path: root/arch/arm/mach-picoxcell
2011-11-09ARM: picoxcell: add extra temp register to addruartJamie Iles
639da5ee3 (ARM: add an extra temp register to the low level debugging addruart macro) didn't include picoxcell as it hadn't been merged at the time. Fix up the compile breakage by adding the extra temp parameter. Signed-off-by: Jamie Iles <jamie@jamieiles.com>
2011-10-04picoxcell: add a definition of VMALLOC_ENDJamie Iles
Nicolas Pitre's vmalloc cleanup series didn't get merged in this cycle so picoxcell is missing a VMALLOC_END definition. Signed-off-by: Jamie Iles <jamie@jamieiles.com>
2011-09-26picoxcell: remove custom ioremap implementationJamie Iles
Nicolas Pitre's generic ioremap() patch set means that we don't need this any more. Signed-off-by: Jamie Iles <jamie@jamieiles.com>
2011-09-26picoxcell: support for Picochip picoxcell devicesJamie Iles
picoXcell is a family of femtocell devices with an ARM application processor and picoArray DSP processor array. This patch adds support for picoXcell boards to be booted using the device tree registering the VIC's, UART's and timers. v3: - fixup vic compatible string in binding v2: - cleanup empty mach headers - convert to of_platform_populate() - simplify uncompress.h - split vic node into 2 devices - add missing __initconst attributes Signed-off-by: Jamie Iles <jamie@jamieiles.com>
