path: root/arch/arm/mach-omap2/board-n8x0.c
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-12-18Merge branch 'i2c-embedded/for-next' of git://git.pengutronix.de/git/wsa/linuxLinus Torvalds
Pull i2c-embedded changes from Wolfram Sang: - CBUS driver (an I2C variant) - continued rework of the omap driver - s3c2410 gets lots of fixes and gains pinctrl support - at91 gains DMA support - the GPIO muxer gains devicetree probing - typical fixes and additions all over * 'i2c-embedded/for-next' of git://git.pengutronix.de/git/wsa/linux: (45 commits) i2c: omap: Remove the OMAP_I2C_FLAG_RESET_REGS_POSTIDLE flag i2c: at91: add dma support i2c: at91: change struct members indentation i2c: at91: fix compilation warning i2c: mxs: Do not disable the I2C SMBus quick mode i2c: mxs: Handle i2c DMA failure properly i2c: s3c2410: Remove recently introduced performance overheads i2c: ocores: Move grlib set/get functions into #ifdef CONFIG_OF block i2c: s3c2410: Add fix for i2c suspend/resume i2c: s3c2410: Fix code to free gpios i2c: i2c-cbus-gpio: introduce driver i2c: ocores: Add support for the GRLIB port of the controller and use function pointers for getreg and setreg functions i2c: ocores: Add irq support for sparc i2c: omap: Move the remove constraint ARM: dts: cfa10049: Add the i2c muxer buses to the CFA-10049 i2c: s3c2410: do not special case HDMIPHY stuck bus detection i2c: s3c2410: use exponential back off while polling for bus idle i2c: s3c2410: do not generate STOP for QUIRK_HDMIPHY i2c: s3c2410: grab adapter lock while changing i2c clock i2c: s3c2410: Add support for pinctrl ...
2012-11-19i2c: i2c-cbus-gpio: introduce driverAaro Koskinen
Add i2c driver to enable access to devices behind CBUS on Nokia Internet Tablets. The patch also adds CBUS I2C configuration for N8x0 which is one of the users of this driver. Acked-by: Felipe Balbi <balbi@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
2012-11-08ARM: OMAP2+: board files: use SoC-specific system restart functionsPaul Walmsley
Modify the board files to use the SoC-specific system restart functions. At this point it's possible to remove omap_prcm_restart() from mach-omap2/prcm.c. While removing the prototypes for the now-unused restart functions, clean up a few more obsolete prototypes in mach-omap2/clock.h. Signed-off-by: Paul Walmsley <paul@pwsan.com> Tested-by: Vaibhav Hiremath <hvaibhav@ti.com>
2012-10-25Merge branch 'omap-for-v3.8/cleanup-headers-menelaus' into ↵Tony Lindgren
omap-for-v3.8/cleanup-headers Conflicts: arch/arm/mach-omap2/board-h4.c arch/arm/mach-omap2/board-n8x0.c
2012-10-17Merge branch 'omap-for-v3.8/cleanup-headers-mmc' into ↵Tony Lindgren
omap-for-v3.8/cleanup-headers Conflicts: arch/arm/mach-omap1/devices.c arch/arm/mach-omap2/omap_hwmod_33xx_data.c arch/arm/mach-omap2/omap_hwmod_3xxx_data.c drivers/mmc/host/omap.c
2012-10-15ARM: OMAP2: Move plat/menelaus.h to linux/mfd/menelaus.hTony Lindgren
We can move menelaus.h to live with other mfd headers to get it out of plat for ARM common zImage support. Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-15ARM: OMAP: Split plat/mmc.h into local headers and platform_dataTony Lindgren
We need to remove this from plat for ARM common zImage support. Also remove includes not needed by the omap_hsmmc.c driver. Cc: linux-mmc@vger.kernel.org Acked-by: Chris Ball <cjb@laptop.org> Acked-by: Venkatraman S <svenkatr@ti.com> [tony@atomide.com: fold in removal of unused driver includes] Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-15ARM: OMAP2+: onenand: header cleanupAfzal Mohammed
For common arm zImage existing onenand header file in platform specific location was moved to generic platform data location, but it contained more than platform data, remove it. New local header has been created for exposing functions. Signed-off-by: Afzal Mohammed <afzal@ti.com>
2012-09-19ARM: omap: move platform_data definitionsArnd Bergmann
Platform data for device drivers should be defined in include/linux/platform_data/*.h, not in the architecture and platform specific directories. This moves such data out of the omap include directories Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Cc: Kevin Hilman <khilman@ti.com> Cc: "Benoît Cousson" <b-cousson@ti.com> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Ohad Ben-Cohen <ohad@wizery.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Omar Ramirez Luna <omar.ramirez@ti.com> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Peter Ujfalusi <peter.ujfalusi@ti.com> Cc: Jarkko Nikula <jarkko.nikula@bitmer.com> Cc: Liam Girdwood <lrg@ti.com> Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: Jean Pihet <j-pihet@ti.com> Cc: J Keerthy <j-keerthy@ti.com> Cc: linux-omap@vger.kernel.org
2012-09-12Merge tag 'omap-cleanup-b-for-3.7' of ↵Tony Lindgren
git://git.kernel.org/pub/scm/linux/kernel/git/pjw/omap-pending into cleanup-makefile-sparse smatch and string-wrapping cleanups for the OMAP subarch code. These changes fix some of the more meaningful warnings that smatch returns for the OMAP subarch code, and unwraps strings that are wrapped at the 80-column boundary, to conform with the current practice. Basic build, boot, and PM logs are available here: http://www.pwsan.com/omap/testlogs/warnings_a_cleanup_3.7/20120912025927/
2012-09-12ARM: OMAP: Split plat/hardware.h, use local soc.h for omap2+Tony Lindgren
As the plat and mach includes need to disappear for single zImage work, we need to remove plat/hardware.h. Do this by splitting plat/hardware.h into omap1 and omap2+ specific files. The old plat/hardware.h already has omap1 only defines, so it gets moved to mach/hardware.h for omap1. For omap2+, we use the local soc.h that for now just includes the related SoC headers to keep this patch more readable. Note that the local soc.h still includes plat/cpu.h that can be dealt with in later patches. Let's also include plat/serial.h from common.h for all the board-*.c files. This allows making the include files local later on without patching these files again. Note that only minimal changes are done in this patch for the drivers/watchdog/omap_wdt.c driver to keep things compiling. Further patches are needed to eventually remove cpu_is_omap usage in the drivers. Also only minimal changes are done to sound/soc/omap/* to remove the unneeded includes and to define OMAP44XX_MCPDM_L3_BASE locally so there's no need to include omap44xx.h. While at it, also sort some of the includes in the standard way. Cc: linux-watchdog@vger.kernel.org Cc: alsa-devel@alsa-project.org Cc: Peter Ujfalusi <peter.ujfalusi@ti.com> Cc: Jarkko Nikula <jarkko.nikula@bitmer.com> Cc: Liam Girdwood <lrg@ti.com> Acked-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-12ARM: OMAP2+: Prepare for irqs.h removalTony Lindgren
As the interrupts should only be defined in the platform_data, and eventually coming from device tree, there's no need to define them in header files. Let's remove the hardcoded references to irqs.h and fix up the includes so we don't rely on headers included in irqs.h. Note that we're defining OMAP_INTC_START as 0 to the interrupts. This will be needed when we enable SPARSE_IRQ. For some drivers we need to add #include <plat/cpu.h> for now until these drivers are fixed to remove cpu_is_omapxxxx() usage. While at it, sort som of the includes the standard way, and add the trailing commas where they are missing in the related data structures. Note that for drivers/staging/tidspbridge we just define things locally. Cc: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-12ARM: OMAP: unwrap stringsPaul Walmsley
Find and unwrap wrapped strings in the style: pr_debug("clockdomain: hardware cannot set/clear wake up of " "%s when %s wakes up\n", clkdm1->name, clkdm2->name); Keeping these strings contiguous seems to be the current Linux kernel policy. The offending lines were found with the following command: pcregrep -rnM '"\s*$\s*"' arch/arm/*omap* While here, some messages have been clarified, some pr_warning( ... calls have been converted to pr_warn( ..., and some printk(KERN_* ... have been converted to pr_*. Signed-off-by: Paul Walmsley <paul@pwsan.com>
2012-09-10ARM: OMAP: remove plat/board.h fileIgor Grinberg
plat/board.h file is now empty - remove it. Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com> Cc: Chris Ball <cjb@laptop.org> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: linux-mmc@vger.kernel.org Cc: linux-mtd@lists.infradead.org Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Chris Ball <cjb@laptop.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-07-31ARM: omap: remove mmc platform data dma_mask and initializationRussell King
DMAengine uses the DMA engine device structure when mapping/unmapping memory for DMA, so the MMC devices do not need their DMA masks initialized (this reflects hardware: the MMC device is not the device doing DMA.) Tested-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-06-20ARM: OMAP2+: Fix MUSB ifdefs for platform init codeTony Lindgren
Commit 62285963 (usb: musb: drop a gigantic amount of ifdeferry) got rid of a bunch of ifdefs in the MUSB code. Looks like the platform init code is still using these dropped defines though, which in many cases results the board defaulting always to host mode. Currently the situation is that USB_MUSB_HDRC is the main Kconfig option with additional USB_GADGET_MUSB_HDRC so only these two should be used to select between host and OTG mode. Fix the situation for omaps. The following users should fix the platform init code in a similar way: Dropped Kconfig option Current users USB_MUSB_OTG blackfin, davinci, not in Kconfigs USB_MUSB_PERIPHERAL davinci, not in Kconfigs USB_MUSB_HOST davinci, not in Kconfigs USB_MUSB_HDRC_HCD blackfin, not in Kconfigs USB_MUSB_OTG blackfin, not in Kconfigs Cc: Mike Frysinger <vapier@gentoo.org> Cc: Sekhar Nori <nsekhar@ti.com> Cc: linux-usb@vger.kernel.org Cc: Felipe Balbi <balbi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-05-08ARM: omap2: use machine specific hook for late initShawn Guo
Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com>
2012-03-27Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: global cleanups" from Arnd Bergmann: "Quite a bit of code gets removed, and some stuff moved around, mostly the old samsung s3c24xx stuff. There should be no functional changes in this series otherwise. Some cleanups have dependencies on other arm-soc branches and will be sent in the second round. Signed-off-by: Arnd Bergmann <arnd@arndb.de>" Fixed up trivial conflicts mainly due to #include's being changes on both sides. * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (121 commits) ep93xx: Remove unnecessary includes of ep93xx-regs.h ep93xx: Move EP93XX_SYSCON defines to SoC private header ep93xx: Move crunch code to mach-ep93xx directory ep93xx: Make syscon access functions private to SoC ep93xx: Configure GPIO ports in core code ep93xx: Move peripheral defines to local SoC header ep93xx: Convert the watchdog driver into a platform device. ep93xx: Use ioremap for backlight driver ep93xx: Move GPIO defines to gpio-ep93xx.h ep93xx: Don't use system controller defines in audio drivers ep93xx: Move PHYS_BASE defines to local SoC header file ARM: EXYNOS: Add clock register addresses for EXYNOS4X12 bus devfreq driver ARM: EXYNOS: add clock registers for exynos4x12-cpufreq PM / devfreq: update the name of EXYNOS clock registers that were omitted PM / devfreq: update the name of EXYNOS clock register ARM: EXYNOS: change the prefix S5P_ to EXYNOS4_ for clock ARM: EXYNOS: use static declaration on regarding clock ARM: EXYNOS: replace clock.c for other new EXYNOS SoCs ARM: OMAP2+: Fix build error after merge ARM: S3C24XX: remove call to s3c24xx_setup_clocks ...
2012-03-07Merge branch 'fixes-non-critical-part2' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/fixes-non-critical * 'fixes-non-critical-part2' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: OMAP3+: PM: VP: fix integer truncation error ARM: OMAP2+: PM: fix wakeupgen warning when hotplug disabled ARM: OMAP2+: PM: fix section mismatch with omap2_init_processor_devices() ARM: OMAP2: Fix section warning for n8x0 when CONFIG_MMC_OMAP is not set ARM: OMAP2+: Fix omap24xx_io_desc warning if SoC subtypes are not selected ARM: OMAP1: Fix section mismatch for omap1_init_early() ARM: OMAP1: Fix typo in lcd_dma.c ARM: OMAP: mailbox: trivial whitespace fix ARM: OMAP: Remove definition cpu_is_omap4430() ARM: OMAP2+: included some headers twice ARM: OMAP: clock.c: included linux/debugfs.h twice ARM: OMAP: don't build hwspinlock in vain ARM: OMAP2+: ads7846_init: put gpio_pendown into pdata if it's provided ARM: omap: pandora: fix usbhs platform data ARM: OMAP: sram: Add am33xx SRAM support (minimal) ARM: OMAP2+: id: Add am33xx SoC type detection ARM: OMAP2+: GPMC: Export gpmc_enable_hwecc and gpmc_calculate_ecc ARM: OMAP: dmtimer: fix missing content/correction in low-power mode support
2012-03-06ARM: OMAP2: Fix section warning for n8x0 when CONFIG_MMC_OMAP is not setTony Lindgren
Otherwise we get: arch/arm/mach-omap2/board-n8x0.c:39:12: warning: 'slot1_cover_open' defined but not used [-Wunused-variable] arch/arm/mach-omap2/board-n8x0.c:40:12: warning: 'slot2_cover_open' defined but not used [-Wunused-variable] arch/arm/mach-omap2/board-n8x0.c:41:23: warning: 'mmc_device' defined but not used [-Wunused-variable] Reported-by: Russell King <linux@arm.linux.org.uk> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-03-05Merge remote-tracking branch 'omap/hsmmc' into for_3.4/cleanup/pm-baseKevin Hilman
2012-02-24ARM: OMAP: McSPI: Remove unused flag from struct omap2_mcspi_device_configJarkko Nikula
Flag single_channel in struct omap2_mcspi_device_config is not used by drivers/spi/spi-omap2-mcspi.c so we may remove it from include/plat/mcspi.h and affected board files. Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-02-20ARM: OMAP: Fix build error when mmc_omap is built as module Tony Lindgren
Otherwise we get the following error: arch/arm/mach-omap2/built-in.o: In function `n8x0_mmc_callback': twl-common.c:(.text+0x108a0): undefined reference to `omap_mmc_notify_cover_event' Fix this by warning about unusable MMC cover events. The long term fix needs to change the MMC drivers to register board specific callbacks directly with PMIC. Reported-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-01-09Merge tag 'pm' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
power management changes for omap and imx A significant part of the changes for these two platforms went into power management, so they are split out into a separate branch. * tag 'pm' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (65 commits) ARM: imx6: remove __CPUINIT annotation from v7_invalidate_l1 ARM: imx6: fix v7_invalidate_l1 by adding I-Cache invalidation ARM: imx6q: resume PL310 only when CACHE_L2X0 defined ARM: imx6q: build pm code only when CONFIG_PM selected ARM: mx5: use generic irq chip pm interface for pm functions on ARM: omap: pass minimal SoC/board data for UART from dt arm/dts: Add minimal device tree support for omap2420 and omap2430 omap-serial: Add minimal device tree support omap-serial: Use default clock speed (48Mhz) if not specified omap-serial: Get rid of all pdev->id usage ARM: OMAP2+: hwmod: Add a new flag to handle hwmods left enabled at init ARM: OMAP4: PRM: use PRCM interrupt handler ARM: OMAP3: pm: use prcm chain handler ARM: OMAP: hwmod: add support for selecting mpu_irq for each wakeup pad ARM: OMAP2+: mux: add support for PAD wakeup interrupts ARM: OMAP: PRCM: add suspend prepare / finish support ARM: OMAP: PRCM: add support for chain interrupt handler ARM: OMAP3/4: PRM: add functions to read pending IRQs, PRM barrier ARM: OMAP2+: hwmod: Add API to enable IO ring wakeup ARM: OMAP2+: mux: add wakeup-capable hwmod mux entries to dynamic list ...
2012-01-09Merge branch 'usb-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb * 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (232 commits) USB: Add USB-ID for Multiplex RC serial adapter to cp210x.c xhci: Clean up 32-bit build warnings. USB: update documentation for usbmon usb: usb-storage doesn't support dynamic id currently, the patch disables the feature to fix an oops drivers/usb/class/cdc-acm.c: clear dangling pointer drivers/usb/dwc3/dwc3-pci.c: introduce missing kfree drivers/usb/host/isp1760-if.c: introduce missing kfree usb: option: add ZD Incorporated HSPA modem usb: ch9: fix up MaxStreams helper USB: usb-skeleton.c: cleanup open_count USB: usb-skeleton.c: fix open/disconnect race xhci: Properly handle COMP_2ND_BW_ERR USB: remove dead code from suspend/resume path USB: add quirk for another camera drivers: usb: wusbcore: Fix dependency for USB_WUSB xhci: Better debugging for critical host errors. xhci: Be less verbose during URB cancellation. xhci: Remove debugging about ring structure allocation. xhci: Remove debugging about toggling cycle bits. xhci: Remove debugging for individual transfers. ...
2012-01-05Merge branch 'restart' into for-linusRussell King
Conflicts: arch/arm/mach-exynos/cpu.c The changes to arch/arm/mach-exynos/cpu.c were moved to mach-exynos/common.c.
2012-01-05ARM: restart: omap: use new restart hookRussell King
Hook these platforms restart code into the new restart hook rather than using arch_reset(). Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-12-14ARM: OMAP2+: UART: Allow UART parameters to be configured from board file.Deepak K
The following UART parameters are defined within the UART driver: 1). Whether the UART uses DMA (dma_enabled), by default set to 0 2). The size of dma buffer (set to 4096 bytes) 3). The time after which the dma should stop if no more data is received. 4). The auto suspend delay that will be passed for pm_runtime_autosuspend where uart will be disabled after timeout Different UARTs may be used for different purpose such as the console, for interfacing bluetooth chip, for interfacing to a modem chip, etc. Therefore, it is necessary to be able to customize the above settings for a given board on a per UART basis. This change allows these parameters to be configured from the board file and allows the parameters to be configured for each UART independently. If a board does not define its own custom parameters for the UARTs, then use the default parameters in the structure "omap_serial_default_info". The default parameters are defined to be the same as the current settings in the UART driver to avoid breaking the UART for any cuurnelty supported boards. By default, make all boards use the default UART parameters. Signed-off-by: Deepak K <deepak.k@ti.com> Signed-off-by: Jon Hunter <jon-hunter@ti.com> Signed-off-by: Govindraj.R <govindraj.raja@ti.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> (for drivers/tty changes) Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-12-12usb: musb: allow building USB_MUSB_TUSB6010 as a moduleArnd Bergmann
Commit 1376d92f9 "usb: musb: allow musb and glue layers to be modules" made the USB_MUSB_TUSB6010 option modular, but actually building the driver as a module does not work, so various randconfig builds actually fail. This changes all code that depends on the option to also check for modular builds, and exports the necessary symbols. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-11-21Merge branch 'irqchip-consolidation' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/maz/arm-platforms into devel-stable Conflicts: arch/arm/mach-omap2/board-4430sdp.c arch/arm/mach-omap2/board-omap4panda.c arch/arm/mach-omap2/include/mach/omap4-common.h arch/arm/plat-omap/include/plat/irqs.h The changes to omap4-common.h were moved to arch/arm/mach-omap2/common.h and the other trivial conflicts resolved. The now empty ifdef in irqs.h was also eliminated.
2011-11-17ARM: 7159/1: OMAP: Introduce local common.h filesTony Lindgren
As suggested by Russell King - ARM Linux <linux@arm.linux.org.uk>, there's no need to keep local prototypes in non-local headers. Add mach-omap1/common.h and mach-omap2/common.h and move the local prototypes there from plat/common.h and mach/omap4-common.h. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-11-15ARM: omap2plus: convert to CONFIG_MULTI_IRQ_HANDLERMarc Zyngier
Convert the omap2plus platforms to be using CONFIG_MULTI_IRQ_HANDLER. Each machine is modified to provide either omap2_intc_handle_irq(), omap3_intc_handle_irq() or gic_handle_irq(). This allows for a major cleanup, removing the MULTI_OMAP setup from the interrupt path. Tested on both Panda and IGEPv2 (single kernel image) Tested-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2011-10-08Merge branch 'depends/rmk/devel-stable' into next/cleanupArnd Bergmann
2011-09-26ARM: OMAP2+: Use SoC specifc map_ioTony Lindgren
There's no longer any need for the board specific map_io. Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-08-24ARM: OMAP: Introduce SoC specific early_initTony Lindgren
Introduce them for each omap variant and just make them all call omap2_init_common_infrastructure for now. Do this for each board-*.c file except for board-generic and board-omap3beagle as they use the same machine ID for multiple SoCs. No functional changes. Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-08-24ARM: OMAP: Move omap2_init_common_devices out of init_earlyTony Lindgren
There's no need to call omap2_init_common_devices from init_early. It no longer does anything else except reprogram the memory timings for some boards, so it's better to do it later so we have a chance to get console messages if something goes wrong. Move it to happen after omap_serial_init gets called. And while patching it anyways, rename it to omap_sdrc_init as suggested by Benoit Cousson <b-cousson@ti.com>. Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-08-21ARM: mach-omap2: convert boot_params to atag_offsetNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-06-20omap: Set separate timer init functions to avoid cpu_is_omap testsTony Lindgren
This is needed for the following patches so we can initialize the rest of the hardware timers later on. As with the init_irq calls, there's no need to do cpu_is_omap calls during the timer init as we only care about the major omap generation. This means that we can initialize the sys_timer with the .timer entries alone. Note that for now we just set stubs for the various sys_timer entries that will get populated in a later patch. The following patches will also remove the omap_dm_timer_init calls and change the init for the rest of the hardware timers to happen with an arch_initcall. Signed-off-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-06-16omap: Use separate init_irq functions to avoid cpu_is_omap tests earlyTony Lindgren
This allows us to remove cpu_is_omap calls from init_irq functions. There should not be any need for cpu_is_omap calls as at this point. During the timer init we only care about SoC generation, and not about subrevisions. The main reason for the patch is that we want to initialize only minimal omap specific code from the init_early call. Signed-off-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-05-12arm: omap2plus: GPIO cleanupIgor Grinberg
use gpio_request_<one|array>() instead of multiple gpiolib calls, remove unneeded variables, etc. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-03-01omap: mmc: split out init for 2420Anand Gadiyar
The MMC controller on the OMAP2420 is different from those on the OMAP2430, OMAP3 and OMAP4 families - all of the latter are identical. The one on the OMAP2420 is closer to that on OMAP1 chips. Currently, the n8x0 is the only OMAP2420 platform supported in mainline which registers the MMC controller. Upcoming changes to register the controllers using hwmod data are potentially invasive. To reduce the risk, separate out the 2420 controller registration from the common init function and update its only user. Also seperating out mux settings for OMAP2420. Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Signed-off-by: Kishore Kadiyala <kishore.kadiyala@ti.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Madhusudhan Chikkature <madhu.cr@ti.com> Cc: Chris Ball <cjb@laptop.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-02-14ARM: OMAP2: use early init hookRussell King - ARM Linux
Move non-mapping and non-irq initialization code out of .map_io and .init_irq respectively into the new init_early hook. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-01-07Merge branch 'usb-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6 * 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (144 commits) USB: add support for Dream Cheeky DL100B Webmail Notifier (1d34:0004) USB: serial: ftdi_sio: add support for TIOCSERGETLSR USB: ehci-mxc: Setup portsc register prior to accessing OTG viewport USB: atmel_usba_udc: fix freeing irq in usba_udc_remove() usb: ehci-omap: fix tll channel enable mask usb: ohci-omap3: fix trivial typo USB: gadget: ci13xxx: don't assume that PAGE_SIZE is 4096 USB: gadget: ci13xxx: fix complete() callback for no_interrupt rq's USB: gadget: update ci13xxx to work with g_ether USB: gadgets: ci13xxx: fix probing of compiled-in gadget drivers Revert "USB: musb: pm: don't rely fully on clock support" Revert "USB: musb: blackfin: pm: make it work" USB: uas: Use GFP_NOIO instead of GFP_KERNEL in I/O submission path USB: uas: Ensure we only bind to a UAS interface USB: uas: Rename sense pipe and sense urb to status pipe and status urb USB: uas: Use kzalloc instead of kmalloc USB: uas: Fix up the Sense IU usb: musb: core: kill unneeded #include's DA8xx: assign name to MUSB IRQ resource usb: gadget: g_ncm added ... Manually fix up trivial conflicts in USB Kconfig changes in: arch/arm/mach-omap2/Kconfig arch/sh/Kconfig drivers/usb/Kconfig drivers/usb/host/ehci-hcd.c and annoying chip clock data conflicts in: arch/arm/mach-omap2/clock3xxx_data.c arch/arm/mach-omap2/clock44xx_data.c
2010-12-22omap2+: Initialize serial port for dynamic remuxing for n8x0Tony Lindgren
Use omap_serial_init_port so we can let the serial code handle the remuxing of the RX pads. Note that this patch alone is not enough and additional GPIO related patches are needed. Only initialize uart3_rx_irrx pin, the other uart pins can be stay static. Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-12-21OMAP2+: io: split omap2_init_common_hw()Paul Walmsley
Split omap2_init_common_hw() into two functions. The first, omap2_init_common_infrastructure(), initializes the hwmod code and data, the OMAP PM code, and the clock code and data. The second, omap2_init_common_devices(), handles any other early device initialization that, for whatever reason, has not been or cannot be moved to initcalls or early platform devices. This patch is required for the hwmod postsetup patch, which allows board files to change the state that hwmods should be placed into at the conclusion of the hwmod _setup() function. For example, for a board whose creators wish to ensure watchdog coverage across the entire kernel boot process, code to change the watchdog's postsetup state will be added in the board-*.c file between the omap2_init_common_infrastructure() and omap2_init_common_devices() function calls. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Tony Lindgren <tony@atomide.com>
2010-12-10Merge branch 'devel-gpio' into omap-for-linusTony Lindgren
2010-12-10usb: musb: add Kconfig options for each glue layerFelipe Balbi
This will make things simpler when choosing which glue layer to compile. It avoids a lot of magic around the "default" Kconfig option and lets the user choose what exactly s/he wants to compile. Signed-off-by: Felipe Balbi <balbi@ti.com>
2010-12-07OMAP: GPIO: Implement GPIO as a platform deviceVaradarajan, Charulatha
Implement GPIO as a platform device. GPIO APIs are used in machine_init functions. Hence it is required to complete GPIO probe before board_init. Therefore GPIO device register and driver register are implemented as postcore_initcalls. omap_gpio_init() does nothing now and this function would be removed in the next patch as it's usage is spread across most of the board files. Inorder to convert GPIO as platform device, modifications are required in clockxxxx_data.c file for OMAP1 so that device names can be used to obtain clock instead of getting clocks by name/NULL ptr. Use runtime pm APIs (pm_runtime_put*/pm_runtime_get*) for enabling or disabling the clocks, modify sysconfig settings and remove usage of clock FW APIs. Note 1: Converting GPIO driver to use runtime PM APIs is not done as a separate patch because GPIO clock names are different for various OMAPs and are different for some of the banks in the same CPU. This would need usage of cpu_is checks and bank id checks while using clock FW APIs in the gpio driver. Hence while making GPIO a platform driver framework, PM runtime APIs are used directly. Note 2: While implementing GPIO as a platform device, pm runtime APIs are used as mentioned above and modification is not done in gpio's prepare for idle/ resume after idle functions. This would be done in the next patch series and GPIO driver would be made to use dev_pm_ops instead of sysdev_class in that series only. Due to the above, the GPIO driver implicitly relies on CM_AUTOIDLE = 1 on its iclk for power management to work, since the driver never disables its iclk. This would be taken care in the next patch series (see Note 3 below). Refer to http://www.mail-archive.com/linux-omap@vger.kernel.org/msg39112.html for more details. Note 3: only pm_runtime_get_sync is called in gpio's probe() and pm_runtime_put* is never called. This is to make the implementation similar to the existing GPIO code. Another patch series would be sent to correct this. In OMAP3 and OMAP4 gpio's debounce clocks are optional clocks. They are enabled/ disabled whenever required using clock framework APIs TODO: 1. Cleanup the GPIO driver. Use function pointers and register offest pointers instead of using hardcoded values 2. Remove all cpu_is_ checks and OMAP specific macros 3. Remove usage of gpio_bank array so that only instance specific information is used in driver code 4. Rename 'method'/ avoid it's usage 5. Fix the non-wakeup gpios handling for OMAP2430, OMAP3 & OMAP4 6. Modify gpio's prepare for idle/ resume after idle functions to use runtime pm implentation. Signed-off-by: Charulatha V <charu@ti.com> Signed-off-by: Rajendra Nayak <rnayak@ti.com> Reviewed-by: Basak, Partha <p-basak2@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> [tony@atomide.com: updated for bank specific revision and updated boards] Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-12-02arm: mach-omap2: n8x0: clean up dummy onenand initAaro Koskinen
When OneNAND support is disabled, the platform code defines NULL board_onenand_data and empty init function for us. By utilizing this we can avoid cluttering board files with dummy definitions/wrappers. Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
