This file will get split between sram242x.S and sram243x.S
in following patch.
This patch changes 24xx to use new register access, except for clock
framework. Clock framework register access will get updates in the
next patch.
Note that board-*.c files change GPMC (General Purpose Memory Controller)
access to use gpmc_cs_write_reg() instead of accessing the registers
directly. The code also uses gpmc_fck instead of it's parent clock
core_l3_ck for GPMC clock.
The H4 board file also adds h4_init_flash() function, which specify the
flash start and end addresses.
Also note that sleep.S removes some unused registers addresses.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Many files include the filename at the beginning, serveral used a wrong one.
Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Patch from Tony Lindgren
Update OMAP PM code from linux-omap tree:
- Move PM code from plat-omap to mach-omap1 and mach-omap2
by Tony Lindgren
- Add minimal PM support for omap24xx by Tony Lindgren and
Richard Woodruff
- Misc updates to omap1 PM code by Tuukka Tikkanen et al
- Updates to the SRAM code needed for PM and FB by Imre Deak
This patch adds support for omap24xx series of processors.
The files live in arch/arm/mach-omap2, and share common
files with omap15xx and omap16xx processors in
arch/arm/plat-omap.
Omap24xx support was originally added for 2.6.9 by TI.
This code was then improved and integrated to share common
code with omap15xx and omap16xx processors by various
omap developers, such as Paul Mundt, Juha Yrjola, Imre Deak,
Tony Lindgren, Richard Woodruff, Nishant Menon, Komal Shah
et al.
