[ Upstream commit 0f83e6b4161617014017a694888dd8743f46f071 ]
The of_find_compatible_node() function returns a node pointer with
refcount incremented, We should use of_node_put() on it when done
Add the missing of_node_put() to release the refcount.
Fixes: fd1c07861491 ("ARM: OMAP4: Fix the init code to have OMAP4460 errata available in DT build")
Signed-off-by: Miaoqian Lin <linmq006@gmail.com>
Message-Id: <20220309104302.18398-1-linmq006@gmail.com>
We have errata i688 workaround produce warnings on SoCs other than
omap4 and omap5:
omap4_sram_init:Unable to allocate sram needed to handle errata I688
omap4_sram_init:Unable to get sram pool needed to handle errata I688
This is happening because there is no ti,omap4-mpu node, or no SRAM
to configure for the other SoCs, so let's remove the warning based
on the SoC revision checks.
As nobody has complained it seems that the other SoC variants do not
need this workaround.
Based on 2 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license version 2 as
published by the free software foundation
published by the free software foundation #
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 4122 file(s).
Reviewed-by: Enrico Weigelt <info@metux.net>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190604081206.933168790@linutronix.de
With the previous patches removing the need for legacy IRQs
now that all of mach-omap2 is booting in device tree only mode,
we can drop struct omap_hwmod_irq_info.
Note that we can now also finally drop omap4_xlate_irq.
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Paul Walmsley <paul@pwsan.com>
Cc: Tero Kristo <t-kristo@ti.com>
Prepare things for making kexec work on SMP omap variants by initializing
SARM RAM base early. This allows us to configure CPU1 for kexec in case
the previous kernel has put CPU1 in low power mode.
Note that this should not prevent moving other SAR RAM code to live
under drivers. However for kexec, we will need this very early.
Acked-by: Santosh Shilimkar <ssantosh@kernel.org>
Tested-by: Keerthy <j-keerthy@ti.com>
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net>
Restore the OMAP4 barrier behaviour using the new implementation which
allows multiplatform systems to hook into the mb() and wmb() ARM
implementations to perform any necessary additional barrier maintanence.
Acked-by: Richard Woodruff <r-woodruff2@ti.com>
This reverts commit 606da4826b89b044b51e3a84958b802204cfe4c7.
We actually need this code for proper behaviour of OMAP4, and it needs
fixing a different way other than just removing the code. Disabling
code which is necessary in the hopes of persuing multiplatform kernels
is a stupid approach.
Pull ARM SoC fixes from Olof Johansson:
"Here's the usual "low-priority fixes that didn't make it into the last
few -rcs, with a twist: We had a fixes pull request that I didn't send
in time to get into 4.0, so we'll send some of them to Greg for
-stable as well.
Contents here is as usual not all that controversial:
- a handful of randconfig fixes from Arnd, in particular for older
Samsung platforms
- Exynos fixes, !SMP building, DTS updates for MMC and lid switch
- Kbuild fix to create output subdirectory for DTB files
- misc minor fixes for OMAP"
* tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (23 commits)
ARM: at91/dt: sama5d3 xplained: add phy address for macb1
kbuild: Create directory for target DTB
ARM: mvebu: Disable CPU Idle on Armada 38x
ARM: DRA7: Enable Cortex A15 errata 798181
ARM: dts: am57xx-beagle-x15: Add thermal map to include fan and tmp102
ARM: dts: DRA7: Add bandgap and related thermal nodes
bus: ocp2scp: SYNC2 value should be changed to 0x6
ARM: dts: am4372: Add "ti,am437x-ocp2scp" as compatible string for OCP2SCP
ARM: OMAP2+: remove superfluous NULL pointer check
ARM: EXYNOS: Fix build breakage cpuidle on !SMP
ARM: dts: fix lid and power pin-functions for exynos5250-spring
ARM: dts: fix mmc node updates for exynos5250-spring
ARM: OMAP4: remove dead kconfig option OMAP4_ERRATA_I688
MAINTAINERS: add OMAP defconfigs under OMAP SUPPORT
ARM: OMAP1: PM: fix some build warnings on 1510-only Kconfigs
ARM: cns3xxx: don't export static symbol
ARM: S3C24XX: avoid a Kconfig warning
ARM: S3C24XX: fix header file inclusions
ARM: S3C24XX: fix building without PM_SLEEP
ARM: S3C24XX: use SAMSUNG_WAKEMASK for s3c2416
The Kconfig-Option OMAP4_ERRATA_I688 is never visible due to a
contradiction in it's dependencies.
The option requires ARCH_MULTIPLATFORM to be 'disabled'. However, an
enclosing menu requires either ARCH_MULTI_V6 or ARCH_MULTI_V7 to be
enabled. These options inherit a dependency from an enclosing menu,
that requires ARCH_MULTIPLATFORM to be 'enabled'.
This is a contradiction and made this option also unavailable for
non-multiplatform configurations.
Since there are no selects on OMAP4_ERRATA_I688, which would ignore
dependencies, the code related to that option is dead and can be
removed.
This (logical) defect has been found with the undertaker tool.
(https://undertaker.cs.fau.de)
Signed-off-by: Stefan Hengelein <stefan.hengelein@fau.de>
OMAP4/5 has been (ab)using the gic_arch_extn to provide
wakeup from suspend, and it makes a lot of sense to convert
this code to use stacked domains instead.
This patch does just this, updating the DT files to actually
reflect what the HW provides.
BIG FAT WARNING: because the DTs were so far lying by not
exposing the WUGEN HW block, kernels with this patch applied
won't have any suspend-resume facility when booted with old DTs,
and old kernels with updated DTs won't even boot.
On a platform with this patch applied, the system looks like
this:
root@bacon-fat:~# cat /proc/interrupts
CPU0 CPU1
16: 0 0 WUGEN 37 gp_timer
19: 233799 155916 GIC 27 arch_timer
23: 0 0 WUGEN 9 l3-dbg-irq
24: 1 0 WUGEN 10 l3-app-irq
27: 282 0 WUGEN 13 omap-dma-engine
44: 0 0 4ae10000.gpio 13 DMA
294: 0 0 WUGEN 20 gpmc
297: 506 0 WUGEN 56 48070000.i2c
298: 0 0 WUGEN 57 48072000.i2c
299: 0 0 WUGEN 61 48060000.i2c
300: 0 0 WUGEN 62 4807a000.i2c
301: 8 0 WUGEN 60 4807c000.i2c
308: 2439 0 WUGEN 74 OMAP UART2
312: 362 0 WUGEN 83 mmc2
313: 502 0 WUGEN 86 mmc0
314: 13 0 WUGEN 94 mmc1
350: 0 0 PRCM pinctrl, pinctrl
406: 35155709 0 GIC 109 ehci_hcd:usb1
407: 0 0 WUGEN 7 palmas
409: 0 0 WUGEN 119 twl6040
410: 0 0 twl6040 5 twl6040_irq_ready
411: 0 0 twl6040 0 twl6040_irq_th
IPI0: 0 1 CPU wakeup interrupts
IPI1: 0 0 Timer broadcast interrupts
IPI2: 95334 902334 Rescheduling interrupts
IPI3: 0 0 Function call interrupts
IPI4: 479 648 Single function call interrupts
IPI5: 0 0 CPU stop interrupts
IPI6: 0 0 IRQ work interrupts
IPI7: 0 0 completion interrupts
Err: 0
Link: https://lkml.kernel.org/r/1426088629-15377-8-git-send-email-marc.zyngier@arm.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
Support for the TI crossbar used on the DRA7 family of chips
is implemented as an ugly hack on the side of the GIC.
Converting it to stacked domains makes it slightly more
palatable, as it results in a cleanup.
Unfortunately, as the DT bindings failed to acknowledge the
fact that this is actually yet another interrupt controller
(the third, actually), we have yet another breakage. Oh well.
Link: https://lkml.kernel.org/r/1426088629-15377-3-git-send-email-marc.zyngier@arm.com
of_device_ids (i.e. compatible strings and the respective data) are not
supposed to change at runtime. All functions working with of_device_ids
provided by <linux/of.h> work with const of_device_ids. So mark the
non-const structs in arch/arm as const, too.
While at it also add some __initconst annotations.
Acked-by: Jason Cooper <jason@lakedameon.net>
Pull ARM updates from Russell King:
- clang assembly fixes from Ard
- optimisations and cleanups for Aurora L2 cache support
- efficient L2 cache support for secure monitor API on Exynos SoCs
- debug menu cleanup from Daniel Thompson to allow better behaviour for
- StrongARM SA11x0 conversion to irq domains, and pxa_timer
- kprobes updates for older ARM CPUs
- move probes support out of arch/arm/kernel to arch/arm/probes
- add inline asm support for the rbit (reverse bits) instruction
- provide an ARM mode secondary CPU entry point (for Qualcomm CPUs)
- remove the unused ARMv3 user access code
- add driver_override support to AMBA Primecell bus
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (55 commits)
ARM: 8256/1: driver coamba: add device binding path 'driver_override'
ARM: 8301/1: qcom: Use secondary_startup_arm()
ARM: 8302/1: Add a secondary_startup that assumes ARM mode
ARM: 8300/1: teach __asmeq that r11 == fp and r12 == ip
ARM: kprobes: Fix compilation error caused by superfluous '*'
ARM: 8297/1: cache-l2x0: optimize aurora range operations
ARM: 8296/1: cache-l2x0: clean up aurora cache handling
ARM: 8284/1: sa1100: clear RCSR_SMR on resume
ARM: 8283/1: sa1100: collie: clear PWER register on machine init
ARM: 8282/1: sa1100: use handle_domain_irq
ARM: 8281/1: sa1100: move GPIO-related IRQ code to gpio driver
ARM: 8280/1: sa1100: switch to irq_domain_add_simple()
ARM: 8279/1: sa1100: merge both GPIO irqdomains
ARM: 8278/1: sa1100: split irq handling for low GPIOs
ARM: 8291/1: replace magic number with PAGE_SHIFT macro in fixup_pv code
ARM: 8290/1: decompressor: fix a wrong comment
ARM: 8286/1: mm: Fix dma_contiguous_reserve comment
ARM: 8248/1: pm: remove outdated comment
ARM: 8274/1: Fix DEBUG_LL for multi-platform kernels (without PL01X)
ARM: 8273/1: Seperate DEBUG_UART_PHYS from DEBUG_LL on EP93XX
Commit 9a1091ef0017 ("irqchip: gic: Support hierarchy irq domain")
changed the GIC driver to use a non-legacy IRQ domain on DT
platforms. This patch assumes that DT-driven systems are getting
all of their interrupts from device tree.
Turns out that OMAP has quite a few hidden gems, and still uses
hardcoded interrupts despite having fairly complete DTs.
This patch attempts to work around these by offering a translation
method that can be called directly from the hwmod code, if present.
The same hack is sprinkled over PRCM and TWL.
It isn't pretty, but it seems to do the job without having to add
more hacks to the interrupt controller code.
Tested on OMAP4 (Panda-ES) and OMAP5 (UEVM5432).
Acked-by: Nishanth Menon <nm@ti.com>
[tony@atomide.com: updated to fix make randconfig issue]
This patch implements generic DT L2C initialisation (the one from
init_IRQ in arch/arm/kernel/irq.c) for Omap4 and AM43 platforms and
kills the SoC specific stuff in arch/arm/mach-omap2/omap4-common.c.
Tested-by: Nishanth Menon <nm@ti.com>
Only a few files really need that platform header. When later splitting
omap_mmc_platform_data into omap_mmc and omap_mmc_hs, those files
declaring an hs mmc platform data will have to change the platform
include, which is a good sanity check.
Also removing omap242x_init_mmc, which is not used anywhere, checked
with grep.
Signed-off-by: Andreas Fenkart <afenkart@gmail.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
In order to handle errata I688, a page of sram was reserved by doing a
static iotable map. Now that we use gen_pool to manage sram, we can
completely remove all of these static mappings and use gen_pool_alloc()
to get the one page of sram space needed to implement errata I688.
omap_bus_sync will be NOP until SRAM initialization happens.
Suggested-by: Sekhar Nori <nsekhar@ti.com>
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
On OMAP SOCs using PL310 controllers, power_ctrl register is not
accessible from non-secure software even on PL310 versions which
support it. The secure code takes care of setting it up correctly
and power transitions are proven on these devices.
For example, AM437x has L2C-310 version r3p3 and ROM code on that
device does not support writing to L2C-310 power control register.
The L2C driver, however, tries writing to this register for all
revisions >= r3p0.
This leads to a warning dump on boot which leads most users to believe
that L2 cache is non-functional.
Since the problem is understood, and cannot be addressed through
software, replace the warning with a pr_info() while maintaining the
WARN_ON() for other truly unexpected scenarios.
Reported-by: Nishanth Menon <nm@ti.com>
Tested-by: Felipe Balbi <balbi@ti.com>
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
gic_init_irq() is no longer used as of:
commit b42b918194c4791510ac049e3d507169a7de8544
Author: Tony Lindgren <tony@atomide.com>
Date: Thu May 30 12:53:05 2013 -0700
ARM: OMAP2+: Remove board-omap4panda.c
Drop it.
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Cc: Tony Lindgren <tony@atomide.com>
Cc: linux-omap@vger.kernel.org
- Major clean-up of the L2 cache support code. The existing mess was
becoming rather unmaintainable through all the additions that others
have done over time. This turns it into a much nicer structure, and
implements a few performance improvements as well.
- Clean up some of the CP15 control register tweaks for alignment
support, moving some code and data into alignment.c
- DMA properties for ARM, from Santosh and reviewed by DT people. This
adds DT properties to specify bus translations we can't discover
automatically, and to indicate whether devices are coherent.
- Hibernation support for ARM
- Make ftrace work with read-only text in modules
- add suspend support for PJ4B CPUs
- rework interrupt masking for undefined instruction handling, which
allows us to enable interrupts earlier in the handling of these
exceptions.
- support for big endian page tables
- fix stacktrace support to exclude stacktrace functions from the
trace, and add save_stack_trace_regs() implementation so that kprobes
can record stack traces.
- Add support for the Cortex-A17 CPU.
- Remove last vestiges of ARM710 support.
- Removal of ARM "meminfo" structure, finally converting us solely to
memblock to handle the early memory initialisation.
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (142 commits)
ARM: ensure C page table setup code follows assembly code (part II)
ARM: consolidate last remaining open-coded alignment trap enable
ARM: remove global cr_no_alignment
ARM: remove CPU_CP15 conditional from alignment.c
ARM: remove unused adjust_cr() function
ARM: move "noalign" command line option to alignment.c
ARM: provide common method to clear bits in CPU control register
ARM: 8025/1: Get rid of meminfo
ARM: 8060/1: mm: allow sub-architectures to override PCI I/O memory type
ARM: 8066/1: correction for ARM patch 8031/2
ARM: 8049/1: ftrace/add save_stack_trace_regs() implementation
ARM: 8065/1: remove last use of CONFIG_CPU_ARM710
ARM: 8062/1: Modify ldrt fixup handler to re-execute the userspace instruction
ARM: 8047/1: rwsem: use asm-generic rwsem implementation
ARM: l2c: trial at enabling some Cortex-A9 optimisations
ARM: l2c: add warnings for stuff modifying aux_ctrl register values
ARM: l2c: print a warning with L2C-310 caches if the cache size is modified
ARM: l2c: remove old .set_debug method
ARM: l2c: kill L2X0_AUX_CTRL_MASK before anyone else makes use of this
Get rid of init call to initialize L2 cache. Instead use the init_early
machine hook. This helps in using the initialization routine across
SoCs without the need of ugly cpu_is_*() checks.
L2 cache initialization for OMAP4 redundantly sets the cache policy to
Round-Robin. This is not needed since thats the PL310 default anyway.
Removing this reduces the number of platform specific aux control
settings.
Since we now always enable NS access to the unlock registers, this can
be removed from OMAP4. Remove the NS access bit for the interrupt
registers from OMAP4 as well - nothing in the kernel accesses that yet,
and we can add it in core code when we have the need.
The cache size should already be present in the L2 cache auxiliary
control register: it is part of the integration process to configure
the hardware IP. Most platforms get this right, yet still many
cargo-cult program, and assume that they always need specifying to
the L2 cache code. Remove them so we can find out which really need
this.
Now that OMAP2 uses the write_sec method, we don't need to enable the L2
cache in OMAP2 specific code; this can be done via the normal mechanisms
in the L2C code. Remove the OMAP2 specific code.
With the write_sec method, we no longer need to override the default
L2C disable method, and we no longer need the L2C set_debug method.
Both of these can be handled via the write_sec method.
Since we now automatically enable early BRESP in core L2C-310 code when
we detect a Cortex-A9, we don't need platforms/SoCs to set this bit
explicitly. Instead, they should seek to preserve the value of bit 30
in the auxiliary control register.
We have a mixture of different devices with different register layouts,
but we group all the bits together in an opaque mess. Split them out
into those which are L2C-310 specific and ones which refer to earlier
devices. Provide full auxiliary control register definitions.
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Santosh says:
> But we should kill all of that since we long back decided to remove
> ES1.0 related code. The mach-omap code alreasy has removed the ES1.0
> compatibility so feel free to remove any specific ES1.0
> related stuff. That silicon is long dead.
All OMAP IP blocks expect LE data, but CPU may operate in BE mode.
Need to use endian neutral functions to read/write h/w registers.
I.e instead of __raw_read[lw] and __raw_write[lw] functions code
need to use read[lw]_relaxed and write[lw]_relaxed functions.
If the first simply reads/writes register, the second will byteswap
it if host operates in BE mode.
Changes are trivial sed like replacement of __raw_xxx functions
with xxx_relaxed variant.
Signed-off-by: Victor Kamensky <victor.kamensky@linaro.org>
Signed-off-by: Taras Kondratiuk <taras.kondratiuk@linaro.org>
Enable the crossbar IP support for DRA7xx soc.
Cc: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: Rajendra Nayak <rnayak@ti.com>
Signed-off-by: Sricharan R <r.sricharan@ti.com>
The same workaround as ff999b8a0983ee15668394ed49e38d3568fc6859
"ARM: OMAP4460: Workaround for ROM bug because of CA9 r2pX GIC ..."
need to be applied not only when system is booting, but when MPUSS hits
OSWR state through CPUIdle too. Without this WA the same issue is
reproduced now on boards PandaES and Tablet/Blaze with SOM OMAP4460
when CONFIG_CPU_IDLE is enabled.
After MPUSS has enterred OSWR and waken up:
- GIC distributor became disabled forever
- scheduling is not performed any more
Cc: Kevin Hilman <khilman@linaro.org>
Reported-by: Taras Kondratiuk <taras.kondratiuk@linaro.org>
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
Signed-off-by: Kevin Hilman <khilman@linaro.org>
for-next
Kexec disables outer cache before jumping to reboot code, but it doesn't
flush it explicitly. Flush is done implicitly inside of l2x0_disable().
But some SoC's override default .disable handler and don't flush cache.
This may lead to a corrupted memory during Kexec reboot on these
platforms.
This patch adds cache flush inside of OMAP4 and Highbank outer_cache.disable()
handlers to make it consistent with default l2x0_disable().
Acked-by: Rob Herring <rob.herring@calxeda.com>
Document the permissions which the various MT_MEMORY* mapping types
will provide.
This is no longer used, omap4 is device tree based now.
Preparing to move the parsing of reboot= to generic kernel code forces
the change in reboot_mode handling to use the enum.
[akpm@linux-foundation.org: fix arch/arm/mach-socfpga/socfpga.c]
Signed-off-by: Robin Holt <holt@sgi.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Russ Anderson <rja@sgi.com>
Cc: Robin Holt <holt@sgi.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Separate out OMAP4 restart and have it similar to other platforms, in
a different file. Main motive is to reuse omap4-common on platforms
other than OMAP4, like AM43x, even if OMAP4 is deselected (otherwise
would have caused build breakage).
Signed-off-by: Afzal Mohammed <afzal@ti.com>
Pull ARM SoC cleanup from Olof Johansson:
"Here is a collection of cleanup patches. Among the pieces that stand
out are:
- The deletion of h720x platforms
- Split of at91 non-dt platforms to their own Kconfig file to keep
them separate
- General cleanups and refactoring of i.MX and MXS platforms
- Some restructuring of clock tables for OMAP
- Convertion of PMC driver for Tegra to dt-only
- Some renames of sunxi -> sun4i (Allwinner A10)
- ... plus a bunch of other stuff that I haven't mentioned"
* tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (119 commits)
ARM: i.MX: remove unused ARCH_* configs
ARM i.MX53: remove platform ahci support
ARM: sunxi: Rework the restart code
irqchip: sunxi: Rename sunxi to sun4i
irqchip: sunxi: Make use of the IRQCHIP_DECLARE macro
clocksource: sunxi: Rename sunxi to sun4i
clocksource: sunxi: make use of CLKSRC_OF
clocksource: sunxi: Cleanup the timer code
ARM: at91: remove trailing semicolon from macros
ARM: at91/setup: fix trivial typos
ARM: EXYNOS: remove "config EXYNOS_DEV_DRM"
ARM: EXYNOS: change the name of USB ohci header
ARM: SAMSUNG: Remove unnecessary code for dma
ARM: S3C24XX: Remove unused GPIO drive strength register definitions
ARM: OMAP4+: PM: Restore CPU power state to ON with clockdomain force wakeup method
ARM: S3C24XX: Removed unneeded dependency on CPU_S3C2412
ARM: S3C24XX: Removed unneeded dependency on CPU_S3C2410
ARM: S3C24XX: Removed unneeded dependency on ARCH_S3C24XX for boards
ARM: SAMSUNG: Fix typo "CONFIG_SAMSUNG_DEV_RTC"
ARM: S5P64X0: Fix typo "CONFIG_S5P64X0_SETUP_SDHCI"
OMAP4460 ROM code bug needs the GIC distributor and local timer
bases to be available for the bug work around. In current code, dt
case these bases are not initialized leading to failure of the
errata work-around.
Fix it by extracting the bases from dt blob and populating them.
Reported-by: Sourav Poddar <sourav.poddar@ti.com>
Tested-by: Sourav Poddar <sourav.poddar@ti.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Update SAR RAM base address for OMAP5 based devices.
Pull ARM SoC multiplatform support from Arnd Bergmann:
"Converting more ARM platforms to multiplatform support. This time,
OMAP gets converted, which is a major step since this is by far the
largest platform in terms of code size. The same thing happens to the
vt8500 platform."
* tag 'multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
net: cwdavinci_cpdma: export symbols for cpsw
remoteproc: omap: depend on OMAP_MBOX_FWK
[media] davinci: do not include mach/hardware.h
ARM: OMAP2+: Make sure files with omap initcalls include soc.h
ARM: OMAP2+: Include soc.h to drm.c to fix compiling
ARM: OMAP2+: Fix warning for hwspinlock omap_postcore_initcall
ARM: multi_v7_defconfig: add ARCH_ZYNQ
ARM: multi_v7_defconfig: remove unnecessary CONFIG_GPIOLIB
arm: vt8500: Remove remaining mach includes
arm: vt8500: Convert debug-macro.S to be multiplatform friendly
arm: vt8500: Remove single platform Kconfig options
ARM: OMAP2+: Remove now obsolete uncompress.h and debug-macro.S
ARM: OMAP2+: Add minimal support for booting vexpress
ARM: OMAP2+: Enable ARCH_MULTIPLATFORM support
ARM: OMAP2+: Disable code that currently does not work with multiplaform
ARM: OMAP2+: Add multiplatform debug_ll support
ARM: OMAP: Fix dmaengine init for multiplatform
ARM: OMAP: Fix i2c cmdline initcall for multiplatform
ARM: OMAP2+: Use omap initcalls
ARM: OMAP2+: Limit omap initcalls to omap only on multiplatform kernels
Now that we have GIC moved to drivers/irqchip and all GIC DT init for
platforms using irqchip_init, move gic.h and update the remaining
includes.
Cc: Anton Vorontsov <avorontsov@mvista.com>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: David Brown <davidb@codeaurora.org>
Cc: Daniel Walker <dwalker@fifo99.com>
Cc: Bryan Huntsman <bryanh@codeaurora.org>
Cc: Magnus Damm <magnus.damm@gmail.com>
Cc: Viresh Kumar <viresh.linux@gmail.com>
Cc: Shiraz Hashim <shiraz.hashim@st.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Samuel Ortiz <sameo@linux.intel.com>
Convert all GIC DT initialization over to use common irqchip_init
function.
Cc: Dinh Nguyen <dinguyen@altera.com>
This way the initcalls don't run on other SoCs on multiplatform
kernels. Otherwise we'll get something like this when booting
on vexpress:
omap_hwmod: _ensure_mpu_hwmod_is_setup: MPU initiator hwmod mpu not yet registered
WARNING: at arch/arm/mach-omap2/pm.c:82 _init_omap_device+0x74/0x94()
_init_omap_device: could not find omap_hwmod for mpu
omap-dma-engine omap-dma-engine: OMAP DMA engine driver
Tested-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Pull ARM SoC cleanups on various subarchitectures from Olof Johansson:
"Cleanup patches for various ARM platforms and some of their associated
drivers. There's also a branch in here that enables Freescale i.MX to
be part of the multiplatform support -- the first "big" SoC that is
moved over (more multiplatform work comes in a separate branch later
during the merge window)."
Conflicts fixed as per Olof, including a silent semantic one in
arch/arm/mach-omap2/board-generic.c (omap_prcm_restart() was renamed to
omap3xxx_restart(), and a new user of the old name was added).
* tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (189 commits)
ARM: omap: fix typo on timer cleanup
ARM: EXYNOS: Remove unused regs-mem.h file
ARM: EXYNOS: Remove unused non-dt support for dwmci controller
ARM: Kirkwood: Use hw_pci.ops instead of hw_pci.scan
ARM: OMAP3: cm-t3517: use GPTIMER for system clock
ARM: OMAP2+: timer: remove CONFIG_OMAP_32K_TIMER
ARM: SAMSUNG: use devm_ functions for ADC driver
ARM: EXYNOS: no duplicate mask/unmask in eint0_15
ARM: S3C24XX: SPI clock channel setup is fixed for S3C2443
ARM: EXYNOS: Remove i2c0 resource information and setting of device names
ARM: Kirkwood: checkpatch cleanups
ARM: Kirkwood: Fix sparse warnings.
ARM: Kirkwood: Remove unused includes
ARM: kirkwood: cleanup lsxl board includes
ARM: integrator: use BUG_ON where possible
ARM: integrator: push down SC dependencies
ARM: integrator: delete static UART1 mapping
ARM: integrator: delete SC mapping on the CP
ARM: integrator: remove static CP syscon mapping
ARM: integrator: remove static AP syscon mapping
Pull ARM SoC Header cleanups from Olof Johansson:
"This is a collection of header file cleanups, mostly for OMAP and
AT91, that keeps moving the platforms in the direction of
multiplatform by removing the need for mach-dependent header files
used in drivers and other places."
Fix up mostly trivial conflicts as per Olof.
* tag 'headers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (106 commits)
ARM: OMAP2+: Move iommu/iovmm headers to platform_data
ARM: OMAP2+: Make some definitions local
ARM: OMAP2+: Move iommu2 to drivers/iommu/omap-iommu2.c
ARM: OMAP2+: Move plat/iovmm.h to include/linux/omap-iommu.h
ARM: OMAP2+: Move iopgtable header to drivers/iommu/
ARM: OMAP: Merge iommu2.h into iommu.h
atmel: move ATMEL_MAX_UART to platform_data/atmel.h
ARM: OMAP: Remove omap_init_consistent_dma_size()
arm: at91: move at91rm9200 rtc header in drivers/rtc
arm: at91: move reset controller header to arm/arm/mach-at91
arm: at91: move pit define to the driver
arm: at91: move at91_shdwc.h to arch/arm/mach-at91
arm: at91: move board header to arch/arm/mach-at91
arn: at91: move at91_tc.h to arch/arm/mach-at91
arm: at91 move at91_aic.h to arch/arm/mach-at91
arm: at91 move board.h to arch/arm/mach-at91
arm: at91: move platfarm_data to include/linux/platform_data/atmel.h
arm: at91: drop machine defconfig
ARM: OMAP: Remove NEED_MACH_GPIO_H
ARM: OMAP: Remove unnecessary mach and plat includes
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/cleanup
From Tony Lindgren <tony@atomide.com>:
More PRCM cleanups via Paul Walmsley <paul@pwsan.com>:
Second set of OMAP PRCM cleanups for 3.8.
These patches remove the use of omap_prcm_get_reset_sources() from the
OMAP watchdog driver, and remove mach-omap2/prcm.c and
plat-omap/include/plat/prcm.h.
Basic test logs for this branch on top of Tony's cleanup-prcm branch
at commit 7fc54fd3084457c7f11b9e2e1e3fcd19a3badc33 are here:
http://www.pwsan.com/omap/testlogs/prcm_cleanup_b_3.8/20121108151646/
However, cleanup-prcm at 7fc54fd3 does not include some fixes
that are needed for a successful test. With several reverts,
fixes, and workarounds applied, the following test logs were
obtained:
http://www.pwsan.com/omap/testlogs/TEST_prcm_cleanup_b_3.8/20121108151930/
which indicate that the series tests cleanly.
This second pull request updates one of the patches which broke
with rmk's allnoconfigs, and also updates the tag description to
indicate that 7fc54fd3 is building cleanly here.
* tag 'omap-for-v3.8/cleanup-prcm-part2-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (27 commits)
ARM: OMAP2: Fix compillation error in cm_common
ARM: OMAP2+: PRCM: remove obsolete prcm.[ch]
ARM: OMAP2+: hwmod: call to _omap4_disable_module() should use the SoC-specific call
ARM: OMAP2+: PRCM: consolidate PRCM-related timeout macros
ARM: OMAP2+: PRCM: split and relocate the PRM/CM globals setup
ARM: OMAP2+: PRCM: remove omap2_cm_wait_idlest()
ARM: OMAP2+: CM/clock: convert _omap2_module_wait_ready() to use SoC-independent CM functions
ARM: OMAP2xxx: APLL/CM: convert to use omap2_cm_wait_module_ready()
ARM: OMAP2+: board files: use SoC-specific system restart functions
ARM: OMAP2+: PRCM: create SoC-specific chip restart functions
ARM: OMAP2xxx: clock: move virt_prcm_set code into clkt2xxx_virt_prcm_set.c
ARM: OMAP2xxx: clock: remove global 'dclk' variable
ARM: OMAP2/3: PRM: add SoC reset functions (using the CORE DPLL method)
ARM: OMAP2+: common: remove mach-omap2/common.c globals and map_common_io code
ARM: OMAP2+: PRCM: remove omap_prcm_get_reset_sources()
watchdog: OMAP: use standard GETBOOTSTATUS interface; use platform_data fn ptr
ARM: OMAP2+: WDT: move init; add read_reset_sources pdata function pointer
ARM: OMAP1: CGRM: fix omap1_get_reset_sources() return type
ARM: OMAP2+: PRM: create PRM reset source API for the watchdog timer driver
ARM: OMAP1: create read_reset_sources() function (for initial use by watchdog)
arch/arm/mach-omap2/cm33xx.c
arch/arm/mach-omap2/io.c
arch/arm/mach-omap2/prm_common.c
