path: root/arch/arm/mach-omap2
2011-11-01Merge branch 'next/pm' of git://git.linaro.org/people/arnd/arm-socLinus Torvalds
* 'next/pm' of git://git.linaro.org/people/arnd/arm-soc: (66 commits) ARM: CSR: PM: use outer_resume to resume L2 cache ARM: CSR: call l2x0_of_init to init L2 cache of SiRFprimaII ARM: OMAP: voltage: voltage layer present, even when CONFIG_PM=n ARM: CSR: PM: add sleep entry for SiRFprimaII ARM: CSR: PM: save/restore irq status in suspend cycle ARM: CSR: PM: save/restore timer status in suspend cycle OMAP4: PM: TWL6030: add cmd register OMAP4: PM: TWL6030: fix ON/RET/OFF voltages OMAP4: PM: TWL6030: address 0V conversions OMAP4: PM: TWL6030: fix uv to voltage for >0x39 OMAP4: PM: TWL6030: fix voltage conversion formula omap: voltage: add a stub header file for external/regulator use OMAP2+: VC: more registers are per-channel starting with OMAP5 OMAP3+: voltage: update nominal voltage in voltdm_scale() not VC post-scale OMAP3+: voltage: rename omap_voltage_get_nom_volt -> voltdm_get_voltage OMAP3+: voltdm: final removal of omap_vdd_info OMAP3+: voltage: move/rename curr_volt from vdd_info into struct voltagedomain OMAP3+: voltage: rename scale and reset functions using voltdm_ prefix OMAP3+: VP: combine setting init voltage into common function OMAP3+: VP: remove unused omap_vp_get_curr_volt() ... Fix up trivial conflict in arch/arm/mach-prima2/l2x0.c (code removal vs edit)
2011-11-01Merge branch 'next/timer' of git://git.linaro.org/people/arnd/arm-socLinus Torvalds
* 'next/timer' of git://git.linaro.org/people/arnd/arm-soc: clocksource: fixup ux500 build problems ARM: omap: use __devexit_p in dmtimer driver ARM: ux500: Reprogram timers upon resume ARM: plat-nomadik: timer: Export reset functions ARM: plat-nomadik: timer: Add support for periodic timers ARM: ux500: Move timer code to separate file ARM: ux500: add support for clocksource DBX500 PRCMU clocksource: add DBX500 PRCMU Timer support ARM: plat-nomadik: MTU sched_clock as an option ARM: OMAP: dmtimer: add error handling to export APIs ARM: OMAP: dmtimer: low-power mode support ARM: OMAP: dmtimer: skip reserved timers ARM: OMAP: dmtimer: pm_runtime support ARM: OMAP: dmtimer: switch-over to platform device driver ARM: OMAP: dmtimer: platform driver ARM: OMAP2+: dmtimer: convert to platform devices ARM: OMAP1: dmtimer: conversion to platform devices ARM: OMAP2+: dmtimer: add device names to flck nodes ARM: OMAP: Add support for dmtimer v2 ip
2011-11-01Merge branch 'next/cleanup' of git://git.linaro.org/people/arnd/arm-socLinus Torvalds
* 'next/cleanup' of git://git.linaro.org/people/arnd/arm-soc: (125 commits) ARM: mach-mxs: fix machines' initializers order mmc: mxcmmc: explicitly includes mach/hardware.h arm/imx: explicitly includes mach/hardware.h in pm-imx27.c arm/imx: remove mx27_setup_weimcs() from mx27.h arm/imx: explicitly includes mach/hardware.h in mach-kzm_arm11_01.c arm/imx: remove mx31_setup_weimcs() from mx31.h ARM: tegra: devices.c should include devices.h ARM: tegra: cpu-tegra: unexport two functions ARM: tegra: cpu-tegra: sparse type fix ARM: tegra: dma: staticify some tables and functions ARM: tegra: tegra2_clocks: don't export some tables ARM: tegra: tegra_powergate_is_powered should be static ARM: tegra: tegra_rtc_read_ms should be static ARM: tegra: tegra_init_cache should be static ARM: tegra: pcie: 0 -> NULL changes ARM: tegra: pcie: include board.h ARM: tegra: pcie: don't cast __iomem pointers ARM: tegra: tegra2_clocks: 0 -> NULL changes ARM: tegra: tegra2_clocks: don't cast __iomem pointers ARM: tegra: timer: don't cast __iomem pointers ... Fix up trivial conflicts in arch/arm/mach-omap2/Makefile, arch/arm/mach-u300/{Makefile.boot,core.c} arch/arm/plat-{mxc,omap}/devices.c
2011-11-01Merge branch 'next/fixes' of git://git.linaro.org/people/arnd/arm-socLinus Torvalds
* 'next/fixes' of git://git.linaro.org/people/arnd/arm-soc: (28 commits) ARM: pxa/cm-x300: properly set bt_reset pin ARM: mmp: rename SHEEVAD to GPLUGD ARM: imx: Fix typo 'MACH_MX31_3DS_MXC_NAND_USE_BBT' ARM: i.MX28: shift frac value in _CLK_SET_RATE plat-mxc: iomux-v3.h: implicitly enable pull-up/down when that's desired ARM: mx5: fix clock usage for suspend ARM: pxa: use correct __iomem annotations ARM: pxa: sharpsl pm needs SPI ARM: pxa: centro and treo680 need palm27x ARM: pxa: make pxafb_smart_*() empty when not enabled ARM: pxa: select POWER_SUPPLY on raumfeld ARM: pxa: pxa95x is incompatible with earlier pxa ARM: pxa: CPU_FREQ_TABLE is needed for CPU_FREQ ARM: pxa: pxa95x/saarb depends on pxa3xx code ARM: pxa: allow selecting just one of TREO680/CENTRO ARM: pxa: export symbols from pxa3xx-ulpi ARM: pxa: make zylonite_pxa*_init declaration match code ARM: pxa/z2: fix building error of pxa27x_cpu_suspend() no longer available ARM: at91: add defconfig for at91sam9g45 family ARM: at91: remove dependency for Atmel PWM driver selector in Kconfig ...
2011-11-01Merge branch 'depends/rmk/memory_h' into next/fixesArnd Bergmann
Fix up all conflicts between the memory.h cleanup and bug fixes. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-10-31Merge branch 'next/fixes' into next/cleanupArnd Bergmann
Conflicts: arch/arm/mach-mxs/include/mach/gpio.h arch/arm/plat-mxc/include/mach/gpio.h drivers/video/omap/lcd_apollon.c drivers/video/omap/lcd_ldp.c drivers/video/omap/lcd_overo.c
2011-10-31Merge branch 'depends/omap2_dss' into next/cleanupArnd Bergmann
Omap cleanups conflicted with omap2_dss work in a nontrivial way, this is the most logical fixup. Conflicts: arch/arm/mach-omap2/board-2430sdp.c arch/arm/mach-omap2/board-4430sdp.c arch/arm/mach-omap2/board-apollon.c arch/arm/mach-omap2/board-h4.c arch/arm/mach-omap2/board-ldp.c arch/arm/mach-omap2/board-rx51.c Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-10-31Merge branch 'depends/rmk/memory_h' into next/fixesArnd Bergmann
2011-10-31Merge branch 'depends/rmk/gpio' into next/fixesArnd Bergmann
This sorts out merge conflicts with the arm/gpio branch that already got merged into mainline Linux. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-10-30Merge branch 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommuLinus Torvalds
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (33 commits) iommu/core: Remove global iommu_ops and register_iommu iommu/msm: Use bus_set_iommu instead of register_iommu iommu/omap: Use bus_set_iommu instead of register_iommu iommu/vt-d: Use bus_set_iommu instead of register_iommu iommu/amd: Use bus_set_iommu instead of register_iommu iommu/core: Use bus->iommu_ops in the iommu-api iommu/core: Convert iommu_found to iommu_present iommu/core: Add bus_type parameter to iommu_domain_alloc Driver core: Add iommu_ops to bus_type iommu/core: Define iommu_ops and register_iommu only with CONFIG_IOMMU_API iommu/amd: Fix wrong shift direction iommu/omap: always provide iommu debug code iommu/core: let drivers know if an iommu fault handler isn't installed iommu/core: export iommu_set_fault_handler() iommu/omap: Fix build error with !IOMMU_SUPPORT iommu/omap: Migrate to the generic fault report mechanism iommu/core: Add fault reporting mechanism iommu/core: Use PAGE_SIZE instead of hard-coded value iommu/core: use the existing IS_ALIGNED macro iommu/msm: ->unmap() should return order of unmapped page ... Fixup trivial conflicts in drivers/iommu/Makefile: "move omap iommu to dedicated iommu folder" vs "Rename the DMAR and INTR_REMAP config options" just happened to touch lines next to each other.
2011-10-30Merge branch 'fbdev-next' of git://github.com/schandinat/linux-2.6Linus Torvalds
* 'fbdev-next' of git://github.com/schandinat/linux-2.6: (270 commits) video: platinumfb: Add __devexit_p at necessary place drivers/video: fsl-diu-fb: merge diu_pool into fsl_diu_data drivers/video: fsl-diu-fb: merge diu_hw into fsl_diu_data drivers/video: fsl-diu-fb: only DIU modes 0 and 1 are supported drivers/video: fsl-diu-fb: remove unused panel operating mode support drivers/video: fsl-diu-fb: use an enum for the AOI index drivers/video: fsl-diu-fb: add several new video modes drivers/video: fsl-diu-fb: remove broken screen blanking support drivers/video: fsl-diu-fb: move some definitions out of the header file drivers/video: fsl-diu-fb: fix some ioctls video: da8xx-fb: Increased resolution configuration of revised LCDC IP OMAPDSS: picodlp: add missing #include <linux/module.h> fb: fix au1100fb bitrot. mx3fb: fix NULL pointer dereference in screen blanking. video: irq: Remove IRQF_DISABLED smscufx: change edid data to u8 instead of char OMAPDSS: DISPC: zorder support for DSS overlays OMAPDSS: DISPC: VIDEO3 pipeline support OMAPDSS/OMAP_VOUT: Fix incorrect OMAP3-alpha compatibility setting video/omap: fix build dependencies ... Fix up conflicts in: - drivers/staging/xgifb/XGI_main_26.c Changes to XGIfb_pan_var() - drivers/video/omap/{lcd_apollon.c,lcd_ldp.c,lcd_overo.c} Removed (or in the case of apollon.c, merged into the generic DSS panel in drivers/video/omap2/displays/panel-generic-dpi.c)
2011-10-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (549 commits) ALSA: hda - Fix ADC input-amp handling for Cx20549 codec ALSA: hda - Keep EAPD turned on for old Conexant chips ALSA: hda/realtek - Fix missing volume controls with ALC260 ASoC: wm8940: Properly set codec->dapm.bias_level ALSA: hda - Fix pin-config for ASUS W90V ALSA: hda - Fix surround/CLFE headphone and speaker pins order ALSA: hda - Fix typo ALSA: Update the sound git tree URL ALSA: HDA: Add new revision for ALC662 ASoC: max98095: Convert codec->hw_write to snd_soc_write ASoC: keep pointer to resource so it can be freed ASoC: sgtl5000: Fix wrong mask in some snd_soc_update_bits calls ASoC: wm8996: Fix wrong mask for setting WM8996_AIF_CLOCKING_2 ASoC: da7210: Add support for line out and DAC ASoC: da7210: Add support for DAPM ALSA: hda/realtek - Fix DAC assignments of multiple speakers ASoC: Use SGTL5000_LINREG_VDDD_MASK instead of hardcoded mask value ASoC: Set sgtl5000->ldo in ldo_regulator_register ASoC: wm8996: Use SND_SOC_DAPM_AIF_OUT for AIF2 Capture ASoC: wm8994: Use SND_SOC_DAPM_AIF_OUT for AIF3 Capture ...
2011-10-28Merge branch 'devel-stable' of ↵Linus Torvalds
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'devel-stable' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (178 commits) ARM: 7139/1: fix compilation with CONFIG_ARM_ATAG_DTB_COMPAT and large TEXT_OFFSET ARM: gic, local timers: use the request_percpu_irq() interface ARM: gic: consolidate PPI handling ARM: switch from NO_MACH_MEMORY_H to NEED_MACH_MEMORY_H ARM: mach-s5p64x0: remove mach/memory.h ARM: mach-s3c64xx: remove mach/memory.h ARM: plat-mxc: remove mach/memory.h ARM: mach-prima2: remove mach/memory.h ARM: mach-zynq: remove mach/memory.h ARM: mach-bcmring: remove mach/memory.h ARM: mach-davinci: remove mach/memory.h ARM: mach-pxa: remove mach/memory.h ARM: mach-ixp4xx: remove mach/memory.h ARM: mach-h720x: remove mach/memory.h ARM: mach-vt8500: remove mach/memory.h ARM: mach-s5pc100: remove mach/memory.h ARM: mach-tegra: remove mach/memory.h ARM: plat-tcc: remove mach/memory.h ARM: mach-mmp: remove mach/memory.h ARM: mach-cns3xxx: remove mach/memory.h ... Fix up mostly pretty trivial conflicts in: - arch/arm/Kconfig - arch/arm/include/asm/localtimer.h - arch/arm/kernel/Makefile - arch/arm/mach-shmobile/board-ap4evb.c - arch/arm/mach-u300/core.c - arch/arm/mm/dma-mapping.c - arch/arm/mm/proc-v7.S - arch/arm/plat-omap/Kconfig largely due to some CONFIG option renaming (ie CONFIG_PM_SLEEP -> CONFIG_ARM_CPU_SUSPEND for the arm-specific suspend code etc) and addition of NEED_MACH_MEMORY_H next to HAVE_IDE.
2011-10-27Merge branch 'gpio' of ↵Linus Torvalds
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'gpio' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (43 commits) ARM: 7135/1: ep93xx: bring back missing <mach/gpio.h> ARM: 7104/1: plat-pxa: break out GPIO driver specifics ARM: 7103/1: plat-pxa: move PXA GPIO driver to GPIO subsystem ARM: 7042/3: mach-ep93xx: break out GPIO driver specifics ARM: 7101/1: arm/tegra: Replace <mach/gpio.h> with <mach/gpio-tegra.h> ARM: 7094/1: arm/tegra: Move EN_VDD_1V05_GPIO to board-harmony.h ARM: 7083/1: rewrite U300 GPIO to use gpiolib ARM: 7074/1: gpio: davinci: eliminate unused variable warnings ARM: 7063/1: Orion: gpio: add missing include of linux/types.h ARM: 7055/1: arm/tegra: mach/gpio.h: include linux/types.h to fix build ARM: 7054/1: arm/tegra: Delete custom gpio_to_irq, and irq_to_gpio ARM: 7053/1: gpio/tegra: Implement gpio_chip.to_irq ARM: 7052/1: gpio/tegra: Remove use of irq_to_gpio ARM: 7057/1: mach-pnx4008: rename GPIO header ARM: 7056/1: plat-nomadik: kill off <plat/gpio.h> ARM: 7050/1: mach-sa1100: delete irq_to_gpio() function ARM: 7049/1: mach-sa1100: move SA1100 GPIO driver to GPIO subsystem ARM: 7045/1: mach-lpc32xx: break out GPIO driver specifics ARM: 7044/1: mach-lpc32xx: move LPC32XX GPIO driver to GPIO subsystem ARM: 7043/1: mach-ixp2000: rename GPIO header ... Fix up trivial conflicts in arch/arm/mach-u300/Kconfig manually
2011-10-25Merge branch 'usb-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb * 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (260 commits) usb: renesas_usbhs: fixup inconsistent return from usbhs_pkt_push() usb/isp1760: Allow to optionally trigger low-level chip reset via GPIOLIB. USB: gadget: midi: memory leak in f_midi_bind_config() USB: gadget: midi: fix range check in f_midi_out_open() QE/FHCI: fixed the CONTROL bug usb: renesas_usbhs: tidyup for smatch warnings USB: Fix USB Kconfig dependency problem on 85xx/QoirQ platforms EHCI: workaround for MosChip controller bug usb: gadget: file_storage: fix race on unloading USB: ftdi_sio.c: Use ftdi async_icount structure for TIOCMIWAIT, as in other drivers USB: ftdi_sio.c:Fill MSR fields of the ftdi async_icount structure USB: ftdi_sio.c: Fill LSR fields of the ftdi async_icount structure USB: ftdi_sio.c:Fill TX field of the ftdi async_icount structure USB: ftdi_sio.c: Fill the RX field of the ftdi async_icount structure USB: ftdi_sio.c: Basic icount infrastructure for ftdi_sio usb/isp1760: Let OF bindings depend on general CONFIG_OF instead of PPC_OF . USB: ftdi_sio: Support TI/Luminary Micro Stellaris BD-ICDI Board USB: Fix runtime wakeup on OHCI xHCI/USB: Make xHCI driver have a BOS descriptor. usb: gadget: add new usb gadget for ACM and mass storage ...
2011-10-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (59 commits) MAINTAINERS: linux-m32r is moderated for non-subscribers linux@lists.openrisc.net is moderated for non-subscribers Drop default from "DM365 codec select" choice parisc: Kconfig: cleanup Kernel page size default Kconfig: remove redundant CONFIG_ prefix on two symbols cris: remove arch/cris/arch-v32/lib/nand_init.S microblaze: add missing CONFIG_ prefixes h8300: drop puzzling Kconfig dependencies MAINTAINERS: microblaze-uclinux@itee.uq.edu.au is moderated for non-subscribers tty: drop superfluous dependency in Kconfig ARM: mxc: fix Kconfig typo 'i.MX51' Fix file references in Kconfig files aic7xxx: fix Kconfig references to READMEs Fix file references in drivers/ide/ thinkpad_acpi: Fix printk typo 'bluestooth' bcmring: drop commented out line in Kconfig btmrvl_sdio: fix typo 'btmrvl_sdio_sd6888' doc: raw1394: Trivial typo fix CIFS: Don't free volume_info->UNC until we are entirely done with it. treewide: Correct spelling of successfully in comments ...
2011-10-25Merge branch 'misc' into for-linusRussell King
Conflicts: arch/arm/mach-integrator/integrator_ap.c
2011-10-25Merge branches 'arnd-randcfg-fixes', 'debug', 'io' (early part), 'l2x0', ↵Russell King
'p2v', 'pgt' (early part) and 'smp' into for-linus
2011-10-23Merge branch 'ppi-irq-core-for-rmk' of ↵Russell King
git://github.com/mzyngier/arm-platforms into devel-stable
2011-10-23ARM: gic: consolidate PPI handlingMarc Zyngier
PPI handling is a bit of an odd beast. It uses its own low level handling code and is hardwired to the local timers (hence lacking a registration interface). Instead, switch the low handling to the normal SPI handling code. PPIs are handled by the handle_percpu_devid_irq flow. This also allows the removal of some duplicated code. Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: David Brown <davidb@codeaurora.org> Cc: Bryan Huntsman <bryanh@codeaurora.org> Cc: Tony Lindgren <tony@atomide.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: David Brown <davidb@codeaurora.org> Tested-by: David Brown <davidb@codeaurora.org> Tested-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2011-10-21Merge branches 'amd/fixes', 'debug/dma-api', 'arm/omap', 'arm/msm', 'core', ↵Joerg Roedel
'iommu/fault-reporting' and 'api/iommu-ops-per-bus' into next Conflicts: drivers/iommu/amd_iommu.c drivers/iommu/iommu.c
2011-10-20ARM: smp: fix clipping of number of CPUsRussell King
Rather than clipping the number of CPUs using the compile-time NR_CPUS constant, use the runtime nr_cpu_ids value instead. This allows the nr_cpus command line option to work as expected. Cc: <stable@kernel.org> Reported-by: Mark Salter <msalter@redhat.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-10-18Merge branch 'mach_memory_h' of git://git.linaro.org/people/nico/linux into ↵Russell King
devel-stable
2011-10-17ARM: 7022/1: allow to detect conflicting zreladdrsSascha Hauer
Boards used to specify zreladdr in their Makefile.boot with zreladdr-y := x, so conflicting zreladdrs were silently overwritten. This patch changes this to zreladdr-y += x, so that we end up with multiple words in zreladdr in such a case. We can detect this later and complain if necessary. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-10-08Merge branch 'depends/rmk/devel-stable' into next/cleanupArnd Bergmann
2011-10-03ARM: OMAP: irq: loop counter fix in omap_init_irq()Tapani Utriainen
Fixes bug where variable i was redundantly used for counting two nested loops. Signed-off-by: Tapani Utriainen <tapani@technexion.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-10-03ARM: OMAP4: Keyboard: Fix section mismatch in the board fileBjarne Steinsbo
`keypad_pads' is referred to by `keypad_data' which is not __initdata, so `keypad_pads' should not be __initdata either. Signed-off-by: Bjarne Steinsbo <bsteinsbo@gmail.com> Reviewed-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-10-01ARM: pm: let platforms select cpu_suspend supportArnd Bergmann
Support for the cpu_suspend functions is only built-in when CONFIG_PM_SLEEP is enabled, but omap3/4, exynos4 and pxa always call cpu_suspend when CONFIG_PM is enabled. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-09-30Merge branch 'for_3.2/voltage-cleanup' of ↵Arnd Bergmann
git://gitorious.org/khilman/linux-omap-pm into omap/voltage
2011-09-30ARM: OMAP: musb: Remove a redundant omap4430_phy_init call in usb_musb_initAxel Lin
Current code calls omap4430_phy_init() twice in usb_musb_init(). Calling omap4430_phy_init() once is enough. This patch removes the first omap4430_phy_init() call, which using an uninitialized pointer as parameter. This patch elimates below build warning: arch/arm/mach-omap2/usb-musb.c: In function 'usb_musb_init': arch/arm/mach-omap2/usb-musb.c:141: warning: 'dev' may be used uninitialized in this function Signed-off-by: Axel Lin <axel.lin@gmail.com> Bjarne Steinsbo <bsteinsbo@gmail.com> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-09-30ARM: OMAP: Fix i2c init for twl4030Tony Lindgren
Looks like 2600 kHz rate does not work reliably on 2430, so just use the 100 kHz rate. Otherwise the system often fails to boot properly with: omap_i2c omap_i2c.2: timeout waiting for bus ready omap_i2c omap_i2c.2: timeout waiting for bus ready twl: i2c_write failed to transfer all messages omap_i2c omap_i2c.2: timeout waiting for bus ready twl: i2c_write failed to transfer all messages omap_i2c omap_i2c.2: timeout waiting for bus ready twl: i2c_write failed to transfer all messages twl: clock init err [-110] omap_i2c omap_i2c.2: timeout waiting for bus ready twl: i2c_write failed to transfer all messages TWL4030 Unable to unlock IDCODE registers --110 Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-09-30ARM: OMAP4: MMC: fix power and audio issue, decouple USBC1 from MMC1Bryan Buckley
Remove OMAP4_USBC1_ICUSB_PWRDNZ_MASK during enable/disable PWRDNZ mode for MMC1_PBIAS and associated extended-drain MMC1 I/O cell. This is in accordance with the control module programming guide. This fixes a bug where if trying to use gpio_98 or gpio_99 and MMC1 at the same time the GPIO signal will be affected by a changing SDMMC1_VDDS. Software must keep MMC1_PBIAS cell and MMC1_IO cell PWRDNZ signals low whenever SDMMC1_VDDS ramps up/down or changes for cell protection purposes. MMC1 is based on SDMMC1_VDDS whereas USBC1 is based on SIM_VDDS therefore they can operate independently. Signed-off-by: Bryan Buckley <bryan.buckley@ti.com> Acked-by: Kishore Kadiyala <kishore.kadiyala@ti.com> Tested-by: Balaji T K <balajitk@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-09-30OMAP: Apollon: Port the display driver to new DSS2Tomi Valkeinen
Port the old omapfb panel driver to DSS2. This patch changes the board file only, the driver is ported in separate patch. Cc: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-09-30OMAP: H4: Port the display driver to new DSS2Tomi Valkeinen
Port the old omapfb panel driver to DSS2. This patch changes the board file only, the driver is ported in separate patch. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-09-30OMAP: LDP: Port the display driver to new DSS2Tomi Valkeinen
Port the old omapfb panel driver to DSS2. This patch changes the board file only, the driver is ported in separate patch. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Stanley Miao <stanley.miao@windriver.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-09-30OMAP: 2420SDP: Port the display driver to new DSS2Tomi Valkeinen
Port the old omapfb panel driver to DSS2. This patch changes the board file only, the driver is ported in separate patch. Cc: Hunyue Yau <hyau@mvista.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-09-30OMAP: omap3touchbook: Remove unused lcd stuffTomi Valkeinen
board-omap3touchbook.c adds an LCD device, but the kernel doesn't contain a driver for the device. So let's remove the unneeded LCD device. Cc: Gregoire Gentil <gregoire@gentil.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-09-30OMAP: RX51: Remove unused old omapfb stuffTomi Valkeinen
RX51 uses the new DSS2 display driver, but the board file still contained some code for the old omapfb driver. The old code can be removed. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-09-30OMAP4: 4430SDP: Add picodlp support to board fileTomi Valkeinen
An on-board projector named picodlp is available for OMAP4430 SDP. Entry for this picodlp as a panel is being added in dss_devices array to the board file. It needs 4 GPIO pins for interfacing with host processor and these are defined and two of them are configured in board file. Two GPIOs power_on and display_select are configured here. picodlp also needs an i2c client over i2c controller-2 at address 0x1b. Signed-off-by: Mayuresh Janorkar <mayur@ti.com> Signed-off-by: Mythri P K <mythripk@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-09-30OMAP4: 4430SDP: Add panel support to board fileTomi Valkeinen
4430SDP has two Taal DSI panels, connected to DSI 1 and DSI 2 modules. The panels use a common PWM backlight, which will be implemented later when the PWM driver has been improved to support the backlight. Until the PWM driver has been improved, the following hack added to arch/arm/mach-omap2/board-4430sdp.c can be used to set the backlight to max: static int omap_4430sdp_hack_backlight(void) { twl_i2c_write_u8(TWL_MODULE_PWM, 0x7f, LED_PWM2OFF); twl_i2c_write_u8(TWL_MODULE_PWM, 0x7f, LED_PWM2ON); twl_i2c_write_u8(TWL6030_MODULE_ID1, 0x30, TWL6030_TOGGLE3); return 0; } late_initcall(omap_4430sdp_hack_backlight); Signed-off-by: Archit Taneja <archit@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-09-30OMAP: 4430SDP: Remove unneeded lcd configTomi Valkeinen
4430SDP board file contains some unused old LCD configurations. They are not used and can be removed. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-09-30OMAP: Add DDC i2c_bus_num to board filesTomi Valkeinen
Add i2c bus number for DVI output for boards with DVI output where the i2c bus has been confirmed to be connected and working. The driver uses this to detect if a panel is connected and to read EDID. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-09-30OMAP: stalker: Remove LCD device from board fileTomi Valkeinen
OMAP3 Stalker board has definitions for LCD, but uses the generic driver without any information what kind of LCD it has. The board should use a particular panel type from panel-generic-dpi driver, not the generic one. As I haven't gotten response the signer-off of stalker board about the issue, this patch removes the LCD support from the board file. This will allow us to clean up the panel-generic-dpi driver and make it support only fixed size panels. CC: Jason Lam <lzg@ema-tech.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-09-30OMAP: use dvi panel driver instead of generic-dpiTomi Valkeinen
Multiple OMAP3/4 boards have a DVI framer output. This patch makes the boards use the new panel-dvi driver, instead of the panel-generic-dpi driver. Separate drivers for fixed size panels and DVI framer gives us cleaner driver code. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-09-30OMAP: DSS2: HDMI: use default dividersTomi Valkeinen
Use default regn and regm2 dividers in the hdmi driver if the board file does not define them. Cc: Mythri P K <mythripk@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-09-30OMAP: Devkit8000: Change lcd driver to AT070TN83Thomas Weber
Change lcd driver from generic to AT070TN83. Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-09-30OMAP: DSS2: Implement dsi_mux_pads for OMAP4Tomi Valkeinen
Implement dsi_mux_pads for OMAP4. On enable the function enables the DSI pins and disables pull down. On disable the function disables the pins and enables pull down. It is unclear from the TRM whether the pull down is active if the pins are disabled, so this implementation may leave the pins floating when the DSI device is disabled. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-09-30OMAP: DSS2: DSI: Improve dsi_mux_pads parametersTomi Valkeinen
dsi_mux_pads() needs to know about the DSI HW module and the DSI lanes used. Split the function into two, enable and disable, which take necessary arguments, and add empty implementations for both. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-09-30OMAP4: TWL: Add common omapdss suppliesTomi Valkeinen
OMAP DSS normally gets power from VCXIO on OMAP4. Add configuration for this into twl-common.c Mark VCXIO as always_on, as VCXIO is used by multiple components, including the MPU, and turning it off when DSS doesn't need it would lead the device to halt. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-09-30OMAP: DSS2: Change DSI device namingTomi Valkeinen
Currently, there are 2 differently named platform devices generated for the 2 DSS DSI modules. In order to use the same driver, the dsi devices should be 2 instances of the same platform device. Change the platform device names from "omapdss_dsi1" and "omapdss_dsi2" to omapdss_dsi", and set the device indices to 0 and 1. Signed-off-by: Archit Taneja <archit@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
