ_TABLE. Cc: Eric Miao <eric.y.miao@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
2013-05-09Merge tag 'for-linus-20130509' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD update from David Woodhouse: - Lots of cleanups from Artem, including deletion of some obsolete drivers - Support partitions larger than 4GiB in device tree - Support for new SPI chips * tag 'for-linus-20130509' of git://git.infradead.org/linux-mtd: (83 commits) mtd: omap2: Use module_platform_driver() mtd: bf5xx_nand: Use module_platform_driver() mtd: denali_dt: Remove redundant use of of_match_ptr mtd: denali_dt: Change return value to fix smatch warning mtd: denali_dt: Use module_platform_driver() mtd: denali_dt: Fix incorrect error check mtd: nand: subpage write support for hardware based ECC schemes mtd: omap2: use msecs_to_jiffies() mtd: nand_ids: use size macros mtd: nand_ids: improve LEGACY_ID_NAND macro a bit mtd: add 4 Toshiba nand chips for the full-id case mtd: add the support to parse out the full-id nand type mtd: add new fields to nand_flash_dev{} mtd: sh_flctl: Use of_match_ptr() macro mtd: gpio: Use of_match_ptr() macro mtd: gpio: Use devm_kzalloc() mtd: davinci_nand: Use of_match_ptr() mtd: dataflash: Use of_match_ptr() macro mtd: remove h720x flash support mtd: onenand: remove OneNAND simulator ...
2013-04-11ARM: pxa: select PXA935 on saar & tavorevbHaojian Zhuang
Since both PXA930 and PXA935 are used in Saar & TavorEVB platform, select PXA935 too. Signed-off-by: Haojian Zhuang <haojian.zhuang@linaro.org>
2013-04-05arm: mach-pxa: amend Kconfig after mtdchar mergeArtem Bityutskiy
The mtdchar module was merged with the mtdcore module, which means that the MTD_CHAR Kconfig symbol does not exist any more. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-11-15ARM: pxa: remove pxa95x supportHaojian Zhuang
PXA95x isn't widely used. And it adds the effort on supporting multiple platform. So remove it. The assumption is that nobody will miss this support. If you are reading this text because you actually require pxa95x support on a new kernel, we can work out a way to revert this patch or add support to the mmp platform. Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-10-13ARM: config: sort select statements alphanumericallyRussell King
As suggested by Andrew Morton: This is a pet peeve of mine. Any time there's a long list of items (header file inclusions, kconfig entries, array initalisers, etc) and someone wants to add a new item, they *always* go and stick it at the end of the list. Guys, don't do this. Either put the new item into a randomly-chosen position or, probably better, alphanumerically sort the list. lets sort all our select statements alphanumerically. This commit was created by the following perl: while (<>) { while (/\\\s*$/) { $_ .= <>; } undef %selects if /^\s*config\s+/; if (/^\s+select\s+(\w+).*/) { if (defined($selects{$1})) { if ($selects{$1} eq $_) { print STDERR "Warning: removing duplicated $1 entry\n"; } else { print STDERR "Error: $1 differently selected\n". "\tOld: $selects{$1}\n". "\tNew: $_\n"; exit 1; } } $selects{$1} = $_; next; } if (%selects and (/^\s*$/ or /^\s+help/ or /^\s+---help---/ or /^endif/ or /^endchoice/)) { foreach $k (sort (keys %selects)) { print "$selects{$k}"; } undef %selects; } print; } if (%selects) { foreach $k (sort (keys %selects)) { print "$selects{$k}"; } } It found two duplicates: Warning: removing duplicated S5P_SETUP_MIPIPHY entry Warning: removing duplicated HARDIRQS_SW_RESEND entry and they are identical duplicates, hence the shrinkage in the diffstat of two lines. We have four testers reporting success of this change (Tony, Stephen, Linus and Sekhar.) Acked-by: Jason Cooper <jason@lakedaemon.net> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-08-16ARM: pxa3xx: add generic DT machine codeDaniel Mack
Add a DT_MACHINE_START entry for PXA3xx machines and a auxdata table for some of the devices. This file can be extended to also support pxa2xx and pxa9xx boards. Signed-off-by: Daniel Mack <zonque@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-04-05ARM: fix __io macro for PCMCIARob Herring
With commit c334bc1 (ARM: make mach/io.h include optional), PCMCIA was broken. PCMCIA depends on __io() returning a valid i/o address, and most ARM platforms require IO_SPACE_LIMIT be set to 0xffffffff for PCMCIA. This needs a better fix with a fixed i/o address mapping, but for now we just restore things to the previous behavior. This fixes at91, omap1, pxa and sa11xx. pxa needs io.h if PCI is enabled, but PCMCIA is not. sa11xx already has IO_SPACE_LIMIT set to 0xffffffff, so it doesn't need an io.h. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Joachim Eastwood <joachim.eastwood@jotron.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Andrew Victor <linux@maxim.org.za> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Tested-by: Paul Parsons <lost.distance@yahoo.com> (pxa270) Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-03-25ARM: dma-mapping: convert ARCH_HAS_DMA_SET_COHERENT_MASK to kconfig symbolRob Herring
The only users of ARCH_HAS_DMA_SET_COHERENT_MASK are 2 ARM platforms: ixp4xx and pxa cm_x2xx. We've been getting lucky that the define is implicitly included before dma-mapping.h, but the removal of io.h broke things (c334bc1 ARM: make mach/io.h include optional). Since memory.h is the correct place, but no longer exists, convert the define to a kconfig entry. Reported-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Nicolas Pitre <nico@linaro.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Imre Kaloz <kaloz@openwrt.org> Cc: Krzysztof Halasa <khc@pm.waw.pl> Cc: Eric Miao <eric.y.miao@gmail.com> Acked-by: Haojian Zhuang <haojian.zhuang@marvell.com> Cc: Vinod Koul <vinod.koul@intel.com> Cc: Dan Williams <dan.j.williams@intel.com>
2011-10-08ARM: pxa: sharpsl pm needs SPIArnd Bergmann
The sharpsl code selects the max1111 spi driver, so it must also ensure that SPI itself is enabled. The platform does not work without max1111. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-10-08ARM: pxa: centro and treo680 need palm27xArnd Bergmann
The two platforms are part of the palm27x family and use the same code. Select the palm27x symbol to make sure they can be built standalone. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-10-08ARM: pxa: select POWER_SUPPLY on raumfeldArnd Bergmann
The raumfeld platform code calls power_supply_set_battery_charged which is part of the power supply layer, so that always has to be enabled. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-10-08ARM: pxa: pxa95x is incompatible with earlier pxaArnd Bergmann
We cannot support ARMv5 and ARMv7 based boards in a single kernel, so introduce a new option in mach-pxa to select between the two. The PJ4 (ARMv7) based boards are now only visible when CONFIG_ARCH_PXA_V7 is set, the other boards are only visible when it's not set. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-05-25mtd: pxa: convert to mtd_device_register()Jamie Iles
Convert to mtd_device_register() and remove the CONFIG_MTD_PARTITIONS preprocessor conditionals as partitioning is always available. Cc: Cc: David Woodhouse <dwmw2@infradead.org> Cc: Artem Bityutskiy <dedekind1@gmail.com> Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-01-06Merge branch 'devel-stable' into develRussell King
Conflicts: arch/arm/mach-pxa/clock.c arch/arm/mach-pxa/clock.h
2011-01-06Merge branch 'misc' into develRussell King
Conflicts: arch/arm/Kconfig arch/arm/common/Makefile arch/arm/kernel/Makefile arch/arm/kernel/smp.c
2010-12-20ARM: pxa: Rename Colibri evalboardMarek Vasut
Rename colibri-pxa270-evalboard to colibri-evalboard as this board is used with all Colibri modules. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-12-20ARM: pxa: Push Colibri evalboard MFP into module filesMarek Vasut
This change -- pushing the MFP configuration back into Module files -- is necessary because some evalboards can be used with multiple modules, where MFP differs from module to module. Therefore MFP isn't board-specific, but module-specific and the module should preconfigure itself for the board. (And there is also the C preprocesor limitation and conflicting #define-s) Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-12-18ARM: pxa: support saarb platformHaojian Zhuang
Saarb platform is a handheld platform that supports Marvell PXA955 silicon. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-12-18ARM: pxa: support pxa95xHaojian Zhuang
The core of PXA955 is PJ4. Add new PJ4 support. And add new macro CONFIG_PXA95x. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-12-16ARM: pxa: PXA_ESERIES depends on FB_W100.Lennert Buytenhek
As arch/arm/mach-pxa/eseries.c references w100fb_gpio_{read,write}() directly. Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-12-05ARM: 6520/1: Kconfig: add new symbol MIGHT_HAVE_PCIHans Ulli Kroll
Today more boards with arm cpu have selectable pci bus. This patch makes this more scalable and remove line continuations in Kconfig Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Hans Ulli Kroll <ulli.kroll@googlemail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-10-09ARM: pxa: append tavorevb3 supportHaojian Zhuang
Bringup tavorevb3 development platform. UART and PMIC are enabled. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-10-08ARM: pxa: encode IRQ number into .nr_irqsHaojian Zhuang
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Acked-by: Antonio Ospite <ospite@studenti.unina.it> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-10-08ARM: pxa: add U2D controller and ULPI driver for pxa3xxIgor Grinberg
USB2.0 Device Controller (U2DC) which is found in Marvell PXA3xx. U2DC supports both High and Full speed modes. PXA320 and PXA300 U2DC supports only UTMI interface. PXA310 U2DC supports only ULPI interface and has the OTG capability. U2D Controller ULPI driver introduced in this patch supports only the PXA310 USB Host via the ULPI. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-08-05[ARM] pxa/palm: Flip Palm LD,TX,T5,Z72 to Palm27xMarek Vasut
2010-08-05[ARM] pxa/palm: Introduce Palm27xMarek Vasut
This contains common code for Palm LD, TX, T5, Z72, Treo680, Centro This code also adds PMIC support for all the devices, Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2010-08-05[ARM] pxa: removing dead CORGI_SSP_DEPRECATEDChristoph Egger
CORGI_SSP_DEPRECATED doesn't exist in Kconfig, therefore removing all references for it from the source code. Signed-off-by: Christoph Egger <siccegge@cs.fau.de> Acked-by: Kristoffer Ericson <kristoffer.ericson@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-08-05[ARM] pxa: PXA_SHARPSL_DETECT_MACH_ID to include head-sharpsl.SEric Miao
With kexec-based kernel boot loader on Zaurus, the machine ID is actually correctly passed, and head-sharpsl.S is not necessary. Introduce PXA_SHARPSL_DETECT_MACH_ID, and include head-sharpsl.S only when that's explicitly enabled. Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-08-05[ARM] pxa: move hidden Kconfig options to right place and vice versaEric Miao
1. TOSA related un-hidden options moved to right under MACH_TOSA 2. SHARPSL_PM related hidden options moved to the end of Kconfig Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-06-18[ARM] pxa/income: Add Income SBC supportMarek Vasut
This is support for custom design based on Toradex Colibri PXA270 CPU card. Initial patch was by Pavel Revak. [daniel - rebased the code to follow the module/board split] Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Pavel Revak <palo@bielyvlk.sk> Cc: Daniel Mack <daniel@caiaq.de> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-06-18[ARM] pxa/colibri270: Split module and base board codeDaniel Mack
Follow the idea of several MX31 based boards and split code that is related to the module from code that is baseboard specific. This makes adding new base board support easier, while avoiding code duplication. Signed-off-by: Daniel Mack <daniel@caiaq.de> Acked-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-05-11[ARM] pxa/vpac270: add ide supportMarek Vasut
This patch adds support for the on-board IDE channel. I tested this with a CDROM connected over 2.5-3.5 IDE reduction with external power supplied to the CDROM. This was not tested with the Voipac 270-HDD-000 (official Voipac HDD module), but I expect no problems. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-05-11[ARM] pxa: add basic support for Voipac PXA270 SBCMarek
This patch adds basic support for the Voipac PXA270 SBC. The device consists of the following hardware: - PXA270 @ 520 MHz - 256MB RAM (sparsemem, 2*128MB regions) - 64MB NOR flash - 640x480 LCD - Ports: 2xUHC, 1xUDC, 1xPCMCIA, VGA, FFUART, 2xPS2, Speaker, MIC Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-05-11[ARM] pxa: add basic support for the Aeronix Zipit Z2 handheldMarek Vasut
This patch adds support for the Zipit Z2. The parts missing from this patch are the battery support, SPI driver for the LCD and support for the Silicon Serial ID chip. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
