Most OMAP3-based boards use exactly the same code for .map_io method in
the machine_desc structure.
This patch introduces omap3_map_io and updates board-* files to use it
as .map_io method.
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
The only difference between them is the physical address of the
uart4 port, which is only present in 36xx chips.
We don't really need to care about keeping these 2 functions, since
the decision to use uart4 is more cleanly done later when we do have
access to omap_revision variable.
Signed-off-by: Sergio Aguirre <saaguirre@ti.com>
Acked-by: Kevin Hilman <khilman@deeprootsystems.com>
[tony@atomide.com: added comment for the uart4_phys]
Board file modified for not to provide gpmc phys_base address to nand driver.
The gpmc_nand_init funciton is now used to detect the nand and required to
adopt _prob function as in nand/omap2.c
Signed-off-by: Sukumar Ghorai <s-ghorai@ti.com>
Otherwise we can get the following error:
error: variable 'tdo24m_mcspi_config' has initializer but incomplete type
the early_param() call in board-omap3touchbook.c expands to:
static const char __setup_str_early_touchbook_revision[]
__section(.init.rodata) _aligned(1) = tbr;
and we have a non-const variable being added to the
same section:
static struct ehci_hcd_omap_platform_data ehci_pdata
__section(.init.rodata);
because of that, gcc generates a section type conflict
which can (and actually should) be avoided by marking
const every variable marked with __initconst.
This patch fixes that for the ehci_hdc_omap_platform_data.
Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com>
Pass board specific data for MUSB (like interface_type,
mode etc) from board file by defining board
specific structure.
Each board file can define this structure based on
its requirement and pass this information to the
driver.
Signed-off-by: Maulik Mankad <x0082077@ti.com>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Felipe Balbi <felipe.balbi@nokia.com>
Cc: David Brownell <david-b@pacbell.net>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Gupta Ajay Kumar <ajay.gupta@ti.com>
hsmmc.[ch] no longer has any dependency on twl4030
and variable names should be renamed to reflect that.
Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com>
mmc-twl4030.[ch] no longer has any dependency on twl4030
and should be renamed to reflect that.
Fix omap2_map_common_io for multi-omap
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@nokia.com>
Recent drivers/mfd/twl4030* renames to twl broke compile for
various boards as the series was missing a patch to change
the board-*.c files.
This patch renames include twl4030.h to include twl.h
and also renames twl4030_i2c_ routines.
Signed-off-by: Balaji T K <balajitk@ti.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Reviewed-by: Felipe Balbi <felipe.balbi@nokia.com>
Cc: Samuel Ortiz <sameo@linux.intel.com>
CM-T35 can be assembled with different set of peripherals thus making
certain interfaces available to user as GPIOs or dedicated pins. Because
of it CM-T35 bootloader sets up mux configuration only for pins
necessary to boot the system and the rest of the mux configuration is
done by the kernel. Besides, having mux configuration in the kernel
allows to minimize dependancy on bootloader.
Remove old mux code for 34xx
Replace omap_cfg_reg() with new style signal or gpio functions
Add new style mux init functions to omap3 board-*.c files
So far Beagle has been confirmed to be a CBB package,
and CM-T35 a CUS package.
This patch adds basic support for CompuLab CM-T35 module.
